Device onboarding: "certificate already exists"
We have onboarded several hundred nrRF9151 devices using the nRF Cloud "bulk onboard" UI (preconnect onboarding using device_credentials_installer.py). Generally, this works fine.
However, for two devices we are getting an error during onboarding: "certificate already exists". But the respective devices (UUID) are not present in nRF Cloud in any of our teams.
We're not sure why this is happening and how to resolve the situation and finish onboarding the two devices.
Any advice is appreciated.
Thanks
  • Hi Terrence,
    We need to investigate this with the team. What is the time interval between step 3 and step 4? Did you see any errors? Steps 1 and 4 were done using bulk onboarding with csv, did you see any errors? Bulk onboarding is asynchronous call so it might take some time to complete. Could you estimate how many devices were onboarded at the same time?
    In the meanwhile, you need to send me all these certificates which were reported as a duplicate.
    -M
  • Time between step 3 and 4: I believe at least several hours, if not days.
    I don't think we saw any errors during step 3. First error was in step 4, for a subset of devices.
    I believe we onboarded several dozen devices in step 4.
    Certs attached.
    Thankscerts2.zip
    ok, understood. Team will need to investigate this. In the meanwhile I will be removing these certificates for you. I will let you know when they are removed.
    -M
  • Hi Terrence,
    I checked these devices and deleted orphaned certificates. Some of these devices seem to have onboarded just fine, see the list:
    50343956-3037-411c-8009-091efaf720a7 removed orphaned certificate
    50343956-3037-4123-8037-0f1128bba843 associated, looks ok
    50343956-3037-43c5-8029-001906c2202a associated, looks ok
    50343956-3037-4563-80df-07227ae0c6d6 removed orphaned certificate
    50343956-3037-4693-8090-0c16d6b8bf49 removed orphaned certificate
    50343956-3037-48c9-8098-211d15f9aff1 removed orphaned certificate
    50343956-3037-4d66-808a-16273b09d886 removed orphaned certificate
    5034474b-3731-4fb9-8020-0713b6b5484e associated, looks ok
    I didn't want to do anything for those devices that are with comment "associated, looks ok". If you have issues with them, let me know. For others, I removed orphaned certificate. You can try to onboard them again. I filed a bug to the team and they will start investigating this. Let's keep this ticket open until I have further information to tell about this issue or you bump into this again.
    Markku Lehto
  • Hi Markku,
    you're right, the three that are associated correctly show up in our team, that appears to be a mistake on our side. For the others, thanks, we'll try to onboard those again.
