LATCH Register does not correctly indicate GPIO after wakeup from SYSTEM OFF
Hello Nordic-Team,
 I am using the SENSING mechanism on GPIOs to wake up a firmware from SYSTEM OFF. Two GPIOs are used for this and it is crucial for the firmware to detect which GPIO caused the wakeup.
On a nRF54L05 (nRF54L15 used as nRF54L05) I am able to readout the GPIO that caused the wakeup, on a nRF54LS05B the corresponding bits for both GPIOs are set even if only one button was pressed, so that I cannot detect the wakeup reason.
Please find attached a test firmware which I used with nRF Connect SDK v3.3.0 on a nRF54L15-DK and a nRF54LS05-DK.
Button0 and Button1 are used to wakeup the firmware.
Best regards
sensing_test_app.zip
    Stefan Schmidt said:
    Sorry, please ignore my posts from today! I confused myself, the IN register shows the actual level on the port, so having both set is perfectly ok for two GPIOs with PULLUPs....
    Thank you for updating, I am really glad to hear that you got the workaround running as expected.
    I haven't yet heard anything from R&D, but I will keep you updated.
    Håkon
  • Hi Håkon,
     my workaround is this tiny function that I register to the start of the mcuboot. It is called pretty early in mcuboot and writes the current value of the LATCH register into the LATCH register:
    Either the button is in the active state in this moment, then the corresponding bit in the LATCH will not be cleared, or it is still bouncing, so that a later matching condition will be latched.
    #ifdef CONFIG_MCUBOOT
    #include <hal/nrf_gpio.h>
    #include <zephyr/init.h>
    #include <zephyr/kernel.h>
    static int latch_workaround(void)
        uint32_t p0_latch = NRF_P0->LATCH;
        NRF_P0->LATCH = p0_latch;
        return 0;
    SYS_INIT(latch_workaround, PRE_KERNEL_1, 0);
    Does that make sense?
    This is actually the position in the init process of the mcuboot:
    EARLY
      __init_nordicsemi_nrf54l_init: nordicsemi_nrf54l_init(NULL)
      __init_sys_clock_driver_init: sys_clock_driver_init(NULL)
    PRE_KERNEL_1
      __init_latch_workaround: latch_workaround(NULL)
      __init___device_dts_ord_40: clk_init(__device_dts_ord_40)
      __init___device_dts_ord_74: uarte_20_init(__device_dts_ord_74)
      __init_uart_console_init: uart_console_init(NULL)
    PRE_KERNEL_2
      __init_grtc_post_init: grtc_post_init(NULL)
    POST_KERNEL
      __init_malloc_prepare: malloc_prepare(NULL)
      __init___device_dts_ord_87: nrf_rram_init(__device_dts_ord_87)
      __init__psa_crypto_init: _psa_crypto_init(NULL)
      __init_mbedtls_heap_init: mbedtls_heap_init(NULL)
    APPLICATION
    SMP
    Best regards
    Stefan
  • Hi Stefan,
    What is the intention behind this snippet? Is it to clear it and use it exclusively for debouncing in the application space?
    This code will help with debouncing, but only if you want to read it again in the application:
    Writing '1' to the source bit will clear the corresponding source:
    https://docs.nordicsemi.com/bundle/ps_nrf54LS05A/page/gpio.html#ariaid-title17
    meaning that your code snippet, ie. NRF_P0->LATCH = NRF_P0->LATCH; will clear the register as a whole.
    Håkon
  • Hi Håkon
    The idea is to clear the LATCH (which will contain both bits set at this moment) very shortly after the wakeup from SYSTEM OFF. At that moment, the triggering GPIO will still be bouncing.
    So at the moment of resetting the LATCH, if the GPIO is
    • "active" >  the corresponding bit in the LATCH will not be cleared
    • "not active" > due to bouncing the bit will be set again in the bouncing phase in the next microseconds.
    So when I read the LATCH in the application (600 ms later) I read the expected value and circumvent the issue that I described.
    Best regards
  • Hi Stefan,
    Thank you for confirming your wanted behaviour. I had to double-check the intention.
    I can confirm that it makes sense, based on your wanted behaviour.
    Håkon
