Failure in ble_stack_init during startup
We are trying to bring up a new run of an existing PCB design. No changes in the area of the processor, but a different assembly house. The first call inside ble_stack_init, a call to nrf_sdh_enable_request(), fails and returns an error code of 8. No reference anywhere gives a usable explanation.
Strangely, if started by "copying" the hex file onto the Jlink "drive" (the nRF52832 DevKit), it succeeds.
What should we be looking for?
  • This is great progress. It seems safe to assume that POR is the likely culprit now. Here is from the nRF52832 Product Specification:
    (Ref. https://docs.nordicsemi.com/r/bundle/ps_nrf52832/page/power.html).
    I don't have a good explanation for why you're not experiencing sudden PORs in debug interface mode or when using drag&drop programming. Generally on powerup, there will be more inrush current, and the regulator may also need some time to settle. Perhaps it becomes more apparent what is happening when you probe VDD in these different scenarios and across different boards.
    The current draw from the chip could also have something to do with it. The current will never drop down in the uA range when the chip is in debug interface mode. So if the drag&drop method is not existing debug mode after programming, then that could potentially explain why it is behaving the same as when you start a debug session in Segger embedded studio.
    (https://docs.nordicsemi.com/r/bundle/ps_nrf52832/page/dif.html?section=debuginterfacemode)
  • I know this is now wandering afield from the nRF52832, but I'm quite stumped. There are no logic lines back to the power supply, and the supply is rated a couple of orders of magnitude more current than used by the nRF52832 and the rest of the system. When programmed via drag&drop, the supply starts with the output voltage is at 1.8V, rises to 2.4V in about 9 mSec, steady at 2.4V for 30 mSec, drops abruptly to 1.8V in about 1.2 mSec, and repeats. This is apparently too slow and too small to trip the reset circuit. Feedback solidly tracks the output action, so I can't see why the TPS62050 switches on steadily when the output is too high. Circuit matches the example circuit in the TPS62050 datasheet, and layout is very tight. And it worked perfectly in the prior rev. Load is in the realm of 10 mA in both cases. Any ideas welcome!
  • My design has the same caps around the nRF52832 as the devkit does, plus 22µF bulk capacitance at the output of the voltage regulator. Could the nRF52832 require more capacitance? Does the code in the softdevice supporting sd_softdevice_enable() make any major transient demands on Vcc? I'm hunting for something that could drive the TPS62050 downswitcher to go into full conduction mode, driving the supply voltage up to almost double. Also, why should the behavior be any different when using drag&drop programming? Even then it's a bit bizarre, but only jumps up to about 2.2V, so not enough to trip the reset. The pattern is very different too, staying mostly steady at 2.2V most of the time, with short drops to the design target of 1.8V.
  • No, but as I indicated in my previous response, if the chip is not in debug mode, the current consumption can drop from a few milliamps to a couple of microamps in sd_softdevice_enable() when it enters System ON mode while waiting for the crystal oscillator to start.
    If your HW supports it, I suggest you try to force PWM mode on. I find it strange that the regulated output is this unstable. Is it maybe not able to handle the varying current draw..?
  • The TPS62050 is supposed to be able to go into a pulse skipping mode at low current draw. It's rated at up to 10V in, and 1.8V out is one of the specific examples in the datasheet. The red herring in all this has been that the previous rev had a max 4.2V in from a rechargeable lithium, whereas the new rev is powered by 4AA at 6V in. I watched as I ramped my bench supply up from 4V to 6V and saw the steady 1.8V output first go into that oscillation up to 2.2V, and then break into the spikes to 3.3V. I have a query out to TI on this. Thank you very much for persisting with me thru this, and I realize now that it's not your problem. I'll come back with the solution, if I can find one.
