Hi, I am able to flash my XIAO nrf52840 using my nrf52840dk however the code does not run once flashed. I checked and the code itself is starting at 0x00027000 presumably because of the default bootloader the board came with. However, I no longer have the bootloader. I tried setting this in my prj.conf to override the default for the board, but it still puts code starting at 0x00027000:
# Build UF2 by default, supported by the Adafruit nRF52 Bootloader CONFIG_BUILD_OUTPUT_UF2=n CONFIG_USE_DT_CODE_PARTITION=n
