Failure in ble_stack_init during startup
We are trying to bring up a new run of an existing PCB design. No changes in the area of the processor, but a different assembly house. The first call inside ble_stack_init, a call to nrf_sdh_enable_request(), fails and returns an error code of 8. No reference anywhere gives a usable explanation.
Strangely, if started by "copying" the hex file onto the Jlink "drive" (the nRF52832 DevKit), it succeeds.
What should we be looking for?
  • In nrf_sdh_enable_request(), it's resetting in this critical region:
        CRITICAL_REGION_ENTER();
    #ifdef ANT_LICENSE_KEY
        ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler, ANT_LICENSE_KEY);
    #else
        ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler);
        m_nrf_sdh_enabled = (ret_code == NRF_SUCCESS);
        CRITICAL_REGION_EXIT();
    According to the highlighting by SES, ANT_LICENSE_KEY is not defined, so it's resetting semoewhere in sd_softdevice_enable, but apparently without getting to app_error_fault_handler. I have no visibility into the softdevice, so please wave your magic wand over it and tell me hwat I'm doing wrong.
  • The limitation when debugging with the softdevice is that you generally cannot continue execution after halting the CPU (for example, when hitting a breakpoint), as the softdevice will detect that it has failed to meet its timing requirements and trigger an error (app_error_fault_handler() is called with id=NRF_FAULT_ID_SD_ASSERT). But I don't see why this should be a problem here.
    In any case, based on what you said earlier, the problem is not reproducible in debug mode. So you would need to use nrfjprog --memrd <register address> from the command line or similar approach to read the register from the running target after the problem has occurred. The challenge with this here is that you may end up reading the register after it has already been cleared by your FW. So I suggest commenting the NRF_POWER -> RESETREAS = ResetReason; line first, then see if it still reads as 0 when it is going in the boot loop.
    There is nothing that can lead to NVIC_SystemReset() being called within this function. You can search through your project for NVIC_SystemReset() to see if is called in any other places than the error handler to verify.
    I added the code you suggested above, and never got it to output (never reached).
    Does this mean that you have redefined the  app_error_fault_handler() in your project? The picture I posted is showing the default handler used in the SDK examples.
    I will be signing off now (I'm based in Norway, so I'm a few hours ahead), but I hope you will be able to gather some more concrete debugging evidence of what is happening.
  • The debugger is so cumbersome as to be completely useless with a softdevice. Hence I have devised my own debugging methods. I have nonvolatile memory available, and a mechanism whereby to record any events of interest, even in a failure to start, such that subsequently getting a successful startup allows me to read the whole history. Very flexible, with recording of whatever plain text is most illuminating for the problem being diagnosed, and it works quite well.
    I have added code within app_error_fault_handler() to record all the details if that handler is called. I just now ran another complete test:
    1) Boot properly via drag&drop, run erase command on NV memory.
    2) Boot via SES F5, observe LED showing repeated resets.
    3) Boot properly via drag&drop, download saved journal.
    I could send the full journa/, but probably more useful to summarize.
    1st boot (1 above) is shown properly.
    2nd attempt, using F5:
       Starts up, gets thru services_init() in main(), then crashes somewhere in advertising_init() with the following message:
       Fault 00004001 00000000 2000FE8C ERROR 4 [NRF_ERROR_NO_MEM] at (null):0
       PC at: 0x00000000
    The above message was formatted by these two lines (in the fault handler). Infotext does just what's expected; these two sprintf's are physically in different routines:
        sprintf (InfoText, "ERROR %u [%s] at %s:%u\r\nPC at: 0x%08x",
                              p_info->err_code,
                              nrf_strerror_get(p_info->err_code),
                              p_info->p_file_name,
                              p_info->line_num,
                              pc);
        sprintf (Str, "\r\nFault %08X %08X %08X %s\r\n", id, pc, info, InfoTxt);
    Thus the values are:
    id - 00004001
    pc - 00000000 (?!?!?)
    info - 2000FE8C
    err_code - 4
    err_string - NRF_ERROR_NO_MEM
    file_name - null
    line_num - 0
    pc - 00000000
    So clearly something went off the rails badly.
    Next the system reboots, and gets as far as calling nrf_sdh_enable_request() from within ble_stack_init(). This drills down to nrf_sdh_enable_request(), which runs to a print just prior to the CRITICAL_REGION, and then reboots from within the CRITICAL_REGION. The only thing called from within there is sd_softdevice_enable(), so the reboot is happening from inside the softdevice. Recall that this is after the above no-memory error.
    From here, it repeatedly reboots and crashes in the CRITICAL_REGION until I intervene and cause a correct reboot via drag&drop in order to read out the record.
    Are you as baffled as me yet?!?
  • Bottom line is:
    The system starts up fine from either loading firmware via drag&drop or from a programmed NVIC_SystemReset. If started from a powerup or from SES pressing F5, it resets somewhere inside the CRITICAL_REGION within nrf_sdh_enable_request(). The only code that could do that is in either CRITICAL_REGION_ENTER(), sd_softdevice_enable(), or CRITICAL_REGION_EXIT(). Those routines tinker heavily with various interrupt flags. Is it possible that some kind of timing or race condition could be causing this?
  • Some more digging:
    Per the above, the first time in from a startup via either power cycle or SES F5, both nrf_sdh_enable_request() and nrf_sdh_ble_enable() return an error code of 8, and sometime after, the error handler gets called with the report above - no pc, nothing to indicate from what it was called.
    I have also added probes that show that the reset is coming from the call to sd_softdevice_enable(), but that is probably just a symptom of the soft device not being properly started above. Once it happens, though, I get continual resets, entering nrf_sdh_enable_request() and crashing with a reset in sd_softdevice_enable() every time.
    I'll be asleep when you come in to work this morning (Monday) as we're 6 hours behind you. But I should be online by about noon your time.
