Missing BLE disconnect event (Supervision Timeout) - nRF9151 + nRF52840
I'm using nRF9151 as a HCI host and nRF52840 as HCI controller (nRF52840 config is based on HCI lpuart example). Recently I updated NCS to 3.2.2 and I started observing the lack of disconnect event on a supervision timeout. The issue didn't occur when both (nRF9151 and nRF52840) apps were on NCS 3.1.0 but also it didn't occur when nRF9151 app was already using NCS 3.2.2 but the nRF52840 was still on NCS 3.1.0.
I found out that it was a known issue, which was fixed on NCS 2.8.0.
Are you aware of that issue on NCS 3.2.2? Maybe it is already fixed on newer NCS versions?
Regards
Filip
  • Hello, here are the files.
    nRF91 .config:
    # Low Power Gateway
    CONFIG_NETWORK_THREAD_STACK_SIZE=8192
    CONFIG_NETWORK_THREAD_PRIORITY=11
    CONFIG_BLE_WORKQUEUE_STACK_SIZE=3072
    CONFIG_BLE_WORKQUEUE_PRIORITY=10
    CONFIG_LPG_MSG_FORWARDER_STACK_SIZE=6144
    CONFIG_LPG_MSG_FORWARDER_PRIORITY=13
    CONFIG_EXTENDED_LOGS=y
    CONFIG_WDT_BEFORE_MAIN=y
    CONFIG_LOG_BACKEND_TD_ENABLE_FLASH=y
    CONFIG_LPG_DAILY_REBOOT_HOUR=3
    CONFIG_LPG_DAILY_REBOOT_MINUTE=0
    # CONFIG_LPG_DFU_91_BL_SUPPORTED is not set
    CONFIG_LPG_SEND_DATA_TIMEOUT=600
    # CONFIG_LPG_PROD_MODE is not set
    CONFIG_TDBP_PAYLOAD_MAX_LEN=256
    # end of Low Power Gateway
    # Zephyr Kernel
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_NET_L2_ETHERNET is not set
    # CONFIG_REGULATOR is not set
    CONFIG_BT_LONG_WQ_STACK_SIZE=1800
    CONFIG_MAIN_STACK_SIZE=6144
    # CONFIG_FPU is not set
    CONFIG_BT_RX_STACK_SIZE=2048
    CONFIG_SERIAL=y
    CONFIG_SPI=y
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MEMC is not set
    # CONFIG_MODEM is not set
    CONFIG_NET_IPV6=y
    CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
    # CONFIG_BT_HCI_VS is not set
    CONFIG_HW_STACK_PROTECTION=y
    CONFIG_BUILD_WITH_TFM=y
    CONFIG_TFM_FLASH_MERGED_BINARY=y
    CONFIG_NUM_IRQS=65
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_SOC_RESET_HOOK=y
    CONFIG_CLOCK_CONTROL=y
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_ROM_START_OFFSET=0
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_XIP=y
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_COUNTER is not set
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_TASK_WDT_HW_FALLBACK_DELAY=1000
    CONFIG_CPU_HAS_ARM_MPU=y
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_PM_DEVICE=y
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_BT_AUTO_PHY_UPDATE=y
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
    # CONFIG_BT_USER_PHY_UPDATE is not set
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_USE_DT_CODE_PARTITION=y
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    # CONFIG_ZERO_LATENCY_IRQS is not set
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_INIT_STACKS is not set
    CONFIG_TIMESLICE_SIZE=20
    CONFIG_FLASH_LOAD_OFFSET=0x50000
    CONFIG_PM_DEVICE_SYSTEM_MANAGED=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    # CONFIG_BUILD_OUTPUT_S19 is not set
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_FLASH_FILL_BUFFER_SIZE=32
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_FLASH=y
    CONFIG_NET_UDP_CHECKSUM=y
    # CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set
    # CONFIG_HCI_NXP_SET_CAL_DATA is not set
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_MFD is not set
    # CONFIG_HCI_NXP_RX_THREAD is not set
    CONFIG_GPIO=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_NET_L2_IEEE802154 is not set
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    # CONFIG_CACHE is not set
    CONFIG_LOG=y
    CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_ROMSTART_RELOCATION_ROM is not set
    CONFIG_DCACHE_LINE_SIZE=32
    # CONFIG_RESET is not set
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_LOG_DOMAIN_NAME=""
    # CONFIG_ASSERT is not set
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
    # CONFIG_PM_DEVICE_RUNTIME is not set
    # CONFIG_DEVICE_DEPS is not set
    CONFIG_PM_DEVICE_POWER_DOMAIN=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_UART_USE_RUNTIME_CONFIGURE=y
    # CONFIG_SYSCON is not set
    CONFIG_CONSOLE=y
    # CONFIG_WINSTREAM is not set
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_REBOOT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_GEN_IRQ_START_VECTOR=0
    CONFIG_SRAM_OFFSET=0
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_SPI_NOR=y
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
    CONFIG_BOOTLOADER_MCUBOOT=y
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_BT_BUF_CMD_TX_COUNT=1
    CONFIG_KERNEL_MEM_POOL=y
    CONFIG_MULTITHREADING=y
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_WATCHDOG=y
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_BT_BUF_CMD_TX_SIZE=65
    CONFIG_BT_BUF_EVT_RX_SIZE=68
    CONFIG_BT_BUF_ACL_TX_SIZE=251
    CONFIG_BT_BUF_ACL_RX_SIZE=251
    CONFIG_BT_L2CAP_TX_MTU=247
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_BOSCH_BMA4XX_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_FIXED_SUBPARTITIONS_ENABLED=y
    CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SW_LPUART_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF91_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF91X_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NXP_PCF8523_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_TD_GPIOS_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_UART_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_MEMORY_REGION_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_RETAINED_RAM_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_RETENTION_ENABLED=y
    # end of Devicetree Info
    # Modules
    # CONFIG_BUILD_ONLY_NO_BLOBS is not set
    # Available modules.
    # td1159-low-power-gateway-91 (/Users/filiprosik/Project/LPG_91/td1159-low-power-gateway-91)
    # LowPowerGateway
    # Device Drivers
    CONFIG_BQ34Z100R2=y
    CONFIG_MAX7320=y
    CONFIG_MAX7320_INIT_PRIORITY=58
    CONFIG_LPG_GPIOS=y
    CONFIG_LPG_GPIO_INIT_PRIORITY=59
    CONFIG_PCF8523=y
    CONFIG_PCF8523_INIT_PRIORITY=70
    CONFIG_BMA400=y
    CONFIG_BMA400_INIT_PRIORITY=80
    # end of LowPowerGateway
    CONFIG_ZEPHYR_TD1159_LOW_POWER_GATEWAY_91_MODULE=y
    # end of td1159-low-power-gateway-91 (/Users/filiprosik/Project/LPG_91/td1159-low-power-gateway-91)
    # nrf (/Users/filiprosik/Project/LPG_91/nrf)
    CONFIG_LOG_BUFFER_SIZE=1536
    # CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
    # CONFIG_MBEDTLS_SSL_MAX_FRAGMENT_LENGTH is not set
    CONFIG_MBEDTLS_MPI_MAX_SIZE=384
    # CONFIG_MBEDTLS_ENTROPY_C is not set
    CONFIG_MBEDTLS_CIPHER_MODE_CBC=y
    CONFIG_MBEDTLS_CIPHER_MODE_CTR=y
    CONFIG_MBEDTLS_CHACHA20_C=y
    CONFIG_MBEDTLS_POLY1305_C=y
    CONFIG_MBEDTLS_CHACHAPOLY_C=y
    CONFIG_MBEDTLS_DHM_C=y
    CONFIG_MBEDTLS_RSA_C=y
    CONFIG_MBEDTLS_SHA512_C=y
    CONFIG_MBEDTLS_GCM_C=y
    # CONFIG_MBEDTLS_CIPHER_MODE_XTS is not set
    CONFIG_MBEDTLS_SSL_SRV_C=y
    CONFIG_MBEDTLS_SSL_COOKIE_C=y
    CONFIG_MBEDTLS_SSL_CLI_C=y
    CONFIG_MBEDTLS_SSL_TLS_C=y
    CONFIG_MBEDTLS_HEAP_SIZE=24576
    CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=32
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
    CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=4096
    CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED=y
    # CONFIG_ZMS is not set
    # CONFIG_NVS is not set
    # CONFIG_NET_IPV6_NBR_CACHE is not set
    # CONFIG_NET_IPV6_MLD is not set
    CONFIG_NET_PKT_RX_COUNT=4
    CONFIG_NET_PKT_TX_COUNT=4
    # CONFIG_NET_PKT_TXTIME is not set
    # CONFIG_NET_PKT_TIMESTAMP is not set
    CONFIG_NET_RX_STACK_SIZE=1500
    CONFIG_NET_TX_STACK_SIZE=1200
    CONFIG_MBEDTLS_SHA1_C=y
    CONFIG_MBEDTLS=y
    CONFIG_MBEDTLS_TLS_VERSION_1_2=y
    CONFIG_MBEDTLS_MAC_SHA256_ENABLED=y
    # CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set
    CONFIG_MBEDTLS_MD_C=y
    CONFIG_MBEDTLS_TLS_LIBRARY=y
    CONFIG_MBEDTLS_X509_LIBRARY=y
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_ECP_C=y
    # CONFIG_MBEDTLS_CTR_DRBG_C is not set
    CONFIG_MBEDTLS_CMAC_C=y
    CONFIG_MBEDTLS_CCM_C=y
    CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C=y
    CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
    CONFIG_TFM_CRYPTO_RNG_MODULE_ENABLED=y
    CONFIG_TFM_PARTITION_CRYPTO=y
    CONFIG_TFM_PARTITION_PLATFORM=y
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=384
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_NRF_SECURITY_ENABLER=y
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS is not set
    # CONFIG_MCUMGR_GRP_ZBASIC is not set
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
    # Subsystems
    # Bootloader
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
    CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
    # CONFIG_NCS_MCUBOOT_BOOTLOADER_SIGN_MERGED_BINARY is not set
    # CONFIG_NCS_MCUBOOT_MANIFEST_UPDATES is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_COMPANY_ID_NORDIC=0x0059
    CONFIG_BT_COMPANY_ID=0x0059
    CONFIG_BT_MAX_CONN=1
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1024
    # CONFIG_BT_RADIO_NOTIFICATION_CONN_CB is not set
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    CONFIG_BT_GATT_DM=y
    CONFIG_BT_GATT_DM_WORKQ_OWN=y
    # CONFIG_BT_GATT_DM_WORKQ_SYS is not set
    CONFIG_BT_GATT_DM_WORKQ_STACK_SIZE=1300
    CONFIG_BT_GATT_DM_WORKQ_PRIO=10
    CONFIG_BT_GATT_DM_WORKQ_INIT_PRIO=50
    CONFIG_BT_GATT_DM_MAX_ATTRS=35
    # CONFIG_BT_GATT_DM_DATA_PRINT is not set
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_BT_GATT_DM=512
    # CONFIG_BT_GATT_DM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_DM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_DM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_GATT_DM_LOG_LEVEL_INF is not set
    # CONFIG_BT_GATT_DM_LOG_LEVEL_DBG is not set
    CONFIG_BT_GATT_DM_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_GATT_DM_LOG_LEVEL=3
    CONFIG_BT_SCAN=y
    CONFIG_BT_SCAN_NAME_MAX_LEN=32
    CONFIG_BT_SCAN_SHORT_NAME_MAX_LEN=32
    CONFIG_BT_SCAN_FILTER_ENABLE=y
    CONFIG_BT_SCAN_MANUFACTURER_DATA_MAX_LEN=32
    CONFIG_BT_SCAN_UUID_CNT=0
    CONFIG_BT_SCAN_NAME_CNT=0
    CONFIG_BT_SCAN_SHORT_NAME_CNT=0
    CONFIG_BT_SCAN_ADDRESS_CNT=0
    CONFIG_BT_SCAN_APPEARANCE_CNT=0
    CONFIG_BT_SCAN_MANUFACTURER_DATA_CNT=1
    # CONFIG_BT_SCAN_CONN_ATTEMPTS_FILTER is not set
    # CONFIG_BT_SCAN_BLOCKLIST is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_INF is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_DBG is not set
    CONFIG_BT_SCAN_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_SCAN_LOG_LEVEL=3
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # end of Bluetooth Services
    # BLE over nRF RPC
    # CONFIG_BT_RPC is not set
    CONFIG_HEAP_MEM_POOL_SIZE=1544
    # CONFIG_BT_SHELL is not set
    CONFIG_BT_CONN_DYNAMIC_CALLBACKS=y
    # CONFIG_BT_RPC_STACK is not set
    CONFIG_BT_CENTRAL=y
    # CONFIG_BT_PERIPHERAL is not set
    CONFIG_BT_OBSERVER=y
    # CONFIG_BT_BROADCASTER is not set
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    # CONFIG_BT_EXT_ADV is not set
    CONFIG_BT_LOG=y
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_LOG_LEVEL_INF is not set
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_LOG_LEVEL=3
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
    CONFIG_BT_RPA_LOG_LEVEL=3
    # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RPA_LOG_LEVEL_INF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_ATT_LOG_LEVEL=3
    # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_GATT_LOG_LEVEL=3
    # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_GATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_L2CAP_LOG_LEVEL=3
    # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HCI_CORE_LOG_LEVEL=3
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CONN_LOG_LEVEL=3
    # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONN_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_KEYS_LOG_LEVEL=3
    # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SERVICE_LOG_LEVEL=3
    # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_DIS is not set
    # CONFIG_BT_CTS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_ZEPHYR_NUS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_BAS_BLS is not set
    CONFIG_BT_BUF_ACL_RX_COUNT_EXTRA=1
    CONFIG_BT_WAIT_NOP=y
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    # CONFIG_BT_HCI_ERR_TO_STR is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_DEBUG_MONITOR_RTT is not set
    CONFIG_BT_LONG_WQ=y
    CONFIG_BT_LONG_WQ_PRIO=10
    CONFIG_BT_LONG_WQ_INIT_PRIO=50
    CONFIG_BT_HCI_HOST=y
    CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT=y
    CONFIG_BT_HCI_TX_PRIO=7
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_CONN_TX_NOTIFY_WQ is not set
    # CONFIG_BT_AUDIO is not set
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    CONFIG_BT_HOST_CRYPTO=y
    CONFIG_BT_HOST_CRYPTO_PRNG=y
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_CONN_TX_USER_DATA_SIZE=16
    CONFIG_BT_CONN_FRAG_COUNT=1
    CONFIG_BT_CONN_TX_MAX=3
    # CONFIG_BT_CONN_PARAM_ANY is not set
    # CONFIG_BT_CONN_CHECK_NULL_BEFORE_CREATE is not set
    # CONFIG_BT_USER_DATA_LEN_UPDATE is not set
    # CONFIG_BT_REMOTE_INFO is not set
    # CONFIG_BT_SMP is not set
    CONFIG_BT_L2CAP_TX_BUF_COUNT=3
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    # CONFIG_BT_L2CAP_SEG_RECV is not set
    # CONFIG_BT_L2CAP_RECONFIGURE_EXPLICIT is not set
    # CONFIG_BT_ATT_ERR_TO_STR is not set
    CONFIG_BT_ATT_TX_COUNT=3
    CONFIG_BT_ATT_PREPARE_COUNT=0
    # CONFIG_BT_ATT_SENT_CB_AFTER_TX is not set
    CONFIG_BT_GATT_AUTO_RESUBSCRIBE=y
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    # CONFIG_BT_GATT_DYNAMIC_DB is not set
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    CONFIG_BT_GATT_CLIENT=y
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    # CONFIG_BT_GATT_AUTO_DISCOVER_CCC is not set
    # CONFIG_BT_GATT_AUTO_UPDATE_MTU is not set
    # CONFIG_BT_GATT_AUTHORIZATION_CUSTOM is not set
    CONFIG_BT_MAX_PAIRED=0
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
    CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
    # CONFIG_BT_SCAN_WITH_IDENTITY is not set
    # CONFIG_BT_SCAN_AND_INITIATE_IN_PARALLEL is not set
    # CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
    CONFIG_BT_DEVICE_NAME="Zephyr"
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_DEVICE_APPEARANCE=0
    CONFIG_BT_ID_MAX=1
    # CONFIG_BT_DF is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_CLASSIC is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    CONFIG_DFU_TARGET=y
    CONFIG_DFU_TARGET_MCUBOOT=y
    CONFIG_DFU_TARGET_SMP=y
    CONFIG_DFU_TARGET_SMP_IMAGE_LIST_SIZE=4
    CONFIG_DFU_TARGET_STREAM=y
    # CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set
    # CONFIG_DFU_TARGET_STREAM_SYNCHRONOUS is not set
    CONFIG_DFU_TARGET_MODEM_DELTA=y
    CONFIG_DFU_TARGET_MODEM_TIMEOUT=60
    CONFIG_DFU_TARGET_FULL_MODEM=y
    CONFIG_DFU_TARGET_FULL_MODEM_EXT_FLASH_SIZE=0x400000
    CONFIG_DFU_TARGET_FULL_MODEM_USE_EXT_PARTITION=y
    # CONFIG_DFU_TARGET_CUSTOM is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_INF is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_DBG is not set
    CONFIG_DFU_TARGET_LOG_LEVEL_DEFAULT=y
    CONFIG_DFU_TARGET_LOG_LEVEL=3
    CONFIG_FMFU_FDEV=y
    # CONFIG_FMFU_CDDL_DECODER_GENERATE is not set
    # CONFIG_FMFU_FDEV_SKIP_PREVALIDATION is not set
    # CONFIG_FMFU_FDEV_LOG_LEVEL_OFF is not set
    # CONFIG_FMFU_FDEV_LOG_LEVEL_ERR is not set
    # CONFIG_FMFU_FDEV_LOG_LEVEL_WRN is not set
    # CONFIG_FMFU_FDEV_LOG_LEVEL_INF is not set
    # CONFIG_FMFU_FDEV_LOG_LEVEL_DBG is not set
    CONFIG_FMFU_FDEV_LOG_LEVEL_DEFAULT=y
    CONFIG_FMFU_FDEV_LOG_LEVEL=3
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # CONFIG_NRF_CLOUD is not set
    # CONFIG_REST_CLIENT is not set
    CONFIG_DOWNLOADER=y
    # Thread and stack buffers
    CONFIG_DOWNLOADER_STACK_SIZE=1280
    CONFIG_DOWNLOADER_MAX_HOSTNAME_SIZE=256
    CONFIG_DOWNLOADER_MAX_FILENAME_SIZE=255
    CONFIG_DOWNLOADER_MAX_REDIRECTS=10
    CONFIG_DOWNLOADER_TRANSPORT_PARAMS_SIZE=256
    CONFIG_DOWNLOADER_TRANSPORT_HTTP=y
    # CONFIG_DOWNLOADER_LOG_LEVEL_OFF is not set
    # CONFIG_DOWNLOADER_LOG_LEVEL_ERR is not set
    # CONFIG_DOWNLOADER_LOG_LEVEL_WRN is not set
    # CONFIG_DOWNLOADER_LOG_LEVEL_INF is not set
    # CONFIG_DOWNLOADER_LOG_LEVEL_DBG is not set
    CONFIG_DOWNLOADER_LOG_LEVEL_DEFAULT=y
    CONFIG_DOWNLOADER_LOG_LEVEL=3
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_FOTA_SOCKET_RETRIES=2
    # CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT is not set
    CONFIG_FOTA_CLIENT_AUTOSCHEDULE_UPDATE=y
    CONFIG_FOTA_DOWNLOAD_MCUBOOT_FLASH_BUF_SZ=512
    CONFIG_FOTA_DOWNLOAD_BUF_SZ=2048
    CONFIG_FOTA_DOWNLOAD_FULL_MODEM_BUF_SZ=4096
    # CONFIG_FOTA_DOWNLOAD_NATIVE_TLS is not set
    CONFIG_FOTA_DOWNLOAD_FILE_NAME_LENGTH=128
    CONFIG_FOTA_DOWNLOAD_HOST_NAME_LENGTH=128
    CONFIG_FOTA_DOWNLOAD_RESOURCE_LOCATOR_LENGTH=512
    CONFIG_FOTA_DOWNLOAD_SEC_TAG_LIST_SIZE_MAX=5
    # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_OFF is not set
    # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_ERR is not set
    # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_WRN is not set
    # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_INF is not set
    # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DBG is not set
    CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DEFAULT=y
    CONFIG_FOTA_DOWNLOAD_LOG_LEVEL=3
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AWS_FOTA is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    CONFIG_TLS_MAX_CREDENTIALS_NUMBER=6
    # CONFIG_MQTT_HELPER is not set
    CONFIG_NRF_MCUMGR_SMP_CLIENT=y
    # CONFIG_NRF_MCUMGR_SMP_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_MCUMGR_SMP_CLIENT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_MCUMGR_SMP_CLIENT_LOG_LEVEL=3
    # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_PROV_CORE_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_PROV_CORE_LOG_LEVEL=3
    # end of Application protocols
    # CONFIG_OPENTHREAD_RPC is not set
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # CONFIG_NFC_RPC is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    CONFIG_FW_INFO=y
    # CONFIG_FW_INFO_API is not set
    CONFIG_FW_INFO_OFFSET=0x200
    CONFIG_FW_INFO_FIRMWARE_VERSION=1
    CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de
    CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c
    CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea
    CONFIG_FW_INFO_HARDWARE_ID=91
    CONFIG_FW_INFO_VERSION=2
    CONFIG_FW_INFO_CRYPTO_ID=0
    CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0
    CONFIG_FW_INFO_MAGIC_LEN=12
    CONFIG_FW_INFO_VALID_VAL=0x9102FFFF
    CONFIG_EXT_API_SUPPORTED=y
    CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y
    # CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set
    # Debug
    # CONFIG_NRF_CPU_LOAD is not set
    # CONFIG_ETB_TRACE is not set
    # CONFIG_PPI_TRACE is not set
    CONFIG_PPI_TRACE_PIN_CNT=8
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_HFCLK_LATENCY=1400
    CONFIG_MPSL_INIT_PRIORITY=40
    CONFIG_MPSL_FORCE_RRAM_ON_ALL_THE_TIME=y
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_SIZE=168
    CONFIG_SRAM_BASE_ADDRESS=0x20016000
    # Zephyr subsystem configurations
    CONFIG_PM_PARTITION_SIZE_LITTLEFS=0x6000
    # CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL is not set
    CONFIG_PM_PARTITION_SIZE_FMFU_STORAGE=0x400000
    CONFIG_PM_PARTITION_REGION_FMFU_STORAGE_EXTERNAL=y
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_ENABLED=y
    CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/peripheral@40000000/spi@b000/w25q01jv@0"
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=1073741824
    # CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY is not set
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x3f7d8
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU is not set
    # end of Full Modem Firmware Update Management(FMFU)
    # Additional MCUmgr configuration
    # Additional MCUmgr group configuration
    # Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr OS group management functionality
    # Additional MCUmgr image management group functionality
    # end of Additional MCUmgr image management group functionality
    # end of Additional MCUmgr group configuration
    # end of Additional MCUmgr configuration
    # CONFIG_CAF is not set
    # CONFIG_DM_MODULE is not set
    # nRF Security
    CONFIG_NORDIC_SECURITY_BACKEND=y
    CONFIG_NRF_SECURITY=y
    # Nordic-added meta types
    CONFIG_PSA_HAS_AEAD_SUPPORT=y
    CONFIG_PSA_HAS_ASYM_ENCRYPT_SUPPORT=y
    CONFIG_PSA_HAS_ASYM_SIGN_SUPPORT=y
    CONFIG_PSA_HAS_CIPHER_SUPPORT=y
    CONFIG_PSA_HAS_HASH_SUPPORT=y
    CONFIG_PSA_HAS_KEY_AGREEMENT=y
    CONFIG_PSA_HAS_KEY_DERIVATION=y
    CONFIG_PSA_HAS_KEY_SUPPORT=y
    CONFIG_PSA_HAS_MAC_SUPPORT=y
    # Nordic added alg types
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # CONFIG_PSA_WANT_ALG_HSS is not set
    # CONFIG_PSA_WANT_ALG_LMS is not set
    # CONFIG_PSA_WANT_ALG_ML_DSA is not set
    # CONFIG_PSA_WANT_ALG_XMSS is not set
    # CONFIG_PSA_WANT_ALG_XMSS_MT is not set
    # CONFIG_PSA_WANT_ALG_ML_KEM is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW=y
    CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT=y
    # CONFIG_PSA_WANT_ALG_SHA_256_192 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
    CONFIG_PSA_WANT_ALG_CHACHA20=y
    # CONFIG_PSA_WANT_ALG_XCHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE128_256 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_192 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_256 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_AES_KW is not set
    # CONFIG_PSA_WANT_ALG_AES_KWP is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE_H2E is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE is not set
    # Nordic added ECC curve types
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # Nordic addded RNG configuration
    CONFIG_PSA_WANT_GENERATE_RANDOM=y
    # Nordic added key types
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XCHACHA20 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HSS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_LMS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XMSS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XMSS_MT_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_44 is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_65 is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_87 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_512 is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_768 is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_PUBLIC_KEY is not set
    CONFIG_MBEDTLS_CFG_FILE="nrf-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-user-config.h"
    CONFIG_MBEDTLS_X509_USE_C=y
    CONFIG_MBEDTLS_X509_CREATE_C=y
    CONFIG_MBEDTLS_X509_CHECK_KEY_USAGE=y
    CONFIG_MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE=y
    CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
    CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
    CONFIG_MBEDTLS_X509_CRT_PARSE_C=y
    CONFIG_MBEDTLS_X509_CSR_WRITE_C=y
    # CONFIG_MBEDTLS_X509_CRT_WRITE_C is not set
    CONFIG_MBEDTLS_X509_REMOVE_INFO=y
    # CONFIG_MBEDTLS_PKCS7_C is not set
    CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
    CONFIG_MBEDTLS_SSL_ENCRYPT_THEN_MAC=y
    CONFIG_MBEDTLS_SSL_EXTENDED_MASTER_SECRET=y
    # CONFIG_MBEDTLS_DEBUG_C is not set
    # CONFIG_MBEDTLS_MEMORY_DEBUG is not set
    CONFIG_MBEDTLS_SSL_ALL_ALERT_MESSAGES=y
    CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION=y
    # CONFIG_MBEDTLS_SSL_DEBUG_ALL is not set
    CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE=y
    # CONFIG_MBEDTLS_SSL_RENEGOTIATION is not set
    # CONFIG_MBEDTLS_SSL_SESSION_TICKETS is not set
    # CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION is not set
    # CONFIG_MBEDTLS_SSL_CACHE_C is not set
    # CONFIG_MBEDTLS_SSL_TICKET_C is not set
    CONFIG_MBEDTLS_SSL_EXPORT_KEYS=y
    CONFIG_MBEDTLS_SSL_CIPHERSUITES=""
    # CONFIG_MBEDTLS_SSL_PROTO_TLS1_3 is not set
    # TLS/DTL Cipher Suites
    CONFIG_MBEDTLS_HAS_CBC_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_GCM_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_CCM_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_CHACHAPOLY_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_CIPHER_MODE_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_ECDH_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_ECDSA_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_RSA_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_ECJPAKE_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED=y
    # end of TLS/DTL Cipher Suites
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_PSA_CORE_OBERON=y
    # PSA Driver Support
    CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y
    CONFIG_PSA_CRYPTO_DRIVER_OBERON=y
    CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
    # Choose DRBG algorithm
    CONFIG_PSA_WANT_ALG_CTR_DRBG=y
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    CONFIG_PSA_USE_CTR_DRBG_DRIVER=y
    # end of Choose DRBG algorithm
    # CryptoCell PSA Driver Configuration
    CONFIG_PSA_USE_CC3XX_CIPHER_DRIVER=y
    CONFIG_PSA_USE_CC3XX_AEAD_DRIVER=y
    CONFIG_PSA_USE_CC3XX_HASH_DRIVER=y
    CONFIG_PSA_USE_CC3XX_MAC_DRIVER=y
    CONFIG_PSA_USE_CC3XX_KEY_AGREEMENT_DRIVER=y
    CONFIG_PSA_USE_CC3XX_ASYMMETRIC_SIGNATURE_DRIVER=y
    CONFIG_PSA_USE_CC3XX_ASYMMETRIC_ENCRYPTION_DRIVER=y
    CONFIG_PSA_USE_CC3XX_KEY_MANAGEMENT_DRIVER=y
    CONFIG_PSA_USE_CC3XX_CTR_DRBG_DRIVER=y
    # end of CryptoCell PSA Driver Configuration
    # CRACEN PSA Driver Configuration
    # end of CRACEN PSA Driver Configuration
    # AES key size configuration
    CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_192=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_256=y
    # end of AES key size configuration
    # RSA key size configuration
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set
    CONFIG_PSA_WANT_RSA_KEY_SIZE_2048=y
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set
    CONFIG_PSA_MAX_RSA_KEY_BITS=2048
    # end of RSA key size configuration
    CONFIG_PSA_ACCEL_CBC_NO_PADDING_AES_128=y
    CONFIG_PSA_ACCEL_CBC_PKCS7_AES_128=y
    CONFIG_PSA_ACCEL_CCM_AES_128=y
    CONFIG_PSA_ACCEL_CHACHA20_POLY1305=y
    CONFIG_PSA_ACCEL_CMAC_AES_128=y
    CONFIG_PSA_ACCEL_CTR_AES_128=y
    CONFIG_PSA_ACCEL_ECB_NO_PADDING_AES_128=y
    CONFIG_PSA_ACCEL_ECDH_SECP_R1_256=y
    CONFIG_PSA_ACCEL_ECDSA_SECP_R1_256_SHA_1=y
    CONFIG_PSA_ACCEL_ECDSA_SECP_R1_256_SHA_224=y
    CONFIG_PSA_ACCEL_ECDSA_SECP_R1_256_SHA_256=y
    CONFIG_PSA_ACCEL_ECDSA_SECP_R1_256_SHA_384=y
    CONFIG_PSA_ACCEL_ECDSA_SECP_R1_256_SHA_512=y
    CONFIG_PSA_ACCEL_GENERATE_RANDOM=y
    CONFIG_PSA_ACCEL_HMAC_SHA_1=y
    CONFIG_PSA_ACCEL_HMAC_SHA_224=y
    CONFIG_PSA_ACCEL_HMAC_SHA_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_DERIVE_BRAINPOOL_P_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_DERIVE_MONTGOMERY_255=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP_K1_224=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP_K1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP_R1_224=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP_R1_384=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_DERIVE_TWISTED_EDWARDS_255=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_EXPORT_BRAINPOOL_P_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_EXPORT_MONTGOMERY_255=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP_K1_224=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP_K1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP_R1_224=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP_R1_384=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_EXPORT_TWISTED_EDWARDS_255=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_GENERATE_BRAINPOOL_P_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_GENERATE_MONTGOMERY_255=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP_K1_224=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP_K1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP_R1_224=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP_R1_384=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_GENERATE_TWISTED_EDWARDS_255=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_IMPORT_BRAINPOOL_P_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_IMPORT_MONTGOMERY_255=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP_K1_224=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP_K1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP_R1_224=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP_R1_384=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_IMPORT_TWISTED_EDWARDS_255=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_PUBLIC_KEY_BRAINPOOL_P_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_PUBLIC_KEY_MONTGOMERY_255=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_PUBLIC_KEY_SECP_K1_224=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_PUBLIC_KEY_SECP_K1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_PUBLIC_KEY_SECP_R1_224=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_PUBLIC_KEY_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_PUBLIC_KEY_SECP_R1_384=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_PUBLIC_KEY_TWISTED_EDWARDS_255=y
    CONFIG_PSA_ACCEL_KEY_TYPE_RSA_1024_KEY_PAIR_EXPORT=y
    CONFIG_PSA_ACCEL_KEY_TYPE_RSA_1024_KEY_PAIR_IMPORT=y
    CONFIG_PSA_ACCEL_KEY_TYPE_RSA_1024_PUBLIC_KEY=y
    CONFIG_PSA_ACCEL_KEY_TYPE_RSA_1536_KEY_PAIR_EXPORT=y
    CONFIG_PSA_ACCEL_KEY_TYPE_RSA_1536_KEY_PAIR_IMPORT=y
    CONFIG_PSA_ACCEL_KEY_TYPE_RSA_1536_PUBLIC_KEY=y
    CONFIG_PSA_ACCEL_KEY_TYPE_RSA_2048_KEY_PAIR_EXPORT=y
    CONFIG_PSA_ACCEL_KEY_TYPE_RSA_2048_KEY_PAIR_IMPORT=y
    CONFIG_PSA_ACCEL_KEY_TYPE_RSA_2048_PUBLIC_KEY=y
    CONFIG_PSA_ACCEL_RSA_OAEP_1024_SHA_224=y
    CONFIG_PSA_ACCEL_RSA_OAEP_1024_SHA_256=y
    CONFIG_PSA_ACCEL_RSA_OAEP_1536_SHA_224=y
    CONFIG_PSA_ACCEL_RSA_OAEP_1536_SHA_256=y
    CONFIG_PSA_ACCEL_RSA_OAEP_2048_SHA_224=y
    CONFIG_PSA_ACCEL_RSA_OAEP_2048_SHA_256=y
    CONFIG_PSA_ACCEL_RSA_PKCS1V15_CRYPT_1024=y
    CONFIG_PSA_ACCEL_RSA_PKCS1V15_CRYPT_1536=y
    CONFIG_PSA_ACCEL_RSA_PKCS1V15_CRYPT_2048=y
    CONFIG_PSA_ACCEL_RSA_PKCS1V15_SIGN_1024_SHA_224=y
    CONFIG_PSA_ACCEL_RSA_PKCS1V15_SIGN_1024_SHA_256=y
    CONFIG_PSA_ACCEL_RSA_PKCS1V15_SIGN_1536_SHA_224=y
    CONFIG_PSA_ACCEL_RSA_PKCS1V15_SIGN_1536_SHA_256=y
    CONFIG_PSA_ACCEL_RSA_PKCS1V15_SIGN_2048_SHA_224=y
    CONFIG_PSA_ACCEL_RSA_PKCS1V15_SIGN_2048_SHA_256=y
    CONFIG_PSA_ACCEL_RSA_PSS_1024_SHA_224=y
    CONFIG_PSA_ACCEL_RSA_PSS_1024_SHA_256=y
    CONFIG_PSA_ACCEL_RSA_PSS_1536_SHA_224=y
    CONFIG_PSA_ACCEL_RSA_PSS_1536_SHA_256=y
    CONFIG_PSA_ACCEL_RSA_PSS_2048_SHA_224=y
    CONFIG_PSA_ACCEL_RSA_PSS_2048_SHA_256=y
    CONFIG_PSA_ACCEL_SHA_1=y
    CONFIG_PSA_ACCEL_SHA_224=y
    CONFIG_PSA_ACCEL_SHA_256=y
    CONFIG_PSA_ACCEL_STREAM_CIPHER_CHACHA20=y
    CONFIG_PSA_NEED_CC3XX_CCM_AES=y
    CONFIG_PSA_NEED_CC3XX_STREAM_CIPHER_CHACHA20_POLY1305=y
    CONFIG_PSA_NEED_CC3XX_AEAD_DRIVER=y
    CONFIG_PSA_NEED_CC3XX_CTR_AES=y
    CONFIG_PSA_NEED_CC3XX_CBC_PKCS7_AES=y
    CONFIG_PSA_NEED_CC3XX_CBC_NO_PADDING_AES=y
    CONFIG_PSA_NEED_CC3XX_ECB_NO_PADDING_AES=y
    CONFIG_PSA_NEED_CC3XX_STREAM_CIPHER_CHACHA20=y
    CONFIG_PSA_NEED_CC3XX_CIPHER_DRIVER=y
    CONFIG_PSA_NEED_CC3XX_ECDH_SECP_R1_256=y
    CONFIG_PSA_NEED_CC3XX_KEY_AGREEMENT_DRIVER=y
    CONFIG_PSA_NEED_CC3XX_ECDSA_SECP_R1_256=y
    CONFIG_PSA_NEED_CC3XX_RSA_PKCS1V15_SIGN=y
    CONFIG_PSA_NEED_CC3XX_RSA_PSS=y
    CONFIG_PSA_NEED_CC3XX_ASYMMETRIC_SIGNATURE_DRIVER=y
    CONFIG_PSA_NEED_CC3XX_RSA_OAEP=y
    CONFIG_PSA_NEED_CC3XX_RSA_PKCS1V15_CRYPT=y
    CONFIG_PSA_NEED_CC3XX_ASYMMETRIC_ENCRYPTION_DRIVER=y
    CONFIG_PSA_NEED_CC3XX_SHA_1=y
    CONFIG_PSA_NEED_CC3XX_SHA_224=y
    CONFIG_PSA_NEED_CC3XX_SHA_256=y
    CONFIG_PSA_NEED_CC3XX_HASH_DRIVER=y
    CONFIG_PSA_NEED_CC3XX_KEY_TYPE_RSA_ANY=y
    CONFIG_PSA_NEED_CC3XX_KEY_TYPE_ECC_ANY=y
    CONFIG_PSA_NEED_CC3XX_KEY_MANAGEMENT_DRIVER=y
    CONFIG_PSA_NEED_CC3XX_HMAC=y
    CONFIG_PSA_NEED_CC3XX_CMAC=y
    CONFIG_PSA_NEED_CC3XX_MAC_DRIVER=y
    CONFIG_PSA_NEED_CC3XX_CTR_DRBG_DRIVER=y
    # CONFIG_CRACEN_LOG_LEVEL_OFF is not set
    # CONFIG_CRACEN_LOG_LEVEL_ERR is not set
    # CONFIG_CRACEN_LOG_LEVEL_WRN is not set
    # CONFIG_CRACEN_LOG_LEVEL_INF is not set
    # CONFIG_CRACEN_LOG_LEVEL_DBG is not set
    CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y
    CONFIG_CRACEN_LOG_LEVEL=3
    CONFIG_PSA_NEED_OBERON_CCM_AES=y
    CONFIG_PSA_NEED_OBERON_GCM_AES=y
    CONFIG_PSA_NEED_OBERON_AEAD_DRIVER=y
    CONFIG_PSA_NEED_OBERON_CTR_AES=y
    CONFIG_PSA_NEED_OBERON_CBC_NO_PADDING_AES=y
    CONFIG_PSA_NEED_OBERON_CBC_PKCS7_AES=y
    CONFIG_PSA_NEED_OBERON_ECB_NO_PADDING_AES=y
    CONFIG_PSA_NEED_OBERON_CIPHER_DRIVER=y
    CONFIG_PSA_NEED_OBERON_SHA_384=y
    CONFIG_PSA_NEED_OBERON_SHA_512=y
    CONFIG_PSA_NEED_OBERON_HASH_DRIVER=y
    CONFIG_PSA_NEED_OBERON_HMAC=y
    CONFIG_PSA_NEED_OBERON_CMAC=y
    CONFIG_PSA_NEED_OBERON_MAC_DRIVER=y
    CONFIG_PSA_NEED_OBERON_HKDF=y
    CONFIG_PSA_NEED_OBERON_TLS12_PRF=y
    CONFIG_PSA_NEED_OBERON_TLS12_PSK_TO_MS=y
    CONFIG_PSA_NEED_OBERON_PBKDF2_AES_CMAC_PRF_128=y
    CONFIG_PSA_NEED_OBERON_TLS12_ECJPAKE_TO_PMS=y
    CONFIG_PSA_NEED_OBERON_KEY_DERIVATION_DRIVER=y
    CONFIG_PSA_NEED_OBERON_RSA_KEY_SIZE_2048=y
    CONFIG_PSA_NEED_OBERON_ANY_RSA_KEY_SIZE=y
    CONFIG_PSA_NEED_OBERON_RSA_PSS=y
    CONFIG_PSA_NEED_OBERON_RSA_PKCS1V15_SIGN=y
    CONFIG_PSA_NEED_OBERON_RSA_ANY_VERIFY=y
    CONFIG_PSA_NEED_OBERON_RSA_ANY_SIGN=y
    CONFIG_PSA_NEED_OBERON_RSA_PKCS1V15_CRYPT=y
    CONFIG_PSA_NEED_OBERON_RSA_OAEP=y
    CONFIG_PSA_NEED_OBERON_RSA_ANY_CRYPT=y
    CONFIG_PSA_NEED_OBERON_ASYMMETRIC_ENCRYPTION_DRIVER=y
    CONFIG_PSA_NEED_OBERON_ASYMMETRIC_SIGNATURE_DRIVER=y
    # PSA API support
    # CONFIG_MBEDTLS_USE_PSA_CRYPTO is not set
    # CONFIG_MBEDTLS_PSA_STATIC_KEY_SLOTS is not set
    CONFIG_PSA_CRYPTO_SYS_INIT=y
    # end of PSA API support
    CONFIG_MBEDTLS_PLATFORM_MEMORY=y
    CONFIG_MBEDTLS_PLATFORM_C=y
    CONFIG_MBEDTLS_MEMORY_C=y
    CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y
    CONFIG_MBEDTLS_THREADING_C=y
    CONFIG_MBEDTLS_BASE64_C=y
    CONFIG_MBEDTLS_OID_C=y
    CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y
    CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT=y
    CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT=y
    CONFIG_MBEDTLS_AES_ENCRYPT_ALT=y
    CONFIG_MBEDTLS_AES_DECRYPT_ALT=y
    CONFIG_MBEDTLS_AES_ALT=y
    CONFIG_MBEDTLS_CMAC_ALT=y
    CONFIG_MBEDTLS_CCM_ALT=y
    CONFIG_MBEDTLS_CHACHA20_ALT=y
    CONFIG_MBEDTLS_POLY1305_ALT=y
    CONFIG_MBEDTLS_CHACHAPOLY_ALT=y
    CONFIG_MBEDTLS_DHM_ALT=y
    CONFIG_MBEDTLS_ECP_ALT=y
    CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT=y
    CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT=y
    CONFIG_MBEDTLS_ECDSA_GENKEY_ALT=y
    CONFIG_MBEDTLS_ECDSA_SIGN_ALT=y
    CONFIG_MBEDTLS_ECDSA_VERIFY_ALT=y
    CONFIG_MBEDTLS_ECJPAKE_ALT=y
    CONFIG_MBEDTLS_RSA_ALT=y
    CONFIG_MBEDTLS_SHA1_ALT=y
    CONFIG_MBEDTLS_SHA224_ALT=y
    CONFIG_MBEDTLS_SHA256_ALT=y
    CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y
    CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1
    CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y
    CONFIG_NRF_SECURITY_ADVANCED=y
    CONFIG_OBERON_ONLY_ENABLED=y
    # Legacy mbed TLS crypto APIs
    CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6
    # CONFIG_CC3XX_BACKEND is not set
    CONFIG_OBERON_BACKEND=y
    CONFIG_MBEDTLS_CTR_DRBG_USE_128_BIT_KEY=y
    CONFIG_MBEDTLS_HMAC_DRBG_C=y
    CONFIG_MBEDTLS_AES_C=y
    # Cipher Selection
    # CBC cipher padding modes
    CONFIG_MBEDTLS_CIPHER_PADDING_PKCS7=y
    CONFIG_MBEDTLS_CIPHER_PADDING_ONE_AND_ZEROS=y
    CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS_AND_LEN=y
    CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS=y
    # end of CBC cipher padding modes
    # CONFIG_MBEDTLS_AES_ONLY_128_BIT_KEY_LENGTH is not set
    # AEAD  - Authenticated Encryption with Associated Data
    # end of AEAD  - Authenticated Encryption with Associated Data
    CONFIG_MBEDTLS_ECDH_C=y
    CONFIG_MBEDTLS_ECDSA_C=y
    CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=y
    CONFIG_MBEDTLS_ECJPAKE_C=y
    # ECC curves
    # CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED is not set
    CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
    # end of ECC curves
    CONFIG_MBEDTLS_HKDF_C=y
    # RSA Encoding Selection
    CONFIG_MBEDTLS_GENPRIME=y
    CONFIG_MBEDTLS_PKCS1_V15=y
    CONFIG_MBEDTLS_PKCS1_V21=y
    # SHA - Secure Hash Algorithm
    CONFIG_MBEDTLS_SHA224_C=y
    CONFIG_MBEDTLS_SHA256_C=y
    CONFIG_MBEDTLS_SHA384_C=y
    # end of SHA - Secure Hash Algorithm
    # CONFIG_MBEDTLS_FORCE_LEGACY_MD is not set
    # CONFIG_MBEDTLS_FORCE_LEGACY_CIPHER is not set
    CONFIG_MBEDTLS_CIPHER_C=y
    CONFIG_MBEDTLS_PK_C=y
    CONFIG_MBEDTLS_PKCS5_C=y
    CONFIG_MBEDTLS_PK_WRITE_C=y
    CONFIG_MBEDTLS_PK_PARSE_C=y
    CONFIG_MBEDTLS_PK_PARSE_EC_EXTENDED=y
    # CONFIG_MBEDTLS_PEM_PARSE_C is not set
    # CONFIG_MBEDTLS_PEM_WRITE_C is not set
    # end of Legacy mbed TLS crypto APIs
    # Zephyr legacy configurations
    # CONFIG_MBEDTLS_DTLS is not set
    # CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_MD5_ENABLED is not set
    # CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set
    CONFIG_MBEDTLS_CIPHER=y
    CONFIG_MBEDTLS_MD=y
    # CONFIG_MBEDTLS_ENTROPY_ENABLED is not set
    # CONFIG_MBEDTLS_GENPRIME_ENABLED is not set
    # end of Zephyr legacy configurations
    CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
    # end of nRF Security
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEST is not set
    # Log levels
    # end of Log levels
    # end of Audio Modules
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEMPLATE is not set
    # CONFIG_UART_ASYNC_ADAPTER is not set
    # Logging over RPC
    # CONFIG_LOG_FORWARDER_RPC is not set
    # CONFIG_LOG_BACKEND_RPC is not set
    CONFIG_LOG_BACKED_RPC_CRASH_INFO_FILENAME_SIZE=1
    # end of Logging over RPC
    # CONFIG_DULT is not set
    # CONFIG_NRF_COMPRESS is not set
    # MCUboot IDs (informative only, do not change)
    CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0
    CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_EXTRA_1_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_EXTRA_2_IMAGE_NUMBER=-1
    # end of MCUboot IDs (informative only, do not change)
    # end of Subsystems
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # CONFIG_APP_JWT is not set
    # Binary libraries
    # end of Binary libraries
    CONFIG_NRF_MODEM_LIB=y
    # Memory configuration
    CONFIG_NRF_MODEM_LIB_HEAP_SIZE=1024
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_NRF9X_SOCKETS_GETADDRINFO=192
    CONFIG_NRF_MODEM_LIB_SHMEM_CTRL_SIZE=0x4e8
    CONFIG_NRF_MODEM_LIB_SHMEM_TX_SIZE=8320
    CONFIG_NRF_MODEM_LIB_SHMEM_RX_SIZE=8192
    CONFIG_NRF_MODEM_LIB_SHMEM_TRACE_SIZE=0
    CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE=128
    # CONFIG_NRF_MODEM_LIB_MEM_DIAG is not set
    # end of Memory configuration
    # CONFIG_NRF_MODEM_LIB_TRACE is not set
    # CONFIG_NRF_MODEM_LIB_ON_FAULT_DO_NOTHING is not set
    # CONFIG_NRF_MODEM_LIB_ON_FAULT_RESET_MODEM is not set
    CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC=y
    CONFIG_NRF_MODEM_LIB_CFUN_HOOKS=y
    # CONFIG_NRF_MODEM_LIB_FAULT_STRERROR is not set
    # Shell
    # CONFIG_NRF_MODEM_LIB_SHELL_TRACE is not set
    # end of Shell
    CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO=1
    # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_INF is not set
    # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DBG is not set
    CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_MODEM_LIB_LOG_LEVEL=3
    # CONFIG_NRF_MODEM_LIB_LOG_FW_VERSION_UUID is not set
    CONFIG_AT_MONITOR=y
    CONFIG_AT_MONITOR_HEAP_SIZE=1024
    # CONFIG_AT_MONITOR_LOG_LEVEL_OFF is not set
    # CONFIG_AT_MONITOR_LOG_LEVEL_ERR is not set
    # CONFIG_AT_MONITOR_LOG_LEVEL_WRN is not set
    # CONFIG_AT_MONITOR_LOG_LEVEL_INF is not set
    # CONFIG_AT_MONITOR_LOG_LEVEL_DBG is not set
    CONFIG_AT_MONITOR_LOG_LEVEL_DEFAULT=y
    CONFIG_AT_MONITOR_LOG_LEVEL=3
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_LTE_LINK_CONTROL=32
    CONFIG_LTE_LC_FUNCTIONAL_MODE_MODULE=y
    CONFIG_LTE_LC_NETWORK_REGISTRATION_MODULE=y
    CONFIG_LTE_LC_CONNECTION_STATUS_MODULE=y
    CONFIG_LTE_LC_MODEM_EVENTS_MODULE=y
    CONFIG_LTE_LC_SYSTEM_MODE_MODULE=y
    # CONFIG_LTE_LC_CONN_EVAL_MODULE is not set
    CONFIG_LTE_LC_EDRX_MODULE=y
    # CONFIG_LTE_LC_NEIGHBOR_CELL_MEAS_MODULE is not set
    # CONFIG_LTE_LC_PERIODIC_SEARCH_MODULE is not set
    CONFIG_LTE_LC_PSM_MODULE=y
    # CONFIG_LTE_LC_RAI_MODULE is not set
    # CONFIG_LTE_LC_MODEM_SLEEP_MODULE is not set
    # CONFIG_LTE_LC_TAU_PRE_WARNING_MODULE is not set
    # CONFIG_LTE_LC_ENV_EVAL_MODULE is not set
    # CONFIG_LTE_LC_PDN_MODULE is not set
    CONFIG_LTE_LC_CELLULAR_PROFILE_MODULE=y
    CONFIG_LTE_LC_DNS_FALLBACK_MODULE=y
    CONFIG_LTE_LC_DNS_FALLBACK_ADDRESS="1.1.1.1"
    # CONFIG_LTE_LOCK_BANDS is not set
    CONFIG_LTE_PLMN_SELECTION_OPTIMIZATION=y
    # CONFIG_LTE_LOCK_PLMN is not set
    # CONFIG_LTE_UNLOCK_PLMN is not set
    CONFIG_LTE_PSM_REQ=y
    CONFIG_LTE_PSM_REQ_FORMAT_STRING=y
    # CONFIG_LTE_PSM_REQ_FORMAT_SECONDS is not set
    CONFIG_LTE_PSM_REQ_RPTAU="00100001"
    CONFIG_LTE_PSM_REQ_RAT="00001000"
    CONFIG_LTE_PSM_REQ_RPTAU_SECONDS=1800
    CONFIG_LTE_PSM_REQ_RAT_SECONDS=60
    CONFIG_LTE_PROPRIETARY_PSM_REQ=y
    CONFIG_LTE_EDRX_REQ=y
    CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="1001"
    CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="1001"
    CONFIG_LTE_EDRX_REQ_VALUE_NTN_NBIOT="1001"
    CONFIG_LTE_PTW_VALUE_LTE_M=""
    CONFIG_LTE_PTW_VALUE_NBIOT=""
    CONFIG_LTE_PTW_VALUE_NTN_NBIOT=""
    # CONFIG_LTE_NETWORK_MODE_DEFAULT is not set
    # CONFIG_LTE_NETWORK_MODE_LTE_M is not set
    CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
    # CONFIG_LTE_NETWORK_MODE_NBIOT is not set
    # CONFIG_LTE_NETWORK_MODE_NBIOT_GPS is not set
    # CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT is not set
    # CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS is not set
    # CONFIG_LTE_NETWORK_MODE_NTN_NBIOT is not set
    CONFIG_LTE_MODE_PREFERENCE_AUTO=y
    CONFIG_LTE_MODE_PREFERENCE_VALUE=0
    CONFIG_LTE_NETWORK_TIMEOUT=300
    CONFIG_LTE_LC_ENV_EVAL_MAX_PLMN_COUNT=3
    # CONFIG_LTE_LC_TRACE is not set
    CONFIG_LTE_LC_WORKQUEUE_STACK_SIZE=1024
    # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_LTE_LINK_CONTROL_LOG_LEVEL=3
    # CONFIG_NTN is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000
    CONFIG_FPROTECT_BLOCK_SIZE=0x8000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_AT_HOST_LIBRARY is not set
    # CONFIG_DK_LIBRARY is not set
    CONFIG_AT_PARSER=y
    # CONFIG_MODEM_BATTERY is not set
    CONFIG_MODEM_INFO=y
    CONFIG_MODEM_INFO_MAX_AT_PARAMS_RSP=10
    CONFIG_MODEM_INFO_BUFFER_SIZE=128
    CONFIG_MODEM_INFO_ADD_NETWORK=y
    CONFIG_MODEM_INFO_ADD_DATE_TIME=y
    CONFIG_MODEM_INFO_ADD_SIM=y
    CONFIG_MODEM_INFO_ADD_SIM_ICCID=y
    CONFIG_MODEM_INFO_ADD_SIM_IMSI=y
    CONFIG_MODEM_INFO_ADD_DEVICE=y
    # CONFIG_PDN is not set
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_GCF_SMS is not set
    # CONFIG_MODEM_KEY_MGMT is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    CONFIG_DATE_TIME=y
    CONFIG_DATE_TIME_AUTO_UPDATE=y
    CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=14400
    CONFIG_DATE_TIME_TOO_OLD_SECONDS=750
    CONFIG_DATE_TIME_RETRY_COUNT=0
    CONFIG_DATE_TIME_RETRY_INTERVAL_SECONDS=60
    CONFIG_DATE_TIME_MODEM=y
    CONFIG_DATE_TIME_NTP=y
    CONFIG_DATE_TIME_THREAD_STACK_SIZE=1280
    CONFIG_DATE_TIME_NTP_QUERY_TIME_SECONDS=5
    CONFIG_DATE_TIME_LOG_LEVEL_OFF=y
    # CONFIG_DATE_TIME_LOG_LEVEL_ERR is not set
    # CONFIG_DATE_TIME_LOG_LEVEL_WRN is not set
    # CONFIG_DATE_TIME_LOG_LEVEL_INF is not set
    # CONFIG_DATE_TIME_LOG_LEVEL_DBG is not set
    # CONFIG_DATE_TIME_LOG_LEVEL_DEFAULT is not set
    CONFIG_DATE_TIME_LOG_LEVEL=0
    CONFIG_HW_ID_LIBRARY=y
    CONFIG_HW_ID_LIBRARY_SOURCE_IMEI=y
    # CONFIG_HW_ID_LIBRARY_SOURCE_BLE_MAC is not set
    # CONFIG_HW_ID_LIBRARY_SOURCE_NET_MAC is not set
    # CONFIG_HW_ID_LIBRARY_SOURCE_DEVICE_ID is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY=y
    CONFIG_HW_UNIQUE_KEY_RANDOM=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_JWT is not set
    # CONFIG_MODEM_ATTEST_TOKEN is not set
    # CONFIG_LOCATION is not set
    # CONFIG_MODEM_ANTENNA is not set
    # CONFIG_QOS is not set
    # CONFIG_IDENTITY_KEY_TFM is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    CONFIG_NCS_BOOT_BANNER=y
    CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="My Application"
    CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
    CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
    # CONFIG_UICC_LWM2M is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    # CONFIG_FLASH_RPC is not set
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_RPC is not set
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    CONFIG_NRF_SW_LPUART=y
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=4
    CONFIG_NRF_SW_LPUART_INIT_PRIORITY=45
    CONFIG_NRF_SW_LPUART_HFXO_ON_RX=y
    CONFIG_NRF_SW_LPUART_MAX_PACKET_SIZE=270
    CONFIG_NRF_SW_LPUART_DEFAULT_TX_TIMEOUT=1000000
    CONFIG_NRF_SW_LPUART_INT_DRIVEN=y
    CONFIG_NRF_SW_LPUART_INT_DRV_TX_BUF_SIZE=270
    CONFIG_NRF_SW_LPUART_LOG_LEVEL_OFF=y
    # CONFIG_NRF_SW_LPUART_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_SW_LPUART_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_SW_LPUART_LOG_LEVEL_INF is not set
    # CONFIG_NRF_SW_LPUART_LOG_LEVEL_DBG is not set
    # CONFIG_NRF_SW_LPUART_LOG_LEVEL_DEFAULT is not set
    CONFIG_NRF_SW_LPUART_LOG_LEVEL=0
    # end of Device Drivers
    # External libraries
    # CONFIG_GETOPT_LIB is not set
    # CONFIG_NRF_CURL is not set
    # end of External libraries
    # Test
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # CONFIG_MOCK_NRF_RPC is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/Users/filiprosik/Project/LPG_91/nrf)
    # mcuboot (/Users/filiprosik/Project/LPG_91/bootloader/mcuboot)
    # MCUboot
    # CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is not set
    CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (/Users/filiprosik/Project/LPG_91/bootloader/mcuboot)
    # mbedtls (/Users/filiprosik/Project/LPG_91/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_PSA_CRYPTO_CLIENT=y
    # CONFIG_PSA_CRYPTO_ENABLE_ALL is not set
    CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=y
    CONFIG_PSA_WANT_ALG_CBC_PKCS7=y
    CONFIG_PSA_WANT_ALG_CCM=y
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    CONFIG_PSA_WANT_ALG_CMAC=y
    CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305=y
    CONFIG_PSA_WANT_ALG_CTR=y
    CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA=y
    CONFIG_PSA_WANT_ALG_ECDH=y
    CONFIG_PSA_WANT_ALG_ECDSA=y
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    CONFIG_PSA_WANT_ALG_GCM=y
    CONFIG_PSA_WANT_ALG_HKDF=y
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    CONFIG_PSA_WANT_ALG_HMAC=y
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_PBKDF2_HMAC is not set
    # CONFIG_PSA_WANT_ALG_PBKDF2_AES_CMAC_PRF_128 is not set
    CONFIG_PSA_WANT_ALG_RSA_OAEP=y
    CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT=y
    CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN=y
    CONFIG_PSA_WANT_ALG_RSA_PSS=y
    CONFIG_PSA_WANT_ALG_SHA_1=y
    CONFIG_PSA_WANT_ALG_SHA_224=y
    CONFIG_PSA_WANT_ALG_SHA_256=y
    CONFIG_PSA_WANT_ALG_SHA_384=y
    CONFIG_PSA_WANT_ALG_SHA_512=y
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    CONFIG_PSA_WANT_ALG_STREAM_CIPHER=y
    CONFIG_PSA_WANT_ALG_TLS12_PRF=y
    CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS=y
    CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS=y
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    CONFIG_PSA_WANT_ECC_SECP_R1_256=y
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    CONFIG_PSA_WANT_KEY_TYPE_AES=y
    CONFIG_PSA_WANT_KEY_TYPE_CHACHA20=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY=y
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE=y
    CONFIG_PSA_CRYPTO=y
    CONFIG_PSA_CRYPTO_PROVIDER_TFM=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_BASIC=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_BASIC=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    CONFIG_DISABLE_MBEDTLS_BUILTIN=y
    # CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_INF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set
    CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y
    CONFIG_MBEDTLS_LOG_LEVEL=3
    # CONFIG_MBEDTLS_DEBUG is not set
    # CONFIG_MBEDTLS_HEAP_CUSTOM_SECTION is not set
    CONFIG_MBEDTLS_INIT=y
    # CONFIG_MBEDTLS_ZEROIZE_ALT is not set
    CONFIG_APP_LINK_WITH_MBEDTLS=y
    # end of mbedtls (/Users/filiprosik/Project/LPG_91/modules/crypto/mbedtls)
    # oberon-psa-crypto (/Users/filiprosik/Project/LPG_91/modules/crypto/oberon-psa-crypto)
    CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    # end of oberon-psa-crypto (/Users/filiprosik/Project/LPG_91/modules/crypto/oberon-psa-crypto)
    # trusted-firmware-m (/Users/filiprosik/Project/LPG_91/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_TFM_BOARD="/Users/filiprosik/Project/LPG_91/nrf/modules/trusted-firmware-m/tfm_boards/nrf9120"
    # CONFIG_TFM_DUMMY_PROVISIONING is not set
    # CONFIG_TFM_REGRESSION_NS is not set
    CONFIG_TFM_LOG_LEVEL_SILENCE=y
    CONFIG_TFM_QCBOR_PATH="/Users/filiprosik/Project/LPG_91/modules/tee/tf-m/trusted-firmware-m/../qcbor"
    CONFIG_TFM_PARTITION_PROTECTED_STORAGE=y
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
    # CONFIG_TFM_PROFILE_TYPE_SMALL is not set
    # CONFIG_TFM_PROFILE_TYPE_MEDIUM is not set
    # CONFIG_TFM_PROFILE_TYPE_AROTLESS is not set
    # CONFIG_TFM_PROFILE_TYPE_LARGE is not set
    # CONFIG_TFM_CMAKE_BUILD_TYPE_RELEASE is not set
    # CONFIG_TFM_CMAKE_BUILD_TYPE_RELWITHDEBINFO is not set
    CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=y
    # CONFIG_TFM_CMAKE_BUILD_TYPE_DEBUG is not set
    CONFIG_TFM_ISOLATION_LEVEL=1
    # CONFIG_TFM_ITS_NUM_ASSETS_OVERRIDE is not set
    CONFIG_TFM_ITS_NUM_ASSETS=10
    # CONFIG_TFM_ITS_MAX_ASSET_SIZE_OVERRIDE is not set
    CONFIG_TFM_ITS_MAX_ASSET_SIZE=512
    CONFIG_TFM_PARTITION_PLATFORM_CUSTOM_REBOOT=y
    CONFIG_TFM_BL2_NOT_SUPPORTED=y
    CONFIG_TFM_IMAGE_VERSION_S="0.0.0+0"
    CONFIG_TFM_IMAGE_VERSION_NS="0.0.0+0"
    # CONFIG_TFM_BL1 is not set
    # CONFIG_TFM_USE_NS_APP is not set
    # CONFIG_TFM_CONNECTION_BASED_SERVICE_API is not set
    CONFIG_TFM_IPC=y
    # CONFIG_TFM_SFN is not set
    # CONFIG_TFM_REGRESSION_S is not set
    # CONFIG_TFM_PSA_TEST_CRYPTO is not set
    # CONFIG_TFM_PSA_TEST_PROTECTED_STORAGE is not set
    # CONFIG_TFM_PSA_TEST_INTERNAL_TRUSTED_STORAGE is not set
    # CONFIG_TFM_PSA_TEST_STORAGE is not set
    # CONFIG_TFM_PSA_TEST_INITIAL_ATTESTATION is not set
    CONFIG_TFM_PSA_TEST_NONE=y
    CONFIG_TFM_EXCEPTION_INFO_DUMP=y
    CONFIG_TFM_PARTITION_INTERNAL_TRUSTED_STORAGE=y
    # CONFIG_TFM_PARTITION_FIRMWARE_UPDATE is not set
    CONFIG_TFM_CRYPTO_KEY_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_AEAD_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_MAC_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_HASH_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_CIPHER_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_ASYM_ENCRYPT_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_ASYM_SIGN_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_KEY_DERIVATION_MODULE_ENABLED=y
    # Platform partition component configs
    CONFIG_TFM_PLATFORM_SERVICE_INPUT_BUFFER_SIZE=64
    CONFIG_TFM_PLATFORM_SERVICE_OUTPUT_BUFFER_SIZE=64
    CONFIG_TFM_PLATFORM_SP_STACK_SIZE=0x500
    # CONFIG_TFM_PLATFORM_NV_COUNTER_MODULE_DISABLED is not set
    # end of Platform partition component configs
    # Crypto component configs
    # CONFIG_TFM_CRYPTO_SINGLE_PART_FUNCS_DISABLED is not set
    CONFIG_TFM_CRYPTO_BUILTIN_KEYS=y
    CONFIG_TFM_CRYPTO_ENGINE_BUF_SIZE=12288
    CONFIG_TFM_CRYPTO_CONC_OPER_NUM=8
    CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE=5120
    CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE=0x2000
    # end of Crypto component configs
    # ITS component configs
    CONFIG_TFM_ITS_CREATE_FLASH_LAYOUT=y
    # CONFIG_TFM_ITS_RAM_FS is not set
    CONFIG_TFM_ITS_VALIDATE_METADATA_FROM_FLASH=y
    CONFIG_TFM_ITS_BUF_SIZE=2048
    CONFIG_TFM_ITS_STACK_SIZE=0x720
    # CONFIG_TFM_ITS_ENCRYPTED is not set
    # end of ITS component configs
    # PS component configs
    CONFIG_TFM_PS_CREATE_FLASH_LAYOUT=y
    # CONFIG_TFM_PS_RAM_FS is not set
    CONFIG_TFM_PS_ROLLBACK_PROTECTION=y
    CONFIG_TFM_PS_VALIDATE_METADATA_FROM_FLASH=y
    CONFIG_TFM_PS_MAX_ASSET_SIZE=2048
    CONFIG_TFM_PS_NUM_ASSETS=10
    CONFIG_TFM_PS_STACK_SIZE=0x700
    # CONFIG_TFM_PS_SUPPORT_FORMAT_TRANSITION is not set
    # end of PS component configs
    # TF-M SPM component configs
    CONFIG_TFM_CONN_HANDLE_MAX_NUM=8
    # CONFIG_TFM_DOORBELL_API is not set
    # end of TF-M SPM component configs
    # TF-M memory regions
    CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0x16000
    CONFIG_PM_PARTITION_SIZE_TFM=0x3FE00
    CONFIG_PM_PARTITION_SIZE_TFM_PROTECTED_STORAGE=0x4000
    CONFIG_PM_PARTITION_SIZE_TFM_INTERNAL_TRUSTED_STORAGE=0x2000
    CONFIG_PM_PARTITION_SIZE_TFM_OTP_NV_COUNTERS=0x2000
    CONFIG_PM_PARTITION_TFM_STORAGE=y
    # end of TF-M memory regions
    # Peripheral Secure mapping
    # CONFIG_NRF_FPU_SECURE is not set
    # CONFIG_NRF_CLOCK_SECURE is not set
    # CONFIG_NRF_POWER_SECURE is not set
    # CONFIG_NRF_SPIM0_SECURE is not set
    # CONFIG_NRF_TWIM0_SECURE is not set
    # CONFIG_NRF_UARTE0_SECURE is not set
    # CONFIG_NRF_SPIM1_SECURE is not set
    # CONFIG_NRF_TWIM1_SECURE is not set
    # CONFIG_NRF_UARTE1_SECURE is not set
    # CONFIG_NRF_SPIM2_SECURE is not set
    # CONFIG_NRF_TWIM2_SECURE is not set
    # CONFIG_NRF_UARTE2_SECURE is not set
    # CONFIG_NRF_SPIM3_SECURE is not set
    # CONFIG_NRF_TWIM3_SECURE is not set
    # CONFIG_NRF_UARTE3_SECURE is not set
    # CONFIG_NRF_SAADC_SECURE is not set
    # CONFIG_NRF_TIMER0_SECURE is not set
    # CONFIG_NRF_TIMER1_SECURE is not set
    # CONFIG_NRF_TIMER2_SECURE is not set
    # CONFIG_NRF_RTC0_SECURE is not set
    # CONFIG_NRF_RTC1_SECURE is not set
    # CONFIG_NRF_DPPI_SECURE is not set
    # CONFIG_NRF_WDT0_SECURE is not set
    # CONFIG_NRF_EGU0_SECURE is not set
    # CONFIG_NRF_EGU1_SECURE is not set
    # CONFIG_NRF_EGU2_SECURE is not set
    # CONFIG_NRF_EGU3_SECURE is not set
    # CONFIG_NRF_EGU4_SECURE is not set
    # CONFIG_NRF_EGU5_SECURE is not set
    # CONFIG_NRF_PWM0_SECURE is not set
    # CONFIG_NRF_PWM1_SECURE is not set
    # CONFIG_NRF_PWM2_SECURE is not set
    # CONFIG_NRF_PWM3_SECURE is not set
    # CONFIG_NRF_PDM_SECURE is not set
    # CONFIG_NRF_I2S_SECURE is not set
    # CONFIG_NRF_IPC_SECURE is not set
    # CONFIG_NRF_NVMC_SECURE is not set
    # CONFIG_NRF_GPIO0_SECURE is not set
    # CONFIG_NRF_GPIOTE0_SECURE is not set
    CONFIG_NRF_GPIO0_PIN_MASK_SECURE=0x00000000
    CONFIG_NRF_DPPI_CHANNEL_MASK_SECURE=0x00000000
    CONFIG_NRF_VMC_SECURE=y
    # end of Peripheral Secure mapping
    # CONFIG_TFM_PROFILE_TYPE_MINIMAL is not set
    CONFIG_TFM_CPU_FREQ_MHZ=128
    # CONFIG_TFM_SECURE_UART is not set
    CONFIG_TFM_EXPERIMENTAL=y
    CONFIG_TFM_HW_INIT_RESET_ON_BOOT=y
    CONFIG_TFM_HW_INIT_NRF_PERIPHERALS=y
    CONFIG_TFM_HALT_ON_CORE_PANIC=y
    CONFIG_TFM_ALLOW_NON_SECURE_RESET=y
    CONFIG_TFM_ALLOW_NON_SECURE_FAULT_HANDLING=y
    CONFIG_TFM_S_CODE_VECTOR_TABLE_SIZE=0x144
    # CONFIG_TFM_PSA_FRAMEWORK_HAS_MM_IOVEC is not set
    # end of trusted-firmware-m (/Users/filiprosik/Project/LPG_91/modules/tee/tf-m/trusted-firmware-m)
    # cmsis_6 (/Users/filiprosik/Project/LPG_91/modules/hal/cmsis_6)
    CONFIG_ZEPHYR_CMSIS_6_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis_6 (/Users/filiprosik/Project/LPG_91/modules/hal/cmsis_6)
    # hal_nordic (/Users/filiprosik/Project/LPG_91/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_IPC_LOG is not set
    # CONFIG_NRFX_NVMC_LOG is not set
    # CONFIG_NRFX_SPIM_LOG is not set
    # CONFIG_NRFX_TIMER_LOG is not set
    # CONFIG_NRFX_TWIM_LOG is not set
    # CONFIG_NRFX_WDT_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    # CONFIG_NRFX_CLOCK_USE_LFRC_CALIBRATION is not set
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_CLOCK_LF_CAL_ENABLED is not set
    # CONFIG_NRFX_CLOCK_LF_SRC_RC is not set
    CONFIG_NRFX_CLOCK_LF_SRC_XTAL=y
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE1=y
    CONFIG_NRFX_GPPI=y
    # CONFIG_NRFX_GPPI_V1 is not set
    # CONFIG_NRFX_I2S is not set
    CONFIG_NRFX_IPC=y
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM is not set
    # CONFIG_NRFX_QDEC is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    CONFIG_NRFX_SPIM=y
    # CONFIG_NRFX_SYSTICK is not set
    CONFIG_NRFX_TIMER=y
    CONFIG_NRFX_TWIM=y
    # CONFIG_NRFX_TWIS is not set
    # CONFIG_NRFX_UARTE is not set
    CONFIG_NRFX_WDT=y
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_reserved_resources_ncs.h"
    # end of hal_nordic (/Users/filiprosik/Project/LPG_91/modules/hal/nordic)
    # littlefs (/Users/filiprosik/Project/LPG_91/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (/Users/filiprosik/Project/LPG_91/modules/fs/littlefs)
    # segger (/Users/filiprosik/Project/LPG_91/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
    CONFIG_SEGGER_RTT_CB_ALIGNMENT=16
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    # CONFIG_SEGGER_RTT_SECTION_NONE is not set
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    # CONFIG_SEGGER_RTT_SECTION_CCM is not set
    CONFIG_SEGGER_RTT_SECTION_CUSTOM=y
    # CONFIG_SEGGER_RTT_SECTION_CUSTOM_DTS_REGION is not set
    CONFIG_SEGGER_RTT_SECTION_CUSTOM_NAME=".rtt_buff_data"
    # CONFIG_SEGGER_RTT_INIT_MODE_ALWAYS is not set
    CONFIG_SEGGER_RTT_INIT_MODE_STRONG_CHECK=y
    # CONFIG_SEGGER_RTT_INIT_MODE_WEAK_CHECK is not set
    # end of segger (/Users/filiprosik/Project/LPG_91/modules/debug/segger)
    # zcbor (/Users/filiprosik/Project/LPG_91/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    CONFIG_ZCBOR=y
    # CONFIG_ZCBOR_CANONICAL is not set
    # CONFIG_ZCBOR_STOP_ON_ERROR is not set
    # CONFIG_ZCBOR_VERBOSE is not set
    CONFIG_ZCBOR_MAX_STR_LEN=256
    # end of zcbor (/Users/filiprosik/Project/LPG_91/modules/lib/zcbor)
    # nrfxlib (/Users/filiprosik/Project/LPG_91/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    CONFIG_NRF_MODEM=y
    CONFIG_NRF_MODEM_LINK_BINARY=y
    CONFIG_NRF_MODEM_LINK_BINARY_CELLULAR=y
    # CONFIG_NRF_MODEM_LINK_BINARY_DECT_PHY is not set
    # CONFIG_NRF_MODEM_LOG is not set
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # end of nrf_modem (Modem library)
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_HAS_HW_NRF_CC3XX=y
    CONFIG_NRF_OBERON=y
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_NRF_DM is not set
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (/Users/filiprosik/Project/LPG_91/nrfxlib)
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_HAS_MEC5_HAL is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="/Users/filiprosik/Project/LPG_91/td1159-low-power-gateway-91/app/src/keys/priv.pem"
    CONFIG_MCUBOOT_ENCRYPTION_KEY_FILE=""
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.4.2+0"
    # CONFIG_MCUBOOT_IMGTOOL_OVERWRITE_ONLY is not set
    # CONFIG_MCUBOOT_IMGTOOL_UUID_VID is not set
    # CONFIG_MCUBOOT_IMGTOOL_UUID_CID is not set
    CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS="--slot-size 0xe6000"
    # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
    # On board MCUboot operation mode
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_USING_OFFSET is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_USING_MOVE=y
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD_WITH_REVERT is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_FIRMWARE_UPDATER is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP_RAM_LOAD is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
    # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
    # CONFIG_MCUBOOT_BOOTLOADER_USES_SHA512 is not set
    # end of On board MCUboot operation mode
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
    CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_bouffalolab module not available.
    # hal_gigadevice module not available.
    # hal_nxp module not available.
    # liblc3 module not available.
    # libsbc module not available.
    # Trusted-firmware-a module not available.
    # Nanopb module not available.
    # Lz4 module not available.
    # loramac-node module not available.
    # LoRa Basics Modem module not available.
    # CANopenNode module not available.
    # CHRE module not available.
    # THRIFT module not available.
    # LVGL module not available.
    # cmsis module not available.
    # cmsis-dsp module not available.
    # cmsis-nn module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD="low_power_gateway"
    CONFIG_BOARD_REVISION="0.3.0"
    CONFIG_BOARD_TARGET="[email protected]/nrf9151/ns"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_LOW_POWER_GATEWAY=y
    CONFIG_BOARD_LOW_POWER_GATEWAY_NRF9151_NS=y
    CONFIG_BOARD_QUALIFIERS="nrf9151/ns"
    # Board Options
    CONFIG_BOARD_REVISION_0_3_0=y
    # end of Board Options
    # Hardware Configuration
    CONFIG_SOC="nrf9151"
    CONFIG_SOC_SERIES="nrf91"
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NORDIC_NRF=y
    CONFIG_SOC_SERIES_NRF91X=y
    CONFIG_SOC_NRF9120=y
    CONFIG_SOC_NRF9151_LACA=y
    CONFIG_HWINFO=y
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_NORDIC_BSP_NAME="stable"
    CONFIG_HAS_HW_NRF_CC310=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIOTE1=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_UARTE1=y
    CONFIG_HAS_HW_NRF_UARTE2=y
    CONFIG_HAS_HW_NRF_VMC=y
    # CONFIG_NRF_SYS_EVENT is not set
    # CONFIG_NRF_PERIPHCONF_SECTION is not set
    # CONFIG_IS_IRONSIDE_SE_SECONDARY_IMAGE is not set
    # CONFIG_IS_GEN_UICR_IMAGE is not set
    CONFIG_NRF_ENABLE_ICACHE=y
    CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0x8000
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0x2000
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    # CONFIG_SOC_NRF54H20_PM_S2RAM_OVERRIDE is not set
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    CONFIG_TFM_NRF_NS_STORAGE=y
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_ARCH="arm"
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_CPU_CORTEX=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # ARM Options
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    # CONFIG_PLATFORM_SPECIFIC_INIT is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_NONSECURE_FIRMWARE=y
    CONFIG_ARM_NONSECURE_PREEMPTIBLE_SECURE_CALLS=y
    CONFIG_ARM_STORE_EXC_RETURN=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    CONFIG_ARM_TRUSTZONE_M=y
    # ARM TrustZone-M Options
    # Non-secure firmware
    # CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS is not set
    # end of ARM TrustZone-M Options
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_CPU_HAS_NRF_IDAU=y
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    CONFIG_ARCH_SUPPORTS_ROM_OFFSET=y
    CONFIG_ARM_MPU=y
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    # CONFIG_USERSPACE is not set
    # CONFIG_NOINIT_SNIPPET_FIRST is not set
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # CONFIG_FRAME_POINTER is not set
    # Interrupt Configuration
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    CONFIG_ARCH_DEVICE_STATE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    # CONFIG_SRAM_SW_ISR_TABLE is not set
    CONFIG_EXCEPTION_DEBUG=y
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_VECTOR_TABLE_RELOCATION=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_STACK_PTR=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # DSP Options
    # end of DSP Options
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    # CONFIG_SCHED_DUMB is not set
    CONFIG_SCHED_SIMPLE=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_DUMB is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_SIMPLE=y
    # Misc Kernel related options
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_CURRENT_THREAD_USE_TLS=y
    # end of Misc Kernel related options
    # Kernel Debugging and Metrics
    CONFIG_BOOT_DELAY=0
    # CONFIG_BOOT_CLEAR_SCREEN is not set
    CONFIG_THREAD_MONITOR=y
    CONFIG_THREAD_NAME=y
    CONFIG_THREAD_MAX_NAME_LEN=32
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # CONFIG_WORKQUEUE_WORK_TIMEOUT is not set
    # System Work Queue Options
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    CONFIG_SYSTEM_WORKQUEUE_WORK_TIMEOUT_MS=0
    # end of System Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # end of Timer API Options
    # Other Kernel Object Options
    CONFIG_POLL=y
    # CONFIG_MEM_SLAB_POINTER_VALIDATE is not set
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
    # end of Other Kernel Object Options
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    # Security Options
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # Memory Domains
    CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
    CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
    # end of Memory Domains
    # SMP Options
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
    # CONFIG_STATIC_INIT_GNU is not set
    # CONFIG_BOOTARGS is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_MUTABLE is not set
    # CONFIG_DEVICE_DT_METADATA is not set
    CONFIG_DEVICE_DEINIT_SUPPORT=y
    # end of Device Options
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Virtual Memory Support
    # MMU Features
    # end of MMU Features
    # end of Virtual Memory Support
    # SoC and Board Hooks
    # CONFIG_SOC_EARLY_RESET_HOOK is not set
    # CONFIG_SOC_PREP_HOOK is not set
    # CONFIG_SOC_EARLY_INIT_HOOK is not set
    # CONFIG_SOC_LATE_INIT_HOOK is not set
    # CONFIG_SOC_PER_CORE_INIT_HOOK is not set
    # CONFIG_BOARD_EARLY_INIT_HOOK is not set
    # CONFIG_BOARD_LATE_INIT_HOOK is not set
    # end of SoC and Board Hooks
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    CONFIG_BT_DRIVERS=y
    # Bluetooth HCI Driver Options
    CONFIG_BT_UART=y
    CONFIG_BT_H4=y
    CONFIG_BT_HCI_INIT_PRIORITY=50
    # CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set
    CONFIG_BT_DRV_TX_STACK_SIZE=256
    CONFIG_BT_DRV_RX_STACK_SIZE=2048
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_FREQUENCY=32768
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    # CONFIG_COMPARATOR is not set
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    CONFIG_CONSOLE_INIT_PRIORITY=40
    # CONFIG_UART_CONSOLE is not set
    # CONFIG_RAM_CONSOLE is not set
    CONFIG_RTT_CONSOLE=y
    CONFIG_RTT_TX_RETRY_CNT=2
    CONFIG_RTT_TX_RETRY_DELAY_MS=2
    # CONFIG_RTT_TX_RETRY_IN_INTERRUPT is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    CONFIG_UART_MCUMGR=y
    CONFIG_UART_MCUMGR_RX_BUF_SIZE=128
    CONFIG_UART_MCUMGR_RX_BUF_COUNT=3
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_CRC_DRIVER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_DP_DRIVER is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    CONFIG_ENTROPY_GENERATOR=y
    # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
    # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
    # CONFIG_ENTROPY_LOG_LEVEL_INF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
    CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
    CONFIG_ENTROPY_LOG_LEVEL=3
    CONFIG_ENTROPY_INIT_PRIORITY=50
    # CONFIG_FAKE_ENTROPY_NATIVE_POSIX is not set
    CONFIG_ENTROPY_PSA_CRYPTO_RNG=y
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    # CONFIG_ETH_DRIVER is not set
    # Firmware drivers
    # CONFIG_ARM_SCMI is not set
    # end of Firmware drivers
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_EX_OP=y
    CONFIG_FLASH_HAS_EXPLICIT_ERASE=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH_JESD216=y
    CONFIG_FLASH_JESD216_API=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    # CONFIG_FLASH_EX_OP_ENABLED is not set
    # MSPI flash device driver
    # end of MSPI flash device driver
    CONFIG_SPI_NOR_SFDP_MINIMAL=y
    # CONFIG_SPI_NOR_SFDP_DEVICETREE is not set
    # CONFIG_SPI_NOR_SFDP_RUNTIME is not set
    CONFIG_SPI_NOR_INIT_PRIORITY=80
    CONFIG_SPI_NOR_CS_WAIT_DELAY=0
    CONFIG_SPI_NOR_SLEEP_WHILE_WAITING_UNTIL_READY=y
    CONFIG_SPI_NOR_SLEEP_ERASE_MS=50
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_SOC_FLASH_NRF_CUSTOM_CONTEXT is not set
    CONFIG_SOC_FLASH_NRF=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_FLASH_LOG_LEVEL=3
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HAPTICS is not set
    # CONFIG_HWINFO_LOG_LEVEL_OFF is not set
    # CONFIG_HWINFO_LOG_LEVEL_ERR is not set
    # CONFIG_HWINFO_LOG_LEVEL_WRN is not set
    # CONFIG_HWINFO_LOG_LEVEL_INF is not set
    # CONFIG_HWINFO_LOG_LEVEL_DBG is not set
    CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y
    CONFIG_HWINFO_LOG_LEVEL=3
    CONFIG_HWINFO_HAS_DRIVER=y
    CONFIG_HWINFO_NRF=y
    # CONFIG_HWSPINLOCK is not set
    CONFIG_I2C=y
    # CONFIG_I2C_CALLBACK is not set
    # CONFIG_I2C_RTIO is not set
    # CONFIG_I2C_TARGET is not set
    # CONFIG_I2C_DW_EXTENDED_SUPPORT is not set
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_NRFX_TWIM=y
    CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
    CONFIG_I2C_INIT_PRIORITY=50
    # CONFIG_I2C_LOG_LEVEL_OFF is not set
    # CONFIG_I2C_LOG_LEVEL_ERR is not set
    # CONFIG_I2C_LOG_LEVEL_WRN is not set
    # CONFIG_I2C_LOG_LEVEL_INF is not set
    # CONFIG_I2C_LOG_LEVEL_DBG is not set
    CONFIG_I2C_LOG_LEVEL_DEFAULT=y
    CONFIG_I2C_LOG_LEVEL=3
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # CONFIG_IEEE802154 is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX is not set
    # CONFIG_MDIO is not set
    # CONFIG_MIPI_DBI is not set
    # Miscellaneous Drivers
    # CONFIG_TIMEAWARE_GPIO is not set
    # Interconn Drivers
    # end of Interconn Drivers
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_MSPI is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    CONFIG_PINCTRL=y
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    CONFIG_PINCTRL_NON_STATIC=y
    CONFIG_PINCTRL_DYNAMIC=y
    CONFIG_PINCTRL_KEEP_SLEEP_STATE=y
    # CONFIG_PINCTRL_NPCX_EX is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_PS2 is not set
    # CONFIG_PSI5 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # CONFIG_SENT is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    CONFIG_SERIAL_INIT_PRIORITY=50
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    CONFIG_UART_ASYNC_API=y
    CONFIG_UART_EXCLUSIVE_API_CALLBACKS=y
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    # CONFIG_UART_NATIVE_POSIX is not set
    # CONFIG_UART_NPCX_FIFO_EX is not set
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    CONFIG_UART_ASYNC_TX_CACHE_SIZE=8
    # CONFIG_UARTE_NRFX_UARTE_COUNT_BYTES_WITH_TIMER is not set
    # CONFIG_UART_NRFX_UARTE_DIRECT_ISR is not set
    # CONFIG_UART_1_INTERRUPT_DRIVEN is not set
    CONFIG_UART_1_ASYNC=y
    CONFIG_UART_1_ENHANCED_POLL_OUT=y
    # CONFIG_UART_1_NRF_PARITY_BIT is not set
    CONFIG_UART_1_NRF_TX_BUFFER_SIZE=256
    CONFIG_UART_1_NRF_HW_ASYNC=y
    # CONFIG_UART_1_NRF_ASYNC_LOW_POWER is not set
    CONFIG_UART_1_NRF_HW_ASYNC_TIMER=1
    # CONFIG_UART_2_INTERRUPT_DRIVEN is not set
    CONFIG_UART_2_ASYNC=y
    CONFIG_UART_2_ENHANCED_POLL_OUT=y
    # CONFIG_UART_2_NRF_PARITY_BIT is not set
    CONFIG_UART_2_NRF_TX_BUFFER_SIZE=32
    CONFIG_UART_2_NRF_HW_ASYNC=y
    # CONFIG_UART_2_NRF_ASYNC_LOW_POWER is not set
    CONFIG_UART_2_NRF_HW_ASYNC_TIMER=2
    # CONFIG_SMBUS is not set
    # CONFIG_SPI_ASYNC is not set
    # CONFIG_SPI_RTIO is not set
    # CONFIG_SPI_SLAVE is not set
    # CONFIG_SPI_EXTENDED_MODES is not set
    CONFIG_SPI_INIT_PRIORITY=50
    CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    # CONFIG_SPI_LOG_LEVEL_OFF is not set
    # CONFIG_SPI_LOG_LEVEL_ERR is not set
    # CONFIG_SPI_LOG_LEVEL_WRN is not set
    # CONFIG_SPI_LOG_LEVEL_INF is not set
    # CONFIG_SPI_LOG_LEVEL_DBG is not set
    CONFIG_SPI_LOG_LEVEL_DEFAULT=y
    CONFIG_SPI_LOG_LEVEL=3
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_NRFX_SPIM=y
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
    # CONFIG_STEPPER is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    CONFIG_NRF_RTC_TIMER=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    CONFIG_NRF_RTC_COUNTER_BIT_WIDTH=24
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # USB common
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    # end of USB common
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_USBC_PPC_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTIO is not set
    # CONFIG_VIRTIO_LOG_LEVEL_OFF is not set
    # CONFIG_VIRTIO_LOG_LEVEL_ERR is not set
    # CONFIG_VIRTIO_LOG_LEVEL_WRN is not set
    # CONFIG_VIRTIO_LOG_LEVEL_INF is not set
    # CONFIG_VIRTIO_LOG_LEVEL_DBG is not set
    CONFIG_VIRTIO_LOG_LEVEL_DEFAULT=y
    CONFIG_VIRTIO_LOG_LEVEL=3
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_WDT_LOG_LEVEL_OFF is not set
    # CONFIG_WDT_LOG_LEVEL_ERR is not set
    # CONFIG_WDT_LOG_LEVEL_WRN is not set
    # CONFIG_WDT_LOG_LEVEL_INF is not set
    # CONFIG_WDT_LOG_LEVEL_DBG is not set
    CONFIG_WDT_LOG_LEVEL_DEFAULT=y
    CONFIG_WDT_LOG_LEVEL=3
    CONFIG_WDT_NRFX=y
    # CONFIG_WDT_NRFX_NO_IRQ is not set
    CONFIG_NET_TC_TX_COUNT=0
    CONFIG_NET_INTERFACE_NAME_LEN=8
    # CONFIG_TEE is not set
    CONFIG_REQUIRES_FULL_LIBC=y
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    # CONFIG_LIBC_ALLOW_LESS_THAN_64BIT_TIME is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    CONFIG_NATIVE_LIBC_INCOMPATIBLE=y
    # C Library
    CONFIG_PICOLIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_ASCTIME_R is not set
    # CONFIG_COMMON_LIBC_CTIME_R is not set
    CONFIG_COMMON_LIBC_TIME=y
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    CONFIG_COMMON_LIBC_REMOVE=y
    CONFIG_PICOLIBC_USE_TOOLCHAIN=y
    # CONFIG_PICOLIBC_IO_FLOAT is not set
    CONFIG_PICOLIBC_IO_LONG_LONG=y
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # end of C++ Language Support
    # Additional libraries
    # Hash Function Support
    CONFIG_SYS_HASH_FUNC32=y
    CONFIG_SYS_HASH_FUNC32_DJB2=y
    CONFIG_SYS_HASH_FUNC32_MURMUR3=y
    # CONFIG_SYS_HASH_FUNC32_CHOICE_DJB2 is not set
    CONFIG_SYS_HASH_FUNC32_CHOICE_MURMUR3=y
    # CONFIG_SYS_HASH_FUNC32_CHOICE_IDENTITY is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_STRESS is not set
    # CONFIG_SYS_HEAP_INFO is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    CONFIG_SYS_HEAP_RUNTIME_STATS=y
    CONFIG_SYS_HEAP_ARRAY_SIZE=0
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_MULTI_HEAP is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # end of Heap and Memory Allocation
    # Memory Blocks
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Memory Blocks
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_BUF_LOG_LEVEL_INF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    CONFIG_NET_BUF_ALIGNMENT=0
    # OS Support Library
    CONFIG_FDTABLE=y
    CONFIG_ZVFS_OPEN_MAX=16
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    CONFIG_ZVFS=y
    CONFIG_ZVFS_EVENTFD=y
    CONFIG_ZVFS_EVENTFD_MAX=1
    CONFIG_ZVFS_POLL=y
    CONFIG_ZVFS_POLL_MAX=3
    CONFIG_ZVFS_SELECT=y
    # end of OS Support Library
    # POSIX API Support
    # POSIX Options
    CONFIG_POSIX_SYSTEM_HEADERS=y
    CONFIG_POSIX_API=y
    CONFIG_POSIX_AEP_CHOICE_NONE=y
    # CONFIG_POSIX_AEP_CHOICE_BASE is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
    CONFIG_POSIX_BASE_DEFINITIONS=y
    CONFIG_POSIX_AEP_REALTIME_MINIMAL=y
    CONFIG_POSIX_ASYNCHRONOUS_IO=y
    CONFIG_POSIX_BARRIERS=y
    CONFIG_MAX_PTHREAD_BARRIER_COUNT=5
    # CONFIG_PTHREAD_CREATE_BARRIER is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL=3
    CONFIG_POSIX_C_LANG_SUPPORT_R=y
    # CONFIG_POSIX_C_LIB_EXT is not set
    # POSIX device I/O
    CONFIG_POSIX_DEVICE_IO=y
    CONFIG_POSIX_OPEN_MAX=16
    # end of POSIX device I/O
    CONFIG_POSIX_FD_MGMT=y
    CONFIG_POSIX_FILE_SYSTEM_R=y
    CONFIG_POSIX_FILE_SYSTEM=y
    # POSIX memory
    CONFIG_POSIX_PAGE_SIZE=0x40
    CONFIG_POSIX_SHARED_MEMORY_OBJECTS=y
    CONFIG_POSIX_MAPPED_FILES=y
    CONFIG_POSIX_MEMLOCK=y
    CONFIG_POSIX_MEMLOCK_RANGE=y
    CONFIG_POSIX_MEMORY_PROTECTION=y
    # end of POSIX memory
    # CONFIG_POSIX_MESSAGE_PASSING is not set
    CONFIG_POSIX_NETWORKING=y
    CONFIG_POSIX_HOST_NAME_MAX=63
    # CONFIG_POSIX_IPV6 is not set
    # CONFIG_POSIX_RAW_SOCKETS is not set
    CONFIG_POSIX_SINGLE_PROCESS=y
    CONFIG_POSIX_SYSCONF_IMPL_MACRO=y
    # CONFIG_POSIX_SYSCONF_IMPL_FULL is not set
    CONFIG_POSIX_UNAME_VERSION_LEN=70
    CONFIG_POSIX_UNAME_NODENAME_LEN=6
    # CONFIG_POSIX_ENV_LOG_LEVEL_OFF is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_ERR is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_WRN is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_INF is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_DBG is not set
    CONFIG_POSIX_ENV_LOG_LEVEL_DEFAULT=y
    CONFIG_POSIX_ENV_LOG_LEVEL=3
    CONFIG_POSIX_MULTI_PROCESS=y
    CONFIG_POSIX_MULTI_PROCESS_ALIAS_GETPID=y
    CONFIG_POSIX_THREADS=y
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_POSIX_THREADS=256
    CONFIG_POSIX_THREAD_THREADS_MAX=5
    CONFIG_MAX_PTHREAD_MUTEX_COUNT=5
    CONFIG_MAX_PTHREAD_COND_COUNT=5
    CONFIG_POSIX_THREAD_KEYS_MAX=5
    CONFIG_PTHREAD_RECYCLER_DELAY_MS=100
    CONFIG_POSIX_THREAD_ATTR_STACKADDR=y
    CONFIG_POSIX_THREAD_ATTR_STACKSIZE=y
    # CONFIG_POSIX_THREADS_EXT is not set
    CONFIG_POSIX_THREAD_PRIORITY_SCHEDULING=y
    CONFIG_POSIX_PTHREAD_ATTR_STACKSIZE_BITS=23
    CONFIG_POSIX_PTHREAD_ATTR_GUARDSIZE_BITS=9
    CONFIG_POSIX_PTHREAD_ATTR_GUARDSIZE_DEFAULT=0
    CONFIG_POSIX_THREAD_PRIO_INHERIT=y
    CONFIG_POSIX_THREAD_PRIO_PROTECT=y
    CONFIG_POSIX_THREAD_SAFE_FUNCTIONS=y
    # CONFIG_PTHREAD_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_LOG_LEVEL=3
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL=3
    # CONFIG_PTHREAD_COND_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_COND_LOG_LEVEL=3
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_KEY_LOG_LEVEL=3
    CONFIG_POSIX_READER_WRITER_LOCKS=y
    CONFIG_MAX_PTHREAD_RWLOCK_COUNT=5
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_RWLOCK_LOG_LEVEL=3
    # POSIX scheduler options
    # CONFIG_POSIX_PRIORITY_SCHEDULING is not set
    # end of POSIX scheduler options
    CONFIG_POSIX_SEMAPHORES=y
    CONFIG_POSIX_SEM_VALUE_MAX=32767
    CONFIG_POSIX_SEM_NSEMS_MAX=256
    CONFIG_POSIX_SEM_NAMELEN_MAX=16
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_POSIX_SEMAPHORES=256
    # POSIX signals
    CONFIG_POSIX_REALTIME_SIGNALS=y
    CONFIG_POSIX_RTSIG_MAX=8
    CONFIG_POSIX_SIGNALS=y
    CONFIG_POSIX_SIGNAL_STRING_DESC=y
    # end of POSIX signals
    CONFIG_POSIX_SPIN_LOCKS=y
    CONFIG_MAX_PTHREAD_SPINLOCK_COUNT=5
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL=3
    # POSIX synchronized I/O
    CONFIG_POSIX_FSYNC=y
    CONFIG_POSIX_SYNCHRONIZED_IO=y
    # end of POSIX synchronized I/O
    CONFIG_POSIX_TIMERS=y
    CONFIG_POSIX_THREAD_CPUTIME=y
    CONFIG_POSIX_MONOTONIC_CLOCK=y
    # CONFIG_POSIX_CPUTIME is not set
    CONFIG_POSIX_CLOCK_SELECTION=y
    CONFIG_POSIX_DELAYTIMER_MAX=32
    CONFIG_POSIX_TIMER_MAX=32
    CONFIG_POSIX_TIMEOUTS=y
    CONFIG_TIMER_CREATE_WAIT=100
    # CONFIG_TIMER_LOG_LEVEL_OFF is not set
    # CONFIG_TIMER_LOG_LEVEL_ERR is not set
    # CONFIG_TIMER_LOG_LEVEL_WRN is not set
    # CONFIG_TIMER_LOG_LEVEL_INF is not set
    # CONFIG_TIMER_LOG_LEVEL_DBG is not set
    CONFIG_TIMER_LOG_LEVEL_DEFAULT=y
    CONFIG_TIMER_LOG_LEVEL=3
    # X/Open system interfaces
    # CONFIG_XSI_REALTIME is not set
    CONFIG_XSI_SINGLE_PROCESS=y
    # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_OFF is not set
    # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_ERR is not set
    # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_WRN is not set
    # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_INF is not set
    # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_DBG is not set
    CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_DEFAULT=y
    CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL=3
    # CONFIG_XOPEN_STREAMS is not set
    # CONFIG_XSI_SYSTEM_LOGGING is not set
    CONFIG_XSI_THREADS_EXT=y
    # end of X/Open system interfaces
    # Miscellaneous POSIX-related options
    CONFIG_EVENTFD=y
    # end of Miscellaneous POSIX-related options
    CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
    # end of POSIX Options
    # POSIX Shell Utilities
    # end of POSIX Shell Utilities
    # end of POSIX API Support
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_LIBGCC_RTLIB=y
    # Utility Library
    # CONFIG_JSON_LIBRARY is not set
    CONFIG_RING_BUFFER=y
    # CONFIG_RING_BUFFER_LARGE is not set
    CONFIG_NOTIFY=y
    CONFIG_BASE64=y
    CONFIG_ONOFF=y
    # CONFIG_UTF8 is not set
    # CONFIG_COBS is not set
    # end of Utility Library
    # Universally Unique Identifier (UUID)
    # CONFIG_UUID is not set
    # end of Universally Unique Identifier (UUID)
    # CONFIG_MIN_HEAP is not set
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    CONFIG_BT=y
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_LE_EXTENDED_FEAT_SET is not set
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
    # CONFIG_BT_PATH_LOSS_MONITORING is not set
    # CONFIG_BT_SUBRATING is not set
    # CONFIG_BT_CHANNEL_SOUNDING is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # Bluetooth Classic Options
    # end of Bluetooth Classic Options
    # end of Bluetooth Host
    # CONFIG_BT_EAD is not set
    # Bluetooth logging
    # Common
    # end of Common
    # Libraries
    # end of Libraries
    # Host
    # end of Host
    # Services
    # end of Services
    # end of Bluetooth logging
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_CPU_LOAD_METRIC is not set
    # CONFIG_CPU_LOAD_LOG_LEVEL_OFF is not set
    # CONFIG_CPU_LOAD_LOG_LEVEL_ERR is not set
    # CONFIG_CPU_LOAD_LOG_LEVEL_WRN is not set
    # CONFIG_CPU_LOAD_LOG_LEVEL_INF is not set
    # CONFIG_CPU_LOAD_LOG_LEVEL_DBG is not set
    CONFIG_CPU_LOAD_LOG_LEVEL_DEFAULT=y
    CONFIG_CPU_LOAD_LOG_LEVEL=3
    CONFIG_CRC=y
    # CONFIG_CRC_LOG_LEVEL_OFF is not set
    # CONFIG_CRC_LOG_LEVEL_ERR is not set
    # CONFIG_CRC_LOG_LEVEL_WRN is not set
    # CONFIG_CRC_LOG_LEVEL_INF is not set
    # CONFIG_CRC_LOG_LEVEL_DBG is not set
    CONFIG_CRC_LOG_LEVEL_DEFAULT=y
    CONFIG_CRC_LOG_LEVEL=3
    # CONFIG_CRC_HW_HANDLER is not set
    # CONFIG_CRC32_K_4_2_TABLE_256 is not set
    # CONFIG_DAP is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_UBSAN is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # CONFIG_SYMTAB is not set
    # end of Debugging Options
    # CONFIG_MIPI_STP_DECODER is not set
    # CONFIG_CS_TRACE_DEFMT is not set
    # CONFIG_CPU_LOAD is not set
    CONFIG_CPU_LOAD_LOG_PERIODICALLY=0
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
    CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE=0x2000
    CONFIG_IMG_BLOCK_BUF_SIZE=512
    # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
    CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y
    CONFIG_IMG_MANAGER_LOG_LEVEL=3
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    CONFIG_FILE_SYSTEM_LIB_LINK=y
    CONFIG_FILE_SYSTEM=y
    CONFIG_FILE_SYSTEM_MAX_TYPES=2
    CONFIG_FILE_SYSTEM_MAX_FILE_NAME=-1
    CONFIG_FILE_SYSTEM_INIT_PRIORITY=99
    CONFIG_FILE_SYSTEM_MKFS=y
    CONFIG_APP_LINK_WITH_FS=y
    CONFIG_FS_LOG_LEVEL_OFF=y
    # CONFIG_FS_LOG_LEVEL_ERR is not set
    # CONFIG_FS_LOG_LEVEL_WRN is not set
    # CONFIG_FS_LOG_LEVEL_INF is not set
    # CONFIG_FS_LOG_LEVEL_DBG is not set
    # CONFIG_FS_LOG_LEVEL_DEFAULT is not set
    CONFIG_FS_LOG_LEVEL=0
    # CONFIG_FAT_FILESYSTEM_ELM is not set
    CONFIG_FILE_SYSTEM_LITTLEFS=y
    # LittleFS Settings
    CONFIG_FS_LITTLEFS_NUM_FILES=8
    CONFIG_FS_LITTLEFS_NUM_DIRS=8
    CONFIG_FS_LITTLEFS_READ_SIZE=64
    CONFIG_FS_LITTLEFS_PROG_SIZE=64
    CONFIG_FS_LITTLEFS_CACHE_SIZE=1024
    CONFIG_FS_LITTLEFS_LOOKAHEAD_SIZE=64
    CONFIG_FS_LITTLEFS_BLOCK_CYCLES=512
    # end of LittleFS Settings
    CONFIG_FS_LITTLEFS_FC_HEAP_SIZE=4096
    CONFIG_FS_LITTLEFS_FMP_DEV=y
    # CONFIG_FS_LITTLEFS_BLK_DEV is not set
    # CONFIG_FS_LITTLEFS_DISK_VERSION is not set
    # CONFIG_FILE_SYSTEM_EXT2 is not set
    # CONFIG_EXT2_LOG_LEVEL_OFF is not set
    # CONFIG_EXT2_LOG_LEVEL_ERR is not set
    # CONFIG_EXT2_LOG_LEVEL_WRN is not set
    # CONFIG_EXT2_LOG_LEVEL_INF is not set
    # CONFIG_EXT2_LOG_LEVEL_DBG is not set
    CONFIG_EXT2_LOG_LEVEL_DEFAULT=y
    CONFIG_EXT2_LOG_LEVEL=3
    # CONFIG_FUSE_CLIENT is not set
    CONFIG_FUSE_CLIENT_UID_VALUE=0
    CONFIG_FUSE_CLIENT_GID_VALUE=0
    CONFIG_FUSE_CLIENT_PID_VALUE=0
    # CONFIG_FUSE_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_FUSE_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_FUSE_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_FUSE_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_FUSE_CLIENT_LOG_LEVEL_DBG is not set
    CONFIG_FUSE_CLIENT_LOG_LEVEL_DEFAULT=y
    CONFIG_FUSE_CLIENT_LOG_LEVEL=3
    # CONFIG_FILE_SYSTEM_VIRTIOFS is not set
    # CONFIG_VIRTIOFS_DEBUG is not set
    CONFIG_VIRTIOFS_MAX_FILES=1024
    CONFIG_VIRTIOFS_MAX_VQUEUE_SIZE=1024
    CONFIG_VIRTIOFS_NO_NOTIFICATION_QUEUE_SLOT=y
    CONFIG_VIRTIOFS_VIRTIOFSD_UNLINK_QUIRK=y
    CONFIG_VIRTIOFS_CREATE_MODE_VALUE=438
    # CONFIG_VIRTIOFS_LOG_LEVEL_OFF is not set
    # CONFIG_VIRTIOFS_LOG_LEVEL_ERR is not set
    # CONFIG_VIRTIOFS_LOG_LEVEL_WRN is not set
    # CONFIG_VIRTIOFS_LOG_LEVEL_INF is not set
    # CONFIG_VIRTIOFS_LOG_LEVEL_DBG is not set
    CONFIG_VIRTIOFS_LOG_LEVEL_DEFAULT=y
    CONFIG_VIRTIOFS_LOG_LEVEL=3
    # CONFIG_FCB is not set
    # end of File Systems
    # CONFIG_GNSS_RTK is not set
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # CONFIG_LLEXT_EDK is not set
    # Logging
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    CONFIG_LOG_FLUSH_SLEEP_US=10000
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    CONFIG_LOG_TIMESTAMP_64BIT=y
    # CONFIG_LOG_TIMESTAMP_USE_REALTIME is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    # CONFIG_LOG_DBG_COLOR_BLUE is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_TIME_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_DATE_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_ISO8601_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP=y
    # end of Output Formatting
    # Backends
    # CONFIG_LOG_BACKEND_BLE is not set
    # CONFIG_LOG_BACKEND_FS is not set
    # CONFIG_LOG_BACKEND_NET is not set
    CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
    CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
    # CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
    CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
    CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
    CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
    CONFIG_LOG_BACKEND_RTT_BUFFER=0
    CONFIG_LOG_BACKEND_RTT_FORCE_PRINTK=y
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_FMT_STRING_VALIDATE is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_RATELIMIT=y
    CONFIG_LOG_RATELIMIT_INTERVAL_MS=5000
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    CONFIG_MEM_ATTR=y
    # CONFIG_MEM_ATTR_HEAP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    CONFIG_MCUMGR=y
    # CONFIG_MCUMGR_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_LOG_LEVEL=3
    # CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS is not set
    # CONFIG_MCUMGR_MGMT_HANDLER_USER_DATA is not set
    # CONFIG_MCUMGR_MGMT_CUSTOM_PAYLOAD is not set
    CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES=15
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS=3
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2=y
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_3=y
    CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS=3
    CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS=0
    CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS=0
    CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL=y
    # CONFIG_MCUMGR_SMP_VERBOSE_ERR_RESPONSE is not set
    # CONFIG_MCUMGR_SMP_LEGACY_RC_BEHAVIOUR is not set
    # SMP Client
    CONFIG_SMP_CLIENT=y
    CONFIG_SMP_CMD_DEFAULT_LIFE_TIME=5
    CONFIG_SMP_CMD_RETRY_TIME=1000
    CONFIG_SMP_CLIENT_CMD_MAX=4
    # CONFIG_MCUMGR_SMP_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_SMP_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_SMP_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_SMP_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_SMP_CLIENT_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_SMP_CLIENT_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_SMP_CLIENT_LOG_LEVEL=3
    # end of SMP Client
    # Command Handlers
    # CONFIG_MCUMGR_GRP_FS is not set
    # CONFIG_MCUMGR_GRP_IMG is not set
    CONFIG_MCUMGR_GRP_IMG_CLIENT=y
    CONFIG_MCUMGR_GRP_IMG_UPLOAD_DATA_ALIGNMENT_SIZE=4
    CONFIG_MCUMGR_GRP_IMG_FLASH_OPERATION_TIMEOUT=15
    # CONFIG_MCUMGR_GRP_IMG_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_IMG_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_IMG_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_IMG_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_IMG_CLIENT_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_IMG_CLIENT_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_IMG_CLIENT_LOG_LEVEL=3
    CONFIG_MCUMGR_GRP_OS=y
    CONFIG_MCUMGR_GRP_OS_RESET_MS=250
    # CONFIG_MCUMGR_GRP_OS_TASKSTAT is not set
    CONFIG_MCUMGR_GRP_OS_ECHO=y
    # CONFIG_MCUMGR_GRP_OS_INFO is not set
    CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO=y
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_OS_LOG_LEVEL=3
    CONFIG_MCUMGR_GRP_OS_CLIENT=y
    CONFIG_MCUMGR_GRP_OS_CLIENT_ECHO=y
    CONFIG_MCUMGR_GRP_OS_CLIENT_RESET=y
    # CONFIG_MCUMGR_GRP_OS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_OS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_OS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_OS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_OS_CLIENT_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_OS_CLIENT_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_OS_CLIENT_LOG_LEVEL=3
    # CONFIG_MCUMGR_GRP_ENUM is not set
    # end of Command Handlers
    # Transports and Transport Related Configuration Options
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=2048
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO=3
    CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=4
    CONFIG_MCUMGR_TRANSPORT_NETBUF_MIN_USER_DATA_SIZE=4
    CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE=4
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL=3
    # CONFIG_MCUMGR_TRANSPORT_DUMMY is not set
    CONFIG_MCUMGR_TRANSPORT_UART=y
    CONFIG_MCUMGR_TRANSPORT_UART_ASYNC=y
    CONFIG_MCUMGR_TRANSPORT_UART_ASYNC_BUFS=2
    CONFIG_MCUMGR_TRANSPORT_UART_ASYNC_BUF_SIZE=128
    CONFIG_MCUMGR_TRANSPORT_UART_ASYNC_RX_TIMEOUT=20000
    CONFIG_MCUMGR_TRANSPORT_UART_MTU=256
    # CONFIG_MCUMGR_TRANSPORT_UDP is not set
    # end of Transports and Transport Related Configuration Options
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_HOSTNAME_ENABLE=y
    CONFIG_NET_HOSTNAME="zephyr"
    CONFIG_NET_HOSTNAME_DYNAMIC=y
    CONFIG_NET_HOSTNAME_MAX_LEN=63
    # CONFIG_NET_HOSTNAME_UNIQUE is not set
    CONFIG_NET_HOSTNAME_LOG_LEVEL=0
    # Link layer options
    # CONFIG_NET_L2_DUMMY is not set
    # CONFIG_NET_L2_VIRTUAL is not set
    # CONFIG_NET_L2_PPP is not set
    # CONFIG_NET_L2_OPENTHREAD is not set
    # CONFIG_NET_L2_CUSTOM_IEEE802154 is not set
    # CONFIG_NET_L2_CANBUS_RAW is not set
    # CONFIG_NET_L2_WIFI_MGMT is not set
    # CONFIG_NET_L2_WIFI_SHELL is not set
    # CONFIG_NET_L2_PTP is not set
    # end of Link layer options
    # IP stack
    CONFIG_NET_IP=y
    CONFIG_NET_NATIVE=y
    CONFIG_NET_NATIVE_IP=y
    CONFIG_NET_NATIVE_IPV6=y
    CONFIG_NET_NATIVE_IPV4=y
    CONFIG_NET_NATIVE_UDP=y
    # CONFIG_NET_OFFLOAD is not set
    CONFIG_NET_OFFLOADING_SUPPORT=y
    CONFIG_NET_INIT_PRIO=90
    CONFIG_NET_IP_DSCP_ECN=y
    CONFIG_NET_IF_MAX_IPV6_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=2
    CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=3
    CONFIG_NET_IF_IPV6_PREFIX_COUNT=2
    CONFIG_NET_IPV6_MTU=1280
    # CONFIG_NET_IPV6_PMTU is not set
    CONFIG_NET_INITIAL_HOP_LIMIT=64
    CONFIG_NET_INITIAL_MCAST_HOP_LIMIT=1
    CONFIG_NET_INITIAL_IPV6_MCAST_LOOP=y
    CONFIG_NET_IPV6_MAX_NEIGHBORS=8
    # CONFIG_NET_IPV6_FRAGMENT is not set
    CONFIG_NET_IPV6_IID_EUI_64=y
    # CONFIG_NET_IPV6_IID_STABLE is not set
    # CONFIG_NET_IPV6_PE is not set
    # CONFIG_NET_6LO is not set
    CONFIG_NET_IPV6_LOG_LEVEL=0
    CONFIG_NET_IPV6_ND_LOG_LEVEL=0
    CONFIG_NET_IPV6_PE_LOG_LEVEL=0
    CONFIG_NET_ICMPV6_LOG_LEVEL=0
    CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL=0
    CONFIG_NET_IPV4=y
    CONFIG_NET_IF_MAX_IPV4_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
    CONFIG_NET_IF_MCAST_IPV4_ADDR_COUNT=1
    CONFIG_NET_IPV4_DEFAULT_NETMASK=24
    CONFIG_NET_IPV4_MTU=576
    CONFIG_NET_INITIAL_TTL=64
    CONFIG_NET_INITIAL_MCAST_TTL=1
    CONFIG_NET_INITIAL_IPV4_MCAST_LOOP=y
    CONFIG_NET_IF_MCAST_IPV4_SOURCE_COUNT=1
    # CONFIG_NET_ICMPV4_ACCEPT_BROADCAST is not set
    # CONFIG_NET_IPV4_ACCEPT_ZERO_BROADCAST is not set
    # CONFIG_NET_IPV4_IGMP is not set
    # CONFIG_NET_IPV4_HDR_OPTIONS is not set
    # CONFIG_NET_IPV4_FRAGMENT is not set
    # CONFIG_NET_IPV4_PMTU is not set
    CONFIG_NET_IPV4_LOG_LEVEL=0
    CONFIG_NET_ICMPV4_LOG_LEVEL=0
    CONFIG_NET_IPV4_ACD_LOG_LEVEL=0
    # CONFIG_NET_IPV4_MAPPING_TO_IPV6 is not set
    CONFIG_NET_TC_RX_COUNT=1
    # CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set
    # CONFIG_NET_TC_TX_SKIP_FOR_HIGH_PRIO is not set
    # CONFIG_NET_TC_RX_SKIP_FOR_HIGH_PRIO is not set
    CONFIG_NET_TC_THREAD_COOPERATIVE=y
    # CONFIG_NET_TC_THREAD_PREEMPTIVE is not set
    CONFIG_NET_TC_NUM_PRIORITIES=16
    # CONFIG_NET_TC_THREAD_PRIO_CUSTOM is not set
    CONFIG_NET_TC_MAPPING_STRICT=y
    CONFIG_NET_TX_DEFAULT_PRIORITY=1
    CONFIG_NET_RX_DEFAULT_PRIORITY=0
    # CONFIG_NET_ALLOW_ANY_PRIORITY is not set
    CONFIG_NET_IP_ADDR_CHECK=y
    CONFIG_NET_MAX_ROUTERS=2
    # CONFIG_NET_TCP is not set
    # CONFIG_NET_TEST_PROTOCOL is not set
    CONFIG_NET_UDP=y
    CONFIG_NET_UDP_MISSING_CHECKSUM=y
    CONFIG_NET_UDP_LOG_LEVEL=0
    CONFIG_NET_MAX_CONN=8
    CONFIG_NET_CONN_PACKET_CLONE_TIMEOUT=100
    CONFIG_NET_MAX_CONTEXTS=6
    # CONFIG_NET_CONTEXT_NET_PKT_POOL is not set
    CONFIG_NET_CONTEXT_SYNC_RECV=y
    CONFIG_NET_CONTEXT_CHECK=y
    # CONFIG_NET_CONTEXT_PRIORITY is not set
    # CONFIG_NET_CONTEXT_TXTIME is not set
    # CONFIG_NET_CONTEXT_RCVTIMEO is not set
    # CONFIG_NET_CONTEXT_SNDTIMEO is not set
    # CONFIG_NET_CONTEXT_RCVBUF is not set
    # CONFIG_NET_CONTEXT_SNDBUF is not set
    CONFIG_NET_CONTEXT_DSCP_ECN=y
    CONFIG_NET_CONTEXT_REUSEADDR=y
    CONFIG_NET_CONTEXT_REUSEPORT=y
    # CONFIG_NET_CONTEXT_RECV_PKTINFO is not set
    # CONFIG_NET_CONTEXT_RECV_HOPLIMIT is not set
    # CONFIG_NET_CONTEXT_TIMESTAMPING is not set
    # CONFIG_NET_CONTEXT_CLAMP_PORT_RANGE is not set
    # CONFIG_NET_TEST is not set
    CONFIG_NET_BUF_RX_COUNT=16
    CONFIG_NET_BUF_TX_COUNT=16
    CONFIG_NET_BUF_FIXED_DATA_SIZE=y
    # CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set
    CONFIG_NET_BUF_DATA_SIZE=128
    CONFIG_NET_PKT_BUF_USER_DATA_SIZE=4
    CONFIG_NET_DEFAULT_IF_FIRST=y
    # CONFIG_NET_DEFAULT_IF_UP is not set
    # CONFIG_NET_DEFAULT_IF_OFFLOADED_NETDEV is not set
    CONFIG_NET_INTERFACE_NAME=y
    # CONFIG_NET_PKT_RXTIME_STATS is not set
    # CONFIG_NET_PKT_TXTIME_STATS is not set
    # CONFIG_NET_PKT_ALLOC_STATS is not set
    # CONFIG_NET_PROMISCUOUS_MODE is not set
    # CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set
    # Stack usage
    # end of Stack usage
    # CONFIG_NET_MGMT is not set
    # CONFIG_NET_STATISTICS is not set
    # CONFIG_NET_LOG is not set
    CONFIG_NET_PKT_LOG_LEVEL=0
    # CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set
    CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0
    # CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set
    CONFIG_NET_CORE_LOG_LEVEL=0
    CONFIG_NET_IF_LOG_LEVEL=0
    CONFIG_NET_TC_LOG_LEVEL=0
    CONFIG_NET_UTILS_LOG_LEVEL=0
    CONFIG_NET_CONTEXT_LOG_LEVEL=0
    CONFIG_NET_CONN_LOG_LEVEL=0
    CONFIG_NET_ROUTE_LOG_LEVEL=0
    # end of IP stack
    # Network Packet Filtering
    # CONFIG_NET_PKT_FILTER is not set
    # end of Network Packet Filtering
    # Network Protocols
    # CONFIG_COAP is not set
    # CONFIG_DNS_RESOLVER is not set
    # CONFIG_MDNS_RESPONDER is not set
    # CONFIG_LLMNR_RESPONDER is not set
    # CONFIG_DNS_SD is not set
    # CONFIG_MQTT_LIB is not set
    # CONFIG_MQTT_SN_LIB is not set
    # CONFIG_TFTP_LIB is not set
    CONFIG_HTTP_PARSER=y
    CONFIG_HTTP_PARSER_URL=y
    # CONFIG_HTTP_PARSER_STRICT is not set
    CONFIG_HTTP_CLIENT=y
    # CONFIG_HTTP_SERVER is not set
    CONFIG_HTTP=y
    CONFIG_NET_HTTP_LOG_LEVEL=0
    CONFIG_NET_HTTP_SERVER_LOG_LEVEL=0
    # CONFIG_WEBSOCKET_CLIENT is not set
    # CONFIG_LWM2M is not set
    # CONFIG_SOCKS is not set
    CONFIG_SNTP=y
    # CONFIG_SNTP_UNCERTAINTY is not set
    CONFIG_SNTP_LOG_LEVEL=0
    # end of Network Protocols
    # Network Libraries
    CONFIG_NET_CONFIG_LOG_LEVEL=0
    # CONFIG_NET_CONFIG_SETTINGS is not set
    # CONFIG_NET_CONFIG_CLOCK_SNTP_INIT is not set
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50
    CONFIG_NET_SOCKETS_POLL_MAX=0
    CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=10000
    CONFIG_NET_SOCKET_MAX_SEND_WAIT=10000
    # CONFIG_NET_SOCKETS_SERVICE is not set
    CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
    CONFIG_NET_SOCKETS_TLS_PRIORITY=45
    CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y
    # CONFIG_NET_SOCKETS_ENABLE_DTLS is not set
    CONFIG_NET_SOCKETS_TLS_MAX_CONTEXTS=2
    CONFIG_NET_SOCKETS_TLS_MAX_CREDENTIALS=4
    CONFIG_NET_SOCKETS_TLS_MAX_CIPHERSUITES=4
    CONFIG_NET_SOCKETS_TLS_MAX_CLIENT_SESSION_COUNT=1
    # CONFIG_NET_SOCKETS_TLS_CERT_VERIFY_CALLBACK is not set
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY=40
    # CONFIG_NET_SOCKETS_OFFLOAD_DISPATCHER is not set
    # CONFIG_NET_SOCKETS_PACKET is not set
    # CONFIG_NET_SOCKETS_INET_RAW is not set
    # CONFIG_NET_SOCKETS_CAN is not set
    CONFIG_NET_SOCKETPAIR=y
    CONFIG_NET_SOCKETPAIR_BUFFER_SIZE=64
    # CONFIG_NET_SOCKETPAIR_STATIC is not set
    CONFIG_NET_SOCKETPAIR_HEAP=y
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_SOCKETPAIR=296
    CONFIG_NET_SOCKETS_LOG_LEVEL=0
    CONFIG_TLS_CREDENTIALS=y
    # CONFIG_TLS_CREDENTIALS_LOG_LEVEL_OFF is not set
    # CONFIG_TLS_CREDENTIALS_LOG_LEVEL_ERR is not set
    # CONFIG_TLS_CREDENTIALS_LOG_LEVEL_WRN is not set
    # CONFIG_TLS_CREDENTIALS_LOG_LEVEL_INF is not set
    # CONFIG_TLS_CREDENTIALS_LOG_LEVEL_DBG is not set
    CONFIG_TLS_CREDENTIALS_LOG_LEVEL_DEFAULT=y
    CONFIG_TLS_CREDENTIALS_LOG_LEVEL=3
    CONFIG_TLS_CREDENTIALS_BACKEND_VOLATILE=y
    # CONFIG_TLS_CREDENTIALS_BACKEND_PROTECTED_STORAGE is not set
    # CONFIG_TLS_CREDENTIAL_FILENAMES is not set
    # CONFIG_NET_SHELL is not set
    # end of Network Libraries
    # Network additional services
    # CONFIG_NET_CAPTURE is not set
    # CONFIG_NET_DHCPV4 is not set
    # CONFIG_NET_DHCPV4_SERVER is not set
    # CONFIG_NET_DHCPV6 is not set
    CONFIG_NET_DHCPV6_DUID_MAX_LEN=22
    # CONFIG_NET_TRICKLE is not set
    # CONFIG_NET_ZPERF is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # end of Network additional services
    # CONFIG_NET_CONNECTION_MANAGER is not set
    # end of Networking
    # Power Management
    # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_OFF is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_ERR is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_WRN is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_INF is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_DBG is not set
    CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT=y
    CONFIG_PM_DEVICE_LOG_LEVEL=3
    # end of Power Management
    # Platform Management Communications Infrastructure (PMCI)
    # CONFIG_MCTP is not set
    # end of Platform Management Communications Infrastructure (PMCI)
    # Portability
    # end of Portability
    # CONFIG_PROFILING is not set
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
    CONFIG_CSPRNG_AVAILABLE=y
    CONFIG_CSPRNG_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    CONFIG_STREAM_FLASH=y
    CONFIG_STREAM_FLASH_INSPECT=y
    CONFIG_STREAM_FLASH_POST_WRITE_CALLBACK=y
    CONFIG_STREAM_FLASH_ERASE=y
    # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_STREAM_FLASH_LOG_LEVEL=3
    # end of Storage
    CONFIG_TASK_WDT=y
    CONFIG_TASK_WDT_CHANNELS=4
    CONFIG_TASK_WDT_HW_FALLBACK=y
    CONFIG_TASK_WDT_MIN_TIMEOUT=10000
    # CONFIG_TASK_WDT_HW_FALLBACK_PAUSE_IN_SLEEP is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # CONFIG_MODULES is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_FLASH_LOAD_SIZE=0x30000
    CONFIG_ROM_END_OFFSET=0x2096
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_ITERABLE_SUBALIGN=4
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_STD_C90 is not set
    CONFIG_STD_C99=y
    # CONFIG_STD_C11 is not set
    # CONFIG_STD_C17 is not set
    # CONFIG_STD_C23 is not set
    CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    # CONFIG_GNU_C_EXTENSIONS is not set
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    # CONFIG_SIZE_OPTIMIZATIONS is not set
    # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    CONFIG_DEBUG_OPTIMIZATIONS=y
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_DEPRECATION_TEST is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    CONFIG_TOOLCHAIN_SUPPORTS_VLA_IN_STATEMENTS=y
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_MOT is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_DEPRECATED=y
    CONFIG_WARN_DEPRECATED=y
    CONFIG_EXPERIMENTAL=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
    # end of Compatibility
    # end of Zephyr Kernel
    nRF91 .dts:
    /dts-v1/;
    /* node '/' defined in zephyr/dts/common/skeleton.dtsi:9 */
    	#address-cells = < 0x1 >;                    /* in zephyr/dts/common/skeleton.dtsi:10 */
    	#size-cells = < 0x1 >;                       /* in zephyr/dts/common/skeleton.dtsi:11 */
    	model = "Low Power Gateway nRF9151";         /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:8 */
    	compatible = "td,low-power-gateway-nrf9151"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:9 */
    	/* node '/chosen' defined in zephyr/dts/common/skeleton.dtsi:12 */
    	chosen {
    		zephyr,entropy = &psa_rng;                   /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:31 */
    		zephyr,flash-controller = &flash_controller; /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:32 */
    		zephyr,bt-uart = &lpuart_ble;                /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:12 */
    		zephyr,bt-hci = &bt_hci_uart;                /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:13 */
    		zephyr,uart_mcumgr = &uart2;                 /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:15 */
    		nordic,pm-ext-flash = &w25q01jv;             /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:138 */
    		zephyr,flash = &flash0;                      /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_ns.dts:10 */
    		zephyr,sram = &sram0_ns;                     /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_ns.dts:11 */
    		zephyr,code-partition = &slot0_ns_partition; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_ns.dts:12 */
    	/* node '/aliases' defined in zephyr/dts/common/skeleton.dtsi:13 */
    	aliases {
    	/* node '/soc' defined in zephyr/dts/arm/armv8-m.dtsi:6 */
    	soc {
    		#address-cells = < 0x1 >;     /* in zephyr/dts/arm/armv8-m.dtsi:7 */
    		#size-cells = < 0x1 >;        /* in zephyr/dts/arm/armv8-m.dtsi:8 */
    		interrupt-parent = < &nvic >; /* in zephyr/dts/arm/armv8-m.dtsi:10 */
    		ranges;                       /* in zephyr/dts/arm/armv8-m.dtsi:11 */
    		compatible = "simple-bus";    /* in zephyr/dts/arm/nordic/nrf9151ns_laca.dtsi:20 */
    		/* node '/soc/interrupt-controller@e000e100' defined in zephyr/dts/arm/armv8-m.dtsi:13 */
    		nvic: interrupt-controller@e000e100 {
    			#address-cells = < 0x1 >;            /* in zephyr/dts/arm/armv8-m.dtsi:14 */
    			compatible = "arm,v8m-nvic";         /* in zephyr/dts/arm/armv8-m.dtsi:15 */
    			reg = < 0xe000e100 0xc00 >;          /* in zephyr/dts/arm/armv8-m.dtsi:16 */
    			interrupt-controller;                /* in zephyr/dts/arm/armv8-m.dtsi:17 */
    			#interrupt-cells = < 0x2 >;          /* in zephyr/dts/arm/armv8-m.dtsi:18 */
    			arm,num-irq-priority-bits = < 0x3 >; /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:70 */
    			phandle = < 0x1 >;                   /* in zephyr/dts/arm/armv8-m.dtsi:10 */
    		/* node '/soc/timer@e000e010' defined in zephyr/dts/arm/armv8-m.dtsi:21 */
    		systick: timer@e000e010 {
    			compatible = "arm,armv8m-systick"; /* in zephyr/dts/arm/armv8-m.dtsi:22 */
    			reg = < 0xe000e010 0x10 >;         /* in zephyr/dts/arm/armv8-m.dtsi:23 */
    			status = "disabled";               /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:75 */
    		/* node '/soc/memory@20000000' defined in zephyr/dts/arm/nordic/nrf91ns.dtsi:36 */
    		sram0: memory@20000000 {
    			compatible = "mmio-sram";     /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:37 */
    			reg = < 0x20000000 0x3f7d8 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:247 */
    		/* node '/soc/peripheral@40000000' defined in zephyr/dts/arm/nordic/nrf91ns.dtsi:40 */
    		peripheral@40000000 {
    			#address-cells = < 0x1 >;               /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:41 */
    			#size-cells = < 0x1 >;                  /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:42 */
    			ranges = < 0x0 0x40000000 0x10000000 >; /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:43 */
    			/* node '/soc/peripheral@40000000/flash-controller@39000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:7 */
    			flash_controller: flash-controller@39000 {
    				compatible = "nordic,nrf91-flash-controller"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:8 */
    				reg = < 0x39000 0x1000 >;                     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:9 */
    				partial-erase;                                /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:10 */
    				#address-cells = < 0x1 >;                     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:12 */
    				#size-cells = < 0x1 >;                        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:13 */
    				/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:15 */
    				flash0: flash@0 {
    					compatible = "soc-nv-flash";   /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:16 */
    					erase-block-size = < 0x1000 >; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:17 */
    					write-block-size = < 0x4 >;    /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:18 */
    					reg = < 0x0 0x100000 >;        /* in zephyr/dts/arm/nordic/nrf9151ns_laca.dtsi:11 */
    					/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:27 */
    					partitions {
    						compatible = "fixed-partitions"; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:28 */
    						#address-cells = < 0x1 >;        /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:29 */
    						#size-cells = < 0x1 >;           /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:30 */
    						/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@0' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:32 */
    						boot_partition: partition@0 {
    							label = "mcuboot";     /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:33 */
    							reg = < 0x0 0x10000 >; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:34 */
    						/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@10000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:37 */
    						slot0_partition: partition@10000 {
    							compatible = "fixed-subpartitions"; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:38 */
    							label = "image-0";                  /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:39 */
    							reg = < 0x10000 0x70000 >;          /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:40 */
    							ranges = < 0x0 0x10000 0x70000 >;   /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:41 */
    							#address-cells = < 0x1 >;           /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:42 */
    							#size-cells = < 0x1 >;              /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:43 */
    							/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@10000/partition@0' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:45 */
    							slot0_s_partition: partition@0 {
    								label = "image-0-secure"; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:46 */
    								reg = < 0x0 0x40000 >;    /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:47 */
    							/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@10000/partition@40000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:50 */
    							slot0_ns_partition: partition@40000 {
    								label = "image-0-nonsecure"; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:51 */
    								reg = < 0x40000 0x30000 >;   /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:52 */
    						/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@80000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:56 */
    						slot1_partition: partition@80000 {
    							compatible = "fixed-subpartitions"; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:57 */
    							label = "image-1";                  /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:58 */
    							reg = < 0x80000 0x70000 >;          /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:59 */
    							ranges = < 0x0 0x80000 0x70000 >;   /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:60 */
    							#address-cells = < 0x1 >;           /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:61 */
    							#size-cells = < 0x1 >;              /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:62 */
    							/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@80000/partition@0' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:64 */
    							slot1_s_partition: partition@0 {
    								label = "image-1-secure"; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:65 */
    								reg = < 0x0 0x40000 >;    /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:66 */
    							/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@80000/partition@40000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:69 */
    							slot1_ns_partition: partition@40000 {
    								label = "image-1-nonsecure"; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:70 */
    								reg = < 0x40000 0x30000 >;   /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:71 */
    						/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@f0000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:75 */
    						tfm_ps_partition: partition@f0000 {
    							label = "tfm-ps";         /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:76 */
    							reg = < 0xf0000 0x4000 >; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:77 */
    						/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@f4000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:80 */
    						tfm_its_partition: partition@f4000 {
    							label = "tfm-its";        /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:81 */
    							reg = < 0xf4000 0x2000 >; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:82 */
    						/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@f6000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:85 */
    						tfm_otp_partition: partition@f6000 {
    							label = "tfm-otp";        /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:86 */
    							reg = < 0xf6000 0x2000 >; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:87 */
    						/* node '/soc/peripheral@40000000/flash-controller@39000/flash@0/partitions/partition@f8000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:90 */
    						storage_partition: partition@f8000 {
    							label = "storage";        /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:91 */
    							reg = < 0xf8000 0x8000 >; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:92 */
    			/* node '/soc/peripheral@40000000/adc@e000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:22 */
    			adc: adc@e000 {
    				compatible = "nordic,nrf-saadc"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:23 */
    				reg = < 0xe000 0x1000 >;         /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:24 */
    				interrupts = < 0xe 0x1 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:25 */
    				status = "disabled";             /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:26 */
    				#io-channel-cells = < 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:27 */
    				zephyr,pm-device-runtime-auto;   /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:28 */
    			/* node '/soc/peripheral@40000000/dppic@17000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:31 */
    			dppic0: dppic: dppic@17000 {
    				compatible = "nordic,nrf-dppic"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:32 */
    				reg = < 0x17000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:33 */
    				status = "okay";                 /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:34 */
    			/* node '/soc/peripheral@40000000/egu@1b000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:37 */
    			egu0: egu@1b000 {
    				compatible = "nordic,nrf-egu"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:38 */
    				reg = < 0x1b000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:39 */
    				interrupts = < 0x1b 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:40 */
    				status = "okay";               /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:41 */
    			/* node '/soc/peripheral@40000000/egu@1c000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:44 */
    			egu1: egu@1c000 {
    				compatible = "nordic,nrf-egu"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:45 */
    				reg = < 0x1c000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:46 */
    				interrupts = < 0x1c 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:47 */
    				status = "okay";               /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:48 */
    			/* node '/soc/peripheral@40000000/egu@1d000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:51 */
    			egu2: egu@1d000 {
    				compatible = "nordic,nrf-egu"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:52 */
    				reg = < 0x1d000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:53 */
    				interrupts = < 0x1d 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:54 */
    				status = "okay";               /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:55 */
    			/* node '/soc/peripheral@40000000/egu@1e000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:58 */
    			egu3: egu@1e000 {
    				compatible = "nordic,nrf-egu"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:59 */
    				reg = < 0x1e000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:60 */
    				interrupts = < 0x1e 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:61 */
    				status = "okay";               /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:62 */
    			/* node '/soc/peripheral@40000000/egu@1f000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:65 */
    			egu4: egu@1f000 {
    				compatible = "nordic,nrf-egu"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:66 */
    				reg = < 0x1f000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:67 */
    				interrupts = < 0x1f 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:68 */
    				status = "okay";               /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:69 */
    			/* node '/soc/peripheral@40000000/egu@20000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:72 */
    			egu5: egu@20000 {
    				compatible = "nordic,nrf-egu"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:73 */
    				reg = < 0x20000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:74 */
    				interrupts = < 0x20 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:75 */
    				status = "okay";               /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:76 */
    			/* node '/soc/peripheral@40000000/ipc@2a000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:79 */
    			ipc: ipc@2a000 {
    				compatible = "nordic,nrf-ipc"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:80 */
    				reg = < 0x2a000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:81 */
    				interrupts = < 0x2a 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:82 */
    				status = "okay";               /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:83 */
    			/* node '/soc/peripheral@40000000/i2s@28000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:86 */
    			i2s0: i2s@28000 {
    				compatible = "nordic,nrf-i2s"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:87 */
    				#address-cells = < 0x1 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:88 */
    				#size-cells = < 0x0 >;         /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:89 */
    				reg = < 0x28000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:90 */
    				interrupts = < 0x28 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:91 */
    				status = "disabled";           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:92 */
    			/* node '/soc/peripheral@40000000/kmu@39000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:95 */
    			kmu: kmu@39000 {
    				compatible = "nordic,nrf-kmu"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:96 */
    				reg = < 0x39000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:97 */
    				interrupts = < 0x39 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:98 */
    				status = "okay";               /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:99 */
    			/* node '/soc/peripheral@40000000/pdm@26000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:102 */
    			pdm0: pdm@26000 {
    				compatible = "nordic,nrf-pdm"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:103 */
    				reg = < 0x26000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:104 */
    				interrupts = < 0x26 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:105 */
    				status = "disabled";           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:106 */
    			/* node '/soc/peripheral@40000000/regulator@4000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:109 */
    			regulators: regulator@4000 {
    				compatible = "nordic,nrf91x-regulators"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:110 */
    				reg = < 0x4000 0x1000 >;                 /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:111 */
    				status = "okay";                         /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:112 */
    			/* node '/soc/peripheral@40000000/vmc@3a000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:115 */
    			vmc: vmc@3a000 {
    				compatible = "nordic,nrf-vmc"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:116 */
    				reg = < 0x3a000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:117 */
    				status = "okay";               /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:118 */
    			/* node '/soc/peripheral@40000000/uart@8000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:121 */
    			uart0: uart@8000 {
    				compatible = "nordic,nrf-uarte"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:122 */
    				reg = < 0x8000 0x1000 >;         /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:123 */
    				interrupts = < 0x8 0x1 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:124 */
    				status = "disabled";             /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:125 */
    			/* node '/soc/peripheral@40000000/uart@9000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:128 */
    			uart1: uart@9000 {
    				compatible = "nordic,nrf-uarte";        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:129 */
    				reg = < 0x9000 0x1000 >;                /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:130 */
    				interrupts = < 0x9 0x1 >;               /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:131 */
    				current-speed = < 0x3d090 >;            /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:94 */
    				status = "okay";                        /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:95 */
    				hw-flow-control;                        /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:96 */
    				pinctrl-0 = < &uart1_default_alt_mon >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:98 */
    				pinctrl-1 = < &uart1_sleep_alt_mon >;   /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:99 */
    				pinctrl-names = "default",
    				                "sleep";                /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:100 */
    				/* node '/soc/peripheral@40000000/uart@9000/nrf-sw-lpuart' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:101 */
    				lpuart_mon: nrf-sw-lpuart {
    					compatible = "nordic,nrf-sw-lpuart"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:102 */
    					status = "okay";                     /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:103 */
    					req-pin = < 0x8 >;                   /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:104 */
    					rdy-pin = < 0x7 >;                   /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:105 */
    					skip-init;                           /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:106 */
    			/* node '/soc/peripheral@40000000/uart@a000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:135 */
    			uart2: uart@a000 {
    				compatible = "nordic,nrf-uarte";    /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:136 */
    				reg = < 0xa000 0x1000 >;            /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:137 */
    				interrupts = < 0xa 0x1 >;           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:138 */
    				current-speed = < 0x3d090 >;        /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:111 */
    				status = "okay";                    /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:112 */
    				hw-flow-control;                    /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:113 */
    				pinctrl-0 = < &uart2_default_alt >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:115 */
    				pinctrl-1 = < &uart2_sleep_alt >;   /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:116 */
    				                "sleep";            /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:117 */
    				/* node '/soc/peripheral@40000000/uart@a000/nrf-sw-lpuart' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:118 */
    				lpuart_ble: nrf-sw-lpuart {
    					compatible = "nordic,nrf-sw-lpuart"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:119 */
    					status = "okay";                     /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:120 */
    					req-pin = < 0x14 >;                  /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:121 */
    					rdy-pin = < 0x15 >;                  /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:122 */
    					skip-init;                           /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:123 */
    					/* node '/soc/peripheral@40000000/uart@a000/nrf-sw-lpuart/bt_hci_uart' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:125 */
    					bt_hci_uart: bt_hci_uart {
    						compatible = "zephyr,bt-hci-uart"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:126 */
    						status = "okay";                   /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:127 */
    			/* node '/soc/peripheral@40000000/uart@b000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:142 */
    			uart3: uart@b000 {
    				compatible = "nordic,nrf-uarte"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:143 */
    				reg = < 0xb000 0x1000 >;         /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:144 */
    				interrupts = < 0xb 0x1 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:145 */
    				status = "disabled";             /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:146 */
    			/* node '/soc/peripheral@40000000/i2c@8000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:149 */
    			i2c0: i2c@8000 {
    				#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:156 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:157 */
    				reg = < 0x8000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:158 */
    				interrupts = < 0x8 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:159 */
    				easydma-maxcnt-bits = < 0xd >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:160 */
    				zephyr,pm-device-runtime-auto;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:162 */
    				compatible = "nordic,nrf-twim"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:161 */
    				status = "okay";                /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:162 */
    				pinctrl-0 = < &i2c0_default >;  /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:163 */
    				pinctrl-1 = < &i2c0_sleep >;    /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:164 */
    				                "sleep";        /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:165 */
    				clock-frequency = < 0x186a0 >;  /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:166 */
    				/* node '/soc/peripheral@40000000/i2c@8000/max7320@5c' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:168 */
    				max7320: max7320@5c {
    					compatible = "maxim,max7320"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:169 */
    					reg = < 0x5c >;               /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:170 */
    					gpio-controller;              /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:171 */
    					ngpios = < 0x8 >;             /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:172 */
    				/* node '/soc/peripheral@40000000/i2c@8000/max7320@5d' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:175 */
    				max7320_2: max7320@5d {
    					compatible = "maxim,max7320"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:176 */
    					reg = < 0x5d >;               /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:177 */
    					gpio-controller;              /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:178 */
    					ngpios = < 0x8 >;             /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:179 */
    				/* node '/soc/peripheral@40000000/i2c@8000/bq34z100r2@55' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:182 */
    				bq34z100r2: bq34z100r2@55 {
    					compatible = "ti,bq34z100r2"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:183 */
    					reg = < 0x55 >;               /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:184 */
    				/* node '/soc/peripheral@40000000/i2c@8000/pcf8523@68' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:187 */
    				pcf8523: pcf8523@68 {
    					compatible = "nxp,pcf8523";           /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:188 */
    					reg = < 0x68 >;                       /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:189 */
    					battery-switch-over = "standard";     /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:190 */
    					alarms-count = < 0x1 >;               /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:191 */
    					clkout-frequency = < 0x0 >;           /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:192 */
    					quartz-load-femtofarads = < 0x1b58 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:193 */
    				/* node '/soc/peripheral@40000000/i2c@8000/bma400@14' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:196 */
    				bma400: bma400@14 {
    					compatible = "bosch,bma4xx"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:197 */
    					reg = < 0x14 >;              /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:198 */
    			/* node '/soc/peripheral@40000000/i2c@9000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:165 */
    			i2c1: i2c@9000 {
    				compatible = "nordic,nrf-twim"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:171 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:172 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:173 */
    				reg = < 0x9000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:174 */
    				interrupts = < 0x9 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:175 */
    				easydma-maxcnt-bits = < 0xd >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:176 */
    				status = "disabled";            /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:177 */
    				zephyr,pm-device-runtime-auto;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:178 */
    			/* node '/soc/peripheral@40000000/i2c@a000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:181 */
    			i2c2: i2c@a000 {
    				compatible = "nordic,nrf-twim"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:187 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:188 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:189 */
    				reg = < 0xa000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:190 */
    				interrupts = < 0xa 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:191 */
    				easydma-maxcnt-bits = < 0xd >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:192 */
    				status = "disabled";            /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:193 */
    				zephyr,pm-device-runtime-auto;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:194 */
    			/* node '/soc/peripheral@40000000/i2c@b000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:197 */
    			i2c3: i2c@b000 {
    				compatible = "nordic,nrf-twim"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:203 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:204 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:205 */
    				reg = < 0xb000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:206 */
    				interrupts = < 0xb 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:207 */
    				easydma-maxcnt-bits = < 0xd >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:208 */
    				status = "disabled";            /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:209 */
    				zephyr,pm-device-runtime-auto;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:210 */
    			/* node '/soc/peripheral@40000000/spi@8000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:213 */
    			spi0: spi@8000 {
    				compatible = "nordic,nrf-spim"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:219 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:220 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:221 */
    				reg = < 0x8000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:222 */
    				interrupts = < 0x8 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:223 */
    				max-frequency = < 0x7a1200 >;   /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:224 */
    				easydma-maxcnt-bits = < 0xd >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:225 */
    				status = "disabled";            /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:226 */
    			/* node '/soc/peripheral@40000000/spi@9000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:229 */
    			spi1: spi@9000 {
    				compatible = "nordic,nrf-spim"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:235 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:236 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:237 */
    				reg = < 0x9000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:238 */
    				interrupts = < 0x9 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:239 */
    				max-frequency = < 0x7a1200 >;   /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:240 */
    				easydma-maxcnt-bits = < 0xd >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:241 */
    				status = "disabled";            /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:242 */
    			/* node '/soc/peripheral@40000000/spi@a000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:245 */
    			spi2: spi@a000 {
    				compatible = "nordic,nrf-spim"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:251 */
    				#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:252 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:253 */
    				reg = < 0xa000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:254 */
    				interrupts = < 0xa 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:255 */
    				max-frequency = < 0x7a1200 >;   /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:256 */
    				easydma-maxcnt-bits = < 0xd >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:257 */
    				status = "disabled";            /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:258 */
    			/* node '/soc/peripheral@40000000/spi@b000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:261 */
    			spi3: spi@b000 {
    				#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:268 */
    				#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:269 */
    				reg = < 0xb000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:270 */
    				interrupts = < 0xb 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:271 */
    				max-frequency = < 0x7a1200 >;   /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:272 */
    				easydma-maxcnt-bits = < 0xd >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:273 */
    				compatible = "nordic,nrf-spim"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:143 */
    				status = "okay";                /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:144 */
    				cs-gpios = < &gpio0 0x4 0x1 >;  /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:145 */
    				pinctrl-0 = < &spi3_default >;  /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:146 */
    				pinctrl-1 = < &spi3_sleep >;    /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:147 */
    				                "sleep";        /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:148 */
    				/* node '/soc/peripheral@40000000/spi@b000/w25q01jv@0' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:149 */
    				w25q01jv: w25q01jv@0 {
    					compatible = "jedec,spi-nor";     /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:150 */
    					reg = < 0x0 >;                    /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:151 */
    					spi-max-frequency = < 0x7a1200 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:152 */
    					jedec-id = [ EF 40 21 ];          /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:153 */
    					size = < 0x40000000 >;            /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:154 */
    					enter-4byte-addr = < 0x1 >;       /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:155 */
    					page-size = < 0x100 >;            /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:156 */
    			/* node '/soc/peripheral@40000000/pwm@21000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:277 */
    			pwm0: pwm@21000 {
    				compatible = "nordic,nrf-pwm"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:278 */
    				reg = < 0x21000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:279 */
    				interrupts = < 0x21 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:280 */
    				status = "disabled";           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:281 */
    				#pwm-cells = < 0x3 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:282 */
    			/* node '/soc/peripheral@40000000/pwm@22000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:285 */
    			pwm1: pwm@22000 {
    				compatible = "nordic,nrf-pwm"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:286 */
    				reg = < 0x22000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:287 */
    				interrupts = < 0x22 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:288 */
    				status = "disabled";           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:289 */
    				#pwm-cells = < 0x3 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:290 */
    			/* node '/soc/peripheral@40000000/pwm@23000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:293 */
    			pwm2: pwm@23000 {
    				compatible = "nordic,nrf-pwm"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:294 */
    				reg = < 0x23000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:295 */
    				interrupts = < 0x23 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:296 */
    				status = "disabled";           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:297 */
    				#pwm-cells = < 0x3 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:298 */
    			/* node '/soc/peripheral@40000000/pwm@24000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:301 */
    			pwm3: pwm@24000 {
    				compatible = "nordic,nrf-pwm"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:302 */
    				reg = < 0x24000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:303 */
    				interrupts = < 0x24 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:304 */
    				status = "disabled";           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:305 */
    				#pwm-cells = < 0x3 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:306 */
    			/* node '/soc/peripheral@40000000/gpio@842500' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:309 */
    			gpio0: gpio@842500 {
    				compatible = "nordic,nrf-gpio"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:310 */
    				gpio-controller;                /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:311 */
    				reg = < 0x842500 0x300 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:312 */
    				#gpio-cells = < 0x2 >;          /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:313 */
    				port = < 0x0 >;                 /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:315 */
    				gpiote-instance = < &gpiote >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:316 */
    				status = "okay";                /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:133 */
    				phandle = < 0x8 >;              /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:145 */
    			/* node '/soc/peripheral@40000000/rtc@14000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:319 */
    			rtc0: rtc@14000 {
    				compatible = "nordic,nrf-rtc"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:320 */
    				reg = < 0x14000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:321 */
    				cc-num = < 0x4 >;              /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:322 */
    				interrupts = < 0x14 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:323 */
    				status = "disabled";           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:324 */
    				clock-frequency = < 0x8000 >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:325 */
    				prescaler = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:326 */
    			/* node '/soc/peripheral@40000000/rtc@15000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:329 */
    			rtc1: rtc@15000 {
    				compatible = "nordic,nrf-rtc"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:330 */
    				reg = < 0x15000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:331 */
    				cc-num = < 0x4 >;              /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:332 */
    				interrupts = < 0x15 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:333 */
    				status = "disabled";           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:334 */
    				clock-frequency = < 0x8000 >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:335 */
    				prescaler = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:336 */
    			/* node '/soc/peripheral@40000000/clock@5000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:339 */
    			clock: clock@5000 {
    				compatible = "nordic,nrf-clock"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:340 */
    				reg = < 0x5000 0x1000 >;         /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:341 */
    				interrupts = < 0x5 0x1 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:342 */
    				status = "okay";                 /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:343 */
    			/* node '/soc/peripheral@40000000/power@5000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:346 */
    			power: power@5000 {
    				compatible = "nordic,nrf-power"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:347 */
    				reg = < 0x5000 0x1000 >;         /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:348 */
    				ranges = < 0x0 0x5000 0x1000 >;  /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:349 */
    				interrupts = < 0x5 0x1 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:350 */
    				status = "okay";                 /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:351 */
    				#address-cells = < 0x1 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:352 */
    				#size-cells = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:353 */
    				/* node '/soc/peripheral@40000000/power@5000/gpregret1@51c' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:355 */
    				gpregret1: gpregret1@51c {
    					#address-cells = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:356 */
    					#size-cells = < 0x1 >;              /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:357 */
    					compatible = "nordic,nrf-gpregret"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:358 */
    					reg = < 0x51c 0x1 >;                /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:359 */
    					status = "okay";                    /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:360 */
    				/* node '/soc/peripheral@40000000/power@5000/gpregret2@520' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:363 */
    				gpregret2: gpregret2@520 {
    					#address-cells = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:364 */
    					#size-cells = < 0x1 >;              /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:365 */
    					compatible = "nordic,nrf-gpregret"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:366 */
    					reg = < 0x520 0x1 >;                /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:367 */
    					status = "okay";                    /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:368 */
    			/* node '/soc/peripheral@40000000/watchdog@18000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:372 */
    			wdt: wdt0: watchdog@18000 {
    				compatible = "nordic,nrf-wdt"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:373 */
    				reg = < 0x18000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:374 */
    				interrupts = < 0x18 0x1 >;     /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:375 */
    				status = "okay";               /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:203 */
    			/* node '/soc/peripheral@40000000/timer@f000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:379 */
    			timer0: timer@f000 {
    				compatible = "nordic,nrf-timer"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:380 */
    				status = "disabled";             /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:381 */
    				reg = < 0xf000 0x1000 >;         /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:382 */
    				cc-num = < 0x6 >;                /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:383 */
    				max-bit-width = < 0x20 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:384 */
    				interrupts = < 0xf 0x1 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:385 */
    				prescaler = < 0x0 >;             /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:386 */
    			/* node '/soc/peripheral@40000000/timer@10000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:389 */
    			timer1: timer@10000 {
    				compatible = "nordic,nrf-timer"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:390 */
    				status = "disabled";             /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:391 */
    				reg = < 0x10000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:392 */
    				cc-num = < 0x6 >;                /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:393 */
    				max-bit-width = < 0x20 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:394 */
    				interrupts = < 0x10 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:395 */
    				prescaler = < 0x0 >;             /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:396 */
    				phandle = < 0xc >;               /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:42 */
    			/* node '/soc/peripheral@40000000/timer@11000' defined in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:399 */
    			timer2: timer@11000 {
    				compatible = "nordic,nrf-timer"; /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:400 */
    				status = "disabled";             /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:401 */
    				reg = < 0x11000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:402 */
    				cc-num = < 0x6 >;                /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:403 */
    				max-bit-width = < 0x20 >;        /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:404 */
    				interrupts = < 0x11 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:405 */
    				prescaler = < 0x0 >;             /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:406 */
    		/* node '/soc/gpiote@40031000' defined in zephyr/dts/arm/nordic/nrf91ns.dtsi:54 */
    		gpiote: gpiote1: gpiote@40031000 {
    			compatible = "nordic,nrf-gpiote"; /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:55 */
    			reg = < 0x40031000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:56 */
    			instance = < 0x1 >;               /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:59 */
    			status = "okay";                  /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:88 */
    			interrupts = < 0x31 0x1 >;        /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:89 */
    			phandle = < 0xb >;                /* in zephyr/dts/arm/nordic/nrf91_peripherals.dtsi:316 */
    	/* node '/pin-controller' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:26 */
    	pinctrl: pin-controller {
    		compatible = "nordic,nrf-pinctrl"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:31 */
    		/* node '/pin-controller/uart2_default_alt' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:5 */
    		uart2_default_alt: uart2_default_alt {
    			phandle = < 0x4 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:115 */
    			/* node '/pin-controller/uart2_default_alt/group1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:6 */
    			group1 {
    				psels = < 0x12 >,
    				        < 0x1000011 >,
    				        < 0x3000015 >,
    				        < 0x2000014 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:7 */
    		/* node '/pin-controller/uart2_sleep_alt' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:14 */
    		uart2_sleep_alt: uart2_sleep_alt {
    			phandle = < 0x5 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:116 */
    			/* node '/pin-controller/uart2_sleep_alt/group1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:15 */
    			group1 {
    				psels = < 0x12 >,
    				        < 0x1000011 >,
    				        < 0x3000015 >,
    				        < 0x2000014 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:16 */
    				low-power-enable;      /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:20 */
    		/* node '/pin-controller/uart1_default_alt_mon' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:24 */
    		uart1_default_alt_mon: uart1_default_alt_mon {
    			phandle = < 0x2 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:98 */
    			/* node '/pin-controller/uart1_default_alt_mon/group1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:25 */
    			group1 {
    				psels = < 0x6 >,
    				        < 0x1000005 >,
    				        < 0x3000007 >,
    				        < 0x2000008 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:26 */
    		/* node '/pin-controller/uart1_sleep_alt_mon' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:33 */
    		uart1_sleep_alt_mon: uart1_sleep_alt_mon {
    			phandle = < 0x3 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:99 */
    			/* node '/pin-controller/uart1_sleep_alt_mon/group1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:34 */
    			group1 {
    				psels = < 0x6 >,
    				        < 0x1000005 >,
    				        < 0x3000007 >,
    				        < 0x2000008 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:35 */
    				low-power-enable;      /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:39 */
    		/* node '/pin-controller/uart1_default_alt_iridium' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:43 */
    		uart1_default_alt_iridium: uart1_default_alt_iridium {
    			phandle = < 0xd >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:81 */
    			/* node '/pin-controller/uart1_default_alt_iridium/group1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:44 */
    			group1 {
    				psels = < 0x1b >,
    				        < 0x100001a >,
    				        < 0x300001d >,
    				        < 0x200001c >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:45 */
    		/* node '/pin-controller/uart1_sleep_alt_iridium' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:52 */
    		uart1_sleep_alt_iridium: uart1_sleep_alt_iridium {
    			phandle = < 0xe >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:82 */
    			/* node '/pin-controller/uart1_sleep_alt_iridium/group1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:53 */
    			group1 {
    				psels = < 0x1b >,
    				        < 0x100001a >,
    				        < 0x300001d >,
    				        < 0x200001c >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:54 */
    				low-power-enable;      /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:58 */
    		/* node '/pin-controller/spi3_default' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:62 */
    		spi3_default: spi3_default {
    			phandle = < 0x9 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:146 */
    			/* node '/pin-controller/spi3_default/group1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:63 */
    			group1 {
    				psels = < 0x6000002 >,
    				        < 0x5000001 >,
    				        < 0x4000000 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:64 */
    		/* node '/pin-controller/spi3_sleep' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:70 */
    		spi3_sleep: spi3_sleep {
    			phandle = < 0xa >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:147 */
    			/* node '/pin-controller/spi3_sleep/group1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:71 */
    			group1 {
    				        < 0x5000001 >,
    				        < 0x4000000 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:72 */
    				low-power-enable;      /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:75 */
    		/* node '/pin-controller/i2c0_default' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:79 */
    		i2c0_default: i2c0_default {
    			phandle = < 0x6 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:163 */
    			/* node '/pin-controller/i2c0_default/group1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:80 */
    			group1 {
    				psels = < 0xc00001e >,
    				        < 0xb00001f >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:81 */
    		/* node '/pin-controller/i2c0_sleep' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:86 */
    		i2c0_sleep: i2c0_sleep {
    			phandle = < 0x7 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:164 */
    			/* node '/pin-controller/i2c0_sleep/group1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:87 */
    			group1 {
    				        < 0xb00001f >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:88 */
    				low-power-enable;      /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common-pinctrl.dtsi:90 */
    	/* node '/entropy_bt_hci' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:34 */
    	rng_hci: entropy_bt_hci {
    		compatible = "zephyr,bt-hci-entropy"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:35 */
    		status = "disabled";                  /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:36 */
    	/* node '/sw-pwm' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:39 */
    	sw_pwm: sw-pwm {
    		compatible = "nordic,nrf-sw-pwm"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:40 */
    		status = "disabled";              /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:41 */
    		generator = < &timer1 >;          /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:42 */
    		clock-prescaler = < 0x0 >;        /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:43 */
    		#pwm-cells = < 0x3 >;             /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:44 */
    	/* node '/cpus' defined in zephyr/dts/arm/nordic/nrf91ns.dtsi:12 */
    	cpus {
    		#address-cells = < 0x1 >; /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:13 */
    		#size-cells = < 0x0 >;    /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:14 */
    		/* node '/cpus/cpu@0' defined in zephyr/dts/arm/nordic/nrf91ns.dtsi:16 */
    		cpu@0 {
    			device_type = "cpu";            /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:17 */
    			compatible = "arm,cortex-m33f"; /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:18 */
    			reg = < 0x0 >;                  /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:19 */
    			#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:20 */
    			#size-cells = < 0x1 >;          /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:21 */
    			/* node '/cpus/cpu@0/mpu@e000ed90' defined in zephyr/dts/arm/nordic/nrf91ns.dtsi:23 */
    			mpu: mpu@e000ed90 {
    				compatible = "arm,armv8m-mpu"; /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:24 */
    				reg = < 0xe000ed90 0x40 >;     /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:25 */
    	/* node '/psa-rng' defined in zephyr/dts/arm/nordic/nrf91ns.dtsi:63 */
    	psa_rng: psa-rng {
    		compatible = "zephyr,psa-crypto-rng"; /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:64 */
    		status = "okay";                      /* in zephyr/dts/arm/nordic/nrf91ns.dtsi:65 */
    	/* node '/lpg_gpios' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:19 */
    	lpg_gpios {
    		compatible = "td,gpios"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:20 */
    		/* node '/lpg_gpios/max7320_rst' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:21 */
    		max7320_rst: max7320_rst {
    			gpios = < &gpio0 0xf 0x0 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:22 */
    			label = "max7320 reset";    /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:23 */
    		/* node '/lpg_gpios/lte_sel' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:26 */
    		lte_sel: lte_sel {
    			gpios = < &gpio0 0x16 0x0 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:27 */
    			label = "lte select";        /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:28 */
    		/* node '/lpg_gpios/debug_pin' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:31 */
    		debug_pin: debug_pin {
    			gpios = < &gpio0 0x13 0x0 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:32 */
    			label = "debug pin";         /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:33 */
    		/* node '/lpg_gpios/nrf52_bt_vcc' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:36 */
    		nrf52_bt_vcc: nrf52_bt_vcc {
    			gpios = < &gpio0 0x10 0x0 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:37 */
    			label = "nrf52_bt_vcc pin";  /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:38 */
    		/* node '/lpg_gpios/nrf52_bt_trig' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:41 */
    		nrf52_bt_trig: nrf52_bt_trig {
    			gpios = < &gpio0 0xd 0x0 >;  /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:42 */
    			label = "nrf52_bt_trig pin"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:43 */
    		/* node '/lpg_gpios/nrf52_bt_wake' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:46 */
    		nrf52_bt_wake: nrf52_bt_wake {
    			gpios = < &gpio0 0xe 0x0 >;  /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:47 */
    			label = "nrf52_bt_wake pin"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:48 */
    		/* node '/lpg_gpios/bma400_int_1' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:51 */
    		bma400_int_1: bma400_int_1 {
    			gpios = < &gpio0 0xb 0x0 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:52 */
    			label = "bma400_int_1 pin"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:53 */
    		/* node '/lpg_gpios/bma400_int_2' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:56 */
    		bma400_int_2: bma400_int_2 {
    			gpios = < &gpio0 0xc 0x0 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:57 */
    			label = "bma400_int_2 pin"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:58 */
    		/* node '/lpg_gpios/nrf52_mon_trig' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:61 */
    		nrf52_mon_trig: nrf52_mon_trig {
    			gpios = < &gpio0 0xa 0x0 >;   /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:62 */
    			label = "nrf52_mon_trig pin"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:63 */
    		/* node '/lpg_gpios/nrf52_mon_wake' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:66 */
    		nrf52_mon_wake: nrf52_mon_wake {
    			gpios = < &gpio0 0x9 0x0 >;   /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:67 */
    			label = "nrf52_mon_wake pin"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:68 */
    		/* node '/lpg_gpios/psram_cs' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:71 */
    		psram_cs: psram_cs {
    			gpios = < &gpio0 0x3 0x0 >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:72 */
    			label = "psram_cs pin";     /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:73 */
    	/* node '/zephyr,user' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:78 */
    	zephyr,user {
    		uart1_default_alt_mon = < &uart1_default_alt_mon >;         /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:79 */
    		uart1_sleep_alt_mon = < &uart1_sleep_alt_mon >;             /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:80 */
    		uart1_default_alt_iridium = < &uart1_default_alt_iridium >; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:81 */
    		uart1_sleep_alt_iridium = < &uart1_sleep_alt_iridium >;     /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:82 */
    		uart1-baud-iridium = < 0x4b00 >;                            /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:83 */
    	/* node '/sram@2003F7D8' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:207 */
    	app_noinit: sram@2003F7D8 {
    		compatible = "zephyr,memory-region"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:208 */
    		reg = < 0x2003f7d8 0x828 >;          /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:209 */
    		zephyr,memory-region = "app_noinit"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:210 */
    		status = "okay";                     /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:211 */
    		/* node '/sram@2003F7D8/retainedmem' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:213 */
    		retainedmem {
    			compatible = "zephyr,retained-ram"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:214 */
    			status = "okay";                    /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:215 */
    			#address-cells = < 0x1 >;           /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:216 */
    			#size-cells = < 0x1 >;              /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:217 */
    			/* node '/sram@2003F7D8/retainedmem/retention@0' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:219 */
    			td_log_memory: retention@0 {
    				compatible = "zephyr,retention"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:220 */
    				status = "okay";                 /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:221 */
    				reg = < 0x0 0x800 >;             /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:222 */
    			/* node '/sram@2003F7D8/retainedmem/retention@800' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:225 */
    			lpg_safeboot_memory: retention@800 {
    				compatible = "zephyr,retention"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:226 */
    				status = "okay";                 /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:227 */
    				reg = < 0x800 0x14 >;            /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:228 */
    			/* node '/sram@2003F7D8/retainedmem/retention@814' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:231 */
    			lpg_format_fs_memory: retention@814 {
    				compatible = "zephyr,retention"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:232 */
    				status = "okay";                 /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:233 */
    				reg = < 0x814 0x4 >;             /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:234 */
    			/* node '/sram@2003F7D8/retainedmem/retention@818' defined in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:237 */
    			gnss_assistance_memory: retention@818 {
    				compatible = "zephyr,retention"; /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:238 */
    				status = "okay";                 /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:239 */
    				reg = < 0x818 0x10 >;            /* in td1159-low-power-gateway-91/boards/td/low_power_gateway_nrf9151/low_power_gateway_nrf9151_common.dtsi:240 */
    	/* node '/reserved-memory' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:107 */
    	reserved-memory {
    		#address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:108 */
    		#size-cells = < 0x1 >;    /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:109 */
    		ranges;                   /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:110 */
    		/* node '/reserved-memory/image_s@20000000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:112 */
    		sram0_s: image_s@20000000 {
    			reg = < 0x20000000 0x16000 >; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:114 */
    		/* node '/reserved-memory/image_ns@20016000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:117 */
    		sram0_ns: image_ns@20016000 {
    			reg = < 0x20016000 0x2a000 >; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:119 */
    		/* node '/reserved-memory/image_ns_modem@20016000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:122 */
    		sram0_ns_modem: image_ns_modem@20016000 {
    			reg = < 0x20016000 0xa000 >; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:124 */
    		/* node '/reserved-memory/image_ns_app@20020000' defined in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:127 */
    		sram0_ns_app: image_ns_app@20020000 {
    			reg = < 0x20020000 0x20000 >; /* in zephyr/dts/vendor/nordic/nrf91xx_partition.dtsi:129 */
    nRF52840 .config:
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_REGULATOR is not set
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
    CONFIG_BT_LONG_WQ_STACK_SIZE=1024
    CONFIG_MAIN_STACK_SIZE=1024
    # CONFIG_FPU is not set
    CONFIG_BT_RX_STACK_SIZE=768
    CONFIG_SERIAL=y
    # CONFIG_SPI is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MEMC is not set
    # CONFIG_MODEM is not set
    CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
    CONFIG_BT_HCI_VS=y
    CONFIG_BT_CTLR=y
    CONFIG_NUM_IRQS=48
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_SOC_RESET_HOOK=y
    CONFIG_CLOCK_CONTROL=y
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_ROM_START_OFFSET=0
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_XIP=y
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_COUNTER is not set
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_CPU_HAS_ARM_MPU=y
    # CONFIG_SHARED_INTERRUPTS is not set
    # CONFIG_PM_DEVICE is not set
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_USE_DT_CODE_PARTITION=y
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_ZERO_LATENCY_IRQS=y
    CONFIG_ZERO_LATENCY_LEVELS=1
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_INIT_STACKS is not set
    CONFIG_TIMESLICE_SIZE=20
    CONFIG_FLASH_LOAD_OFFSET=0xc000
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    # CONFIG_BUILD_OUTPUT_S19 is not set
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_FLASH_FILL_BUFFER_SIZE=32
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_FLASH=y
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set
    # CONFIG_HCI_NXP_SET_CAL_DATA is not set
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_ACL_TX_COUNT=7
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_MFD is not set
    # CONFIG_HCI_NXP_RX_THREAD is not set
    CONFIG_GPIO=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    # CONFIG_CACHE is not set
    # CONFIG_LOG is not set
    CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_ROMSTART_RELOCATION_ROM is not set
    CONFIG_DCACHE_LINE_SIZE=32
    # CONFIG_RESET is not set
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    # CONFIG_ASSERT is not set
    # CONFIG_DEVICE_DEPS is not set
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    # CONFIG_SYSCON is not set
    # CONFIG_CONSOLE is not set
    # CONFIG_WINSTREAM is not set
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_GEN_SW_ISR_TABLE=y
    # CONFIG_REBOOT is not set
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_GEN_IRQ_START_VECTOR=0
    CONFIG_SRAM_OFFSET=0
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
    CONFIG_BOOTLOADER_MCUBOOT=y
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_KERNEL_MEM_POOL=y
    CONFIG_MULTITHREADING=y
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    # CONFIG_WATCHDOG is not set
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_BUF_EVT_RX_SIZE=68
    CONFIG_BT_BUF_ACL_TX_SIZE=251
    CONFIG_BT_BUF_ACL_RX_SIZE=251
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
    CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GENERIC_FEM_TWO_CTRL_PINS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SW_LPUART_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF52_HFXO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
    CONFIG_DT_HAS_SKYWORKS_SKY66112_11_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    # end of Devicetree Info
    # Modules
    # CONFIG_BUILD_ONLY_NO_BLOBS is not set
    # Available modules.
    # td1159-low-power-gateway-52 (/Users/filiprosik/Project/LPG_52/td1159-low-power-gateway-52)
    CONFIG_ZEPHYR_TD1159_LOW_POWER_GATEWAY_52_MODULE=y
    # end of td1159-low-power-gateway-52 (/Users/filiprosik/Project/LPG_52/td1159-low-power-gateway-52)
    # nrf (/Users/filiprosik/Project/LPG_52/nrf)
    # CONFIG_NRF_802154_RADIO_DRIVER is not set
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    # CONFIG_ZMS is not set
    # CONFIG_NVS is not set
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_NRF_SECURITY_ENABLER=y
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU is not set
    # CONFIG_IMG_ERASE_PROGRESSIVELY is not set
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    # Subsystems
    # Bootloader
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
    CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
    # CONFIG_NCS_MCUBOOT_BOOTLOADER_SIGN_MERGED_BINARY is not set
    # CONFIG_NCS_MCUBOOT_MANIFEST_UPDATES is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_COMPANY_ID_NORDIC=0x0059
    CONFIG_BT_COMPANY_ID=0x0059
    CONFIG_BT_MAX_CONN=1
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_LL_SOFTDEVICE=y
    # SoftDevice Controller
    CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1536
    # CONFIG_BT_CTLR_SDC_LLPM is not set
    # CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
    # CONFIG_BT_CTLR_SDC_ALLOW_PARALLEL_SCANNING_AND_INITIATING is not set
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
    # CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT=y
    CONFIG_BT_CTLR_SDC_CENTRAL_ACL_EVENT_SPACING_DEFAULT=7500
    # CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
    CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PRIO=6
    # CONFIG_BT_CTLR_DF is not set
    CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y
    CONFIG_BT_CTLR_FAL_SIZE=8
    # CONFIG_BT_CTLR_SDC_EVENT_TRIGGER is not set
    # CONFIG_BT_CTLR_SDC_CONN_ANCHOR_POINT_REPORT is not set
    # CONFIG_BT_CTLR_FRAME_SPACE_UPDATE is not set
    # CONFIG_BT_CTLR_CHANNEL_SOUNDING is not set
    # CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING is not set
    CONFIG_BT_CTLR_SDC_LE_POWER_CLASS_1=y
    CONFIG_BT_LL_SOFTDEVICE_INIT_PRIORITY=40
    # end of SoftDevice Controller
    # CONFIG_BT_RADIO_NOTIFICATION_CONN_CB is not set
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_SCAN is not set
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # end of Bluetooth Services
    # BLE over nRF RPC
    CONFIG_HEAP_MEM_POOL_SIZE=0
    # CONFIG_BT_SHELL is not set
    CONFIG_BT_CONN_DYNAMIC_CALLBACKS=y
    # CONFIG_BT_RPC_STACK is not set
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_OBSERVER=y
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    CONFIG_BT_REMOTE_VERSION=y
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    # CONFIG_BT_EXT_ADV is not set
    CONFIG_BT_BUF_ACL_RX_COUNT_EXTRA=1
    CONFIG_BT_HAS_HCI_VS=y
    # CONFIG_BT_HCI_MESH_EXT is not set
    CONFIG_BT_WAIT_NOP=y
    CONFIG_BT_RPA=y
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    # CONFIG_BT_HCI_ERR_TO_STR is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_LONG_WQ is not set
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_CONN_TX_NOTIFY_WQ is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # CONFIG_NRF_CLOUD is not set
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOADER is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # CONFIG_OPENTHREAD_RPC is not set
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # CONFIG_NFC_RPC is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_NRF_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    CONFIG_PPI_TRACE_PIN_CNT=8
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    CONFIG_MPSL_FEM_ANY_SUPPORT=y
    CONFIG_MPSL_FEM_GENERIC_TWO_CTRL_PINS_SUPPORT=y
    CONFIG_MPSL_FEM_NCS_SUPPORTED_FEM_USED=y
    CONFIG_MPSL_FEM_API_AVAILABLE=y
    CONFIG_MPSL_FEM=y
    CONFIG_MPSL_FEM_SIMPLE_GPIO=y
    # CONFIG_MPSL_FEM_POWER_MODEL is not set
    CONFIG_MPSL_FEM_DEVICE_CONFIG_254=y
    CONFIG_MPSL_FEM_INIT_PRIORITY=50
    CONFIG_MPSL_THREAD_COOP_PRIO=6
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=25
    CONFIG_MPSL_HFCLK_LATENCY=1400
    CONFIG_MPSL_INIT_PRIORITY=40
    # CONFIG_MPSL_USE_EXTERNAL_CLOCK_CONTROL is not set
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_SIZE=256
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x40000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # Full Modem Firmware Update Management(FMFU)
    # end of Full Modem Firmware Update Management(FMFU)
    # Additional MCUmgr configuration
    # Additional MCUmgr group configuration
    # Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr OS group management functionality
    # Additional MCUmgr image management group functionality
    # end of Additional MCUmgr image management group functionality
    # end of Additional MCUmgr group configuration
    # end of Additional MCUmgr configuration
    # CONFIG_CAF is not set
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # Nordic-added meta types
    # Nordic added alg types
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # CONFIG_PSA_WANT_ALG_HSS is not set
    # CONFIG_PSA_WANT_ALG_LMS is not set
    # CONFIG_PSA_WANT_ALG_ML_DSA is not set
    # CONFIG_PSA_WANT_ALG_XMSS is not set
    # CONFIG_PSA_WANT_ALG_XMSS_MT is not set
    # CONFIG_PSA_WANT_ALG_ML_KEM is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_SHA_256_192 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20 is not set
    # CONFIG_PSA_WANT_ALG_XCHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE128_256 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_192 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_256 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_AES_KW is not set
    # CONFIG_PSA_WANT_ALG_AES_KWP is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE_H2E is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE is not set
    # Nordic added ECC curve types
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # Nordic addded RNG configuration
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # Nordic added key types
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XCHACHA20 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HSS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_LMS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XMSS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XMSS_MT_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_44 is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_65 is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_87 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_512 is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_768 is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_PUBLIC_KEY is not set
    # end of nRF Security
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEST is not set
    # Log levels
    # end of Log levels
    # end of Audio Modules
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEMPLATE is not set
    # CONFIG_UART_ASYNC_ADAPTER is not set
    # CONFIG_TRUSTED_STORAGE is not set
    # Logging over RPC
    CONFIG_LOG_BACKED_RPC_CRASH_INFO_FILENAME_SIZE=1
    # end of Logging over RPC
    # CONFIG_DULT is not set
    # CONFIG_NRF_COMPRESS is not set
    # MCUboot IDs (informative only, do not change)
    CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0
    CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=1
    CONFIG_MCUBOOT_EXTRA_1_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_EXTRA_2_IMAGE_NUMBER=-1
    # end of MCUboot IDs (informative only, do not change)
    # end of Subsystems
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # CONFIG_APP_JWT is not set
    # Binary libraries
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
    CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_PARSER is not set
    CONFIG_MULTITHREADING_LOCK=y
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    # CONFIG_HW_UNIQUE_KEY_LOAD is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    CONFIG_NCS_BOOT_BANNER=y
    CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="My Application"
    CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
    CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_ENTROPY_CC3XX=y
    # CONFIG_FLASH_RPC is not set
    CONFIG_HW_CC3XX=y
    CONFIG_CLOCK_CONTROL_MPSL=y
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_RPC is not set
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_NORMAL_PRIORITY_TIMEOUT_US=10000
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_RPC_CONTROLLER is not set
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=1
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    CONFIG_NRF_SW_LPUART=y
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=2
    CONFIG_NRF_SW_LPUART_INIT_PRIORITY=45
    CONFIG_NRF_SW_LPUART_HFXO_ON_RX=y
    CONFIG_NRF_SW_LPUART_MAX_PACKET_SIZE=270
    CONFIG_NRF_SW_LPUART_DEFAULT_TX_TIMEOUT=1000000
    CONFIG_NRF_SW_LPUART_INT_DRIVEN=y
    CONFIG_NRF_SW_LPUART_INT_DRV_TX_BUF_SIZE=270
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # CONFIG_MOCK_NRF_RPC is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/Users/filiprosik/Project/LPG_52/nrf)
    # mcuboot (/Users/filiprosik/Project/LPG_52/bootloader/mcuboot)
    # MCUboot
    CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (/Users/filiprosik/Project/LPG_52/bootloader/mcuboot)
    # cmsis_6 (/Users/filiprosik/Project/LPG_52/modules/hal/cmsis_6)
    CONFIG_ZEPHYR_CMSIS_6_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis_6 (/Users/filiprosik/Project/LPG_52/modules/hal/cmsis_6)
    # hal_nordic (/Users/filiprosik/Project/LPG_52/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_RADIO is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # CONFIG_NRFX_CLOCK is not set
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE0=y
    CONFIG_NRFX_GPPI=y
    # CONFIG_NRFX_GPPI_V1 is not set
    # CONFIG_NRFX_I2S is not set
    # CONFIG_NRFX_LPCOMP is not set
    # CONFIG_NRFX_NFCT is not set
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM is not set
    # CONFIG_NRFX_QDEC is not set
    # CONFIG_NRFX_QSPI is not set
    # CONFIG_NRFX_RNG is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_RTC2 is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPI0 is not set
    # CONFIG_NRFX_SPI1 is not set
    # CONFIG_NRFX_SPI2 is not set
    # CONFIG_NRFX_SPIM is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TEMP is not set
    CONFIG_NRFX_TIMER=y
    # CONFIG_NRFX_TWI0 is not set
    # CONFIG_NRFX_TWI1 is not set
    # CONFIG_NRFX_TWIM is not set
    # CONFIG_NRFX_TWIS is not set
    # CONFIG_NRFX_UART0 is not set
    # CONFIG_NRFX_UARTE is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_reserved_resources_ncs.h"
    # end of nrfx drivers
    # end of hal_nordic (/Users/filiprosik/Project/LPG_52/modules/hal/nordic)
    # segger (/Users/filiprosik/Project/LPG_52/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # end of segger (/Users/filiprosik/Project/LPG_52/modules/debug/segger)
    # zcbor (/Users/filiprosik/Project/LPG_52/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (/Users/filiprosik/Project/LPG_52/modules/lib/zcbor)
    # nrfxlib (/Users/filiprosik/Project/LPG_52/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # end of nrf_modem (Modem library)
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    CONFIG_MPSL=y
    CONFIG_MPSL_BUILD_TYPE_LIB=y
    CONFIG_MPSL_LIB_DIR="nrf52"
    CONFIG_MPSL_LIB_FLOAT_ABI_DIR="soft-float"
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_HAS_HW_NRF_CC3XX=y
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (/Users/filiprosik/Project/LPG_52/nrfxlib)
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_HAS_MEC5_HAL is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="/Users/filiprosik/Project/LPG_52/td1159-low-power-gateway-52/app/private-key.pem"
    CONFIG_MCUBOOT_ENCRYPTION_KEY_FILE=""
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.1.1+0"
    CONFIG_MCUBOOT_IMGTOOL_OVERWRITE_ONLY=y
    # CONFIG_MCUBOOT_IMGTOOL_UUID_VID is not set
    # CONFIG_MCUBOOT_IMGTOOL_UUID_CID is not set
    CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS="--pad"
    # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
    # On board MCUboot operation mode
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_USING_OFFSET is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_USING_MOVE is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY=y
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD_WITH_REVERT is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_FIRMWARE_UPDATER is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP_RAM_LOAD is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
    # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
    # CONFIG_MCUBOOT_BOOTLOADER_USES_SHA512 is not set
    # end of On board MCUboot operation mode
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
    # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_bouffalolab module not available.
    # hal_gigadevice module not available.
    # hal_nxp module not available.
    # liblc3 module not available.
    # libsbc module not available.
    # LittleFS module not available.
    # mbedtls module not available.
    # Trusted-firmware-m module not available.
    # Trusted-firmware-a module not available.
    # Nanopb module not available.
    # Lz4 module not available.
    # loramac-node module not available.
    # LoRa Basics Modem module not available.
    # CANopenNode module not available.
    # CHRE module not available.
    # THRIFT module not available.
    # LVGL module not available.
    # cmsis module not available.
    # cmsis-dsp module not available.
    # cmsis-nn module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD="low_power_gateway_ble"
    CONFIG_BOARD_REVISION="0.3.0"
    CONFIG_BOARD_TARGET="[email protected]/nrf52840"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_LOW_POWER_GATEWAY_BLE=y
    CONFIG_BOARD_LOW_POWER_GATEWAY_BLE_NRF52840=y
    CONFIG_BOARD_QUALIFIERS="nrf52840"
    # Board Options
    CONFIG_BOARD_REVISION_0_3_0=y
    # end of Board Options
    # Hardware Configuration
    CONFIG_SOC="nrf52840"
    CONFIG_SOC_SERIES="nrf52"
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NORDIC_NRF=y
    CONFIG_SOC_SERIES_NRF52X=y
    CONFIG_SOC_NRF52840=y
    CONFIG_SOC_NRF52840_QIAA=y
    # CONFIG_HWINFO is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF52X=y
    CONFIG_SOC_NORDIC_BSP_NAME="stable"
    CONFIG_HAS_HW_NRF_ACL=y
    CONFIG_HAS_HW_NRF_CC310=y
    CONFIG_HAS_HW_NRF_CCM=y
    CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_ECB=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE0=y
    CONFIG_HAS_HW_NRF_MWU=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PPI=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
    CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
    CONFIG_HAS_HW_NRF_RNG=y
    CONFIG_HAS_HW_NRF_SWI0=y
    CONFIG_HAS_HW_NRF_SWI1=y
    CONFIG_HAS_HW_NRF_SWI2=y
    CONFIG_HAS_HW_NRF_SWI3=y
    CONFIG_HAS_HW_NRF_SWI4=y
    CONFIG_HAS_HW_NRF_SWI5=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_UARTE1=y
    CONFIG_HAS_NORDIC_RAM_CTRL=y
    # CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set
    # CONFIG_NRF_SYS_EVENT is not set
    # CONFIG_NRF_PERIPHCONF_SECTION is not set
    # CONFIG_IS_IRONSIDE_SE_SECONDARY_IMAGE is not set
    # CONFIG_IS_GEN_UICR_IMAGE is not set
    CONFIG_NRF_ENABLE_ICACHE=y
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    # CONFIG_SOC_NRF54H20_PM_S2RAM_OVERRIDE is not set
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_TRACE_PORT is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # end of Hardware Configuration
    CONFIG_ARCH="arm"
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_CPU_CORTEX=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # ARM Options
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    # CONFIG_PLATFORM_SPECIFIC_INIT is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M4=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_MPU_STACK_GUARD=y
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_HAS_SWO=y
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    CONFIG_ARCH_SUPPORTS_ROM_OFFSET=y
    CONFIG_ARM_MPU=y
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_USERSPACE is not set
    # CONFIG_NOINIT_SNIPPET_FIRST is not set
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # CONFIG_FRAME_POINTER is not set
    # Interrupt Configuration
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    CONFIG_ARCH_DEVICE_STATE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    # CONFIG_SRAM_SW_ISR_TABLE is not set
    CONFIG_EXCEPTION_DEBUG=y
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_VECTOR_TABLE_RELOCATION=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_STACK_PTR=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # DSP Options
    # end of DSP Options
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    # General Kernel Options
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    # CONFIG_SCHED_DUMB is not set
    CONFIG_SCHED_SIMPLE=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_DUMB is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_SIMPLE=y
    # Misc Kernel related options
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_CURRENT_THREAD_USE_TLS=y
    # end of Misc Kernel related options
    # Kernel Debugging and Metrics
    CONFIG_BOOT_DELAY=0
    # CONFIG_BOOT_CLEAR_SCREEN is not set
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # CONFIG_WORKQUEUE_WORK_TIMEOUT is not set
    # System Work Queue Options
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    CONFIG_SYSTEM_WORKQUEUE_WORK_TIMEOUT_MS=0
    # end of System Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # end of Timer API Options
    # Other Kernel Object Options
    CONFIG_POLL=y
    # CONFIG_MEM_SLAB_POINTER_VALIDATE is not set
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
    # end of Other Kernel Object Options
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    # Security Options
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # Memory Domains
    CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
    CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
    # end of Memory Domains
    # SMP Options
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
    # CONFIG_STATIC_INIT_GNU is not set
    # CONFIG_BOOTARGS is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_MUTABLE is not set
    # CONFIG_DEVICE_DT_METADATA is not set
    CONFIG_DEVICE_DEINIT_SUPPORT=y
    # end of Device Options
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Virtual Memory Support
    # MMU Features
    # end of MMU Features
    # end of Virtual Memory Support
    # SoC and Board Hooks
    # CONFIG_SOC_EARLY_RESET_HOOK is not set
    # CONFIG_SOC_PREP_HOOK is not set
    # CONFIG_SOC_EARLY_INIT_HOOK is not set
    # CONFIG_SOC_LATE_INIT_HOOK is not set
    # CONFIG_SOC_PER_CORE_INIT_HOOK is not set
    # CONFIG_BOARD_EARLY_INIT_HOOK is not set
    # CONFIG_BOARD_LATE_INIT_HOOK is not set
    # end of SoC and Board Hooks
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    CONFIG_BT_DRIVERS=y
    # Bluetooth HCI Driver Options
    CONFIG_BT_HCI_INIT_PRIORITY=50
    # CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set
    CONFIG_BT_DRV_TX_STACK_SIZE=256
    CONFIG_BT_DRV_RX_STACK_SIZE=768
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
    CONFIG_CLOCK_CONTROL_NRF=y
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_FREQUENCY=32768
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    # CONFIG_COMPARATOR is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_CRC_DRIVER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_DP_DRIVER is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_ENTROPY_INIT_PRIORITY=50
    # CONFIG_FAKE_ENTROPY_NATIVE_POSIX is not set
    CONFIG_ENTROPY_NRF5_RNG=y
    # CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
    CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
    CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
    CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
    CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    # Firmware drivers
    # CONFIG_ARM_SCMI is not set
    # end of Firmware drivers
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_EXPLICIT_ERASE=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    # MSPI flash device driver
    # end of MSPI flash device driver
    # CONFIG_SOC_FLASH_NRF_CUSTOM_CONTEXT is not set
    CONFIG_SOC_FLASH_NRF=y
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE is not set
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    CONFIG_SOC_FLASH_NRF_TIMEOUT_MULTIPLIER=10
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HAPTICS is not set
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX is not set
    # CONFIG_MDIO is not set
    # CONFIG_MIPI_DBI is not set
    # Miscellaneous Drivers
    # CONFIG_TIMEAWARE_GPIO is not set
    # Interconn Drivers
    # end of Interconn Drivers
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_MSPI is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    CONFIG_PINCTRL=y
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_KEEP_SLEEP_STATE=y
    # CONFIG_PINCTRL_NPCX_EX is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_PS2 is not set
    # CONFIG_PSI5 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # CONFIG_SENT is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    CONFIG_SERIAL_INIT_PRIORITY=50
    CONFIG_UART_ASYNC_API=y
    CONFIG_UART_EXCLUSIVE_API_CALLBACKS=y
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    # CONFIG_UART_NATIVE_POSIX is not set
    # CONFIG_UART_NPCX_FIFO_EX is not set
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    CONFIG_UART_ASYNC_TX_CACHE_SIZE=8
    # CONFIG_UARTE_NRFX_UARTE_COUNT_BYTES_WITH_TIMER is not set
    # CONFIG_UART_NRFX_UARTE_DIRECT_ISR is not set
    # CONFIG_UART_1_INTERRUPT_DRIVEN is not set
    CONFIG_UART_1_ASYNC=y
    CONFIG_UART_1_ENHANCED_POLL_OUT=y
    # CONFIG_UART_1_NRF_PARITY_BIT is not set
    CONFIG_UART_1_NRF_TX_BUFFER_SIZE=32
    CONFIG_UART_1_NRF_HW_ASYNC=y
    CONFIG_UART_1_NRF_ASYNC_LOW_POWER=y
    CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
    # CONFIG_SMBUS is not set
    # CONFIG_STEPPER is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    CONFIG_NRF_RTC_COUNTER_BIT_WIDTH=24
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # USB common
    # CONFIG_NRF_USBD_COMMON is not set
    # end of USB common
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_USBC_PPC_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTIO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_TEE is not set
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    # CONFIG_LIBC_ALLOW_LESS_THAN_64BIT_TIME is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    CONFIG_PICOLIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_ASCTIME_R is not set
    # CONFIG_COMMON_LIBC_CTIME_R is not set
    CONFIG_COMMON_LIBC_TIME=y
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    # CONFIG_COMMON_LIBC_REMOVE is not set
    CONFIG_PICOLIBC_USE_TOOLCHAIN=y
    # CONFIG_PICOLIBC_IO_FLOAT is not set
    CONFIG_PICOLIBC_IO_LONG_LONG=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # end of C++ Language Support
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_STRESS is not set
    # CONFIG_SYS_HEAP_INFO is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    CONFIG_SYS_HEAP_ARRAY_SIZE=0
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_MULTI_HEAP is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # end of Heap and Memory Allocation
    # Memory Blocks
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Memory Blocks
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_POOL_USAGE is not set
    CONFIG_NET_BUF_ALIGNMENT=0
    # OS Support Library
    # CONFIG_FDTABLE is not set
    CONFIG_ZVFS_OPEN_MAX=4
    # CONFIG_PRINTK_SYNC is not set
    # CONFIG_MPSC_PBUF is not set
    # CONFIG_SPSC_PBUF is not set
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # CONFIG_ZVFS is not set
    # end of OS Support Library
    # POSIX API Support
    # POSIX Options
    # CONFIG_POSIX_API is not set
    CONFIG_POSIX_AEP_CHOICE_NONE=y
    # CONFIG_POSIX_AEP_CHOICE_BASE is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
    # CONFIG_POSIX_ASYNCHRONOUS_IO is not set
    # CONFIG_POSIX_BARRIERS is not set
    # CONFIG_POSIX_C_LANG_SUPPORT_R is not set
    # CONFIG_POSIX_C_LIB_EXT is not set
    # POSIX device I/O
    # CONFIG_POSIX_DEVICE_IO is not set
    CONFIG_POSIX_OPEN_MAX=4
    # end of POSIX device I/O
    # CONFIG_POSIX_FD_MGMT is not set
    # CONFIG_POSIX_FILE_SYSTEM_R is not set
    # CONFIG_POSIX_FILE_SYSTEM is not set
    # POSIX memory
    CONFIG_POSIX_PAGE_SIZE=0x40
    # CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
    # CONFIG_POSIX_MAPPED_FILES is not set
    # CONFIG_POSIX_MEMORY_PROTECTION is not set
    # end of POSIX memory
    # CONFIG_POSIX_MESSAGE_PASSING is not set
    # CONFIG_POSIX_SINGLE_PROCESS is not set
    # CONFIG_POSIX_MULTI_PROCESS is not set
    # CONFIG_POSIX_THREADS is not set
    # CONFIG_POSIX_READER_WRITER_LOCKS is not set
    # POSIX scheduler options
    # CONFIG_POSIX_PRIORITY_SCHEDULING is not set
    # end of POSIX scheduler options
    # CONFIG_POSIX_SEMAPHORES is not set
    # POSIX signals
    # CONFIG_POSIX_REALTIME_SIGNALS is not set
    # CONFIG_POSIX_SIGNALS is not set
    # end of POSIX signals
    # CONFIG_POSIX_SPIN_LOCKS is not set
    # POSIX synchronized I/O
    # CONFIG_POSIX_FSYNC is not set
    # CONFIG_POSIX_SYNCHRONIZED_IO is not set
    # end of POSIX synchronized I/O
    # CONFIG_POSIX_TIMERS is not set
    # X/Open system interfaces
    # CONFIG_XSI_REALTIME is not set
    # CONFIG_XSI_SINGLE_PROCESS is not set
    # CONFIG_XOPEN_STREAMS is not set
    # CONFIG_XSI_SYSTEM_LOGGING is not set
    # CONFIG_XSI_THREADS_EXT is not set
    # end of X/Open system interfaces
    # Miscellaneous POSIX-related options
    # CONFIG_EVENTFD is not set
    # end of Miscellaneous POSIX-related options
    CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
    # end of POSIX Options
    # POSIX Shell Utilities
    # end of POSIX Shell Utilities
    # end of POSIX API Support
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_LIBGCC_RTLIB=y
    # Utility Library
    # CONFIG_JSON_LIBRARY is not set
    CONFIG_RING_BUFFER=y
    # CONFIG_RING_BUFFER_LARGE is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    CONFIG_ONOFF=y
    # CONFIG_UTF8 is not set
    # CONFIG_COBS is not set
    # end of Utility Library
    # Universally Unique Identifier (UUID)
    # CONFIG_UUID is not set
    # end of Universally Unique Identifier (UUID)
    # CONFIG_MIN_HEAP is not set
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    CONFIG_BT=y
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    CONFIG_BT_HCI_RAW=y
    CONFIG_BT_HCI_RAW_H4=y
    CONFIG_BT_HCI_RAW_H4_ENABLE=y
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_LE_EXTENDED_FEAT_SET is not set
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
    # CONFIG_BT_PATH_LOSS_MONITORING is not set
    # CONFIG_BT_SUBRATING is not set
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # Bluetooth Classic Options
    # end of Bluetooth Classic Options
    # end of Bluetooth Host
    CONFIG_BT_CTLR_ENTROPY_SUPPORT=y
    CONFIG_BT_CTLR_CRYPTO_SUPPORT=y
    CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
    CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
    CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
    CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
    CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
    CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_CODING_SELECTION_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
    CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
    CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
    CONFIG_BT_CTLR_LE_POWER_CONTROL_SUPPORT=y
    CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING_SUPPORT=y
    CONFIG_BT_CTLR_SUBRATING_SUPPORT=y
    CONFIG_BT_CTLR_FRAME_SPACE_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_EXTENDED_FEAT_SET_SUPPORT=y
    CONFIG_BT_CTLR_SHORTER_CONNECTION_INTERVALS_SUPPORT=y
    CONFIG_HAS_BT_CTLR=y
    CONFIG_BT_CTLR_HCI=y
    CONFIG_BT_CTLR_HCI_NUM_CMD_PKT_MAX=1
    # Bluetooth Controller configuration
    CONFIG_BT_CTLR_ENTROPY=y
    CONFIG_BT_CTLR_CRYPTO=y
    CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
    CONFIG_BT_CTLR_TX_PWR_ANTENNA=21
    # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
    # Bluetooth Controller features
    CONFIG_BT_CTLR_LE_ENC=y
    CONFIG_BT_CTLR_EXT_REJ_IND=y
    CONFIG_BT_CTLR_LE_PING=y
    CONFIG_BT_CTLR_DATA_LENGTH=y
    CONFIG_BT_CTLR_PHY=y
    CONFIG_BT_CTLR_CONN_RSSI=y
    # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
    CONFIG_BT_CTLR_FILTER_ACCEPT_LIST=y
    CONFIG_BT_CTLR_PRIVACY=y
    CONFIG_BT_CTLR_RL_SIZE=8
    CONFIG_BT_CTLR_EXT_SCAN_FP=y
    CONFIG_BT_CTLR_PHY_2M=y
    CONFIG_BT_CTLR_PHY_CODED=y
    CONFIG_BT_CTLR_CHAN_SEL_2=y
    # CONFIG_BT_CTLR_ADV_EXT is not set
    # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
    # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
    # CONFIG_BT_CTLR_SUBRATING is not set
    # CONFIG_BT_CTLR_EXTENDED_FEAT_SET is not set
    CONFIG_BT_CTLR_ASSERT_DEBUG=y
    CONFIG_BT_CTLR_ASSERT_HANDLER=y
    # CONFIG_BT_CTLR_VS_SCAN_REQ_RX is not set
    # CONFIG_BT_EAD is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_CPU_LOAD_METRIC is not set
    # CONFIG_CRC is not set
    # CONFIG_DAP is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_UBSAN is not set
    # CONFIG_STACK_USAGE is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # CONFIG_SYMTAB is not set
    # end of Debugging Options
    # CONFIG_MIPI_STP_DECODER is not set
    # CONFIG_CS_TRACE_DEFMT is not set
    # CONFIG_CPU_LOAD is not set
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
    CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE=0x30
    CONFIG_IMG_BLOCK_BUF_SIZE=512
    # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM_LIB_LINK is not set
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_FCB is not set
    # end of File Systems
    # CONFIG_GNSS_RTK is not set
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # CONFIG_LLEXT_EDK is not set
    # Logging
    # CONFIG_LOG_OUTPUT is not set
    # end of Logging
    CONFIG_MEM_ATTR=y
    # CONFIG_MEM_ATTR_HEAP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
    # end of Power Management
    # Platform Management Communications Infrastructure (PMCI)
    # CONFIG_MCTP is not set
    # end of Platform Management Communications Infrastructure (PMCI)
    # Portability
    # end of Portability
    # CONFIG_PROFILING is not set
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
    CONFIG_CSPRNG_AVAILABLE=y
    CONFIG_CSPRNG_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SECURE_STORAGE is not set
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    CONFIG_STREAM_FLASH=y
    CONFIG_STREAM_FLASH_INSPECT=y
    CONFIG_STREAM_FLASH_POST_WRITE_CALLBACK=y
    # CONFIG_STREAM_FLASH_ERASE is not set
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # CONFIG_MODULES is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_FLASH_LOAD_SIZE=0x76000
    CONFIG_ROM_END_OFFSET=0xc6
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_ITERABLE_SUBALIGN=4
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_STD_C90 is not set
    CONFIG_STD_C99=y
    # CONFIG_STD_C11 is not set
    # CONFIG_STD_C17 is not set
    # CONFIG_STD_C23 is not set
    CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    # CONFIG_GNU_C_EXTENSIONS is not set
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_DEPRECATION_TEST is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    CONFIG_TOOLCHAIN_SUPPORTS_VLA_IN_STATEMENTS=y
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_MOT is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
    # end of Compatibility
    nRF52840 .dts:
    /dts-v1/;
    /* node '/' defined in zephyr/dts/common/skeleton.dtsi:9 */
    	#address-cells = < 0x1 >;                /* in zephyr/dts/common/skeleton.dtsi:10 */
    	#size-cells = < 0x1 >;                   /* in zephyr/dts/common/skeleton.dtsi:11 */
    	model = "Low Power Gateway BLE";         /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:10 */
    	compatible = "td,low-power-gateway-ble"; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:11 */
    	/* node '/chosen' defined in zephyr/dts/common/skeleton.dtsi:12 */
    	chosen {
    		zephyr,bt-hci = &bt_hci_sdc;                 /* in zephyr/dts/arm/nordic/nrf52840.dtsi:14 */
    		zephyr,entropy = &cryptocell;                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:15 */
    		zephyr,flash-controller = &flash_controller; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:16 */
    		zephyr,sram = &sram0;                        /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:9 */
    		zephyr,flash = &flash0;                      /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:10 */
    		zephyr,code-partition = &slot0_partition;    /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:11 */
    		zephyr,bt-c2h-uart = &lpuart;                /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:14 */
    	/* node '/aliases' defined in zephyr/dts/common/skeleton.dtsi:13 */
    	aliases {
    	/* node '/soc' defined in zephyr/dts/arm/armv7-m.dtsi:6 */
    	soc {
    		#address-cells = < 0x1 >;     /* in zephyr/dts/arm/armv7-m.dtsi:7 */
    		#size-cells = < 0x1 >;        /* in zephyr/dts/arm/armv7-m.dtsi:8 */
    		interrupt-parent = < &nvic >; /* in zephyr/dts/arm/armv7-m.dtsi:10 */
    		ranges;                       /* in zephyr/dts/arm/armv7-m.dtsi:11 */
    		compatible = "simple-bus";    /* in zephyr/dts/arm/nordic/nrf52840_qiaa.dtsi:29 */
    		/* node '/soc/interrupt-controller@e000e100' defined in zephyr/dts/arm/armv7-m.dtsi:13 */
    		nvic: interrupt-controller@e000e100 {
    			#address-cells = < 0x1 >;            /* in zephyr/dts/arm/armv7-m.dtsi:14 */
    			compatible = "arm,v7m-nvic";         /* in zephyr/dts/arm/armv7-m.dtsi:15 */
    			reg = < 0xe000e100 0xc00 >;          /* in zephyr/dts/arm/armv7-m.dtsi:16 */
    			interrupt-controller;                /* in zephyr/dts/arm/armv7-m.dtsi:17 */
    			#interrupt-cells = < 0x2 >;          /* in zephyr/dts/arm/armv7-m.dtsi:18 */
    			arm,num-irq-priority-bits = < 0x3 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:585 */
    			phandle = < 0x1 >;                   /* in zephyr/dts/arm/armv7-m.dtsi:10 */
    		/* node '/soc/timer@e000e010' defined in zephyr/dts/arm/armv7-m.dtsi:21 */
    		systick: timer@e000e010 {
    			compatible = "arm,armv7m-systick"; /* in zephyr/dts/arm/armv7-m.dtsi:22 */
    			reg = < 0xe000e010 0x10 >;         /* in zephyr/dts/arm/armv7-m.dtsi:23 */
    			status = "disabled";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:590 */
    		/* node '/soc/ficr@10000000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:48 */
    		ficr: ficr@10000000 {
    			compatible = "nordic,nrf-ficr"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:49 */
    			reg = < 0x10000000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:50 */
    			#nordic,ficr-cells = < 0x1 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:51 */
    			status = "okay";                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:52 */
    		/* node '/soc/uicr@10001000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:55 */
    		uicr: uicr@10001000 {
    			compatible = "nordic,nrf-uicr"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:56 */
    			reg = < 0x10001000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:57 */
    			status = "okay";                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:58 */
    			gpio-as-nreset;                 /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:82 */
    		/* node '/soc/memory@20000000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:61 */
    		sram0: memory@20000000 {
    			compatible = "mmio-sram";     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:62 */
    			reg = < 0x20000000 0x40000 >; /* in zephyr/dts/arm/nordic/nrf52840_qiaa.dtsi:15 */
    		/* node '/soc/clock@40000000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:65 */
    		clock: clock@40000000 {
    			compatible = "nordic,nrf-clock"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:66 */
    			reg = < 0x40000000 0x1000 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:67 */
    			interrupts = < 0x0 0x1 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:68 */
    			status = "okay";                 /* in zephyr/dts/arm/nordic/nrf52840.dtsi:69 */
    		/* node '/soc/power@40000000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:72 */
    		power: power@40000000 {
    			compatible = "nordic,nrf-power"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:73 */
    			reg = < 0x40000000 0x1000 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:74 */
    			interrupts = < 0x0 0x1 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:75 */
    			status = "okay";                 /* in zephyr/dts/arm/nordic/nrf52840.dtsi:76 */
    			#address-cells = < 0x1 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:77 */
    			#size-cells = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:78 */
    			/* node '/soc/power@40000000/gpregret1@4000051c' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:80 */
    			gpregret1: gpregret1@4000051c {
    				#address-cells = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:81 */
    				#size-cells = < 0x1 >;              /* in zephyr/dts/arm/nordic/nrf52840.dtsi:82 */
    				compatible = "nordic,nrf-gpregret"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:83 */
    				reg = < 0x4000051c 0x1 >;           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:84 */
    				status = "okay";                    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:85 */
    			/* node '/soc/power@40000000/gpregret2@40000520' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:88 */
    			gpregret2: gpregret2@40000520 {
    				#address-cells = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:89 */
    				#size-cells = < 0x1 >;              /* in zephyr/dts/arm/nordic/nrf52840.dtsi:90 */
    				compatible = "nordic,nrf-gpregret"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:91 */
    				reg = < 0x40000520 0x1 >;           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:92 */
    				status = "okay";                    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:93 */
    			/* node '/soc/power@40000000/regulator@40000578' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:96 */
    			reg1: regulator@40000578 {
    				compatible = "nordic,nrf5x-regulator"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:97 */
    				reg = < 0x40000578 0x1 >;              /* in zephyr/dts/arm/nordic/nrf52840.dtsi:98 */
    				regulator-name = "REG1";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:99 */
    				regulator-initial-mode = < 0x0 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:100 */
    			/* node '/soc/power@40000000/regulator@40000580' defined in zephyr/dts/arm/nordic/nrf52840_qiaa.dtsi:19 */
    			reg0: regulator@40000580 {
    				compatible = "nordic,nrf52x-regulator-hv"; /* in zephyr/dts/arm/nordic/nrf52840_qiaa.dtsi:20 */
    				reg = < 0x40000580 0x1 >;                  /* in zephyr/dts/arm/nordic/nrf52840_qiaa.dtsi:21 */
    				regulator-name = "REG0";                   /* in zephyr/dts/arm/nordic/nrf52840_qiaa.dtsi:22 */
    				status = "disabled";                       /* in zephyr/dts/arm/nordic/nrf52840_qiaa.dtsi:23 */
    		/* node '/soc/radio@40001000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:104 */
    		radio: radio@40001000 {
    			compatible = "nordic,nrf-radio"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:105 */
    			reg = < 0x40001000 0x1000 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:106 */
    			interrupts = < 0x1 0x1 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:107 */
    			status = "okay";                 /* in zephyr/dts/arm/nordic/nrf52840.dtsi:108 */
    			ieee802154-supported;            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:109 */
    			ble-2mbps-supported;             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:110 */
    			ble-coded-phy-supported;         /* in zephyr/dts/arm/nordic/nrf52840.dtsi:111 */
    			tx-high-power-supported;         /* in zephyr/dts/arm/nordic/nrf52840.dtsi:112 */
    			/* node '/soc/radio@40001000/ieee802154' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:114 */
    			ieee802154: ieee802154 {
    				compatible = "nordic,nrf-ieee802154"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:115 */
    				status = "disabled";                  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:116 */
    			/* node '/soc/radio@40001000/bt_hci_sdc' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:119 */
    			bt_hci_sdc: bt_hci_sdc {
    				compatible = "nordic,bt-hci-sdc"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:120 */
    				status = "okay";                  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:121 */
    			/* node '/soc/radio@40001000/bt_hci_controller' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:123 */
    			bt_hci_controller: bt_hci_controller {
    				compatible = "zephyr,bt-hci-ll-sw-split"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:124 */
    				status = "disabled";                      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:125 */
    		/* node '/soc/uart@40002000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:129 */
    		uart0: uart@40002000 {
    			compatible = "nordic,nrf-uarte"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:132 */
    			reg = < 0x40002000 0x1000 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:133 */
    			interrupts = < 0x2 0x1 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:134 */
    			status = "disabled";             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:135 */
    		/* node '/soc/i2c@40003000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:138 */
    		i2c0: i2c@40003000 {
    			compatible = "nordic,nrf-twim"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:146 */
    			#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:147 */
    			#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:148 */
    			reg = < 0x40003000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:149 */
    			interrupts = < 0x3 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:150 */
    			easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:151 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:152 */
    			zephyr,pm-device-runtime-auto;  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:153 */
    		/* node '/soc/spi@40003000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:156 */
    		spi0: spi@40003000 {
    			compatible = "nordic,nrf-spim"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:164 */
    			#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:165 */
    			#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:166 */
    			reg = < 0x40003000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:167 */
    			interrupts = < 0x3 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:168 */
    			max-frequency = < 0x7a1200 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:169 */
    			easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:170 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:171 */
    		/* node '/soc/i2c@40004000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:174 */
    		i2c1: i2c@40004000 {
    			compatible = "nordic,nrf-twim"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:182 */
    			#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:183 */
    			#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:184 */
    			reg = < 0x40004000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:185 */
    			interrupts = < 0x4 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:186 */
    			easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:187 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:188 */
    			zephyr,pm-device-runtime-auto;  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:189 */
    		/* node '/soc/spi@40004000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:192 */
    		spi1: spi@40004000 {
    			compatible = "nordic,nrf-spim"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:200 */
    			#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:201 */
    			#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:202 */
    			reg = < 0x40004000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:203 */
    			interrupts = < 0x4 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:204 */
    			max-frequency = < 0x7a1200 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:205 */
    			easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:206 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:207 */
    		/* node '/soc/nfct@40005000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:210 */
    		nfct: nfct@40005000 {
    			compatible = "nordic,nrf-nfct"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:211 */
    			reg = < 0x40005000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:212 */
    			interrupts = < 0x5 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:213 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:214 */
    		/* node '/soc/gpiote@40006000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:217 */
    		gpiote: gpiote0: gpiote@40006000 {
    			compatible = "nordic,nrf-gpiote"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:218 */
    			reg = < 0x40006000 0x1000 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:219 */
    			instance = < 0x0 >;               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:222 */
    			status = "okay";                  /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:69 */
    			interrupts = < 0x6 0x1 >;         /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:70 */
    			phandle = < 0x4 >;                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:559 */
    		/* node '/soc/adc@40007000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:225 */
    		adc: adc@40007000 {
    			compatible = "nordic,nrf-saadc"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:226 */
    			reg = < 0x40007000 0x1000 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:227 */
    			interrupts = < 0x7 0x1 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:228 */
    			status = "disabled";             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:229 */
    			#io-channel-cells = < 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:230 */
    			zephyr,pm-device-runtime-auto;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:231 */
    		/* node '/soc/timer@40008000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:234 */
    		timer0: timer@40008000 {
    			compatible = "nordic,nrf-timer"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:235 */
    			status = "disabled";             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:236 */
    			reg = < 0x40008000 0x1000 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:237 */
    			cc-num = < 0x4 >;                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:238 */
    			max-bit-width = < 0x20 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:239 */
    			interrupts = < 0x8 0x1 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:240 */
    			prescaler = < 0x0 >;             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:241 */
    		/* node '/soc/timer@40009000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:244 */
    		timer1: timer@40009000 {
    			compatible = "nordic,nrf-timer"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:245 */
    			status = "disabled";             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:246 */
    			reg = < 0x40009000 0x1000 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:247 */
    			cc-num = < 0x4 >;                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:248 */
    			max-bit-width = < 0x20 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:249 */
    			interrupts = < 0x9 0x1 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:250 */
    			prescaler = < 0x0 >;             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:251 */
    			phandle = < 0x5 >;               /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:42 */
    		/* node '/soc/timer@4000a000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:254 */
    		timer2: timer@4000a000 {
    			compatible = "nordic,nrf-timer"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:255 */
    			status = "disabled";             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:256 */
    			reg = < 0x4000a000 0x1000 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:257 */
    			cc-num = < 0x4 >;                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:258 */
    			max-bit-width = < 0x20 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:259 */
    			interrupts = < 0xa 0x1 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:260 */
    			prescaler = < 0x0 >;             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:261 */
    		/* node '/soc/rtc@4000b000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:264 */
    		rtc0: rtc@4000b000 {
    			compatible = "nordic,nrf-rtc"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:265 */
    			reg = < 0x4000b000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:266 */
    			cc-num = < 0x3 >;              /* in zephyr/dts/arm/nordic/nrf52840.dtsi:267 */
    			interrupts = < 0xb 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:268 */
    			status = "disabled";           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:269 */
    			clock-frequency = < 0x8000 >;  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:270 */
    			prescaler = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:271 */
    		/* node '/soc/temp@4000c000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:274 */
    		temp: temp@4000c000 {
    			compatible = "nordic,nrf-temp"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:275 */
    			reg = < 0x4000c000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:276 */
    			interrupts = < 0xc 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:277 */
    			status = "okay";                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:278 */
    		/* node '/soc/random@4000d000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:281 */
    		rng: random@4000d000 {
    			compatible = "nordic,nrf-rng"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:282 */
    			reg = < 0x4000d000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:283 */
    			interrupts = < 0xd 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:284 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:285 */
    		/* node '/soc/ecb@4000e000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:288 */
    		ecb: ecb@4000e000 {
    			compatible = "nordic,nrf-ecb"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:289 */
    			reg = < 0x4000e000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:290 */
    			interrupts = < 0xe 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:291 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:292 */
    		/* node '/soc/ccm@4000f000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:295 */
    		ccm: ccm@4000f000 {
    			compatible = "nordic,nrf-ccm"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:296 */
    			reg = < 0x4000f000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:297 */
    			interrupts = < 0xf 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:298 */
    			length-field-length-8-bits;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:299 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:300 */
    		/* node '/soc/watchdog@40010000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:303 */
    		wdt: wdt0: watchdog@40010000 {
    			compatible = "nordic,nrf-wdt"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:304 */
    			reg = < 0x40010000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:305 */
    			interrupts = < 0x10 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:306 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:307 */
    		/* node '/soc/rtc@40011000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:310 */
    		rtc1: rtc@40011000 {
    			compatible = "nordic,nrf-rtc"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:311 */
    			reg = < 0x40011000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:312 */
    			cc-num = < 0x4 >;              /* in zephyr/dts/arm/nordic/nrf52840.dtsi:313 */
    			interrupts = < 0x11 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:314 */
    			status = "disabled";           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:315 */
    			clock-frequency = < 0x8000 >;  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:316 */
    			prescaler = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:317 */
    		/* node '/soc/qdec@40012000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:320 */
    		qdec: qdec0: qdec@40012000 {
    			compatible = "nordic,nrf-qdec"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:321 */
    			reg = < 0x40012000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:322 */
    			interrupts = < 0x12 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:323 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:324 */
    		/* node '/soc/comparator@40013000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:327 */
    		comp: comparator@40013000 {
    			compatible = "nordic,nrf-comp"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:332 */
    			reg = < 0x40013000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:333 */
    			interrupts = < 0x13 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:334 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:335 */
    		/* node '/soc/egu@40014000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:338 */
    		egu0: swi0: egu@40014000 {
    			compatible = "nordic,nrf-egu",
    			             "nordic,nrf-swi"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:339 */
    			reg = < 0x40014000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:340 */
    			interrupts = < 0x14 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:341 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:342 */
    		/* node '/soc/egu@40015000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:345 */
    		egu1: swi1: egu@40015000 {
    			             "nordic,nrf-swi"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:346 */
    			reg = < 0x40015000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:347 */
    			interrupts = < 0x15 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:348 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:349 */
    		/* node '/soc/egu@40016000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:352 */
    		egu2: swi2: egu@40016000 {
    			             "nordic,nrf-swi"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:353 */
    			reg = < 0x40016000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:354 */
    			interrupts = < 0x16 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:355 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:356 */
    		/* node '/soc/egu@40017000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:359 */
    		egu3: swi3: egu@40017000 {
    			             "nordic,nrf-swi"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:360 */
    			reg = < 0x40017000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:361 */
    			interrupts = < 0x17 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:362 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:363 */
    		/* node '/soc/egu@40018000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:366 */
    		egu4: swi4: egu@40018000 {
    			             "nordic,nrf-swi"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:367 */
    			reg = < 0x40018000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:368 */
    			interrupts = < 0x18 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:369 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:370 */
    		/* node '/soc/egu@40019000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:373 */
    		egu5: swi5: egu@40019000 {
    			             "nordic,nrf-swi"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:374 */
    			reg = < 0x40019000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:375 */
    			interrupts = < 0x19 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:376 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:377 */
    		/* node '/soc/timer@4001a000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:380 */
    		timer3: timer@4001a000 {
    			compatible = "nordic,nrf-timer"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:381 */
    			status = "disabled";             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:382 */
    			reg = < 0x4001a000 0x1000 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:383 */
    			cc-num = < 0x6 >;                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:384 */
    			max-bit-width = < 0x20 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:385 */
    			interrupts = < 0x1a 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:386 */
    			prescaler = < 0x0 >;             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:387 */
    		/* node '/soc/timer@4001b000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:390 */
    		timer4: timer@4001b000 {
    			compatible = "nordic,nrf-timer"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:391 */
    			status = "disabled";             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:392 */
    			reg = < 0x4001b000 0x1000 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:393 */
    			cc-num = < 0x6 >;                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:394 */
    			max-bit-width = < 0x20 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:395 */
    			interrupts = < 0x1b 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:396 */
    			prescaler = < 0x0 >;             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:397 */
    		/* node '/soc/pwm@4001c000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:400 */
    		pwm0: pwm@4001c000 {
    			compatible = "nordic,nrf-pwm"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:401 */
    			reg = < 0x4001c000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:402 */
    			interrupts = < 0x1c 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:403 */
    			status = "disabled";           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:404 */
    			#pwm-cells = < 0x3 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:405 */
    		/* node '/soc/pdm@4001d000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:408 */
    		pdm0: pdm@4001d000 {
    			compatible = "nordic,nrf-pdm"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:409 */
    			reg = < 0x4001d000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:410 */
    			interrupts = < 0x1d 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:411 */
    			status = "disabled";           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:412 */
    		/* node '/soc/acl@4001e000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:415 */
    		acl: acl@4001e000 {
    			compatible = "nordic,nrf-acl"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:416 */
    			reg = < 0x4001e000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:417 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:418 */
    		/* node '/soc/flash-controller@4001e000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:421 */
    		flash_controller: flash-controller@4001e000 {
    			compatible = "nordic,nrf52-flash-controller"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:422 */
    			reg = < 0x4001e000 0x1000 >;                  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:423 */
    			partial-erase;                                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:424 */
    			#address-cells = < 0x1 >;                     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:426 */
    			#size-cells = < 0x1 >;                        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:427 */
    			/* node '/soc/flash-controller@4001e000/flash@0' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:429 */
    			flash0: flash@0 {
    				compatible = "soc-nv-flash";   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:430 */
    				erase-block-size = < 0x1000 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:431 */
    				write-block-size = < 0x4 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:432 */
    				reg = < 0x0 0x100000 >;        /* in zephyr/dts/arm/nordic/nrf52840_qiaa.dtsi:11 */
    				/* node '/soc/flash-controller@4001e000/flash@0/partitions' defined in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:16 */
    				partitions {
    					compatible = "fixed-partitions"; /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:17 */
    					#address-cells = < 0x1 >;        /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:18 */
    					#size-cells = < 0x1 >;           /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:19 */
    					/* node '/soc/flash-controller@4001e000/flash@0/partitions/partition@0' defined in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:21 */
    					boot_partition: partition@0 {
    						label = "mcuboot";    /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:22 */
    						reg = < 0x0 0xc000 >; /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:23 */
    					/* node '/soc/flash-controller@4001e000/flash@0/partitions/partition@c000' defined in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:26 */
    					slot0_partition: partition@c000 {
    						label = "image-0";        /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:27 */
    						reg = < 0xc000 0x76000 >; /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:28 */
    					/* node '/soc/flash-controller@4001e000/flash@0/partitions/partition@82000' defined in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:31 */
    					slot1_partition: partition@82000 {
    						label = "image-1";         /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:32 */
    						reg = < 0x82000 0x76000 >; /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:33 */
    					/* node '/soc/flash-controller@4001e000/flash@0/partitions/partition@f8000' defined in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:45 */
    					storage_partition: partition@f8000 {
    						label = "storage";        /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:46 */
    						reg = < 0xf8000 0x8000 >; /* in zephyr/dts/vendor/nordic/nrf52840_partition.dtsi:47 */
    		/* node '/soc/ppi@4001f000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:436 */
    		ppi: ppi@4001f000 {
    			compatible = "nordic,nrf-ppi"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:437 */
    			reg = < 0x4001f000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:438 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:439 */
    		/* node '/soc/mwu@40020000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:442 */
    		mwu: mwu@40020000 {
    			compatible = "nordic,nrf-mwu"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:443 */
    			reg = < 0x40020000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:444 */
    			status = "okay";               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:445 */
    		/* node '/soc/pwm@40021000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:448 */
    		pwm1: pwm@40021000 {
    			compatible = "nordic,nrf-pwm"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:449 */
    			reg = < 0x40021000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:450 */
    			interrupts = < 0x21 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:451 */
    			status = "disabled";           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:452 */
    			#pwm-cells = < 0x3 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:453 */
    		/* node '/soc/pwm@40022000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:456 */
    		pwm2: pwm@40022000 {
    			compatible = "nordic,nrf-pwm"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:457 */
    			reg = < 0x40022000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:458 */
    			interrupts = < 0x22 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:459 */
    			status = "disabled";           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:460 */
    			#pwm-cells = < 0x3 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:461 */
    		/* node '/soc/spi@40023000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:464 */
    		spi2: spi@40023000 {
    			compatible = "nordic,nrf-spim"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:472 */
    			#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:473 */
    			#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:474 */
    			reg = < 0x40023000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:475 */
    			interrupts = < 0x23 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:476 */
    			max-frequency = < 0x7a1200 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:477 */
    			easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:478 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:479 */
    		/* node '/soc/rtc@40024000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:482 */
    		rtc2: rtc@40024000 {
    			compatible = "nordic,nrf-rtc"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:483 */
    			reg = < 0x40024000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:484 */
    			cc-num = < 0x4 >;              /* in zephyr/dts/arm/nordic/nrf52840.dtsi:485 */
    			interrupts = < 0x24 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:486 */
    			status = "disabled";           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:487 */
    			clock-frequency = < 0x8000 >;  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:488 */
    			prescaler = < 0x1 >;           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:489 */
    		/* node '/soc/i2s@40025000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:492 */
    		i2s0: i2s@40025000 {
    			compatible = "nordic,nrf-i2s"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:493 */
    			#address-cells = < 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:494 */
    			#size-cells = < 0x0 >;         /* in zephyr/dts/arm/nordic/nrf52840.dtsi:495 */
    			reg = < 0x40025000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:496 */
    			interrupts = < 0x25 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:497 */
    			status = "disabled";           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:498 */
    		/* node '/soc/usbd@40027000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:501 */
    		usbd: usbd@40027000 {
    			compatible = "nordic,nrf-usbd"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:502 */
    			reg = < 0x40027000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:503 */
    			interrupts = < 0x27 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:504 */
    			num-bidir-endpoints = < 0x1 >;  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:505 */
    			num-in-endpoints = < 0x7 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:506 */
    			num-out-endpoints = < 0x7 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:507 */
    			num-isoin-endpoints = < 0x1 >;  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:508 */
    			num-isoout-endpoints = < 0x1 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:509 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:510 */
    		/* node '/soc/uart@40028000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:513 */
    		uart1: uart@40028000 {
    			compatible = "nordic,nrf-uarte";    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:514 */
    			reg = < 0x40028000 0x1000 >;        /* in zephyr/dts/arm/nordic/nrf52840.dtsi:515 */
    			interrupts = < 0x28 0x1 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:516 */
    			status = "okay";                    /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:53 */
    			current-speed = < 0x3d090 >;        /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:54 */
    			pinctrl-0 = < &uart1_default_alt >; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:56 */
    			pinctrl-1 = < &uart1_sleep_alt >;   /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:57 */
    			pinctrl-names = "default",
    			                "sleep";            /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:58 */
    			/* node '/soc/uart@40028000/nrf-sw-lpuart' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:60 */
    			lpuart: nrf-sw-lpuart {
    				compatible = "nordic,nrf-sw-lpuart"; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:61 */
    				status = "okay";                     /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:62 */
    				req-pin = < 0x2d >;                  /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:63 */
    				rdy-pin = < 0x1f >;                  /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:64 */
    		/* node '/soc/qspi@40029000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:520 */
    		qspi: qspi@40029000 {
    			compatible = "nordic,nrf-qspi"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:521 */
    			#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:522 */
    			#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:523 */
    			reg = < 0x40029000 0x1000 >,
    			      < 0x12000000 0x8000000 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:524 */
    			reg-names = "qspi",
    			            "qspi_mm";          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:525 */
    			interrupts = < 0x29 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:526 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:527 */
    		/* node '/soc/pwm@4002d000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:530 */
    		pwm3: pwm@4002d000 {
    			compatible = "nordic,nrf-pwm"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:531 */
    			reg = < 0x4002d000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:532 */
    			interrupts = < 0x2d 0x1 >;     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:533 */
    			status = "disabled";           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:534 */
    			#pwm-cells = < 0x3 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:535 */
    		/* node '/soc/spi@4002f000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:538 */
    		spi3: spi@4002f000 {
    			compatible = "nordic,nrf-spim"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:539 */
    			#address-cells = < 0x1 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:540 */
    			#size-cells = < 0x0 >;          /* in zephyr/dts/arm/nordic/nrf52840.dtsi:541 */
    			reg = < 0x4002f000 0x1000 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:542 */
    			interrupts = < 0x2f 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:543 */
    			max-frequency = < 0x1e84800 >;  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:544 */
    			easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:545 */
    			rx-delay-supported;             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:546 */
    			rx-delay = < 0x2 >;             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:547 */
    			status = "disabled";            /* in zephyr/dts/arm/nordic/nrf52840.dtsi:548 */
    		/* node '/soc/gpio@50000000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:551 */
    		gpio0: gpio@50000000 {
    			compatible = "nordic,nrf-gpio";              /* in zephyr/dts/arm/nordic/nrf52840.dtsi:552 */
    			gpio-controller;                             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:553 */
    			reg = < 0x50000000 0x200 0x50000500 0x300 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:554 */
    			#gpio-cells = < 0x2 >;                       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:556 */
    			port = < 0x0 >;                              /* in zephyr/dts/arm/nordic/nrf52840.dtsi:558 */
    			gpiote-instance = < &gpiote >;               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:559 */
    			status = "okay";                             /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:74 */
    			phandle = < 0x6 >;                           /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:26 */
    		/* node '/soc/gpio@50000300' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:562 */
    		gpio1: gpio@50000300 {
    			compatible = "nordic,nrf-gpio";              /* in zephyr/dts/arm/nordic/nrf52840.dtsi:563 */
    			gpio-controller;                             /* in zephyr/dts/arm/nordic/nrf52840.dtsi:564 */
    			reg = < 0x50000300 0x200 0x50000800 0x300 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:565 */
    			#gpio-cells = < 0x2 >;                       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:567 */
    			ngpios = < 0x10 >;                           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:568 */
    			port = < 0x1 >;                              /* in zephyr/dts/arm/nordic/nrf52840.dtsi:570 */
    			gpiote-instance = < &gpiote >;               /* in zephyr/dts/arm/nordic/nrf52840.dtsi:571 */
    			status = "okay";                             /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:78 */
    			phandle = < 0x7 >;                           /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:27 */
    		/* node '/soc/crypto@5002a000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:574 */
    		cryptocell: crypto@5002a000 {
    			compatible = "arm,cryptocell-310"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:575 */
    			reg = < 0x5002a000 0x1000 >,
    			      < 0x5002b000 0x1000 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:576 */
    			reg-names = "wrapper",
    			            "core";                /* in zephyr/dts/arm/nordic/nrf52840.dtsi:577 */
    			interrupts = < 0x2a 0x1 >;         /* in zephyr/dts/arm/nordic/nrf52840.dtsi:578 */
    			status = "okay";                   /* in zephyr/dts/arm/nordic/nrf52840.dtsi:579 */
    	/* node '/pin-controller' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:26 */
    	pinctrl: pin-controller {
    		compatible = "nordic,nrf-pinctrl"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:31 */
    		/* node '/pin-controller/uart1_default_alt' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble-pinctrl.dtsi:5 */
    		uart1_default_alt: uart1_default_alt {
    			phandle = < 0x2 >; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:56 */
    			/* node '/pin-controller/uart1_default_alt/group1' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble-pinctrl.dtsi:6 */
    			group1 {
    				psels = < 0x2a >,
    				        < 0x1000002 >,
    				        < 0x30001ff >,
    				        < 0x20001ff >; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble-pinctrl.dtsi:7 */
    		/* node '/pin-controller/uart1_sleep_alt' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble-pinctrl.dtsi:14 */
    		uart1_sleep_alt: uart1_sleep_alt {
    			phandle = < 0x3 >; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:57 */
    			/* node '/pin-controller/uart1_sleep_alt/group1' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble-pinctrl.dtsi:15 */
    			group1 {
    				psels = < 0x2a >,
    				        < 0x1000002 >,
    				        < 0x30001ff >,
    				        < 0x20001ff >; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble-pinctrl.dtsi:16 */
    				low-power-enable;      /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble-pinctrl.dtsi:20 */
    	/* node '/entropy_bt_hci' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:34 */
    	rng_hci: entropy_bt_hci {
    		compatible = "zephyr,bt-hci-entropy"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:35 */
    		status = "disabled";                  /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:36 */
    	/* node '/sw-pwm' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:39 */
    	sw_pwm: sw-pwm {
    		compatible = "nordic,nrf-sw-pwm"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:40 */
    		status = "disabled";              /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:41 */
    		generator = < &timer1 >;          /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:42 */
    		clock-prescaler = < 0x0 >;        /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:43 */
    		#pwm-cells = < 0x3 >;             /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:44 */
    	/* node '/cpus' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:19 */
    	cpus {
    		#address-cells = < 0x1 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:20 */
    		#size-cells = < 0x0 >;    /* in zephyr/dts/arm/nordic/nrf52840.dtsi:21 */
    		/* node '/cpus/cpu@0' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:23 */
    		cpu@0 {
    			device_type = "cpu";           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:24 */
    			compatible = "arm,cortex-m4f"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:25 */
    			reg = < 0x0 >;                 /* in zephyr/dts/arm/nordic/nrf52840.dtsi:26 */
    			#address-cells = < 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:27 */
    			#size-cells = < 0x1 >;         /* in zephyr/dts/arm/nordic/nrf52840.dtsi:28 */
    			/* node '/cpus/cpu@0/itm@e0000000' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:30 */
    			itm: itm@e0000000 {
    				compatible = "arm,armv7m-itm";     /* in zephyr/dts/arm/nordic/nrf52840.dtsi:31 */
    				reg = < 0xe0000000 0x1000 >;       /* in zephyr/dts/arm/nordic/nrf52840.dtsi:32 */
    				swo-ref-frequency = < 0x1e84800 >; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:33 */
    	/* node '/clocks' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:38 */
    	clocks {
    		/* node '/clocks/hfxo' defined in zephyr/dts/arm/nordic/nrf52840.dtsi:39 */
    		hfxo: hfxo {
    			compatible = "nordic,nrf52-hfxo"; /* in zephyr/dts/arm/nordic/nrf52840.dtsi:40 */
    			clock-frequency = < 0x3d09000 >;  /* in zephyr/dts/arm/nordic/nrf52840.dtsi:41 */
    			startup-time-us = < 0x578 >;      /* in zephyr/dts/arm/nordic/nrf52840.dtsi:42 */
    			#clock-cells = < 0x0 >;           /* in zephyr/dts/arm/nordic/nrf52840.dtsi:43 */
    	/* node '/skyFem' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:24 */
    	nrf_radio_fem: skyFem {
    		compatible = "skyworks,sky66112-11",
    		             "generic-fem-two-ctrl-pins"; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:25 */
    		ctx-gpios = < &gpio0 0x16 0x0 >;          /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:26 */
    		crx-gpios = < &gpio1 0x0 0x0 >;           /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:27 */
    		tx-gain-db = < 0x12 >;                    /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:28 */
    	/* node '/gpio_pins' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:31 */
    	gpio_pins: gpio_pins {
    		compatible = "gpio-leds"; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:32 */
    		/* node '/gpio_pins/csd_1' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:33 */
    		csd_1: csd_1 {
    			gpios = < &gpio0 0x1c 0x0 >; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:34 */
    			label = "CSD 1";             /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:35 */
    		/* node '/gpio_pins/csd_2' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:37 */
    		csd_2: csd_2 {
    			gpios = < &gpio0 0x1d 0x0 >; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:38 */
    			label = "CSD 2";             /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:39 */
    		/* node '/gpio_pins/cps' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:41 */
    		cps: cps {
    			gpios = < &gpio0 0x14 0x0 >; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:42 */
    			label = "CPS";               /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:43 */
    		/* node '/gpio_pins/chl' defined in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:45 */
    		chl: chl {
    			gpios = < &gpio0 0xf 0x0 >; /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:46 */
    			label = "CHL";              /* in td1159-low-power-gateway-52/boards/td/low_power_gateway_ble/low_power_gateway_ble.dts:47 */
    Connection parameters:
    - interval min  = 6     (7.5ms)
    - interval max  = 6     (7.5ms)
    - latency       = 0
    - timeout       = 400   (4s)
    I'm not really sure what do you mean by details about my method. I'm just forcing the supervision timeout to happen by powering off the peripheral device during the connection and I'm expecting the disconnect event which never occurs (neither with supervision timeout reason nor with any other reason - there is no disconnect event at all).
    Filip
    An update from the team. We think this may be a uart issue with Ipuart and there seems to be an issue with your dts/config. Firstly, you have enabled Ipuart on two uart instances on nrf91. This is not supported. You have also enabled hw-flow-control on the Ipuart instance which isn't supported. Could you please check this?
    Best Regards,
    Samruddhi
  • Hi, we added support for lpuart on two uart instances. I don't think it's an issue as everything worked perfectly fine on NCS 3.1.0. Now, beside the missing supervision timeout event, everything also works just fine. Why would lpuart drop supervision timeout event while everything else works ok?
    Filip
    It also seems that you have HWFC enabled. Did you remove this and check the issue? Can you also provide the logic analyzer capture?
    Best Regards,
    Samruddhi
    I managed to recreate the issue with devkits and samples on NCS v3.2.2 (without my changes).
    As peripheral, I used sample peripheral_gatt_dm and modified it so it just advertises with a possibility to connect. I flashed it on nRF52840dk.
    As central, I used sample central_bas and modified it so it filters only specific uuid (you need to put the peripheral's uuid here) and connects to it with no further actions. I built it for 2 devkits: nRF21540dk and nRF9160dk (0.8.2). The nRF52840 on the nRF9160dk needs to be flashed with hci_lpuart sample.
    First, I tested it with nRF21540dk: I turned on the peripheral and the central connected to it in a moment, then I turned off the peripheral and after supervision timeout (4s), I received the disconnected event with reason 0x08 (timeout) - it works fine.
    Then I did the same with nRF9160dk and instead of expected disconnect event with reason timeout,
    I received an error from lpuart - disconnect event never occurred.
    It seems like it actually is some issue with lpuart, but it's not due to my modifications to it. Could you try to recreate it on your side? I'm attaching the modified samples.
    Filip
    Supervision timeout.zip
