nRF54L15 BLE RX current comsumption
I measured the power consumption of the BLE RX using the nRF54L15.(nRF54L15-DK v1.0.0)
3.0V operation
apps: scan_adv (delete advertising)
west build -b nrf54l15dk/nrf54l15/cpuapp
proj.conf
CONFIG_BT=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_OBSERVER=y
CONFIG_LOG=n
CONFIG_SERIAL=n
Result: The average current consumption was 3.73mA.
This is 330uA higher than the 3.4mA stated in the datasheet.
Is this correct behavior? Is further processing required to reduce it to 3.4mA?
  • That seems to be correct, but this silkscreen doesn't seem to match an nRF54L15 DK v1.0.0, so can you show how the entire board, and how is the nRF54L15 DK powered here?
    And is the application you're running just the scan_adv sample without any changes?
    Simon
  • Yes. I downloaded it from the NORDIC website.
    I'll also upload the V1.0.0 P6 connector.
    Power is supplied via the USB connector.
    I'll upload main.c and proj.conf.
    /* main.c - Application main entry point */
     * Copyright (c) 2015-2016 Intel Corporation
    #include <zephyr/types.h>
    #include <stddef.h>
    #include <zephyr/sys/util.h>
    static uint8_t mfg_data[] = { 0xff, 0xff, 0x00 };
    static const struct bt_data ad[] = {
    	BT_DATA(BT_DATA_MANUFACTURER_DATA, mfg_data, 3),
    static void scan_cb(const bt_addr_le_t *addr, int8_t rssi, uint8_t adv_type,
    		    struct net_buf_simple *buf)
    	mfg_data[2]++;
    	struct bt_le_scan_param scan_param = {
    		.type       = BT_LE_SCAN_TYPE_PASSIVE,
    		.options    = BT_LE_SCAN_OPT_NONE,
    		.interval   = 0x0010,
    		.window     = 0x0010,
    	int err;
    	printk("Starting Scanner/Advertiser Demo\n");
    	/* Initialize the Bluetooth Subsystem */
    	err = bt_enable(NULL);
    	if (err) {
    		printk("Bluetooth init failed (err %d)\n", err);
    		return 0;
    	printk("Bluetooth initialized\n");
    	err = bt_le_scan_start(&scan_param, scan_cb);
    	if (err) {
    		printk("Starting scanning failed (err %d)\n", err);
    		return 0;
    	do {
    		k_sleep(K_MSEC(4000));
    #if 0
    		/* Start advertising */
    		err = bt_le_adv_start(BT_LE_ADV_NCONN, ad, ARRAY_SIZE(ad),
    				      NULL, 0);
    		if (err) {
    			printk("Advertising failed to start (err %d)\n", err);
    			return 0;
    		k_sleep(K_MSEC(400));
    		err = bt_le_adv_stop();
    		if (err) {
    			printk("Advertising failed to stop (err %d)\n", err);
    			return 0;
    	} while (1);
    	return 0;
    6471.prj.conf
  • Hi
    I just wanted to confirm that I reproduced this on my end now, with the scan_adv sample on NCS v3.2.0 as well, and it seems to be because it's not power optimized, so something else must be running in the background.
    I still haven't found exactly what, and will continue to look into it, but due to a public holiday in Norway tomorrow, I won't be able to get back to you until next week. In the meantime, you can try experimenting with adding power management to the sample and try disabling parts of the sample you're not using, like advertising, UART/shell/logging and enabling power management with CONFIG_PM. See this blog post for details:  Optimizing Power on nRF5340 SoC Designs
    Simon
