nRF7002 drops downlink in power save / RPU powers down RX while still advertising PM=0 (no PM=1 Null), so the AP delivers directly and the frame is lost
Hello all !
Summary
While in power save the nRF7002 RPU powers down its receiver without sending a PM=1 (Null) frame first, so from the AP point of view the station is still in active mode (PM=0). The AP therefore delivers downlink frames (for example a TCP SYN-ACK) directly instead of buffering them. Since the receiver is off the frame is never ACKed, and the AP retransmits it at the MAC layer (retry=1) around 40 times into a dead receiver. The result is intermittent failure of connection setup (TCP handshake, DHCP-ACK, DNS / gateway ARP) ending in the usual 3 s socket timeout, recovered only by a retry or reconnect. First attempt connections are unreliable on perfectly healthy APs.
Environment
  • nRF7002 (companion radio) + nRF5340 host (MDBT53-P1M)
  • nRF Connect SDK v3.2.4 (Zephyr 4.2.99), nrf_wifi driver
  • CONFIG_NRF_WIFI_LOW_POWER=y, legacy PS (WIFI_PS_MODE_LEGACY), WIFI_PS_PARAM_STATE=enabled
  • WPA2-PSK, normal infrastructure AP, 2.4 GHz ch 6, beacon interval 100 TU, DTIM period 1, STA AID = 1
Evidence
1. TCP handshake, decrypted (server 20.107.35.42:443, STA 192.167.14.97)
13.342  STA → server   52809 → 443 [SYN]
13.364  server → STA   443 → 52809 [SYN, ACK]                       +22 ms, server is healthy
13.367  server → STA   [TCP Retransmission] [SYN, ACK]   ┐
13.375  server → STA   [TCP Retransmission] [SYN, ACK]   │  ~17 copies of the SAME
  ...                                                    │  SYN-ACK in ~66 ms
13.430  server → STA   [TCP Retransmission] [SYN, ACK]   ┘
14.022  STA → server   [TCP Retransmission] 52809 → 443 [SYN]  ×7
   SYN-ACK retransmit count per connection (4 cycles): 39, 3, 3, 5
2. Same window at the raw 802.11 layer (no decryption), this is the key part
time     dir         frame      retry  PM
13.342   STA → AP    QoS Data   0      0     the SYN (STA awake to transmit)
13.364   AP  → STA   QoS Data   0      -     SYN-ACK, 1st delivery
13.367   AP  → STA   QoS Data   1      -     ┐
13.375   AP  → STA   QoS Data   1      -     │ ~17× the SAME frame, wlan.fc.retry=1
  ...                                        │ = 802.11 MAC retransmission (no ACK from STA)
13.430   AP  → STA   QoS Data   1      -     ┘
   STA "Null PM=1" frames seen at: 12.460 … 15.020   → NONE in between (the whole handshake)
  • Every SYN-ACK copy has wlan.fc.retry = 1, so the AP is re-sending one un-ACKed frame. This is not TCP RTO.
  • The STA sends no PM=1 Null during the handshake. It advertises active mode the whole time, yet does not ACK, so its receiver must be off.
3. Beacon TIM: the AP never buffers it (so it is not a "missed DTIM" problem)
STA AID = 1
beacon during the storm:  dtim_count=0  dtim_period=1  multicast=0  bitmap=0x78bb07
   0x78 = 0b01111000 → AIDs 3,4,5,6 have buffered data;  AID 1 (our STA) is NOT set
The PS buffering and TIM signalling on the AP side works fine, it flags other AIDs. Our STA's reply is simply never queued, because the STA never told the AP it was asleep.
4. Same failure on DHCP and DNS (device console, separate runs)
DHCP:  Received dhcp [op=0x2 flags=0x80]        OFFER received (broadcast)
       send request dst=255.255.255.255 ...
       DHCP timeout after 3 retries             broadcast ACK never arrived → DHCP failed -7
DNS:   submitting DNS query (server = gateway 192.167.1.1)
       Query timeout ; DNS attempt 1/5 failed (ret=-101)   -ENETUNREACH: gateway ARP reply
       ... ×5 → DNS resolution failed                      missed, so the query is unsendable
What we tried (none of it fixes it)
  • WIFI_PS_PARAM_TIMEOUT (post-TX wake window): applied successfully, no observable change.
  • CONFIG_NRF70_RPU_PS_IDLE_TIMEOUT_MS: tried 10 / 25 / 100 ms, identical residual.
  • WIFI_PS_PARAM_EXIT_STRATEGY = EVERY_TIM: improves the buffered legs (DHCP/DNS) but not the TCP SYN-ACK, since nothing is buffered there, the AP delivers it directly.
  • Only WIFI_PS_PARAM_STATE = disabled (Constantly Awake Mode) eliminates it: the receiver stays on, the STA ACKs normally, retransmits drop to single digits or zero.
Questions
  1. Is it expected that, with CONFIG_NRF_WIFI_LOW_POWER=y, the RPU powers the receiver down without sending a PM=1 Null first? Per 802.11 a STA in active mode (PM=0) must keep its receiver on; to sleep it must announce PM=1 so the AP buffers.
  2. If this is by design: is there a way to make the RPU announce PM=1 before sleeping (so the AP buffers and TIM-signals the reply), or to keep the RX up while a recently active flow may still receive an immediate reply (for example during a TCP handshake)?
  3. If not by design, this looks like an RPU firmware defect, please advise.
Best regards and thank you in advance !
