PDM data to speaker
Hi,I am working with pdm mic to read data .I can able to get the audio data using dmic_read api in pcm format.I got clock of 1280000 and sampling rate of 16000 of each 16 bit sample.Now I want to play that data in tas2562 speaker amplifier.I configured pins for i2s tx i.e,clock,fclk,data out pin and I got clock frequency of 507936 of sampling rate 15873.And I got following output.I am making buffer slab free for every loop.
00> [00:00:00.001,215] <inf> dmic_sample: DMIC sample
00> [00:00:00.001,229] <inf> dmic_nrfx_pdm: PDM clock frequency: 1280000, actual PCM rate: 16000
00> [00:00:00.001,268] <inf> i2s_nrfx: I2S MCK frequency: 507936, actual PCM rate: 15873
00> Configure Stream Successful.
00> Trigger Command Successful.
00> [00:00:10.911,696] <err> dmic_nrfx_pdm: No room in RX queue
00> [00:00:11.012,512] <err> i2s_nrfx: Next buffers not supplied on time
00> [00:00:11.952,097] <err> dmic_sample: read failed: -11
  • Hi Edvin,
    Assuming this is what you see as well:
    Yes,I am seeing same what you have mentioned
    One way to work around this is to split this up into two threads. One constantly reading the mic, storing the data in buffers, and another one emptying it, outputting to the speaker.
    I checked with the code you shared where it skips the block of data ,it worked.But I didn't understand why we have used mem_slab of 64 blocks and  #AUDIO_Q_LEN  of 32,as we're doing in real time it will automatically clear buffer when we sent to speaker then why can't we use limited buffers of 16 and make it work.Why data is getting hold in that many buffers.When I tried I got following
    00> [00:00:00.002,148] <inf> dmic_sample: DMIC sample
    00> [00:00:00.002,162] <inf> dmic_nrfx_pdm: PDM clock frequency: 1280000, actual PCM rate: 16000
    00> [00:00:00.002,187] <inf> i2s_nrfx: I2S MCK frequency: 507936, actual PCM rate: 15873
    00> [00:00:14.976,144] <err> dmic_nrfx_pdm: Failed to allocate buffer: -12
    00> [00:00:15.115,783] <err> i2s_nrfx: Next buffers not supplied on time
    00> [00:00:15.976,247] <wrn> dmic_sample: dmic_read backpressure/retry: 1
    Since there is a difference in sample rate, there will still be some data that can't be output to the speaker, but you will be able to detect it, and skip one block.
    As I checked Nrf54 datasheet it says the following sampling rates will occur in I2S configuration with some error.I am not sure how I can tune samples .And also make me sure is this correct process for reading pdm data and send to speaker?
    With Regards,
    Kashyap
  • Hello Kashyap,
    It is correct that you probably don't need that many buffers. I just experimented with your sample to see why it was failing (and forgot to turn the buffer count back down after it didn't seem to affect much to increase it).
    Having too many buffers will increase the time it takes before the first buffer is dropped, but it also introduces a delay (don't know whether that is an issue in your case).
    So you should be able to turn these down a bit.
    What exactly did you try in this case? What changes did you do?
    I assume this comes from this table:
    https://docs.nordicsemi.com/bundle/ps_nrf9151/page/i2s.html#ariaid-title6
    As you can see, it is not possible to make it exactly 16 000 Hz. You will have some error. So you need to pick a sample rate for the I2S that is either a bit too fast or a bit too slow. Perhaps, in your case, you can pick one that is a bit too fast. This means that you will still get some cracks in the sound, but it will not loose any data. You can experiment and see what works best in your case. I still recommend that you do this in two separate threads. Keep track of how many of the buffers that are filled. If no buffers are ready, wait for the DMIC to finish another sampling before you try to queue up the buffer in the speaker.
    Edvin
  • What exactly did you try in this case? What changes did you do?
    I tried to reduced block count to 16 and also AUDIO_Q_LEN to 16 and 8 but after few seconds I got same issue even if Iused thread method also
    00> *** Using Zephyr OS v4.1.99-ff8f0c579eeb ***
    00> [00:00:14.990,039] <err> dmic_nrfx_pdm: Failed to allocate buffer: -12
    00> [00:00:15.129,861] <err> i2s_nrfx: Next buffers not supplied on time
    00> [00:00:15.990,132] <wrn> dmic_sample: dmic_read backpressure/retry: 1
    Here can we send buffer of data to speaker or we're waiting all the data i getting qued then we sending to speaker?And I want to do some processing before data is sending to speaker.I want to do filtering and also ANC in that case i need to use 2 channel data.
  • I think the BLOCK_COUNT needs to be at least AUDIO_Q_LEN + 10. The AUDIO_Q_LEN uses blocks from the mem_slab (size = BLOCK_COUNT), and then you need some more for the dmic. I think the limit is AUDIO_Q_LEN + 2 for DMIC DMA + 4 for I2S tx queue and 2 for I2S HW. In addition, you need 2 for handover. Perhaps use AUDIO_Q_LEN + 12 to be sure.
    Edvin
  • Yes,when I follow this buffers I am just loosing one block of audio per second but audio flow is working fine.But when I used I2S_RX and TX there it worked even for 4 blocks in mem_slab without issue .Is it because here  PDM to I2s it's taking many blocks in recent approach(threads).
    And in final I want to know reading data from PDM Mic and getting PCM data will cause more processing in time in compare with using I2S MIC  with i2s_read?.I want to confirm what mic should I use as I will be doing more processing before sending to speaker.Will both the processes will require same processing or different?
    With Regards,
    Kashyap
