WHY I AM GETTIG THE 66.3 microA for this code in the nrf52840
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "nrf_clock.h"
#include "nrf_power.h"
#include "nrfx_rtc.h"
#include "app_error.h"
#define WAKEUP_SECONDS 10
#define TICKS 8
// Configuration
const nrfx_rtc_t rtc_inst = NRFX_RTC_INSTANCE(2);
/** @brief Handler for RTC interrupts */
void rtc_handler(nrfx_rtc_int_type_t int_type)
if (int_type == NRFX_RTC_INT_COMPARE0)
// 1. Get the current counter value
uint32_t current_ticks = nrfx_rtc_counter_get(&rtc_inst);
// 2. Set the next wakeup relative to "now"
uint32_t next_wakeup = current_ticks + (WAKEUP_SECONDS * TICKS);
// 3. Handle the 24-bit mask (RTC counter is 24-bit)
next_wakeup &= RTC_COUNTER_COUNTER_Msk;
nrfx_rtc_cc_set(&rtc_inst, 0, next_wakeup, true);
/** @brief Start LFRC (Internal RC) for ION_RAMOFF_RTC 1.50 uA profile */
static void lfclk_config(void)
// Use direct register access to avoid "nrf_clock_lf_src_t" type errors
// 0 = RC Oscillator
NRF_CLOCK->LFCLKSRC = (CLOCK_LFCLKSRC_SRC_RC << CLOCK_LFCLKSRC_SRC_Pos);
NRF_CLOCK->TASKS_LFCLKSTART = 1;
while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
/** @brief Configure RTC2 */
static void rtc_config(void)
nrfx_rtc_config_t config = NRFX_RTC_DEFAULT_CONFIG;
config.prescaler = 4095; // 8 Hz
uint32_t err_code = nrfx_rtc_init(&rtc_inst, &config, rtc_handler);
nrfx_rtc_cc_set(&rtc_inst, 0,WAKEUP_SECONDS*TICKS, true);
nrfx_rtc_enable(&rtc_inst);
/** @brief Disable RAM retention to hit the 1.50 uA target */
static void disable_ram_retention(void)
// On nRF52840, there are 9 RAM sections.
// We disable sections 2-8 to preserve the stack (usually in section 0 or 1).
// Writing 0xFFFFFFFF to POWERCLR turns off Power and Retention for that block.
for (int i = 1; i <= 6; i++)
NRF_POWER->RAM[i].POWERCLR = /*0xFFFFFFFF*/1;
void power_off_all_unused_peripherals(void)
// 1. Reset all GPIO pins to 'Input Disconnected' (The default reset state)
// nRF52840 has 32 pins on Port 0 and 16 pins on Port 1.
for (uint32_t i = 0; i < 32; i++) {
NRF_P0->PIN_CNF[i] = (GPIO_PIN_CNF_INPUT_Disconnect << GPIO_PIN_CNF_INPUT_Pos);
for (uint32_t i = 0; i < 16; i++) {
NRF_P1->PIN_CNF[i] = (GPIO_PIN_CNF_INPUT_Disconnect << GPIO_PIN_CNF_INPUT_Pos);
// 2. Disable high-power EasyDMA peripherals
NRF_UARTE0->ENABLE = 0; NRF_UARTE1->ENABLE = 0;
NRF_SPIM0->ENABLE = 0; NRF_SPIM1->ENABLE = 0;
NRF_SPIM2->ENABLE = 0; NRF_SPIM3->ENABLE = 0;
NRF_TWIM0->ENABLE = 0; NRF_TWIM1->ENABLE = 0;
NRF_QSPI->ENABLE = 0;
// 3. Power cycle DMA blocks (Workaround for base current leakage)
*(volatile uint32_t *)0x40002FFC = 0; // UARTE0
*(volatile uint32_t *)0x40003FFC = 0; // SPIM0/TWIM0
*(volatile uint32_t *)0x40004FFC = 0; // SPIM1/TWIM1
*(volatile uint32_t *)0x40023FFC = 0; // SPIM2
*(volatile uint32_t *)0x40028FFC = 0; // UARTE1
*(volatile uint32_t *)0x40029FFC = 0; // QSPI
*(volatile uint32_t *)0x4002FFFC = 0; // SPIM3
// 4. Disable Radio and Analog blocks
NRF_SAADC->ENABLE = 0;
NRF_RADIO->TASKS_DISABLE = 1;
NRF_NFCT->TASKS_DISABLE = 1;
NRF_COMP->ENABLE = 0;
NRF_LPCOMP->ENABLE = 0;
// 5. Disable PWM, PDM, and I2S
NRF_PWM0->ENABLE = 0; NRF_PWM1->ENABLE = 0;
NRF_PWM2->ENABLE = 0; NRF_PWM3->ENABLE = 0;
NRF_PDM->ENABLE = 0; NRF_I2S->ENABLE = 0;
// 6. Stop unused Timers/RTCs (Keep RTC2 active!)
NRF_TIMER0->TASKS_STOP = 1; NRF_TIMER1->TASKS_STOP = 1;
NRF_TIMER2->TASKS_STOP = 1; NRF_TIMER3->TASKS_STOP = 1;
NRF_TIMER4->TASKS_STOP = 1;
NRF_RTC0->TASKS_STOP = 1; NRF_RTC1->TASKS_STOP = 1;
// 7. Kill PPI and GPIOTE
NRF_PPI->CHEN = 0;
for (int i = 0; i < 8; i++) { NRF_GPIOTE->CONFIG[i] = 0; }
NRF_CLOCK->TASKS_HFCLKSTOP = 1;
// 1. Initialize Clock
// log_init();
power_off_all_unused_peripherals();
lfclk_config();
// 2. Initialize RTC
rtc_config();
// 3. Drop RAM power (RAMOFF state)
disable_ram_retention();
// 4. Enter System ON sleep
while (true)
__WFE();
__SEV();
__WFE();
  • The difference from the 70 uA to the 3 uA is i disconected jlink pins to my the custom board so i got the 3 uA
    #include <stdint.h>
    #include "nrf.h"
    #define TICKS 8
    next_wakeup &= RTC_COUNTER_COUNTER_Msk; // 24-bit mask
    /** @brief Start LFRC (Internal RC oscillator) */
    /** @brief Configure RTC2 with 8 Hz tick rate */
    config.prescaler = 4095; // 32768 / (4095+1) = 8 Hz
    nrfx_rtc_cc_set(&rtc_inst, 0, WAKEUP_SECONDS * TICKS, true);
    /** @brief Disable ALL RAM retention (RAMOFF state) */
    // nRF52840 has RAM blocks 0-8 (9 total).
    // Write 0xFFFFFFFF to POWERCLR to clear all Power and Retention bits.
    for (int i = 0; i <= 8; i++)
    NRF_POWER->RAM[i].POWERCLR = 0xFFFFFFFF;
    /** @brief Shut down all unused peripherals */
    static void power_off_all_unused_peripherals(void)
    // 1. Disconnect all GPIO pins
    // 2. Disable EasyDMA peripherals
    // 3. Power cycle DMA blocks (errata workaround for leakage)
    // 5. Disable PWM, PDM, I2S
    // 6. Stop unused Timers and RTCs (keep RTC2 active!)
    // 7. Disable PPI and all GPIOTE channels (event mode adds ~17 uA!)
    NRF_PPI->CHEN = 0;
    // 8. Stop HFCLK
    // power_off_all_unused_peripherals();
    lfclk_config();
    // Enable DC/DC converter (up to 35% power savings)
    nrf_power_dcdcen_set(true);
    rtc_config();
    // Disable all RAM retention -> RAMOFF state (target: 1.50 uA)
    // disable_ram_retention();
    // System ON sleep loop
    while (true)
    __WFE();
    __SEV();
    __WFE();
    Great. Glad to hear that you solved your problem!
    Håkon
  • System ON, no RAM retention, wake on RTC (running from LFRC clock)
    You cannot wake up with unpowered RAM in systemon idle mode. Or you could, but it will fail horribly.
    explain
    then why the above feautre is present in the datasheet explain
  • When you wake up from system on, you will start execution from the program counter.
    If you then access cleared / uninitialised RAM, your firmware will not execute as wanted.
    It is to show how much the RAM retention adds in sleep, but I agree; it is not a great metric, since waking up with no RAM retention is not a wanted scenario.
    Håkon
  • Hii Sir,
    I just want one thing give me the code or tips to implement the System ON, no RAM retention, wake on RTC (running from LFRC clock).
    please give me the reasonable answer or code
