Debug build
I created a copy of the nRF Cloud CoAP Device Message sample application for the Thingy 91 X.  It builds using the default optimization level.  However it fails to build when I select "Optimize for debugging (-Og)".
The tfm_s section is too small for the generated code.
Here is a copy of the build output.
-- Build files have been written to: D:/Work/nrf_cloud_coap_device_message/build/nrf_cloud_coap_device_message/tfm
[17/493] Performing build step for 'tfm'
[149/153] Linking C executable bin\tfm_s.axf
FAILED: bin/tfm_s.axf
cmd.exe /C "cd . && C:\ncs\toolchains\fd21892d0f\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -mcpu=cortex-m33 -g -mcpu=cortex-m33 --entry=Reset_Handler -specs=nano.specs -specs=nosys.specs -Wl,-check-sections -Wl,-fatal-warnings -Wl,--gc-sections -Wl,--no-wchar-size-warning -Wl,--print-memory-usage -Wl,-Map=D:/Work/nrf_cloud_coap_device_message/build/nrf_cloud_coap_device_message/tf        fm/bin/tfm_s.map -mfloat-abi=hard -mfpu=fpv5-sp-d16 -Wl,--cmse-implib,--out-implib=D:/Work/nrf_cloud_coap_device_message/build/nrf_cloud_coap_device_message/tfm/secure_fw/s_veneers.o -T D:/Work/nrf_clo        oud_coap_device_message/build/nrf_cloud_coap_device_message/tfm/platform/target/nrf91/nrf_common/CMakeFiles/tfm_s_scatter.dir/./__/__/__/__/generated/platform/ext/common/gcc/tfm_common_s.ld @CMakeFiles        s\tfm_s.rsp -o bin\tfm_s.axf  && cd ."
c:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.exe: address 0x3971b of bin\tfm_s.axf section `.ER_TFM_CODE' is not within region `FLASH'
c:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.exe: address 0x3c520 of bin\tfm_s.axf section `.TFM_UNPRIV_CODE' is not within region `FLASH'
c:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.exe: address 0x3fc40 of bin\tfm_s.axf section `.gnu.sgstubs' is not within region `FLASH'
c:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.exe: bin\tfm_s.axf section `.TFM_DATA' will not fit in region `FLASH'
c:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 32236 bytes
Memory region         Used Size  Region Size  %age Used
           FLASH:       64492 B      32256 B    199.94%
             RAM:       14560 B        16 KB     88.87%
collect2.exe: error: ld returned 1 exit status
I tried copying partitions.yml from the build folder to the root folder and modified to increase the tfm section.  Unfortunately the build process does not seem to recognize the memory map.
I tried naming it pm.yml and pm_static.yml.
Neither seem to be accepted.
Here is the options selected for the build configuration.
Here is the generated partitions.yml file.
app:
  address: 0x38000
  end_address: 0x100000
  region: flash_primary
app_image:
  address: 0x30200
  span:
  - tfm
  - app
b0:
  address: 0x0
  end_address: 0x8000
b0_container:
  address: 0x0
  end_address: 0x8000
  span:
  - b0
external_flash:
  address: 0x4d2000
  end_address: 0x2000000
  region: external_flash
fmfu_storage:
  address: 0xd0000
  device: DT_CHOSEN(nordic_pm_ext_flash)
  end_address: 0x4d0000
mcuboot:
  address: 0x8200
  end_address: 0x1c000
mcuboot_pad:
  address: 0x30000
  end_address: 0x30200
mcuboot_primary:
  address: 0x30000
  span:
  - mcuboot_pad
  - app
  - tfm
mcuboot_primary_app:
  address: 0x30200
  span:
  - tfm
  - app
mcuboot_secondary:
  address: 0x0
  end_address: 0xd0000
  share_size:
  - mcuboot_primary
mcuboot_sram:
  address: 0x20000000
  end_address: 0x20040000
  orig_span: &id001
  - sram_primary
  - nrf_modem_lib_rx
  - nrf_modem_lib_tx
  - nrf_modem_lib_ctrl
  - tfm_sram
  region: sram_primary
  span: *id001
nrf_modem_lib_ctrl:
  address: 0x20004000
  end_address: 0x200044e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - tfm_sram
    - start
nrf_modem_lib_rx:
  address: 0x20006568
  end_address: 0x20008568
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20004000
  orig_span: &id002
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id002
nrf_modem_lib_tx:
  address: 0x200044e8
  end_address: 0x20006568
  inside:
  - sram_nonsecure
  placement:
    after:
otp:
  address: 0xff8388
  end_address: 0xff83fc
  region: otp
provision:
  address: 0xff8108
  end_address: 0xff8388
  region: otp
s0:
  address: 0x8000
  span:
  - mcuboot
  - s0_pad
s0_image:
  address: 0x8200
  span:
  - mcuboot
s0_pad:
  address: 0x8000
  end_address: 0x8200
  share_size:
  - mcuboot_pad
s1:
  address: 0x1c000
  end_address: 0x30000
  span:
  - s1_pad
  - s1_image
s1_image:
  address: 0x1c200
  share_size:
  - mcuboot
s1_pad:
  address: 0x1c000
  end_address: 0x1c200
  share_size:
  - mcuboot_pad
settings_storage:
  address: 0x4d0000
  end_address: 0x4d2000
sram_nonsecure:
  address: 0x20004000
  orig_span: &id003
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id003
sram_primary:
  address: 0x20008568
sram_secure:
  address: 0x20000000
  end_address: 0x20004000
  orig_span: &id004
  - tfm_sram
  span: *id004
tfm:
  address: 0x30200
  end_address: 0x38000
tfm_nonsecure:
  address: 0x38000
  span:
  - app
tfm_secure:
  address: 0x30000
  span:
  - mcuboot_pad
  - tfm
tfm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
Can someone help me work this out?
  • Hi.
    I see. You can increase the TF-M partition with this partition layout. You can for instance put it in a pm_static_thingy91x_nrf9151_ns in the project root folder and point to it using "-DPM_STATIC_YML_FILE=pm_static_thingy91x_nrf9151_ns" as an extra CMake argument in the build configuration:
    b0:
      address: 0x0
    b0_container:
      address: 0x0
      span: [b0]
    s0:
      address: 0x8000
      span: [mcuboot, s0_pad]
    s0_pad:
      address: 0x8000
      share_size: [mcuboot_pad]
    s0_image:
      address: 0x8200
      span: [mcuboot]
    mcuboot:
      address: 0x8200
    s1:
      address: 0x1c000
      span: [s1_pad, s1_image]
    s1_pad:
      address: 0x1c000
    s1_image:
      address: 0x1c200
      share_size: [mcuboot]
    mcuboot_primary:
      address: 0x30000
      span: [mcuboot_pad, app, tfm]
    tfm_secure:
      address: 0x30000
      span: [mcuboot_pad, tfm]
    mcuboot_pad:
      address: 0x30000
      address: 0x30200
      span: [tfm, app]
    app_image:
      address: 0x30200
      span: [tfm, app]
    tfm:
      address: 0x30200
    tfm_nonsecure:
      address: 0x40000
      span: [app]
    app:
      address: 0x40000
    mcuboot_secondary:
      address: 0x0
      share_size: [mcuboot_primary]
    fmfu_storage:
      address: 0xD0000
    settings_storage:
      address: 0x4D0000
    With this, the TF-M partition is 64 kB and I see that the project builds with debug optimization enabled for all images. However, I do not have a Thingy91x at hand now, so I have not been able to test it.
  • That resolved the problem. I am now able to build with debug optimizations and debug the code.
    Thank you for all your help.
