nRF5340 ESB, scanning RSSI across channels
I have worked a bit with ESB and see that there are functions to get/set a channel, as well as check the RSSI value in the "struct esb_payload" for a packet. Are there already some existing functions in the ESB library, or lower level libraries, that allow for scanning all the channels and reviewing all their RSSI values? Or would it have to be done in the application side with the existing ESB library functions?
We're trying to ultimately implement adaptive frequency hopping, but with ESB.
I'm working with the nRF5340, Windows 11, and NCS Connect SDK v2.5.0.
EDIT 1 - I tried using some of the 'fw' code from the RSSI Viewer app (in a standalone application i.e., no ESB) and flashed it onto the nRF. It did report fluctuating values across all the channels I was interested in. But when I undo the commenting out of the ESB functionality, logs seem to report 1 TX_FAILED event followed by no other packets received.
  • See the PTX project here, adapted from NCS v2.5.0 at nrf/samples/esb/esb_ptx/
  • For PRX project, I used the one exactly from NCS v2.5.0 at nrf/samples/esb/esb_prx/
EDIT 2 - From reviewing the RSSI code some more, it seems to switch the radio to RX mode, read the RSSI, then disable the radio. Perhaps that's causing ESB to be disabled somehow?
