nRF54LM20 I2C Communication issue
Hi Team,
I am trying BMI270 Sample using nRF54LM20 DK. But the problem here is it getting exited after checking the device is ready section.
/* ---------------- PIN CONTROL ---------------- */
&pinctrl {
    i2c20_default_alt: i2c20_default_alt {
        group1 {
            psels = <
                NRF_PSEL(TWIM_SDA, 1, 17)
                NRF_PSEL(TWIM_SCL, 1, 16)
    i2c20_sleep_alt: i2c20_sleep_alt {
        group1 {
            psels = <
            low-power-enable;
/* ---------------- USB ---------------- */
&zephyr_udc0 {
    cdc_acm_uart0: cdc_acm_uart0 {
        compatible = "zephyr,cdc-acm-uart";
    cdc_acm_uart1: cdc_acm_uart1 {
/* ---------------- I2C + BMI270 ---------------- */
&i2c20 {
    status = "okay";
    pinctrl-0 = <&i2c20_default_alt>;
    pinctrl-1 = <&i2c20_sleep_alt>;
    clock-frequency = <I2C_BITRATE_STANDARD>;
    bmi270: bmi270@69 {
        compatible = "bosch,bmi270";
        reg = <0x69>;
        status = "okay";
&uart20 {
    status = "disabled";
/* ---------------- BUZZER ---------------- */
    aliases {
        bmi270 = &bmi270;
Added my overlay file for your reference.
Thanks and regards,
Vinay
  • Hi Vidar,
    I am using I2C21 instance for nRF54LM20 and I have not enabled any other peripheral instances.
    I have gone through your suggestions and then I had replied previously.
    I have understood your point thats why I had changed the pinmux for I2C Instance I am using. Now its P1.20 and P1.21. I hope thats not been used by any other bus or peripherals.
    I am trying to communicate with BMI270 Sensor. I am using SDK example BMI270. I observed that the app.overlay is used for Arduino I2C. So using the configuration I have generated overlay for nRF54LM20B. But still when I debug the application I can see its showing device is not ready.
    Adding overlay for your reference.
    &pinctrl {
        i2c3_my_default: i2c23_default_alt {
            group1 {
                psels = <
                    NRF_PSEL(TWIM_SDA, 1, 21)
                    NRF_PSEL(TWIM_SCL, 1, 20)
                bias-pull-up;
        i2c3_my_sleep: i2c23_sleep_alt {
            group1 {
                psels = <
                low-power-enable;
    &zephyr_udc0 {
    &i2c23 {
    	status = "okay";
    	pinctrl-0 = <&i2c3_my_default>;
    	pinctrl-1 = <&i2c3_my_sleep>;
    	zephyr,concat-buf-size = <257>;
        bmi270@68 {
                reg = <0x68>;
    &uart20 {
        aliases {
            bmi270 = &bmi270;
    #include <zephyr/dt-bindings/pwm/pwm.h>
    	aliases {
    		pwm-led0 = &pwm_led2;
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led2: pwm_led_2 {
    			pwms = <&pwm130 0 PWM_MSEC(20) PWM_POLARITY_NORMAL>;
    &pwm130 {
    	status = "okay";
    	pinctrl-0 = <&pwm130_default>;
    	pinctrl-1 = <&pwm130_sleep>;
    Thanks and regards,
    Vinay
  • Hi Vinay,
    P1.20 and P1.21 are connected to the 32 KHz crystal by default and are not routed to the pin header: https://docs.nordicsemi.com/bundle/ug_nrf54lm20_dk/page/UG/nRF54LM20_DK/hw_desription/connector_if.html. Try with P1.23 (SDA) and P1.24 (SCL) instead.
    Suggested app.overlay:
     * Copyright (c) 2021 Bosch Sensortec GmbH
    &pinctrl {
    	i2c23_default: i2c23_default {
    		group1 {
    			psels = <NRF_PSEL(TWIM_SDA, 1, 23)>,
    				<NRF_PSEL(TWIM_SCL, 1, 24)>;
    			bias-pull-up;
    	i2c23_sleep: i2c23_sleep {
    		group1 {
    			low-power-enable;
    &i2c23 {
    	status = "okay";
    	pinctrl-0 = <&i2c23_default>;
    	pinctrl-1 = <&i2c23_sleep>;
        bmi270@68 {
                reg = <0x68>;
    Vidar
  • Hi Vidar,
    Thank you for your reply.
    Is it possible to suggest me where I can find BMI270 examples because whatever example I am using not detecting the device.
    I had imported it from zephyr/samples/sensor/bmi270.
    But the overlay file is generated for Arduino_i2c. I had copied overlay elements provided by you. But still its showing device not available
    Thanks and regards,
    Vinay
  • Hi Vinay,
    This sample is a good starting point.
    The Arduino lable is not relevant. If you tried with the overlay I posted and it still did not work, then my next suggesting would be to go over the connections and if possible probe the bus lines with a logic analyser or oscilloscope. Perhaps you can post picture of your setup so I can see how you have connected the sensor as well.
    Vidar
