pm_device_action_run behavior when multipile sensors are connected on same bus
I have an application in which there are two high speed sensors consider it as sensors 1 and sensor 2. Both sensors are connected over same SPI lines having different CS pins and power supply pins using different LDOs.
According to my application, in idle case when there is no requirement of reading data from the sensors, I am turning off their powers and suspend the SPI bus using Zephyr's PM APIs. I registred pm_action APIs for both the sensors in the respective drivers and I am using CONFIG_PM_DEVICE to manage device state using PM_DEVICE_ACTION_RESUME and PM_DEVICE_ACTION_SUSPEND.
In actual application, I will call the pm_device_action_run(dev, PM_DEVICE_ACTION_SUSPEND); to a sensor at a time, and this will suspend the SPI bus when it executed. In this case what should happen to the second sensor as the SPI bus is already suspeded.
What I observed is, when I call pm_device_action_run(dev, PM_DEVICE_ACTION_SUSPEND); from sensor 1 it suspend the interface and I can see the success return from pm_device_action_run. Now when application tried to suspend the sensor 2 using the same API then I observed that pm_action API of that sensor 2 is not executing which is registered in the driver. In short, if Sensor 1 is suspended then if I call pm_device_action_run it is not reaching to the driver pm_action API and I am not able to execute the Sensor 2 power suspend operations.
Is it something expected or I am handling such scenario differently. I am curious how the Zephyr is handling such scenarion as using common interface for multiple sensor is quite common and I believe Zephyr is alreayd handling it but I am not aware about it.
If someone can help here to understand me such usecase that would be helpful.
