Segger RTT (NCS 3.2.4)
We are developing the nRF5340 for the Thingy91X based on Connectivity Bridge (NCS 3.2.4).
I want to output logs from SWD and view them with RTT Viewer, but even when I call LOG_INF() or printk() at the beginning of the main function, no logs are output at all.
The following definitions are already present in prj.conf, but are there any other settings that need to be configured?
prj.conf
# Logging
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_RTT_MODE_DROP=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_LOG_PRINTK=y
# Console
CONFIG_CONSOLE=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_LOG_BACKEND_UART=n
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
# printk support
CONFIG_PRINTK=y
main.c
 * Copyright (c) 2020 Nordic Semiconductor ASA
#include <zephyr/kernel.h>
#include <app_event_manager.h>
#include <hw_id.h>
#define MODULE main
#include "module_state_event.h"
LOG_MODULE_REGISTER(MODULE);
static uint8_t usb_serial_str[] = "THINGY91_12PLACEHLDRS";
/* Overriding weak function to set iSerialNumber at runtime. */
uint8_t *usb_update_sn_string_descriptor(void)
#if defined(CONFIG_SOC_SERIES_NRF52X)
	snprintk(usb_serial_str, sizeof(usb_serial_str), "THINGY91_%04X%08X",
				(uint32_t)(NRF_FICR->DEVICEADDR[1] & 0x0000FFFF)|0x0000C000,
				(uint32_t)NRF_FICR->DEVICEADDR[0]);
#else
	char buf[HW_ID_LEN] = {0};
	if (!hw_id_get(buf, ARRAY_SIZE(buf))) {
		snprintk(usb_serial_str, sizeof(usb_serial_str), "THINGY91X_%s", buf);
	return usb_serial_str;
	LOG_ERR("This is a error message!");
	LOG_WRN("This is a warning message!");
	LOG_INF("This is a information message!");
	LOG_DBG("This is a debugging message!");
	printk("This is a printk message!");
	if (app_event_manager_init()) {
		LOG_ERR("Application Event Manager not initialized");
	} else {
		module_set_state(MODULE_STATE_READY);
	return 0;
  • Thanks for confirming. To ensure that it is not entering a boot loop either, please try adding CONFIG_RESET_ON_FATAL_ERROR=n to your project configuration file (prj.conf)
  • Oh ... my bad!
    Too many modem traces!
    You just want logging, so that snippet is wrong.
  • Adding CONFIG_RESET_ON_FATAL_ERROR=n did not change the situation.
  • Thanks for confirming. To help verify your setup, please try programming the attached hex file and see if that works which I've confirmed worked on my end. It's based on the "Hello World" sample, but changed the code to the following:
    #include <stdio.h>
    LOG_MODULE_REGISTER(app);
    	LOG_INF("RTT test");
    	for(;;) {
    		printk("Hello World! %s\n", CONFIG_BOARD_TARGET);
    		k_msleep(1000);
    and added the following two lines to the project configuration (prj.conf):
    CONFIG_LOG=y
    Expected output
    Hex file
    8015.merged.hex
  • When I write the provided hex file, "Hello World!" is displayed in the RTT Viewer (updated two lines every two seconds).
    I tried adding that main statement to the Connectivity Bridge's default code, but nothing is displayed in the RTT Viewer.
    #include <hw_id.h>
    #define MODULE main
    #else
    	for(;;) {
    		k_msleep(1000);
    	} else {
    	return 0;
