NRF5340, WS2812, I2S
Hello.
I'm trying to use WS2812 leds with I2S. I'm using two boards for testing: an NRF5340DK and my board based on the HOLYIOT-21069-5340 module.
I'm using a zephyr/samples/drivers/led/led_strip as an example.
I need the control signal to be on P1.00. I'm trying it with the NRF5340DK board first.
Here's my overlay file:
#include <zephyr/dt-bindings/led/led.h>
    aliases {
        ledstrip = &ledstrip;
&pinctrl {
    i2s0_default_alt: i2s0_default_alt {
		group1 {
			psels = <NRF_PSEL(I2S_SCK_M, 1, 15)>,
				<NRF_PSEL(I2S_LRCK_M, 1, 12)>,
				<NRF_PSEL(I2S_SDOUT, 1, 0)>; // Output pin to LED strip
&i2s0 {
    status = "okay";
    pinctrl-0 = <&i2s0_default_alt>;
    pinctrl-names = "default";
	ledstrip: ws2812@0 {
		compatible = "worldsemi,ws2812-i2s";
		reg = <0>;
		chain-length = <2>; /* arbitrary; change at will */
		color-mapping = <LED_COLOR_ID_GREEN
					LED_COLOR_ID_RED
					LED_COLOR_ID_BLUE>;
		reset-delay = <500>;
&uart0 {
    status = "disabled";
&i2c1 {
&spi4 {
&pwm0 {
&qspi {
&usbd {
&usbreg {
If I use pin P1.00, nothing works — the pin stays high all the time. If I use P1.01 or P1.13, everything works.
P1.00 is listed in the description as a "General purpose I/O." Nothing seems to be connected to it on the board either. Why can't I use it?
The second problem occurs when I try to use my board. The board is based on a HOLYIOT-21069-5340 module with nRF5340 QKAA.
I use the exact same code without rebuilding it.
I'm just doing a "west flash," but instead of a NRF5340DK board, I'm connecting my HOLYIOT-21069-5340 module. And for some reason, the driver stops working, and I get the following messages in debug:
[00:00:00.000,213] <dbg> ws2812_i2s: ws2812_i2s_init: Word clock: freq 100000 Hz period 10 us
*** Booting Zephyr OS build v4.3.0-7395-g768095e06b41 ***
[00:00:00.000,274] <inf> main: Found LED strip device ws2812@0
[00:00:00.000,274] <inf> main: Displaying pattern on strip
[00:00:01.001,403] <err> i2s_nrfx: Cannot write in state: 3
[00:00:01.001,434] <err> ws2812_i2s: Failed to write data: -5
[00:00:01.001,434] <err> main: couldn't update strip: -5
[00:00:02.001,586] <err> i2s_nrfx: Cannot write in state: 3
[00:00:02.001,586] <err> ws2812_i2s: Failed to write data: -5
[00:00:02.001,586] <err> main: couldn't update strip: -5
My prj.conf:
CONFIG_LOG=y
CONFIG_LED_STRIP=y
CONFIG_LED_STRIP_LOG_LEVEL_DBG=y
CONFIG_SPI=y
CONFIG_I2S=y
CONFIG_WS2812_STRIP_I2S=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
I do it simply:
1. Build: west build -b nrf5340dk/nrf5340/cpuapp --sysbuild
2. Flash: west flash
3. Debug output: west rtt
    Did you try scoping the pins to see if there is a difference between the two solutions?
    Could it be that there is a soldering issue or a routing issue on your custom board? Did you try to use other pins for your custom board?
    D233374 said:
    As far as I understand, the I2C unit is clocked from the 32 MHz bus, not the 32 kHz bus. Therefore, switching the 32 kHz bus to the RC source didn't help.
    You have not provided a schematic for your custom board, but having a 32k source is mandatory for the rtos. If you do not have an external 32k (default in nRF5340-DK), you need to set the source to internal 32k RC oscillator.
    Håkon
