Update 2016-Mar-29: I used SDK v10 along with SoftDevice S110 v8 when I run the experiments described in this question.
Update 2016-Mar-30: Upload source code of the modified NUS module used in the experiments: test_characteristic.zip
I am modifying a copy of ble_nus.c (from SDK v10) to test the behavior of characteristics bigger than 20 bytes. Here is how I have the notifying part of ble_nus_string_send()
modified to try to send a RX characteristic notification with new value length over 20.
uint32_t err_code;
uint16_t nTransactions = length/20;
int16_t i;
uint16_t tempU16;
hvx_params.handle = p_nus->rx_handles.value_handle;
if ((length % 20) != 0)
nTransactions += 1;
// for (i = nTransactions - 1; i > -1; i--)
for (i = 0; i < nTransactions; i++)
hvx_params.p_data = &p_string[i * 20];
hvx_params.offset = i * 20;
tempU16 = (length - i * 20) ;
if (tempU16 > 20)
tempU16 = 20;
hvx_params.p_len = &tempU16;
hvx_params.type = BLE_GATT_HVX_NOTIFICATION;
err_code = sd_ble_gatts_hvx(p_nus->conn_handle, &hvx_params);
if (err_code != NRF_SUCCESS)
return err_code;
Of course I have also modified the characteristic sizes to BLE_GATTS_VAR_ATTR_LEN_MAX
I also enable read permission of the RX characteristic for my little experiment. My question is at the behavior of the code.
Both way of running the for
loop (commented out way and the active way) only result in Android version of Master Control Panel receiving notification of the first 20 byte of the p_string
I passed to the function. However:
With
, when I read the RX characteristic value, I have all the bytes of thep_string
I tried to notify.For example, if I call with
p_string
= "01234567890123456789ABC", I will get a notify of value "01234567890123456789", but if I read, I can read all "01234567890123456789ABC" -
With
I only got the first 20 byte ofp_string
, the rest is lost.For example, if I call with
p_string
= "01234567890123456789ABC", I will get a notify of value "01234567890123456789", and when I read, I could still only get "01234567890123456789"
I have tested with up to 59 bytes sent. I assume little would change with more/fewer bytes. So I have two questions:
Why is there such a difference? Could it be due to how
sd_ble_gatts_hvx()
is implemented? -
Is there any way to perform a notification for more than 20 byte at all? Apparently this does not work. Back in 2013 a Nordic employee said that it was impossible, but I hope things have changed.
