Zephyr Output of USB UART Serial Leaks Into Input Buffer
I wrote a simple terminal that reads the keyboard input from USB UART device
and echos it back to the same device. It works as follows:
1. It registers an interrupt handler (uart_isr)
2. The handler reads input data and writes it to a buffer
3. Main loop prints the buffer
Unfortunatelly the ISR reads 15 characters from the early Zephyr
boot process standard output "*** Booting Zeph". Subsequent ISR calls
read keystrokes properly. An example application interaction can look as follows:
1. Zephyr boots
2. Main loop prints: `size: 16, buffer: *** Booting Zeph`
3. The user presses 1, 2, 3 on the keyboard
4. Main loop prints: `size: 16, buffer: *** Booting Zeph123`
The application code looks as follows:
#include <zephyr/kernel.h>
#include <zephyr/drivers/uart.h>
#include <zephyr/device.h>
#include <stdint.h> // int32_t
uint32_t buffer_size = 0;
uint8_t buffer[64];
void uart_isr(const device *dev, void *user_data) {
    while (uart_irq_update(dev) == 1 && uart_irq_is_pending(dev) == 1) {
        if (uart_irq_rx_ready(dev) != 1) return;
        uint32_t remaining_space = sizeof(buffer) - buffer_size;
        if (remaining_space > 1) {
            buffer_size += uart_fifo_read(
                dev,
                &buffer[buffer_size],
                remaining_space - 1
int main() {
    const device *uart_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_console));
    if (!device_is_ready(uart_dev)) return -ENODEV;
    if (uart_irq_callback_set(uart_dev, uart_isr)) return -ENODEV;
    uart_irq_rx_enable(uart_dev);
    while (1) {
        buffer[buffer_size] = 0;
        printk("size: %i, buffer: %s\n", buffer_size, buffer);
        k_msleep(3000); // give some time to accumulate data in the receive buffer
    return 0;
prj.conf:
CONFIG_SERIAL=y
The samples/subsys/console/getchar sample exhibits the same behaviour.
Did I do something wrong or is it a Zephyr bug?
  • I have already tried to reproduce what you are observing using the same build target and Zephyr version (checked out at commit hash bcf31c20f0) without success. If you are unable to flash .hex files, please let me know which format you prefer instead. I also had a look at the commit you mentioned and I struggle to see how it could be related to the issue you mentioned. I don't see how this change could result in getchar() returning characters from the boot string.
  • I don't understand how the TX queue leaks into the RX queue as well. I played around with this code and commenting out the changes made in 23a helped with my case. The crucial part was not running the else branch when TX is disabled. The commit broke that.
    The change 23a doesn't even make sense. Why would you even start transmiting when TX is disabled.
