https_client sample: connection refused
We are working on a project in which data must be sent to server using NB-Iot.
We are struggling establishing an HTTPS connection with a server using the NRF9160 development kit.
As a starting point I copied some parts of the https_client sample from the sdk-nrf repo (v3.2.2). Here is the code:
static int Test()
	int err;
	printk("HTTPS client sample started\n\r");
	/* Setup handler for Zephyr NET Connection Manager events. */
	net_mgmt_init_event_callback(&l4_cb, l4_event_handler, L4_EVENT_MASK);
	net_mgmt_add_event_callback(&l4_cb);
	/* Setup handler for Zephyr NET Connection Manager Connectivity layer. */
	net_mgmt_init_event_callback(&conn_cb, connectivity_event_handler, CONN_LAYER_EVENT_MASK);
	net_mgmt_add_event_callback(&conn_cb);
	printk("Bringing network interface up\n");
	/* Connecting to the configured connectivity layer.
	 * Wi-Fi or LTE depending on the board that the sample was built for.
	err = conn_mgr_all_if_up(true);
	if (err) {
		printk("conn_mgr_all_if_up, error: %d\n", err);
		return err;
	 /* Provision certificates before connecting to the network */
	err = cert_provision();
	if (err) {
		return 0;
	printk("Connecting to the network\n");
	err = conn_mgr_all_if_connect(true);
	if (err) {
		printk("conn_mgr_all_if_connect, error: %d\n", err);
		return 0;
	/* Resend connection status if the sample is built for NATIVE_SIM.
	 * This is necessary because the network interface is automatically brought up
	 * at SYS_INIT() before main() is called.
	 * This means that NET_EVENT_L4_CONNECTED fires before the
	 * appropriate handler l4_event_handler() is registered.
	if (IS_ENABLED(CONFIG_BOARD_NATIVE_SIM)) {
		conn_mgr_mon_resend_status();
	k_sem_take(&network_connected_sem, K_FOREVER);
	send_http_request();
	/* A small delay for the TCP connection teardown */
	k_sleep(K_SECONDS(1));
	/* The HTTP transaction is done, take the network connection down */
	err = conn_mgr_all_if_disconnect(true);
	if (err) {
		printk("conn_mgr_all_if_disconnect, error: %d\n", err);
	err = conn_mgr_all_if_down(true);
	if (err) {
		printk("conn_mgr_all_if_down, error: %d\n", err);
	return 0;
int cert_provision(void)
	int err;
	printk("Provisioning certificate\n");
#if CONFIG_MODEM_KEY_MGMT
	bool exists;
	int mismatch;
	/* It may be sufficient for you application to check whether the correct
	 * certificate is provisioned with a given tag directly using modem_key_mgmt_cmp().
	 * Here, for the sake of the completeness, we check that a certificate exists
	 * before comparing it with what we expect it to be.
	err = modem_key_mgmt_exists(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, &exists);
	if (err) {
		printk("Failed to check for certificates err %d\n", err);
		return err;
	if (exists) {
		mismatch = modem_key_mgmt_cmp(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert,
					      sizeof(cert));
		if (!mismatch) {
			printk("Certificate match\n");
			return 0;
		printk("Certificate mismatch\n");
		err = modem_key_mgmt_delete(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN);
		if (err) {
			printk("Failed to delete existing certificate, err %d\n", err);
	printk("Provisioning certificate to the modem\n");
	/*  Provision certificate to the modem */
	err = modem_key_mgmt_write(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert,
				   sizeof(cert));
	if (err) {
		printk("Failed to provision certificate, err %d\n", err);
		return err;
#else /* CONFIG_MODEM_KEY_MGMT */
	err = tls_credential_add(TLS_SEC_TAG,
				 TLS_CREDENTIAL_CA_CERTIFICATE,
				 cert,
				 sizeof(cert));
	if (err == -EEXIST) {
		printk("CA certificate already exists, sec tag: %d\n", TLS_SEC_TAG);
	} else if (err < 0) {
		printk("Failed to register CA certificate: %d\n", err);
		return err;
#endif /* !CONFIG_MODEM_KEY_MGMT */
	return 0;
int tls_setup(int fd)
	int err;
	int verify;
	/* Security tag that we have provisioned the certificate with */
	const sec_tag_t tls_sec_tag[] = {
		TLS_SEC_TAG,
	/* Set up TLS peer verification */
	enum {
		NONE = 0,
		OPTIONAL = 1,
		REQUIRED = 2,
	verify = REQUIRED;
	err = setsockopt(fd, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
	if (err) {
		printk("Failed to setup peer verification, err %d\n", errno);
		return err;
	/* Associate the socket with the security tag
	 * we have provisioned the certificate with.
	err = setsockopt(fd, SOL_TLS, TLS_SEC_TAG_LIST, tls_sec_tag, sizeof(tls_sec_tag));
	if (err) {
		printk("Failed to setup TLS sec tag, err %d\n", errno);
		return err;
	err = setsockopt(fd, SOL_TLS, TLS_HOSTNAME,
			CONFIG_HTTPS_HOSTNAME,
			sizeof(CONFIG_HTTPS_HOSTNAME) - 1);
	if (err) {
		printk("Failed to setup TLS hostname, err %d\n", errno);
		return err;
	return 0;
static void on_net_event_l4_disconnected(void)
	printk("Disconnected from the network\n");
static void on_net_event_l4_connected(void)
	k_sem_give(&network_connected_sem);
static void l4_event_handler(struct net_mgmt_event_callback *cb,
			     uint64_t event,
			     struct net_if *iface)
	switch (event) {
	case NET_EVENT_L4_CONNECTED:
		printk("Network connectivity established and IP address assigned\n");
		on_net_event_l4_connected();
	case NET_EVENT_L4_DISCONNECTED:
		printk("Network connectivity lost\n");
		on_net_event_l4_disconnected();
static void connectivity_event_handler(struct net_mgmt_event_callback *cb,
				       uint64_t event,
	if (event == NET_EVENT_CONN_IF_FATAL_ERROR) {
		printk("Fatal error received from the connectivity layer\n");
		return;
I am getting this warning and error :
<wrn> modem_key_mgmt: Failed to retrieve CMEE status, err -1
Failed to check for certificates err -1
I noticed that in this example the function nrf_modem_lib_init() is never called, i don't really understand why it use in some examples and not in others.
I thought that maybe the problem was coming from the project configuration so secondly I used directly the sample by cloning it on my computer.
Now I am getting this log:
Certificate match
+CEREG: 2,"BD84","09A19608",7
+CSCON: 1
+CGEV: ME PDN ACT 0,0
+CNEC_ESM: 50,0
%MDMEV: SEARCH STATUS 2
+CEREG: 5,"BD84","09A19608",7,,,"11100000","11100000"
Looking up example.com
Resolved 172.66.147.243 (AF_INET)
Connecting to example.com:443
connect() failed, err: 111
+CGEV: ME PDN DEACT 0
+CEREG: 0
+CGEV: ME DETACH
+CSCON: 0
connect() returns 111 (connection refused).
I must admit I am quite lost on which libraries to use (zephyr vs nrf) to setup Nb-IOT vs Lte-M and TLS.
I just want to make a simple HTTPS POST request via NB-IOT.
Any help would be greatly appreciated.
Thank you,
Arthur
    Apologies for a late response. Even though you've set CONFIG_LTE_LC_PDN_DEFAULT_FAM_IPV4=y to request an IPv4 only, your prj.conf still may have both CONFIG_NET_IPV4=y and CONFIG_NET_IPV6=y. The Connection Manager may be waiting for an IPv6 address that will never arrive.
    So before any other changes can you try adding CONFIG_NET_IPV6=n to prj.conf and pristine build. Let us know if it works. Thanks
    Best Regards,
    Syed Maysum
