Does the pstorage module require the scheduler? Can it be used without the scheduler and FreeRTOS?
Thanks
Thanks
The task isn't exiting I think it's stack is getting corrupted somehow. I'm pretty positive it's not a stack overflow since I gave the task a huge stack on the nRF52 and it still happens. Everything is fine until the actual call to the SD flash write routine. Sometime after I hit the task exit handler.
Stack corruptions are tough. Can you post your task code and maybe we can spot something?
The pstorage module doesn't require the scheduler.
