Mesh OTA couldn't resume after target node reset
I use NCS 3.2.4 and 54L15 DK. In the DFU target, I added configuration
CONFIG_DFU_TARGET=Y
CONFIG_DFU_TARGET_MCUBOOT=y
CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS=y
and also added the following content in dfu_recover function.
static int dfu_recover(struct bt_mesh_dfu_srv *srv,
                       const struct bt_mesh_dfu_img *img,
                       const struct bt_mesh_blob_io **io)
    size_t offset = 0;
    int err = dfu_target_mcuboot_offset_get(&offset);
    if (err) {
        printk("Failed to get MCUboot offset (err %d)\n", err);
        offset = 0;
    printk("Recovering BLOB transfer, already written: %zu bytes\n", offset);
    err = bt_mesh_blob_io_flash_init(&blob_flash_stream,
                                     FIXED_PARTITION_ID(slot1_partition),
                                     offset);
    if (err) {
        return err;
    *io = &blob_flash_stream.io;
    return 0;
After the distributor finished transmitting 3 chunks more, I manually reset the target device. In the RTT window, I entered the shell command: mesh models dfu cli resume, but the command returned error -22.
How can I implement the resume/breakpoint resumption feature for Mesh OTA?
  • In NCS v3.3.0, the distributor and target were used without any modifications. After compilation, the code was flashed onto the DK for testing.
    Then, following the previously described procedure to modify the target, a manual reset was performed on the target after the upgrade reached 3%. However, after the reset, the read progress was 0.
    The distributor returned error -22 for the two test.
    Could u have a try?
    John
  • Can you please zip and upload the applications that you are using, together with the build command you are using (even if it is just "west build -b nrf54l15dk/nrf54l15").
    If you are building using VS Code, right click the build configuration, and select "Copy build command" to copy the build command.
    Edvin
  • This is a modified target example used for testing; The distributor has not been modified. After configuring CONFIG_DFU_TARGET=y, a compilation error occurs due to multiple definitions of dfu_target_init. Since I don't want to modify the original SDK files, I copied dfu_target.c into the project and renamed it to dfu_target_init_.
    Build command: west build --build-dir e:/Nordic/Code/target_330/build e:/Nordic/Code/target_330 --pristine --board nrf54l15dk/nrf54l15/cpuapp -- -DDEBUG_THREAD_INFO=On -DCONFIG_DEBUG_THREAD_INFO=y -Dtarget_330_DEBUG_THREAD_INFO=Off -Dmcuboot_DEBUG_THREAD_INFO=Off
    target_330.rar
    John
  • I tested both NCS v3.3.0 and v3.2.4, but I am not able to build it using the command:
    west build --build-dir _build --board nrf54l15dk/nrf54l15/cpuapp -- -DDEBUG_THREAD_INFO=On -DCONFIG_DEBUG_THREAD_INFO=y -Dtarget_330_DEBUG_THREAD_INFO=Off -Dmcuboot_DEBUG_THREAD_INFO=Off
    This is the build log:
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/fd21892d0f/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/nordic/SDKs/ncs/v3.2.4/zephyr/.cache
    -- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
    -- Board: nrf54l15dk, qualifiers: nrf54l15/cpuapp
    Parsing C:/Users/edho/Downloads/target_330/target_330/Kconfig.sysbuild
    Loaded configuration 'C:/Users/edho/Downloads/target_330/target_330/_build/_sysbuild/empty.conf'
    Merged configuration 'C:/Users/edho/Downloads/target_330/target_330/sysbuild.conf'
    Configuration saved to 'C:/Users/edho/Downloads/target_330/target_330/_build/zephyr/.config'
    Kconfig header saved to 'C:/Users/edho/Downloads/target_330/target_330/_build/_sysbuild/autoconf.h'
    -- Sysbuild assigned MCUboot image IDs:
       * Application: 0
       * Running CMake for mcuboot *
    -- Application: C:/nordic/SDKs/ncs/v3.2.4/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Zephyr version: 4.2.99 (C:/nordic/SDKs/ncs/v3.2.4/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/fd21892d0f/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/nordic/SDKs/ncs/v3.2.4/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts
    -- Found devicetree overlay: C:/Users/edho/Downloads/target_330/target_330/sysbuild/mcuboot/app.overlay
    -- Generated zephyr.dts: C:/Users/edho/Downloads/target_330/target_330/_build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Users/edho/Downloads/target_330/target_330/_build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Users/edho/Downloads/target_330/target_330/_build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    Parsing C:/nordic/SDKs/ncs/v3.2.4/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/nordic/SDKs/ncs/v3.2.4/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp_defconfig'
    Merged configuration 'C:/Users/edho/Downloads/target_330/target_330/sysbuild/mcuboot/prj.conf'
    Merged configuration 'C:/Users/edho/Downloads/target_330/target_330/sysbuild/mcuboot/socs/nrf54l15_cpuapp.conf'
    Merged configuration 'C:/Users/edho/Downloads/target_330/target_330/_build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Users/edho/Downloads/target_330/target_330/_build/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/Users/edho/Downloads/target_330/target_330/_build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Found gen_kobject_list: C:/nordic/SDKs/ncs/v3.2.4/zephyr/scripts/build/gen_kobject_list.py
    MCUBoot bootloader key file: C:/nordic/SDKs/ncs/v3.2.4/bootloader/mcuboot/root-ed25519.pem
    CMake Warning at CMakeLists.txt:442 (message):
      WARNING: Using default MCUboot signing key file, this file is for debug use
      only and is not secure!
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/edho/Downloads/target_330/target_330/_build/mcuboot
       * Running CMake for target_330 *
    -- Application: C:/Users/edho/Downloads/target_330/target_330
    -- Generated zephyr.dts: C:/Users/edho/Downloads/target_330/target_330/_build/target_330/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Users/edho/Downloads/target_330/target_330/_build/target_330/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Users/edho/Downloads/target_330/target_330/_build/target_330/zephyr/include/generated/zephyr/devicetree_generated.h
    C:/Users/edho/Downloads/target_330/target_330/prj.conf:85: warning: attempt to assign the value 'n' to the undefined symbol DFU_TARGET_MODE_DELTAParsing C:/nordic/SDKs/ncs/v3.2.4/zephyr/Kconfig
    Merged configuration 'C:/Users/edho/Downloads/target_330/target_330/prj.conf'
    Merged configuration 'C:/Users/edho/Downloads/target_330/target_330/boards/nrf54l15dk_nrf54l15_cpuapp.conf'
    Merged configuration 'C:/Users/edho/Downloads/target_330/target_330/_build/target_330/zephyr/misc/generated/extra_kconfig_options.conf'
    Merged configuration 'C:/Users/edho/Downloads/target_330/target_330/_build/target_330/zephyr/.config.sysbuild'
    C:/Users/edho/Downloads/target_330/target_330/prj.conf:86: warning: attempt to assign the value 'n' to the undefined symbol DFU_TARGET_FULL_MODE
    error: Aborting due to Kconfig warnings
    CMake Error at C:/nordic/SDKs/ncs/v3.2.4/zephyr/cmake/modules/kconfig.cmake:387 (message):
      command failed with return code: 1
      C:/nordic/SDKs/ncs/v3.2.4/nrf/cmake/modules/kconfig.cmake:112 (include)
      C:/nordic/SDKs/ncs/v3.2.4/zephyr/cmake/modules/zephyr_default.cmake:131 (include)
      C:/nordic/SDKs/ncs/v3.2.4/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/nordic/SDKs/ncs/v3.2.4/zephyr/share/zephyr-package/cma-- Configuring incomplete, errors occurred!
    ke/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:4 (find_package)
    CMake Error at cmake/modules/sysbuild_extensions.cmake:530 (message):
      CMake configure failed for Zephyr project: target_330
      Location: C:/Users/edho/Downloads/target_330/target_330
      cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
      cmake/modules/sysbuild_default.cmake:21 (include)
      C:/nordic/SDKs/ncs/v3.2.4/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/nordic/SDKs/ncs/v3.2.4/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      C:/nordic/SDKs/ncs/v3.2.4/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    See also "C:/Users/edho/Downloads/target_330/target_330/_build/CMakeFiles/CMakeOutput.log".
    ←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\fd21892d0f\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/fd21892d0f/opt/bin/python.exe '-BC:\Users\edho\Downloads\target_330\target_330\_build' -GNinja -DBOARD=nrf54l15dk/nrf54l15/cpuapp -DDEBUG_THREAD_INFO=On -DCONFIG_DEBUG_THREAD_INFO=y -Dtarget_330_DEBUG_THREAD_INFO=Off -Dmcuboot_DEBUG_THREAD_INFO=Off '-SC:\nordic\SDKs\ncs\v3.2.4\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\Users\edho\Downloads\target_330\target_330'
    ←[0
    I do see from the log that the issue is that DFU_TARGET_FULL_MODE is not defined, and I could remove it from prj.conf and retry. But this suggests that we are not testing on the same thing/environment.
    Do you have anything that I can build using an unmodified SDK and toolchain, and reproduce on a DK?
    Also, what do you use to upload the DFU image? Some other device running on a DK? If so, can you please share what you are using here, so that I can actually test it?
    Edvin
  • So sorry that there is some mistake in the prj.conf. Pls use the new prj.conf and  DFU image as attachment.
    Also you could set a higher version to generate a DFU image,that is  CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION in the prj.conf. Then make a pristine buld and you would get a DFU image in the build folder.
    Mesh_54_v2.0.zip
    1373.prj.conf
    John
