NRF52810 draws ~4mA when advertising
Hey.
We designed custom PCB board (basically an humidity sensor) with Nordic IC. It works fine, but when I did current measurements I noticed that in advertising mode, uC draws ~5mA with spikes up to 16mA. LOGs are disabled, there is no UART periphery active. NRF_SDH_CLOCK_LF_SRC is set to NRF_CLOCK_LF_SRC_XTAL.
If I build image with BLE functionality disabled or set all GPIOs to input, the baseline current is still at ~5mA.
Without debugger I observe similar situation, but current draw is  ~4mA.
To make sure it's not other ICs on the board, I took a board without Nordic and current draw was ~10uA.
Schematics:
Am I missing something? I did tests where all GPIOs were set as inputs, tried running it without SD enabled, but still the same results.
Thank you!
