nrf connect vscode extension fresh install not working on macOS
I am attempting to install and use the NRF Connect for vscode extension pack.  I have made several attempts googling solutions posted by others facing similar issues.  I am blocked and asking for help.  Thanks very much.
based on the AI generated response before posting I attempted the following:
nrfutil sdk-manager sdk register v3.2.4
Error: Failed to run 'west zephyr-export' in SDK directory '/opt/nordic/ncs/v3.2.4' using the west command from the toolchain associated with the SDK: 185bb0e3b6. Check the log for details.
I also installed the nrf connect extension pack per the AI recommendations and retried "nrfutil sdk-manager sdk register v3.2.4" and got identical results.
[west]: exited with code -2.
[08:17:26] nrfutil-sdk-manager toolchain install --ncs-version v3.2.4: Checking downloads for v3.2.4
[08:17:26] nrfutil-sdk-manager toolchain install --ncs-version v3.2.4: Download toolchain v3.2.4
[08:18:49] nrfutil-sdk-manager toolchain install --ncs-version v3.2.4: Toolchain downloaded: success
[08:18:49] nrfutil-sdk-manager toolchain install --ncs-version v3.2.4: Unpack toolchain v3.2.4
[08:19:09] nrfutil-sdk-manager toolchain install --ncs-version v3.2.4: Toolchain unpacked to /opt/nordic/ncs/tmp/.tmpm3CjUe: success
[08:19:09] nrfutil-sdk-manager toolchain install --ncs-version v3.2.4: Install toolchain v3.2.4
[08:19:09] nrfutil-sdk-manager toolchain install --ncs-version v3.2.4: Toolchain installed at /opt/nordic/ncs/toolchains/185bb0e3b6: success
[08:24:40] nrfutil-sdk-manager install v3.2.4 --sdk-path /opt/nordic/ncs/v3.2.4 --type nrf: Install toolchain v3.2.4
[08:24:40] nrfutil-sdk-manager install v3.2.4 --sdk-path /opt/nordic/ncs/v3.2.4 --type nrf: Toolchain with version v3.2.4 already installed: success
[08:24:40] nrfutil-sdk-manager install v3.2.4 --sdk-path /opt/nordic/ncs/v3.2.4 --type nrf: Download SDK v3.2.4
[08:28:41] nrfutil-sdk-manager install v3.2.4 --sdk-path /opt/nordic/ncs/v3.2.4 --type nrf: null: success
[08:28:41] nrfutil-sdk-manager install v3.2.4 --sdk-path /opt/nordic/ncs/v3.2.4 --type nrf: Calculating SDK checksum
[08:28:44] nrfutil-sdk-manager install v3.2.4 --sdk-path /opt/nordic/ncs/v3.2.4 --type nrf: Verified download: success
[08:28:44] nrfutil-sdk-manager install v3.2.4 --sdk-path /opt/nordic/ncs/v3.2.4 --type nrf: Unpack SDK v3.2.4
[08:29:15] nrfutil-sdk-manager install v3.2.4 --sdk-path /opt/nordic/ncs/v3.2.4 --type nrf: Unpacked SDK tarball: success
[west]: usage: west [-h] [-z ZEPHYR_BASE] [-v] [-q] [-V] <command> ...
[west]: west: unknown command "zephyr-export"; workspace /opt/nordic/ncs/v3.2.4 does not define this extension command -- try "west help" and "west -vv status"
[west]: exited with code 1.
[west]: FATAL ERROR: failed manifest import in zephyr (zephyr):
[west]: Failed importing "west.yml" from revision "ncs-v3.2.4"
[west]: Hint: zephyr must be cloned, owned by the user and its manifest-rev ref must point to a commit with the import data
[west]: To fix, run "west update. If it still fails, try "west -vv ..."
Here is my generated support info:
// IMPORTANT: The following data can contain sensitive or confidential information about your environment.
// If you do not want others to see this information, make sure to remove it before sharing the data.
// For help and support, visit Nordic Semiconductor's DevZone at devzone.nordicsemi.com/.
"platform": {
"os": "darwin",
"osVersion": "Darwin Kernel Version 24.6.0: Wed Nov 5 21:30:44 PST 2025; root:xnu-11417.140.69.705.2~1/RELEASE_ARM64_T6041",
"osKernel": "24.6.0",
"vscode": "1.111.0",
"electron": "39.6.0",
"node": "v22.22.0",
"appName": "Visual Studio Code",
"appHost": "desktop"
"system": {
"date": "2026-03-17T14:37:51.866Z",
"vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
"nrfConnectForDesktopInstalled": false,
"vscodeUptime": "00:20:49",
"osUptime": "61:51:05",
"cpu": "Apple M4 Max"
"workspace": {
"name": null,
"workspaceFile": null,
"folders": []
"sdks": [
"version": "?.?.?",
"path": "/opt/nordic/ncs/v3.2.4"
"version": "v4.3.99",
"path": "/Users/chet/Library/CloudStorage/Dropbox/Chet/git/my_threads_app"
"apps": [],
"toolchains": [
"version": "3.2.4",
"path": "/opt/nordic/ncs/toolchains/185bb0e3b6",
"displayName": "nRF Connect SDK Toolchain v3.2.4",
"compilerTools": [
"Zephyr SDK (arm) 0.17.0",
"Zephyr SDK (riscv) 0.17.0"
"connectedDevices": [],
"tools": {
"/opt/nordic/ncs/toolchains/185bb0e3b6/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.17.0 (arm64)",
"/Applications/SEGGER/JLink/JLinkExe": "9.26 (x64,arm64)",
"/usr/local/bin/nrfjprog": "10.24.2 (x64,arm64)",
"/opt/nordic/ncs/toolchains/185bb0e3b6/nrfutil/bin/nrfutil": "8.1.1 (x64,arm64)",
"/opt/nordic/ncs/toolchains/185bb0e3b6/nrfutil/home/bin/nrfutil-device": "2.17.1 (x64,arm64)",
"/opt/nordic/ncs/toolchains/185bb0e3b6/bin/cmake": "3.21.0 (arm64)",
"/opt/nordic/ncs/toolchains/185bb0e3b6/bin/west": "1.4.0",
"/opt/nordic/ncs/toolchains/185bb0e3b6/bin/python3": "3.12.4 (arm64)",
"/opt/nordic/ncs/toolchains/185bb0e3b6/bin/ninja": "1.10.2 (arm64)",
"/opt/nordic/ncs/toolchains/185bb0e3b6/bin/gperf": "3.1 (arm64)",
"/opt/nordic/ncs/toolchains/185bb0e3b6/bin/dtc": "1.6.1 (arm64)",
"/opt/nordic/ncs/toolchains/185bb0e3b6/bin/gn": "2223 (arm64)",
"/opt/nordic/ncs/toolchains/185bb0e3b6/bin/git": "git version 2.37.3 (arm64)",
"debugger (arm)": "/opt/nordic/ncs/toolchains/185bb0e3b6/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb",
"debugger (riscv)": "/opt/nordic/ncs/toolchains/185bb0e3b6/opt/zephyr-sdk/riscv64-zephyr-elf/bin/riscv64-zephyr-elf-gdb"
"nrfutil": {
"nrfutil-device": {
"version": "2.17.1",
"binPath": "/Users/chet/.vscode/extensions/nordic-semiconductor.nrf-connect-2026.3.1484-darwin-arm64/platform/nrfutil/bin/nrfutil-device",
"jlinkInfo": {
"description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
"expectedVersion": {
"version": "JLink_V8.76",
"versionFormat": "string"
"name": "JlinkARM",
"version": "JLink_V9.26",
"nrfutil-sdk-manager": {
"version": "1.11.0",
"binPath": "/Users/chet/.vscode/extensions/nordic-semiconductor.nrf-connect-2026.3.1484-darwin-arm64/platform/nrfutil/bin/nrfutil-sdk-manager"
"environment": {
"westEnv": {
"GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/185bb0e3b6/Cellar/git/2.37.3/libexec/git-core",
"HOME": "/Users/chet",
"PATH": "/opt/nordic/ncs/toolchains/185bb0e3b6/bin:/opt/nordic/ncs/toolchains/185bb0e3b6/usr/bin:/opt/nordic/ncs/toolchains/185bb0e3b6/usr/local/bin:/opt/nordic/ncs/toolchains/185bb0e3b6/opt/bin:/opt/nordic/ncs/toolchains/185bb0e3b6/opt/nanopb/generator-bin:/opt/nordic/ncs/toolchains/185bb0e3b6/nrfutil/bin:/opt/nordic/ncs/toolchains/185bb0e3b6/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/185bb0e3b6/opt/zephyr-sdk/riscv64-zephyr-elf/bin:/opt/homebrew/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/opt/ST/STM32CubeCLT_1.18.0:/opt/ST/STM32CubeCLT_1.18.0/GNU-tools-for-STM32/bin:/opt/ST/STM32CubeCLT_1.18.0/STM32CubeProgrammer/bin:/opt/ST/STM32CubeCLT_1.18.0/STLink-gdb-server/bin:/opt/ST/STM32CubeCLT_1.18.0/CMake/bin:/opt/ST/STM32CubeCLT_1.18.0/Ninja/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/usr/local/go/bin:/Users/chet/Library/Application Support/JetBrains/Toolbox/scripts:/Users/chet/Qt/6.8.3/macos/bin:/Users/chet/go/bin:/opt/homebrew/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/opt/ST/STM32CubeCLT_1.18.0:/opt/ST/STM32CubeCLT_1.18.0/GNU-tools-for-STM32/bin:/opt/ST/STM32CubeCLT_1.18.0/STM32CubeProgrammer/bin:/opt/ST/STM32CubeCLT_1.18.0/STLink-gdb-server/bin:/opt/ST/STM32CubeCLT_1.18.0/CMake/bin:/opt/ST/STM32CubeCLT_1.18.0/Ninja/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/usr/local/go/bin:/Users/chet/Library/Application Support/JetBrains/Toolbox/scripts:/Users/chet/Qt/6.8.3/macos/bin:/Users/chet/go/bin",
"ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/185bb0e3b6/opt/zephyr-sdk",
"USER": "chet"
"inherited": {
"ELECTRON_RUN_AS_NODE": "1",
"PATH": "/opt/homebrew/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/opt/ST/STM32CubeCLT_1.18.0:/opt/ST/STM32CubeCLT_1.18.0/GNU-tools-for-STM32/bin:/opt/ST/STM32CubeCLT_1.18.0/STM32CubeProgrammer/bin:/opt/ST/STM32CubeCLT_1.18.0/STLink-gdb-server/bin:/opt/ST/STM32CubeCLT_1.18.0/CMake/bin:/opt/ST/STM32CubeCLT_1.18.0/Ninja/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/usr/local/go/bin:/Users/chet/Library/Application Support/JetBrains/Toolbox/scripts:/Users/chet/Qt/6.8.3/macos/bin:/Users/chet/go/bin",
"USER": "chet"
"terminal": {
"defaultProfile": null
"config": {
"ozonePath": "",
"applications": [],
"applicationOptions": {},
"west": {
"env": {
"$base": "terminal"
"verbose": ""
"boardRoots": [],
"taskBindings": {},
"buildTerminal": {
"condensedProgress": true
"debugging": {
"flash": true,
"bindings": {},
"justMyCode": false,
"focusOnNrfDebug": true
"flash": {
"softreset": false,
"erase": false,
"recover": false
"enableTelemetry": true,
"thirdpartyIntegration": {},
"toolchainManager": {
"indexURL": null,
"installDirectory": null
"sdkManager": {
"region": "default"
"defaultOpenAction": "ask",
"terminalProfile": {
"shell": {}
"remoteDevices": []
"extensions": {
"internal": {
"version": "2026.3.1484",
"path": "/Users/chet/.vscode/extensions/nordic-semiconductor.nrf-connect-2026.3.1484-darwin-arm64",
"isActive": true
"nordic-semiconductor.nrf-terminal": null,
"nordic-semiconductor.nrf-devicetree": null,
"nordic-semiconductor.nrf-kconfig": null
"external": {
"marus25.cortex-debug": null,
"ms-vscode.cpptools": null,
"ms-vscode.js-debug": "1.110.0",
"ms-vscode.vscode-js-profile-table": "1.0.10"
  •  ~  nrfutil sdk-manager sdk register v3.2.4
     ✘  ~  nrfutil sdk-manager sdk register v3.2.4 --use-current-environment
    error: unexpected argument '--use-current-environment' found
      tip: a similar argument exists: '--with-current-environment'
    Usage: nrfutil sdk-manager sdk register --with-current-environment <VERSION>
    For more information, try '--help'.
     ✘  ~  nrfutil sdk-manager sdk register v3.2.4 --with-current-environment
    Error: No such file or directory (os error 2)
  • I did try rolling back to version 2026.1.448 of the extension as described in one of the tickets I was asked to look at.  And I have the same problems.  So my attempt at the command line is in the vscode integrated terminal, but it is using version 2026.1.448.
  • Where is the log located that it mentions when it errors out when I run the command in the terminal.  Maybe I can send that to you?
  • Logs should be in you username directory: {USER_HOME_DIRECTORY}/.nrfutil/
  • [2026-03-15T01:14:51.489Z] [2854] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with search
    [2026-03-15T01:14:51.489Z] [2854] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-15T01:14:51.490Z] [2854] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_TOOLCHAIN_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-15T01:14:51.490Z] [2854] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-15T01:14:52.114Z] [2854] INFO - [log] Downloading from https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-macos-aarch64.json log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=344
    [2026-03-15T01:14:52.115Z] [2854] INFO - [log] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=27
    [2026-03-15T01:14:52.734Z] [2854] INFO - [log] Get request to https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-macos-aarch64.json returned status code 200: OK log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=349
    [2026-03-15T01:14:53.028Z] [2854] INFO - [log] Download finished log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=358
    [2026-03-15T01:15:18.268Z] [2872] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with install v3.2.4
    [2026-03-15T01:15:18.268Z] [2872] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-15T01:15:23.258Z] [2872] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_TOOLCHAIN_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-15T01:15:23.921Z] [2872] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-15T01:15:24.508Z] [2872] INFO - [log] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=27
    [2026-03-15T01:15:25.287Z] [2872] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=361
    [2026-03-15T01:15:25.288Z] [2872] INFO - [log] File /opt/nordic/ncs/toolchains/toolchains.json empty, reading directory /opt/nordic/ncs/toolchains log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=386
    [2026-03-15T01:15:25.288Z] [2872] INFO - [log] Skipping toolchain entry: Failed to read toolchain manifest from `/opt/nordic/ncs/toolchains/toolchains.json/manifest.json` log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=212
    [2026-03-15T01:15:25.289Z] [2872] INFO - [log] Downloading from https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-macos-aarch64.json log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=344
    [2026-03-15T01:15:25.892Z] [2872] INFO - [log] Get request to https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-macos-aarch64.json returned status code 200: OK log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=349
    [2026-03-15T01:15:26.182Z] [2872] INFO - [log] Download finished log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=358
    [2026-03-15T01:15:26.184Z] [2872] INFO - [log] Downloading bundle-id 185bb0e3b6 from index log.target="toolchain_manager_core::install" log.module_path="toolchain_manager_core::install" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/install.rs" log.line=162
    [2026-03-15T01:15:26.185Z] [2872] INFO - [log] Downloading from https://publicburan.blob.core.windows.net/artifactory/NCS/external/bundles/v3/ncs-toolchain-aarch64-macos-185bb0e3b6.tar.gz to /opt/nordic/ncs/downloads/ncs-toolchain-aarch64-macos-185bb0e3b6.tar.gz log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=171
    [2026-03-15T01:15:26.185Z] [2872] INFO - [log] No '-part' file found for resumable download log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=122
    [2026-03-15T01:15:26.185Z] [2872] INFO - [log] Not adding Range header to request log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=234
    [2026-03-15T01:15:26.185Z] [2872] INFO - [log] Adding 'x-ms-version: 2025-07-05' header to request log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=253
    [2026-03-15T01:15:26.942Z] [2872] INFO - [log] Server supported partial content to resumable downloads are possible log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=286
    [2026-03-15T01:16:49.930Z] [2872] INFO - [log] Download finished log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=413
    [2026-03-15T01:16:49.930Z] [2872] INFO - [log] Verifying toolchain tarball /opt/nordic/ncs/downloads/ncs-toolchain-aarch64-macos-185bb0e3b6.tar.gz log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=248
    [2026-03-15T01:17:06.660Z] [2872] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=361
    [2026-03-15T01:17:06.660Z] [2872] INFO - [log] File /opt/nordic/ncs/toolchains/toolchains.json empty, reading directory /opt/nordic/ncs/toolchains log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=386
    [2026-03-15T01:17:06.660Z] [2872] INFO - [log] Skipping toolchain entry: Failed to read toolchain manifest from `/opt/nordic/ncs/toolchains/toolchains.json/manifest.json` log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=212
    [2026-03-15T01:17:06.660Z] [2872] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-15T01:17:06.660Z] [2872] INFO - [log] Registering the NcsToolchainConfig.cmake package log.target="toolchain_manager_core" log.module_path="toolchain_manager_core" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/lib.rs" log.line=206
    [2026-03-15T01:17:06.846Z] [2872] INFO - [log] Attempting download from 'https://publicburan.blob.core.windows.net/artifactory/ncs-src-mirror/external/sdk-nrf/v3.2.4/src.tar.gz' log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=176
    [2026-03-15T01:17:06.846Z] [2872] INFO - [log] No '-part' file found for resumable download log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=122
    [2026-03-15T01:17:06.846Z] [2872] INFO - [log] Not adding Range header to request log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=234
    [2026-03-15T01:17:06.846Z] [2872] INFO - [log] Adding 'x-ms-version: 2025-07-05' header to request log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=253
    [2026-03-15T01:17:07.520Z] [2872] INFO - [log] Server supported partial content to resumable downloads are possible log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=286
    [2026-03-15T01:21:33.174Z] [2872] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-15T01:21:35.822Z] [2872] ERROR - [log] Failed to run 'west zephyr-export' in SDK directory.
    Exit status: Some(1)
    Stdout:
    Stderr: usage: west [-h] [-z ZEPHYR_BASE] [-v] [-q] [-V] <command> ...
     log.target="nrfutil_sdk_manager::sdk::register" log.module_path="nrfutil_sdk_manager::sdk::register" log.file="src/sdk/register.rs" log.line=171
    [2026-03-15T01:22:29.552Z] [3017] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with install v3.2.3
    [2026-03-15T01:22:29.552Z] [3017] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-15T01:22:29.553Z] [3017] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_TOOLCHAIN_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-15T01:22:30.294Z] [3017] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-15T01:22:30.902Z] [3017] INFO - [log] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=27
    [2026-03-15T01:22:31.639Z] [3017] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=361
    [2026-03-15T01:22:31.639Z] [3017] INFO - [log] Downloading from https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-macos-aarch64.json log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=344
    [2026-03-15T01:22:32.222Z] [3017] INFO - [log] Get request to https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-macos-aarch64.json returned status code 200: OK log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=349
    [2026-03-15T01:22:32.508Z] [3017] INFO - [log] Download finished log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=358
    [2026-03-15T01:22:32.512Z] [3017] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-15T01:22:32.512Z] [3017] INFO - [log] Registering the NcsToolchainConfig.cmake package log.target="toolchain_manager_core" log.module_path="toolchain_manager_core" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/lib.rs" log.line=206
    [2026-03-15T01:22:32.545Z] [3017] INFO - [log] Attempting download from 'https://publicburan.blob.core.windows.net/artifactory/ncs-src-mirror/external/sdk-nrf/v3.2.3/src.tar.gz' log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=176
    [2026-03-15T01:22:32.545Z] [3017] INFO - [log] No '-part' file found for resumable download log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=122
    [2026-03-15T01:22:32.545Z] [3017] INFO - [log] Not adding Range header to request log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=234
    [2026-03-15T01:22:32.545Z] [3017] INFO - [log] Adding 'x-ms-version: 2025-07-05' header to request log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=253
    [2026-03-15T01:22:33.219Z] [3017] INFO - [log] Server supported partial content to resumable downloads are possible log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=286
    [2026-03-15T01:26:48.407Z] [3017] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-15T01:26:48.512Z] [3017] ERROR - [log] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    west: unknown command "zephyr-export"; workspace /opt/nordic/ncs/v3.2.3 does not define this extension command -- try "west help" and "west -vv status"
    [2026-03-15T01:27:22.526Z] [3066] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with install v3.2.4
    [2026-03-15T01:27:22.526Z] [3066] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-15T01:27:22.526Z] [3066] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_TOOLCHAIN_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-15T01:27:23.191Z] [3066] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-15T01:27:23.774Z] [3066] INFO - [log] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=27
    [2026-03-15T01:27:24.636Z] [3066] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=361
    [2026-03-15T01:27:24.636Z] [3066] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-15T01:27:24.638Z] [3066] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-15T01:27:24.759Z] [3066] ERROR - [log] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    [2026-03-15T19:10:57.925Z] [8026] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with install v3.2.4
    [2026-03-15T19:10:57.925Z] [8026] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-15T19:10:57.925Z] [8026] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_TOOLCHAIN_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-15T19:10:58.797Z] [8026] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-15T19:10:59.419Z] [8026] INFO - [log] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=27
    [2026-03-15T19:11:00.170Z] [8026] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=361
    [2026-03-15T19:11:00.172Z] [8026] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-15T19:11:00.174Z] [8026] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-15T19:11:00.374Z] [8026] ERROR - [log] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    [2026-03-16T01:26:22.359Z] [10717] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with install v3.2.4
    [2026-03-16T01:26:22.359Z] [10717] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-16T01:26:22.360Z] [10717] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_TOOLCHAIN_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-16T01:26:23.206Z] [10717] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-16T01:26:23.829Z] [10717] INFO - [log] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=27
    [2026-03-16T01:26:24.557Z] [10717] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=361
    [2026-03-16T01:26:24.558Z] [10717] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-16T01:26:24.561Z] [10717] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-16T01:26:24.751Z] [10717] ERROR - [log] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    [2026-03-16T16:55:36.523Z] [20647] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk install v3.2.4 --sdk-path /Users/chet/nordic
    [2026-03-16T16:55:36.524Z] [20647] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-16T16:55:49.003Z] [20647] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-16T16:55:50.283Z] [20647] INFO - [log] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=27
    [2026-03-16T16:56:23.789Z] [20690] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk install v3.2.4 --sdk-path /Users/chet/nordic
    [2026-03-16T16:56:23.789Z] [20690] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-16T16:56:23.789Z] [20690] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-16T16:56:24.406Z] [20690] INFO - [log] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=27
    [2026-03-16T16:56:25.172Z] [20690] INFO - [log] Attempting download from 'https://publicburan.blob.core.windows.net/artifactory/ncs-src-mirror/external/sdk-nrf/v3.2.4/src.tar.gz' log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=176
    [2026-03-16T16:56:25.173Z] [20690] INFO - [log] No '-part' file found for resumable download log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=122
    [2026-03-16T16:56:25.173Z] [20690] INFO - [log] Not adding Range header to request log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=234
    [2026-03-16T16:56:25.173Z] [20690] INFO - [log] Adding 'x-ms-version: 2025-07-05' header to request log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=253
    [2026-03-16T16:56:25.909Z] [20690] INFO - [log] Server supported partial content to resumable downloads are possible log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=286
    [2026-03-16T19:56:49.599Z] [25146] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk install v3.2.4 --sdk-path /Users/chet/nordic/v3.2.4
    [2026-03-16T19:56:49.600Z] [25146] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-16T19:56:49.601Z] [25146] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-16T19:56:50.413Z] [25146] INFO - [log] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=27
    [2026-03-16T19:58:10.141Z] [25430] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk register v3.2.4
    [2026-03-16T19:58:10.141Z] [25430] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-16T20:01:37.283Z] [26500] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk install v3.2.4
    [2026-03-16T20:01:37.283Z] [26500] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-16T20:01:37.283Z] [26500] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-16T20:01:38.005Z] [26500] INFO - [log] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json log.target="nrfutil_sdk_manager::sdk::package_index" log.module_path="nrfutil_sdk_manager::sdk::package_index" log.file="src/sdk/package_index.rs" log.line=27
    [2026-03-16T20:16:13.481Z] [26657] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk register v3.2.4
    [2026-03-16T20:16:13.481Z] [26657] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-16T20:17:51.838Z] [26682] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with toolchain install --ncs-version v3.2.4
    [2026-03-16T20:17:51.838Z] [26682] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-16T20:17:51.838Z] [26682] INFO - [log] Environment variable 'NRFUTIL_SDK_MANAGER_TOOLCHAIN_REMOTE_CONFIG_TOKEN' not found for token access log.target="nrfutil_secrets" log.module_path="nrfutil_secrets" log.file="/nrfutil-rs/crates/nrfutil-secrets/src/lib.rs" log.line=57
    [2026-03-16T20:17:52.640Z] [26682] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=361
    [2026-03-16T20:17:52.640Z] [26682] INFO - [log] File /opt/nordic/ncs/toolchains/toolchains.json empty, reading directory /opt/nordic/ncs/toolchains log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=386
    [2026-03-16T20:17:52.640Z] [26682] INFO - [log] Skipping toolchain entry: Failed to read toolchain manifest from `/opt/nordic/ncs/toolchains/toolchains.json/manifest.json` log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=212
    [2026-03-16T20:17:52.641Z] [26682] INFO - [log] Downloading from https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-macos-aarch64.json log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=344
    [2026-03-16T20:17:53.250Z] [26682] INFO - [log] Get request to https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-macos-aarch64.json returned status code 200: OK log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=349
    [2026-03-16T20:17:53.532Z] [26682] INFO - [log] Download finished log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=358
    [2026-03-16T20:17:53.541Z] [26682] INFO - [log] Downloading bundle-id 185bb0e3b6 from index log.target="toolchain_manager_core::install" log.module_path="toolchain_manager_core::install" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/install.rs" log.line=162
    [2026-03-16T20:17:53.541Z] [26682] INFO - [log] Downloading from https://publicburan.blob.core.windows.net/artifactory/NCS/external/bundles/v3/ncs-toolchain-aarch64-macos-185bb0e3b6.tar.gz to /opt/nordic/ncs/downloads/ncs-toolchain-aarch64-macos-185bb0e3b6.tar.gz log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=171
    [2026-03-16T20:17:53.541Z] [26682] INFO - [log] No '-part' file found for resumable download log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=122
    [2026-03-16T20:17:53.541Z] [26682] INFO - [log] Not adding Range header to request log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=234
    [2026-03-16T20:17:53.541Z] [26682] INFO - [log] Adding 'x-ms-version: 2025-07-05' header to request log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=253
    [2026-03-16T20:17:54.276Z] [26682] INFO - [log] Server supported partial content to resumable downloads are possible log.target="nrfutil_http::download" log.module_path="nrfutil_http::download" log.file="/nrfutil-rs/crates/nrfutil-http/src/download.rs" log.line=286
    [2026-03-16T20:19:19.992Z] [26682] INFO - [log] Download finished log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=413
    [2026-03-16T20:19:19.992Z] [26682] INFO - [log] Verifying toolchain tarball /opt/nordic/ncs/downloads/ncs-toolchain-aarch64-macos-185bb0e3b6.tar.gz log.target="toolchain_manager_core::index" log.module_path="toolchain_manager_core::index" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/index.rs" log.line=248
    [2026-03-16T20:19:36.249Z] [26682] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=361
    [2026-03-16T20:19:36.249Z] [26682] INFO - [log] File /opt/nordic/ncs/toolchains/toolchains.json empty, reading directory /opt/nordic/ncs/toolchains log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=386
    [2026-03-16T20:19:36.249Z] [26682] INFO - [log] Skipping toolchain entry: Failed to read toolchain manifest from `/opt/nordic/ncs/toolchains/toolchains.json/manifest.json` log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=212
    [2026-03-16T20:19:36.249Z] [26682] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-16T20:19:36.249Z] [26682] INFO - [log] Registering the NcsToolchainConfig.cmake package log.target="toolchain_manager_core" log.module_path="toolchain_manager_core" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/lib.rs" log.line=206
    [2026-03-16T20:44:27.272Z] [26842] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk register v3.2.4
    [2026-03-16T20:44:27.272Z] [26842] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-16T20:44:27.273Z] [26842] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-16T20:44:29.925Z] [26842] ERROR - [log] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    [2026-03-16T21:12:27.392Z] [28812] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk register v3.2.4
    [2026-03-16T21:12:27.392Z] [28812] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-16T21:12:27.392Z] [28812] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-16T21:12:27.523Z] [28812] ERROR - [log] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    [2026-03-17T14:49:23.873Z] [48524] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk register v3.2.4
    [2026-03-17T14:49:23.873Z] [48524] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-17T14:49:23.875Z] [48524] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-17T14:49:23.986Z] [48524] ERROR - [log] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    [2026-03-17T14:52:59.768Z] [48964] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk register v3.2.4
    [2026-03-17T14:52:59.768Z] [48964] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-17T14:52:59.768Z] [48964] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-17T14:52:59.864Z] [48964] ERROR - [log] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    [2026-03-18T14:52:37.393Z] [66263] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk register v3.2.4
    [2026-03-18T14:52:37.394Z] [66263] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
    [2026-03-18T14:52:37.395Z] [66263] INFO - [log] Retrieving toolchains from file /opt/nordic/ncs/toolchains/toolchains.json log.target="toolchain_manager_core::sdk" log.module_path="toolchain_manager_core::sdk" log.file="/nrfutil-rs/crates/toolchain-manager-core/src/sdk.rs" log.line=339
    [2026-03-18T14:52:37.502Z] [66263] ERROR - [log] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    [2026-03-18T14:53:49.414Z] [66477] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.11.0, platform = aarch64-apple-darwin, classification = nrf-external) invoked with sdk register v3.2.4 --with-current-environment
    [2026-03-18T14:53:49.414Z] [66477] INFO - [log] Loading config from default location log.target="nrfutil_sdk_manager::config::file" log.module_path="nrfutil_sdk_manager::config::file" log.file="src/config/file.rs" log.line=113
