System mode from ntn to lte doesnt save to non volatile memory
Hi! This is a general info post since i have found a temporary fix to it, but whilst trying out ntn, we noticed that when switching from %XSYSTEMMODE: 0,0,1,0,0 to %XSYSTEMMODE: 1,1,1,3,0 CFUN=1 hangs and causes the config to not be saved thus remaining stuck in ntn mode, working with monogoto, we figured the only fix was to run a factory reset then to run the system mode command and CFUN=1 which this time doesnt hang.
  • I do not have a serial connection to my board, only rtt, and i could not find a sample named serial modem to adapt to rtt thus i cannot try it, this is the sequence of at commands i currently run tho.
    00> [00:01:37.034,149] <inf> ntn_manager: NTN: AT> AT%XSYSTEMMODE=0,0,0,0,1 [SYSMODE NTN]
    00> [00:01:37.041,320] <inf> ntn_manager: NTN: AT< OK [SYSMODE NTN] dt=7ms
    00> [00:01:37.041,412] <inf> ntn_manager: NTN: AT> AT%XBANDLOCK=2,,"23,255,256" [BANDLOCK]
    00> [00:01:37.042,175] <inf> ntn_manager: NTN: AT< OK [BANDLOCK] dt=1ms
    00> [00:01:37.042,236] <inf> ntn_manager: NTN: AT> AT%LOCATION=1 [LOCATION subscribe]
    00> [00:01:37.042,999] <inf> ntn_manager: NTN: AT< OK [LOCATION subscribe] dt=0ms
    00> [00:01:37.050,598] <inf> ntn_manager: NTN: modem location set: lat=--.------ lon=--.------ alt=146.5 acc=0 val=0 (infinite)
    00> [00:01:37.050,659] <inf> ntn_manager: NTN: AT> AT+CGDCONT=0,"IP","data.mono" [CGDCONT NTN IP]
    00> [00:01:37.051,361] <inf> ntn_manager: NTN: AT< OK [CGDCONT NTN IP] dt=1ms
    00> [00:01:37.051,422] <inf> ntn_manager: NTN: AT> AT+CEREG=5 [CEREG]
    00> [00:01:37.051,971] <inf> ntn_manager: NTN: AT< OK [CEREG] dt=0ms
    00> [00:01:37.052,001] <inf> ntn_manager: NTN: AT> AT+CNEC=24 [CNEC]
    00> [00:01:37.052,581] <inf> ntn_manager: NTN: AT< OK [CNEC] dt=1ms
    00> [00:01:37.052,642] <inf> ntn_manager: NTN: AT> AT+CSCON=3 [CSCON]
    00> [00:01:37.053,192] <inf> ntn_manager: NTN: AT< OK [CSCON] dt=1ms
    00> [00:01:37.053,253] <inf> ntn_manager: NTN: AT> AT%MDMEV=2 [MDMEV]
    00> [00:01:37.053,802] <inf> ntn_manager: NTN: AT< OK [MDMEV] dt=0ms
    00> [00:01:37.053,833] <inf> ntn_manager: NTN: Skylo - sending AT%SKYLO=0,1 and AT%SKYLO=1,1
    00> [00:01:37.053,894] <inf> ntn_manager: NTN: AT> AT%SKYLO=0,1 [SKYLO generic]
    00> [00:01:37.054,687] <inf> ntn_manager: NTN: AT< OK [SKYLO generic] dt=1ms
    00> [00:01:37.054,748] <inf> ntn_manager: NTN: AT> AT%SKYLO=1,1 [SKYLO MO-device]
    00> [00:01:37.055,572] <inf> ntn_manager: NTN: AT< OK [SKYLO MO-device] dt=1ms
    00> [00:01:37.055,572] <inf> ntn_manager: NTN: Skylo AT commands accepted (OK)
    00> [00:01:37.055,664] <inf> ntn_manager: NTN: AT> AT+CPSMS=1,"","","10100101","10000011" [CPSMS NTN]
    00> [00:01:37.056,243] <inf> ntn_manager: NTN: AT< OK [CPSMS NTN] dt=1ms
    00> [00:01:37.056,304] <inf> ntn_manager: NTN: AT> AT+CFUN=1 [CFUN=1]
    00> [00:01:37.080,505] <inf> ntn_manager: NTN: AT< OK [CFUN=1] dt=24ms
    and the next command that hangs is AT+CFUN=0 about 5 minutes later
  • Is there a modem trace option to use rtt instead of serial?
  • Hello, apologies for the late reply, I have been out of office the last days.
    Yes, we do have support for modem tracing over RTT.
    There should be support for this in the serial modem application
    Then in JLink RTT Viewer use Logging -> Start Data logging.
    Øyvind
  • issue is currently being resolved in private ticket, possible firmware issue, TBD.
