Poor alignment of pa lna signal with RF burst
We are developing a beacon device with 10dBm power amplifier. During software development we noticed the control signals provided by ble_common_opt_pa_lna_t align poorly with the actual RF burst of the advertising beacon. We used a PCA10040 and measured RF output directly from the nRF52832. The amplifier control signal was routed out P0.23. In the bmp files below from the scope the measured RF power (shown in green) starts nearly 10usec ahead of the pa control signal from PPI. During testing with an actual external amplifier this results in significant loss of the advertising signal. The code (shown below) was a direct copy from your example in the blogs.
In general a power amplifier should have at least 1usec of turn on time ahead of the RF burst. Given the jitter and latency associated with your implementation on the PPI bus, 5 usec of advance notice would be useful. We are using S132 2.0.0-8 on nRF52832-QFAA-BA. Please advise how this can be resolved.
static void pa_lna_assist(void) { ret_code_t err_code;
static const uint32_t gpio_toggle_ch = 0;
static const uint32_t ppi_set_ch = 0;
static const uint32_t ppi_clr_ch = 1;
// Configure SoftDevice PA/LNA assist
ble_opt_t opt;
memset(&opt, 0, sizeof(ble_opt_t));
// Common PA/LNA config
opt.common_opt.pa_lna.gpiote_ch_id  = gpio_toggle_ch;        // GPIOTE channel
opt.common_opt.pa_lna.ppi_ch_id_set = ppi_set_ch;            // PPI channel for pin clearing
opt.common_opt.pa_lna.ppi_ch_id_clr = ppi_clr_ch;            // PPI channel for pin setting
// PA config
opt.common_opt.pa_lna.pa_cfg.active_high = 1;                // Set the pin to be active high
opt.common_opt.pa_lna.pa_cfg.enable      = 1;                // Enable toggling
opt.common_opt.pa_lna.pa_cfg.gpio_pin    = 23;      // The GPIO pin to toggle
// LNA config
opt.common_opt.pa_lna.lna_cfg.active_high  = 1;              // Set the pin to be active high
opt.common_opt.pa_lna.lna_cfg.enable       = 1;              // Enable toggling
opt.common_opt.pa_lna.lna_cfg.gpio_pin     = 22;   // The GPIO pin to toggle
NRF_GPIO->DIRSET = PA_MASK;
err_code = sd_ble_opt_set(BLE_COMMON_OPT_PA_LNA, &opt);
} Leading edge of channel 1 burst
All three advertising bursts and RF in green Test Setup
  • Can you clarify your post? Does the attached file fix the problem? In all of our testing the pa lna assist was configured immediately after starting the soft device and always before advertising was started. PA turn on was always inevitably after the start of the tx burst at the end of the CW phase. The issue seems to be related to a delay in the radio events used by the SD to provide this function.
  • Hi, sorry, the example does not affect timing no, your summary still applies. The example was just updated to the production release of the S132, and in addition it uses the ppi and gpiote libraries to allocate channels, this to avoid hardcoding channels that might be dynamically requested by other SDK modules. I placed the example 2 places in devzone to ensure some visibilty.
