multiple BLE connections
I have a combined asset_tracker_v2 and central_main. I can connect perfectly and receive data from a single BLE advertiser. I need to be able to connect to 1-4 simultaneous advertisers. I see that there is a single default_conn that is used to manage the connection. I modified prj.conf as follows:
# Increase max connections (e.g., 4)
CONFIG_BT_MAX_CONN=4
CONFIG_BT_MAX_PAIRED=4
I also changed the following in my central_main
static struct bt_conn *default_conn;
static struct bt_conn *Gconn[CONFIG_BT_MAX_CONN];
static uint8_t conn_count = 0;
I am not sure how to replace default_conn (It is used in many places) with Gconn[conn_count] and what I need to do to connect to all of the advertisers and receive data from all of the advertisers. any help you can give would be greatly appreciated. This is in testing to go into customer evaluation and production. I have attached the central_main code. This is slightly modified from the original central_uart to be able to run with asset_tracker_v2.
 * Copyright (c) 2018 Nordic Semiconductor ASA
/** @file
 *  @brief Nordic UART Service Client sample
#include <errno.h>
#include <zephyr/device.h>
#include <zephyr/kernel.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/uuid.h>
#include <bluetooth/gatt_dm.h>
#include <bluetooth/scan.h>
#include <bluetooth/services/nus.h>
#include <bluetooth/services/nus_client.h>
#include <zephyr/settings/settings.h>
#include <zephyr/drivers/uart.h>
#include "jfet_files/jfet_common.h"
#include "mainpage.h"
#include <zephyr/drivers/watchdog.h>
/* merge */
#ifdef LTE_MERGE
// #include <zephyr/kernel.h>
// #include <stdio.h>
// #include <string.h>
// #include <stdlib.h>
// #include <app_event_manager.h>
// #include <modem/nrf_modem_lib.h>
// #include <zephyr/sys/reboot.h>
// #include <net/nrf_cloud.h>
/* Module name is used by the Application Event Manager macros in this file */
// #define MODULE main
// #include <caf/events/module_state_event.h>
// #include "modules_common.h"
// #include "events/app_module_event.h"
// #include "events/cloud_module_event.h"
// #include "events/data_module_event.h"
// #include "events/sensor_module_event.h"
// #include "events/util_module_event.h"
// #include "events/modem_module_event.h"
// #include <zephyr/logging/log.h>
// #include <zephyr/logging/log_ctrl.h>
// #include "jfet_files/jfet_common.h"
/* uncomment out if using thread */
#define USE_THREAD 1
#define LOG_MODULE_NAME central_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME, 4);
///* UART payload buffer element size. */
// #define UART_BUF_SIZE 20
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define NUS_WRITE_TIMEOUT K_MSEC(150)
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_RX_TIMEOUT 50000 /* Wait for RX complete event time in microseconds. */
// static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
// static struct k_work_delayable uart_work;
static struct k_work scan_work;
K_SEM_DEFINE(nus_write_sem, 0, 1);
// struct uart_data_t
//	void *fifo_reserved;
//	uint8_t data[UART_BUF_SIZE];
//	uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
K_FIFO_DEFINE(fifo_uart_rx_data);
static struct bt_nus_client nus_client;
static void ble_data_sent(struct bt_nus_client *nus, uint8_t err, const uint8_t *const data, uint16_t len) {
  ARG_UNUSED(nus);
  ARG_UNUSED(data);
  ARG_UNUSED(len);
  k_sem_give(&nus_write_sem);
  if (err) {
    LOG_WRN("ATT error code: 0x%02X", err);
static uint8_t ble_data_received(struct bt_nus_client *nus, const uint8_t *data, uint16_t len) {
  ARG_UNUSED(nus);
  char bleData[60];
  //	int64_t time_ms = k_uptime_get();
  memset(bleData, 0, sizeof(bleData));
  strncpy(bleData, data, len);
  bleData[len] = '\0';
  // myPrintkW("ble_data_received() entered... %s\n", bleData);
  //	printk("ble_data_received() entered... len=%d\n", len);
  //	printk("ble_data_received() uptime %3.2f ... len=%d\n", time_ms / 1000.0, len);
  //	printk("ble_data_received() uptime %3.2f len=%d ", time_ms / 1000.0, len);
  //	myPrintkI("\"%s\"\r\n", bleData);
  parseBLEString(bleData);
  //	myPrintkI("BLEID: %s BLEHDCTemp: %s BLEHDCHum: %3.2f\r\n", BLEID, BLEHDCTemp, BLEHDCHum);
  ARG_UNUSED(nus);
#if 0
	int err;
	for (uint16_t pos = 0; pos != len;)
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx)
			LOG_WRN("Not able to allocate UART send data buffer");
			return BT_GATT_ITER_CONTINUE;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx->data) - 1;
		if ((len - pos) > tx_data_size)
			tx->len = tx_data_size;
			tx->len = (len - pos);
		memcpy(tx->data, &data[pos], tx->len);
		pos += tx->len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) && (data[len - 1] == '\r'))
			tx->data[tx->len] = '\n';
			tx->len++;
		err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
		if (err)
			k_fifo_put(&fifo_uart_tx_data, tx);
		k_free(tx);
#if 0
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data) {
  ARG_UNUSED(dev);
  static size_t aborted_len;
  struct uart_data_t *buf;
  static uint8_t *aborted_buf;
  static bool disable_req;
  switch (evt->type) {
  case UART_TX_DONE:
    LOG_DBG("UART_TX_DONE");
    if ((evt->data.tx.len == 0) || (!evt->data.tx.buf)) {
      return;
    if (aborted_buf) {
      buf = CONTAINER_OF(aborted_buf, struct uart_data_t, data[0]);
      aborted_buf = NULL;
      aborted_len = 0;
    } else {
      buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t, data[0]);
    k_free(buf);
    buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
    if (!buf) {
      return;
    if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
      LOG_WRN("Failed to send data over UART");
  case UART_RX_RDY:
    LOG_DBG("UART_RX_RDY");
    buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data[0]);
    buf->len += evt->data.rx.len;
    if (disable_req) {
      return;
    if ((evt->data.rx.buf[buf->len - 1] == '\n') || (evt->data.rx.buf[buf->len - 1] == '\r')) {
      disable_req = true;
      uart_rx_disable(uart);
  case UART_RX_DISABLED:
    LOG_DBG("UART_RX_DISABLED");
    disable_req = false;
    buf = k_malloc(sizeof(*buf));
    if (buf) {
      buf->len = 0;
    } else {
      LOG_WRN("Not able to allocate UART receive buffer");
      k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
      return;
    uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_RX_TIMEOUT);
  case UART_RX_BUF_REQUEST:
    LOG_DBG("UART_RX_BUF_REQUEST");
    if (buf) {
      buf->len = 0;
      uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
    } else {
  case UART_RX_BUF_RELEASED:
    LOG_DBG("UART_RX_BUF_RELEASED");
    printf("\r\n\nUART_RX_BUF_RELEASED\r\n");
    buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t, data[0]);
    if (buf->len > 0) {
      k_fifo_put(&fifo_uart_rx_data, buf);
    } else {
      k_free(buf);
  case UART_TX_ABORTED:
    LOG_DBG("UART_TX_ABORTED");
    if (!aborted_buf) {
      aborted_buf = (uint8_t *)evt->data.tx.buf;
    aborted_len += evt->data.tx.len;
    uart_tx(uart, &buf->data[aborted_len], buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item) {
  if (buf) {
    buf->len = 0;
  } else {
    return;
static int uart_init(void) {
  int err;
  struct uart_data_t *rx;
  if (!device_is_ready(uart)) {
    LOG_ERR("UART device not ready");
    return -ENODEV;
  rx = k_malloc(sizeof(*rx));
  if (rx) {
    rx->len = 0;
  } else {
    return -ENOMEM;
  k_work_init_delayable(&uart_work, uart_work_handler);
  err = uart_callback_set(uart, uart_cb, NULL);
  if (err) {
    return err;
  return uart_rx_enable(uart, rx->data, sizeof(rx->data), UART_RX_TIMEOUT);
static void discovery_complete(struct bt_gatt_dm *dm, void *context) {
  struct bt_nus_client *nus = context;
  LOG_INF("Service discovery completed");
  bt_gatt_dm_data_print(dm);
  bt_nus_handles_assign(dm, nus);
  bt_nus_subscribe_receive(nus);
  bt_gatt_dm_data_release(dm);
static void discovery_service_not_found(struct bt_conn *conn, void *context) { LOG_INF("Service not found"); }
static void discovery_error(struct bt_conn *conn, int err, void *context) { LOG_WRN("Error while discovering GATT database: (%d)", err); }
struct bt_gatt_dm_cb discovery_cb = {
    .completed = discovery_complete,
    .service_not_found = discovery_service_not_found,
    .error_found = discovery_error,
static void gatt_discover(struct bt_conn *conn) {
  int err;
  myPrintkS("gatt_discover() entered... count: %d\n", conn_count);
  if (conn != default_conn) {
    return;
  myPrintkS("bt_gatt_dm_start() entered...\n");
  err = bt_gatt_dm_start(conn, BT_UUID_NUS_SERVICE, &discovery_cb, &nus_client);
  myPrintkS("bt_gatt_dm_start() returned...%d \n", err);
  if (err) {
    LOG_ERR("could not start the discovery procedure, error "
            "code: %d",
            err);
static void exchange_func(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params) {
  if (!err) {
    LOG_INF("MTU exchange done");
  } else {
    LOG_WRN("MTU exchange failed (err %" PRIu8 ")", err);
static void connected(struct bt_conn *conn, uint8_t conn_err) {
  int err;
  // myPrintkW("connected() entered... %s\n", addr);
  //  myPrintkW("bt_addr_le_to_str() returned... %s\n", addr);
  if (conn_err) {
    LOG_INF("Failed to connect to %s, 0x%02x %s", addr, conn_err, bt_hci_err_to_str(conn_err));
    if (default_conn == conn) {
      bt_conn_unref(default_conn);
      default_conn = NULL;
      (void)k_work_submit(&scan_work);
    return;
  myPrintkI("BT Connected: %s count: %d\r\n", addr, conn_count);
  //  LOG_INF("Connected: %s", addr);
  static struct bt_gatt_exchange_params exchange_params;
  exchange_params.func = exchange_func;
  err = bt_gatt_exchange_mtu(conn, &exchange_params);
  if (err) {
    LOG_WRN("MTU exchange failed (err %d)", err);
  err = bt_conn_set_security(conn, BT_SECURITY_L2);
  if (err) {
    LOG_WRN("Failed to set security: %d", err);
    gatt_discover(conn);
  //  if (conn_count == CONFIG_BT_MAX_CONN) {
  myPrintkI("Maximum connections reached, stopping scan\r\n");
  err = bt_scan_stop();
  if (err) {
    LOG_ERR("Stop LE scan failed (err %d)", err);
static void disconnected(struct bt_conn *conn, uint8_t reason) {
  LOG_INF("BT Disconnected: %s, reason 0x%02x %s", addr, reason, bt_hci_err_to_str(reason));
  if (default_conn != conn) {
    return;
static void security_changed(struct bt_conn *conn, bt_security_t level, enum bt_security_err err) {
  if (!err) {
    LOG_INF("Security changed: %s level %u", addr, level);
  } else {
    LOG_WRN("Security failed: %s level %u err %d %s", addr, level, err, bt_security_err_to_str(err));
BT_CONN_CB_DEFINE(conn_callbacks) = {.connected = connected, .disconnected = disconnected, .security_changed = security_changed};
static void scan_filter_match(struct bt_scan_device_info *device_info, struct bt_scan_filter_match *filter_match, bool connectable) {
  bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
  LOG_INF("Filters matched. Address: %s connectable: %d", addr, connectable);
static void scan_connecting_error(struct bt_scan_device_info *device_info) { LOG_WRN("Connecting failed"); }
static void scan_connecting(struct bt_scan_device_info *device_info, struct bt_conn *conn) { default_conn = bt_conn_ref(conn); }
// static void scan_connecting(struct bt_scan_device_info * device_info, struct bt_conn * conn) { Gconn[conn_count++] = bt_conn_ref(conn); }
static int nus_client_init(void) {
  int err;
  struct bt_nus_client_init_param init = {.cb = {
                                              .received = ble_data_received,
                                              .sent = ble_data_sent,
  err = bt_nus_client_init(&nus_client, &init);
  if (err) {
    LOG_ERR("NUS Client initialization failed (err %d)", err);
    return err;
  LOG_INF("NUS Client module initialized");
  return err;
BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL, scan_connecting_error, scan_connecting);
static void try_add_address_filter(const struct bt_bond_info *info, void *user_data) {
  int err;
  uint8_t *filter_mode = user_data;
  bt_addr_le_to_str(&info->addr, addr, sizeof(addr));
  struct bt_conn *conn = bt_conn_lookup_addr_le(BT_ID_DEFAULT, &info->addr);
  if (conn) {
    bt_conn_unref(conn);
    return;
  err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_ADDR, &info->addr);
  if (err) {
    LOG_ERR("Address filter cannot be added (err %d): %s", err, addr);
    return;
  LOG_INF("Address filter added: %s", addr);
  *filter_mode |= BT_SCAN_ADDR_FILTER;
static int scan_start(void) {
  int err;
  uint8_t filter_mode = 0;
  if (err) {
    LOG_ERR("Failed to stop scanning (err %d)", err);
    return err;
  bt_scan_filter_remove_all();
  err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_NUS_SERVICE);
  if (err) {
    LOG_ERR("UUID filter cannot be added (err %d", err);
    return err;
  filter_mode |= BT_SCAN_UUID_FILTER;
  bt_foreach_bond(BT_ID_DEFAULT, try_add_address_filter, &filter_mode);
  err = bt_scan_filter_enable(filter_mode, false);
  if (err) {
    LOG_ERR("Filters cannot be turned on (err %d)", err);
    return err;
  err = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
  if (err) {
    LOG_ERR("Scanning failed to start (err %d)", err);
    return err;
  myPrintkI("Scan started\r\n");
  LOG_INF("Scan started");
  return 0;
static void scan_work_handler(struct k_work *item) {
  ARG_UNUSED(item);
  (void)scan_start();
static void scan_init(void) {
  struct bt_scan_init_param scan_init = {
      .connect_if_match = true,
  bt_scan_init(&scan_init);
  bt_scan_cb_register(&scan_cb);
  k_work_init(&scan_work, scan_work_handler);
  LOG_INF("Scan module initialized");
static void auth_cancel(struct bt_conn *conn) {
  LOG_INF("Pairing cancelled: %s", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded) {
  LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason) {
  LOG_WRN("Pairing failed conn: %s, reason %d %s", addr, reason, bt_security_err_to_str(reason));
static struct bt_conn_auth_cb conn_auth_callbacks = {
    .cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {.pairing_complete = pairing_complete, .pairing_failed = pairing_failed};
#if 1
struct k_timer wdt_timer; //!< timer to reset WDT
 * \fn void wdt_handler(struct k_work *work)
 * \brief work function WDT timer handler
 * \param work
void wdt_handler(struct k_work *work) {
  if (stopWDTFeed == 0) /* check if WDT feed disabled*/
    //		myPrintkS("Feeding watchdog... %d\n",stopWDTFeed);
    wdt_feed(wdt, wdt_channel_id);
K_WORK_DEFINE(wdt_work, wdt_handler);
 * \fn void wdt_timer_handler(struct k_timer *dummy)
 * \brief timer CLI command handler
 * timer handler just submits timer work function to the work queue
 * \param dummy pointer to a timer sturcture
void wdt_timer_handler(struct k_timer *dummy) { k_work_submit(&wdt_work); }
#ifdef USE_THREAD
#define MY_STACK_SIZE 1024
#define MY_PRIORITY 7
const k_tid_t my_uart_thread_id;
void my_uart_thread_logic(void *arg1, void *arg2, void *arg3) {
  int err = 0;
  struct uart_data_t nus_data = {
      .len = 0,
  myPrintkI("starting BLE thread\r\n");
  /* Your logic from main()'s loop goes here */
  while (1) {
    // e.g., k_fifo_get(&fifo_uart_rx_data, K_FOREVER);
    // ... process data ...
    /* IMPORTANT: If your loop doesn't have a blocking call like
       k_fifo_get(..., K_FOREVER), you MUST add a sleep to prevent
       starving other threads of the same priority. */
    //	for (;;)
      /* Wait indefinitely for data to be sent over Bluetooth */
      struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data, K_FOREVER);
      printf("\r\n\nUART seen %s\r\n\n", buf->data);
      int plen = MIN(sizeof(nus_data.data) - nus_data.len, buf->len);
      int loc = 0;
      while (plen > 0) {
        memcpy(&nus_data.data[nus_data.len], &buf->data[loc], plen);
        nus_data.len += plen;
        loc += plen;
        if (nus_data.len >= sizeof(nus_data.data) || (nus_data.data[nus_data.len - 1] == '\n') ||
            (nus_data.data[nus_data.len - 1] == '\r')) {
          if (nus_data.data[0] == ':') {
            memset(cliCommand, 0, strlen(cliCommand));
            memcpy(cliCommand, &nus_data.data[1], nus_data.len - 1);
            cliCommand[strlen(cliCommand) - 1] = '\0';
            printf("\r\nCLI Command: %s\r\n", cliCommand);
            executeCmd(cliCommand);
          } else {
            myPrintkI("\r\nBLE Send: %d %s\r\n\n", nus_data.len, nus_data.data);
            err = bt_nus_client_send(&nus_client, nus_data.data, nus_data.len);
            if (err) {
              LOG_WRN("Failed to send data over BLE connection"
                      "(err %d)",
                      err);
            //						err = k_sem_take(&nus_write_sem, NUS_WRITE_TIMEOUT);
            //						if (err)
            //							LOG_WRN("NUS send timeout");
          nus_data.len = 0;
        plen = MIN(sizeof(nus_data.data), buf->len - loc);
      //			k_free(buf);
    k_msleep(10);
#ifdef USE_THREAD
K_THREAD_DEFINE(my_uart_thread_id, MY_STACK_SIZE, my_uart_thread_logic, NULL, NULL, NULL, MY_PRIORITY, 0, 0);
int central_uart_main(void) {
  int err;
  k_msgq_init(&my_msgq1, my_msgq1_buffer, sizeof(struct data_item_type), 1);
  k_msgq_init(&my_msgq2, my_msgq2_buffer, sizeof(struct data_item_type), 1);
  k_msgq_init(&my_msgq3, my_msgq3_buffer, sizeof(struct data_battery_type), 1);
#if 1
  struct wdt_timeout_cfg wdt_config = {
      /* Reset SoC when watchdog timer expires. */
      .flags = WDT_FLAG_RESET_SOC,
      /* Expire watchdog after max window */
      .window.min = WDT_MIN_WINDOW,
      .window.max = WDT_MAX_WINDOW,
  err = bt_conn_auth_cb_register(&conn_auth_callbacks);
  if (err) {
    //		LOG_ERR("Failed to register authorization callbacks.");
    myPrintkE("Failed to register authorization callbacks.\r\n");
    return 0;
  myPrintkI("Passed register authorization callbacks.\r\n");
  err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
  if (err) {
    myPrintkE("Failed to register authorization info callbacks.\r\n");
    return 0;
  myPrintkI("Passed register authorization info callbacks.\r\n");
  err = bt_enable(NULL);
  if (err) {
    myPrintkE("Bluetooth init failed (err %d)\r\n", err);
    //		LOG_ERR("Bluetooth init failed (err %d)", err);
    return 0;
  myPrintkI("Bluetooth initialized\r\n");
  //	LOG_INF("Bluetooth initialized");
  if (IS_ENABLED(CONFIG_SETTINGS)) {
    settings_load();
  //	err = uart_init();
  //	if (err != 0)
  //		printk("\r\nuart_init failed (err %d)\r\n", err);
  //		return 0;
  //		printk("\r\nuart_init passed (err %d)\r\n", err);
  err = nus_client_init();
  if (err != 0) {
    myPrintkE("nus_client_init failed (err %d)\r\n", err);
    return 0;
  myPrintkI("nus_client_init passed (err %d)\r\n", err);
  scan_init();
  err = scan_start();
  if (err) {
    myPrintkE("scan_start failed (err %d)\r\n", err);
    return 0;
  myPrintkI("scan_start passed (err %d)\r\n", err);
  //	printk("Starting Bluetooth Central UART (central_uart_tjm) sample\n");
  myPrintkI("Starting Bluetooth Central UART (central_uart_tjm)\r\n");
  /* set up watchdog timer */
#if 1
  if (!device_is_ready(wdt)) {
    myPrintkE("%s: Watchdog device not ready.\n", wdt->name);
    return 0;
  myPrintkI("%s: Watchdog device ready.\n", wdt->name);
  wdt_channel_id = wdt_install_timeout(wdt, &wdt_config);
  switch (wdt_channel_id) {
  case -EBUSY:
    myPrintkE("Watchdog timeout can not be installed while watchdog has already been setup.\n");
    return 0;
  case -ENOTSUP:
    myPrintkE("Watchdog Callback support rejected, continuing anyway\n");
    return 0;
  case -EINVAL:
    myPrintkE("Watchdog install error: invalid configuration\n");
    return 0;
    if (wdt_channel_id < 0) {
      myPrintkE("Watchdog install error: %d\n", wdt_channel_id);
      return 0;
    myPrintkI("Watchdog install passed\n");
#if 0
		myPrintkE("Watchdog install error\n");
		return 0;
	if (wdt_channel_id == -ENOTSUP)
		/* IWDG driver for STM32 doesn't support callback */
		wdt_config.callback = NULL;
	myPrintkI("Watchdog Callback support passed\n");
  err = wdt_setup(wdt, WDT_OPT);
  if (err < 0) {
    myPrintkE("Watchdog setup error\n");
    return 0;
  myPrintkI("Watchdog setup passed. Start WDT feed timer\n");
#if 1
  k_timer_init(&wdt_timer, wdt_timer_handler, NULL);
  k_timer_start(&wdt_timer, K_MSEC(WDG_FEED_INTERVAL), K_MSEC(WDG_FEED_INTERVAL));
#else
  /* Feeding watchdog. */
  myPrintkS("Feeding watchdog %d times %d ms\n", WDT_FEED_TRIES, WDG_FEED_INTERVAL);
  for (int i = 0; i < WDT_FEED_TRIES; ++i) {
    myPrintkS("Feeding watchdog...\n");
    k_sleep(K_MSEC(WDG_FEED_INTERVAL));
  /* Waiting for the SoC reset. */
  myPrintkS("Waiting for reset...\n");
  while (1) {
    k_yield();
  return 0;
#endif /* end WDT timer */
#ifdef LTE_MERGE
  /* merge from dl_agri_new_nrf9160 */
  if (app_event_manager_init()) {
    /* Without the Application Event Manager, the application will not work
     * as intended. A reboot is required in an attempt to recover.
    //		LOG_ERR("Application Event Manager could not be initialized, rebooting...");
    //		strcpy(flashParameters.sysRebootReason, "Event manager init failed");
    //		setFlashxParameters(runFlag ? false : true);
    //		k_sleep(K_SECONDS(5));
    //		sys_reboot(SYS_REBOOT_COLD);
  } else {
    //		module_set_state(MODULE_STATE_READY);
    //		SEND_EVENT(app, APP_EVT_START);
#if defined(CONFIG_NRF_MODEM_LIB)
//		modem_init();
#endif /* end dl_agri)new_nrf9160 merge */
#ifndef USE_THREAD
      .len = 0,
  for (;;) {
    int loc = 0;
    while (plen > 0) {
      loc += plen;
      if (nus_data.len >= sizeof(nus_data.data) || (nus_data.data[nus_data.len - 1] == '\n') || (nus_data.data[nus_data.len - 1] == '\r')) {
          //					printf("\r\nCLI Command: %s\r\n", cliCommand);
        } else {
        if (err) {
                  "(err %d)",
                  err);
        if (err) {
        nus_data.len = 0;
    k_free(buf);
  return 0;
void parseBLEString(char *bleData) {
  myPrintkS("parseBLEString BLE data seen %s\r\n", bleData);
  uint8_t i;
  int len = strlen(bleData);
  struct data_item_type tempBLEData;
  struct data_item_type temp2BLEData;
  struct data_battery_type tempBatteryData;
  /* parse all parameters on the command line into cmdLineparameter array */
  numBLEParameters = 0; /* no parameters seen yet */
  BLEParameter[numBLEParameters++] = &bleData[0];
  for (i = 0; i < len; i++) {
    //            printf("%d 0x%02X %c\r\n",i,bleData[i],bleData[i]);
    if ((bleData[i] == ' ') || (bleData[i] == '\t')) {
      bleData[i] = '\0';
      BLEParameter[numBLEParameters++] = &bleData[i + 1];
  bleData[i] = '\0';
  /* wait for HSC temperature/humidity data */
  if (strcmp(BLEParameter[2], "t1") == 0) {
    strcpy(tempBLEData.BLEId, BLEParameter[1]);
    tempBLEData.BLETemp = atof(BLEParameter[3]);
    tempBLEData.BLEHum = atof(BLEParameter[5]);
    memcpy(my_msgq1_buffer, &tempBLEData, sizeof(struct data_item_type));
    myPrintkS("BLEId: %s BLEHDC2080Temp: %3.2f BLEHDC2080Hum: %3.2f\r\n", tempBLEData.BLEId, tempBLEData.BLETemp, tempBLEData.BLEHum);
    /* send data to consumers */
    if (k_msgq_put(&my_msgq1, my_msgq1_buffer, K_NO_WAIT) != 0) {
      myPrintkW("Message queue 1 is full, purging old data\r\n");
      /* message queue is full: purge old data & try again */
      k_msgq_purge(&my_msgq1);
      k_msgq_put(&my_msgq1, my_msgq1_buffer, K_NO_WAIT);
  /* wait for BME688 temperature/humidity data */
  if (strcmp(BLEParameter[2], "t2") == 0) {
    strcpy(temp2BLEData.BLEId, BLEParameter[1]);
    temp2BLEData.BLETemp = atof(BLEParameter[3]);
    temp2BLEData.BLEHum = atof(BLEParameter[5]);
    memcpy(my_msgq2_buffer, &temp2BLEData, sizeof(struct data_item_type));
    myPrintkS("BLEId: %s BLEBME688Temp2: %3.2f BLEBME688Hum2: %3.2f\r\n", temp2BLEData.BLEId, temp2BLEData.BLETemp, temp2BLEData.BLEHum);
    if (k_msgq_put(&my_msgq2, my_msgq2_buffer, K_NO_WAIT) != 0) {
      myPrintkW("Message queue 2 is full, purging old data\r\n");
      k_msgq_purge(&my_msgq2);
      k_msgq_put(&my_msgq2, my_msgq2_buffer, K_NO_WAIT);
  /* wait for Battery data */
  if (strcmp(BLEParameter[2], "bat") == 0) {
    strcpy(tempBatteryData.BLEId, BLEParameter[1]);
    tempBatteryData.BLEBattery = atoi(BLEParameter[3]);
    memcpy(my_msgq3_buffer, &tempBatteryData, sizeof(struct data_battery_type));
    myPrintkS("BLEId: %s Battery: %d \r\n", tempBatteryData.BLEId, tempBatteryData.BLEBattery);
    if (k_msgq_put(&my_msgq3, my_msgq3_buffer, K_NO_WAIT) != 0) {
      myPrintkW("Message queue 3 is full, purging old data\r\n");
      k_msgq_purge(&my_msgq3);
      k_msgq_put(&my_msgq3, my_msgq3_buffer, K_NO_WAIT);
 * Black \033[0;30m.
 * Red \033[0;31m.
 * Green \033[0;32m.
 * Yellow \033[0;33m.
 * Blue \033[0;34m.
 * Purple \033[0;35m.
 * Cyan \033[0;36m.
 * White \033[0;37m.
/* yellow (Warning)*/
#if 0
void myPrintkW(char *str) {
  printk("%s", "\33[1;33m");
  printk("%s", str);
  // printk("%s", myStr);
  printk("%s", "\33[0m");
  return;
int myPrintkW(char *restrict fmt, ...) {
  int n = 0;
  va_list ap;
  va_start(ap, fmt);
  //  n = vprintf(fmt, ap);
  vprintk(fmt, ap);
  va_end(ap);
  // printf("n=%d\n", n);
  return n;
/* Green (Information)*/
#if 0
void myPrintkI(char *str) {
  printk("%s", "\33[1;32m");
  printk("%s", str);
  return;
int myPrintkI(char *restrict fmt, ...) {
  int n = 0;
  va_list ap;
  va_start(ap, fmt);
  vprintk(fmt, ap);
  va_end(ap);
  return n;
/* CYAN (Status)*/
#if 0
void myPrintkS(char *str) {
  printk("%s", "\33[1;36m");
  printk("%s", str);
int myPrintkS(char *restrict fmt, ...) {
  int n = 0;
  va_list ap;
  va_start(ap, fmt);
  vprintk(fmt, ap);
  va_end(ap);
  return n;
/* Red (Error)*/
#if 0
void myPrintkE(char *str) {
  printk("%s", "\33[1;31m");
  printk("%s", str);
  return;
int myPrintkE(char *restrict fmt, ...) {
  int n = 0;
  va_list ap;
  va_start(ap, fmt);
  vprintk(fmt, ap);
  va_end(ap);
  return n;
  • Sigrid
    any progress on thsi? how can I connect and discover N advertisers? what am I doing wrong?
  • Sigrid
    any progress? I have attached my latest central_uart_maun.c. I have increased the maximum BT connection count to 4 but I have not added in the arrays for discoveries. It works perfectly for a single advertiser. When I have 2 advertisers it connects to both but only discovers one as expected since I have made no provision for multiple discoveries.
    What do I need to do make this central_uart_main  discover all the advertisers after a connection. This is a customer requirement to connect to multiple advertisers.
    /** @file
    #include <errno.h>
    /* merge */
    #ifdef LTE_MERGE
    LOG_MODULE_REGISTER(LOG_MODULE_NAME);
    //	uint16_t len;
    K_FIFO_DEFINE(fifo_ble_rx_data);
      ARG_UNUSED(nus);
      ARG_UNUSED(data);
      ARG_UNUSED(len);
      if (err) {
    struct data_item_t ble_fifo;
      ARG_UNUSED(nus);
      memset(&ble_fifo, 0, sizeof(ble_fifo));
      memcpy(ble_fifo.bleData, data, len);
      ble_fifo.bleData[len] = '\0';
      //  for (int i = 0; 1; i++) {
      //    myPrintkS("%d %c\n", i, ble_fifo.bleData[i]);
      //    if (ble_fifo.bleData[i] == '\0') {
      //      break;
      // myPrintkS("ble_data_received() entered... %s\n", blble_fifo.bleDataData);
      // myPrintkS("ble_data_received() entered... len=%d\n", len);
      k_fifo_put(&fifo_ble_rx_data, &ble_fifo);
      // parseBLEString(bleData);
      ARG_UNUSED(nus);
    #if 0
    	int err;
    		if (!tx)
    		pos += tx->len;
    			tx->len++;
    		if (err)
    		k_free(tx);
    #if 0
      ARG_UNUSED(dev);
      case UART_TX_DONE:
          return;
        if (aborted_buf) {
          aborted_buf = NULL;
          aborted_len = 0;
        } else {
        k_free(buf);
        if (!buf) {
          return;
      case UART_RX_RDY:
        if (disable_req) {
          return;
          disable_req = true;
        if (buf) {
          buf->len = 0;
        } else {
          return;
        if (buf) {
          buf->len = 0;
        } else {
        if (buf->len > 0) {
        } else {
          k_free(buf);
        if (!aborted_buf) {
      if (buf) {
        buf->len = 0;
      } else {
        return;
      int err;
        return -ENODEV;
      if (rx) {
        rx->len = 0;
      } else {
        return -ENOMEM;
      if (err) {
        return err;
      myPrintkB("Service discovery completed\r\n");
      int err;
        return;
      if (err) {
                "code: %d",
                err);
      if (!err) {
      } else {
      int err;
      //  myPrintkB("connected() entered... Device: %s\n", addr);
      if (conn_err) {
        myPrintkE("Failed to connect to %s, 0x%02x %s", addr, conn_err, bt_hci_err_to_str(conn_err));
        return;
      for (int i = 0; i < BT_ADDR_LE_STR_LEN; i++) {
        currentBleConnectionID[conn_count][i] = addr[i]; /* Store the connection ID for this connection */
      conn_count++; /* Increment connection count */
      myPrintkB("conn_count: %d, Connected: %s\r\n", conn_count, addr);
      if (err) {
      if (err) {
    #if 1
        myPrintkB("Maximum connections reached, stopping scan\r\n");
        if (err) {
      } else {
        myPrintkB("Maximum connections not reached, continuing scan\r\n");
        if (err) {
          return;
    #else
      if (err) {
      myPrintkB("Scan stopped\r\n");
      LOG_INF("Disconnected: %s, reason 0x%02x %s", addr, reason, bt_hci_err_to_str(reason));
        return;
      if (!err) {
      } else {
      myPrintkB("Filters matched. Address: %s connectable: %d\r\n", addr, connectable);
      int err;
      if (err) {
        return err;
      return err;
      int err;
      if (conn) {
        return;
      if (err) {
        return;
      int err;
      if (err) {
        return err;
      if (err) {
        return err;
      if (err) {
        return err;
      if (err) {
        return err;
      myPrintkB("Scan started\r\n");
      return 0;
      ARG_UNUSED(item);
      (void)scan_start();
    #if 1
     * \param work
    struct data_item_t *ptr_ble_fifo;
    #if 0
    struct k_timer ble_timer; //!< timer to read ble strings
     * \fn void ble_handler(struct k_work *work)
     * \brief work function BLE timer handler
     * \param work
    void ble_handler(struct k_work *work) {
      ptr_ble_fifo = k_fifo_get(&fifo_ble_rx_data, K_NO_WAIT);
      if (ptr_ble_fifo == NULL) {
        //    myPrintkW("ble_handler() no data in fifo...\n");
        return;
      //  myPrintkW("ble_handler() got data from fifo:\n");
      //    myPrintkI("%d %c\n", i, ptr_ble_fifo->bleData[i]);
      //    if (ptr_ble_fifo->bleData[i] == '\0') {
      //      break;
      //  myPrintkI("ble_handler() got data from fifo: %s\n", ptr_ble_fifo->bleData);
      //  parseBLEString(ptr_ble_fifo->bleData);
    K_WORK_DEFINE(ble_work, ble_handler);
     * \fn void ble_timer_handler(struct k_timer *dummy)
    void ble_timer_handler(struct k_timer *dummy) { k_work_submit(&ble_work); }
    #ifdef USE_THREAD
      int err = 0;
          .len = 0,
      myPrintkB("starting BLE thread\r\n");
      while (1) {
        //	for (;;)
          if (ptr_ble_fifo != NULL) {
          //      struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data, K_FOREVER);
          struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data, K_NO_WAIT);
          if (buf == NULL) {
            //        myPrintkW("my_uart_thread_logic() no data in fifo...\n");
            k_msleep(100);
            continue;
          int loc = 0;
          while (plen > 0) {
            loc += plen;
              } else {
                if (err) {
                          "(err %d)",
                          err);
                //						if (err)
              nus_data.len = 0;
          //			k_free(buf);
        k_msleep(10);
    #ifdef USE_THREAD
      int err;
    #if 1
      k_fifo_init(&fifo_ble_rx_data);
      myPrintkB("BLE RX FIFO Initialized\r\n");
      if (err) {
        myPrintkE("Failed to register BLE authorization callbacks.\r\n");
        return 0;
      myPrintkB("Passed register BLE authorization callbacks.\r\n");
      if (err) {
        return 0;
      myPrintkB("Passed register authorization info callbacks.\r\n");
      if (err) {
        return 0;
      myPrintkB("Bluetooth initialized\r\n");
        settings_load();
      //	if (err != 0)
      //		return 0;
      if (err != 0) {
        return 0;
      myPrintkB("nus_client_init passed (err %d)\r\n", err);
      scan_init();
      err = scan_start();
      if (err) {
        return 0;
      myPrintkB("scan_start passed (err %d)\r\n", err);
      myPrintkB("Starting Bluetooth Central UART (central_uart_tjm)\r\n");
    #if 1
        return 0;
      myPrintkB("%s: Watchdog device ready.\n", wdt->name);
      case -EBUSY:
        return 0;
      case -ENOTSUP:
        return 0;
      case -EINVAL:
        return 0;
          return 0;
        myPrintkB("Watchdog install passed\n");
    #if 0
    		return 0;
      //  k_timer_init(&ble_timer, ble_timer_handler, NULL);
      //  k_timer_start(&ble_timer, K_MSEC(100), K_MSEC(100));
      if (err < 0) {
        return 0;
      myPrintkB("Watchdog setup passed. Start WDT feed timer\n");
    #if 1
    #else
      while (1) {
        k_yield();
      return 0;
    #ifdef LTE_MERGE
      } else {
    //		modem_init();
    #ifndef USE_THREAD
          .len = 0,
      for (;;) {
        int loc = 0;
        while (plen > 0) {
          loc += plen;
            } else {
            if (err) {
                      "(err %d)",
                      err);
            if (err) {
            nus_data.len = 0;
        k_free(buf);
      return 0;
    int findID_IMEI(uint32_t id_IMEI) {
      int i;
      /* if found return index */
      for (i = 0; i < CONFIG_BT_MAX_CONN; i++) {
        if (currentBLEData[i].ID_IMEI == id_IMEI) {
          return i;
      /* if not found, return the first available slot */
        if (currentBLEData[i].ID_IMEI == 0) {
          return i;
      return -1;
      uint8_t i;
      uint32_t id_IMEI = 0;
      int indexBLEData = 0;
      //  myPrintkW("BLEId: %08X BLEHDC2080Temp: %d BLEHDC2080Hum: %d\r\n", currentBLEData[currentJSONCount].ID_IMEI,
      //  currentBLEData[currentJSONCount].tempHDC,
      //            currentBLEData[currentJSONCount].humHDC);
      //  myPrintkS("BLEId: %08X (%lu)\r\n", currentBLEData[currentJSONCount].ID_IMEI, (unsigned long)currentBLEData[currentJSONCount].ID_IMEI);
                            //  myPrintkW("dutycycle: %d\r\n", flashParameters.dutyCycle);
          bleData[i] = '\0';
      bleData[i] = '\0';
    #if 1
        id_IMEI = strtoul(BLEParameter[1], NULL, 16);
        indexBLEData = findID_IMEI(id_IMEI);
        myPrintkB("findID_IMEI returned index: %d for id_IMEI: %08X (%lu)\r\n", indexBLEData, id_IMEI, (unsigned long)id_IMEI);
        if (indexBLEData >= 0) {
          currentBLEData[indexBLEData].ID_IMEI = id_IMEI;
          if (flashParameters.tempUnitsCentigrade) {
            currentBLEData[indexBLEData].tempHDC = (int)(atof(BLEParameter[3]) * 100) + (indexBLEData * -40);
          } else {
            currentBLEData[indexBLEData].tempHDC = (int)((atof(BLEParameter[3]) * 9.0 / 5.0) + 32.0) * 100;
          currentBLEData[indexBLEData].humHDC = (int)(atof(BLEParameter[5]) * 100);
          myPrintkB("index: %d BLEId: %08X (%lu) BLEHDC2080Temp: %3.2f BLEHDC2080Hum: %3.2f\r\n", indexBLEData,
                    currentBLEData[indexBLEData].ID_IMEI, (unsigned long)currentBLEData[indexBLEData].ID_IMEI,
                    currentBLEData[indexBLEData].tempHDC / 100.0, currentBLEData[indexBLEData].humHDC / 100.0);
    #if 1
            currentBLEData[indexBLEData].tempBME688 = (int)(atof(BLEParameter[3]) * 100);
          } else {
            currentBLEData[indexBLEData].tempBME688 = (int)((atof(BLEParameter[3]) * 9.0 / 5.0) + 32.0) * 100;
          currentBLEData[indexBLEData].humBME688 = (int)(atof(BLEParameter[5]) * 100);
          myPrintkB("index: %d BLEId: %08X (%lu) BLEBME688Temp: %3.2f BLEBME688Hum: %3.2f\r\n", indexBLEData,
                    currentBLEData[indexBLEData].tempBME688 / 100.0, currentBLEData[indexBLEData].humBME688 / 100.0);
          currentBLEData[indexBLEData].battery = (int)(atoi(BLEParameter[3]));
          myPrintkB("index: %d BLEId: %08X (%lu) battery: %d \r\n", indexBLEData, currentBLEData[indexBLEData].ID_IMEI,
                    (unsigned long)currentBLEData[indexBLEData].ID_IMEI, currentBLEData[indexBLEData].battery);
     * Black \033[0;30m.
     * Red \033[0;31m.
     * Green \033[0;32m.
     * Blue \033[0;34m.
     * Cyan \033[0;36m.
     * White \033[0;37m.
    #if 0
      printk("%s", str);
      return;
      int n = 0;
      va_list ap;
      va_start(ap, fmt);
      vprintk(fmt, ap);
      va_end(ap);
      return n;
    #if 0
      printk("%s", str);
      return;
      int n = 0;
      va_list ap;
      va_start(ap, fmt);
      vprintk(fmt, ap);
      va_end(ap);
      return n;
    /* CYAN (Status)*/
    #if 0
      printk("%s", str);
      int n = 0;
      va_list ap;
      va_start(ap, fmt);
      vprintk(fmt, ap);
      va_end(ap);
      return n;
    /* Red (Error)*/
    #if 0
      printk("%s", str);
      return;
      int n = 0;
      va_list ap;
      va_start(ap, fmt);
      vprintk(fmt, ap);
      va_end(ap);
      return n;
    /* Blue (Debug)*/
    int myPrintkB(char *restrict fmt, ...) {
      int n = 0;
      va_list ap;
      printk("%s", "\33[1;34m");
      va_start(ap, fmt);
      vprintk(fmt, ap);
      va_end(ap);
      return n;
    /* Purple (Debug)*/
    int myPrintkP(char *restrict fmt, ...) {
      int n = 0;
      va_list ap;
      printk("%s", "\33[1;35m");
      va_start(ap, fmt);
      vprintk(fmt, ap);
      va_end(ap);
      return n;
  • Sigrid
    I have the modified central_uart working. At least it shows signs of life. let me do more testing at my end. you do not need to do anything now.
