Issue with Partition Manager to Devicetree migration on nRF54L15 (MCUboot + TF-M)
Hello.
I am currently migrating a project from NCS v3.2.4 to v3.3.1 and transitioning from Partition Manager to devicetree-based partitioning, following the official migration guide:
https://nrfconnectdocs.nordicsemi.com/ncs/latest/nrf/releases_and_maturity/migration/migration_partitions.html
While the build process succeeds using the generated .overlay files, the application fails to boot after MCUboot.
It enters a continuous reboot loop.
Serial Terminal Log:
*** Booting MCUboot v2.3.0-dev-3de5b4df5f9f ***
*** Using nRF Connect SDK v3.3.1-1d7a0b0e49b8 ***
*** Using Zephyr OS v4.3.99-37e6c28576ee ***
I: Starting bootloader
I: Image index: 0, Swap type: none
I: Bootloader chainload address offset: 0x14000
I: Image version: v0.3.0
I: Jumping to the first image slot
... (loop repeats)
Configuration Details:
  • Device: nRF54L15
  • Setup: MCUboot + TF-M
  • Context: I have been unable to find specific examples for an nRF54L15 setup with both MCUboot and TF-M using the new devicetree partitioning method.
  • pm_static.yml: Original working partition configuration.
  • generate.overlay: Generated via pm_to_dts.py.
  • app.overlay: Modified version of the generated file
    (removed redundant nodes, and manually adjusted cpuapp_sram to reflect previous Kconfig settings:
    CONFIG_PM_PARTITION_SIZE_TFM=0x1F800 and CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0x10000).
  • mcuboot.overlay: File used for MCUboot.
app:
  address: 0x34000
  end_address: 0xc6000
  region: flash_primary
mcuboot:
  address: 0x0
  end_address: 0xc000
mcuboot_pad:
  address: 0x14000
  end_address: 0x14800
mcuboot_primary:
  address: 0x14000
  orig_span: &id001
  - mcuboot_pad
  - tfm
  - app
  span: *id001
mcuboot_primary_app:
  address: 0x14800
  orig_span: &id002
  - tfm
  - app
  span: *id002
mcuboot_secondary:
  address: 0xc6000
  end_address: 0x141000
littlefs_storage:
  address: 0x141000
  end_address: 0x155000
settings_storage:
  address: 0x155000
  end_address: 0x165000
tfm_its:
  address: 0xc000
  end_address: 0xe000
tfm_otp_nv_counters:
  address: 0xe000
  end_address: 0x10000
tfm_ps:
  address: 0x10000
  end_address: 0x14000
tfm:
  address: 0x14800
  end_address: 0x34000
nonsecure_storage:
  address: 0x155000
  orig_span: &id004
  - settings_storage
  span: *id004
tfm_nonsecure:
  address: 0x34000
  orig_span: &id007
  - app
  span: *id007
tfm_secure:
  address: 0x14000
  orig_span: &id008
  - mcuboot_pad
  - tfm
  span: *id008
tfm_storage:
  address: 0xc000
  orig_span: &id009
  - tfm_its
  - tfm_otp_nv_counters
  - tfm_ps
  span: *id009
&cpuapp_rram {
	partitions {
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x0 0xc000>;
		tfm_its_partition: partition@c000 {
			label = "tfm-its";
			reg = <0xc000 0x2000>;
		tfm_otp_partition: partition@e000 {
			label = "tfm-otp";
			reg = <0xe000 0x2000>;
		tfm_ps_partition: partition@10000 {
			label = "tfm-ps";
			reg = <0x10000 0x4000>;
		slot0_partition: partition@14000 {
			compatible = "fixed-subpartitions";
			label = "image-0";
			reg = <0x14000 0xb2000>;
			ranges = <0x0 0x14000 0xb2000>;
			#address-cells = <1>;
			#size-cells = <1>;
			slot0_s_partition: partition@0 {
				label = "image-0-secure";
				reg = <0x0 0x20000>;
			slot0_ns_partition: partition@20000 {
				label = "image-0-nonsecure";
				reg = <0x20000 0x92000>;
		slot1_partition: partition@c6000 {
			label = "image-1";
			reg = <0xc6000 0x7b000>;
		littlefs_storage: partition@141000 {
			label = "littlefs-storage";
			reg = <0x141000 0x14000>;
		nonsecure_storage: partition@155000 {
			label = "nonsecure-storage";
			reg = <0x155000 0x10000>;
		storage_partition: partition@155000 {
			label = "storage";
/delete-node/ &sram0_ns;
&cpuapp_sram {
	sram0_s: image_s@0 {
		/* Secure image memory */
		reg = <0x0 DT_SIZE_K(64)>;
		ranges = <0x0 0x0 DT_SIZE_K(64)>;
	sram0_ns: image_ns@10000 {
		#size-cells = <1>;
		/* Non-Secure image memory */
		reg = <0x10000 DT_SIZE_K(192)>;
		ranges = <0x0 0x10000 DT_SIZE_K(192)>;
/delete-node/ &slot0_partition;
/delete-node/ &tfm_ps_partition;
/delete-node/ &tfm_its_partition;
/delete-node/ &tfm_otp_partition;
/delete-node/ &slot0_ns_partition;
/delete-node/ &storage_partition;
&cpuapp_rram {
	partitions {
			label = "mcuboot";
			reg = <0x0 0xc000>;
			label = "tfm-its";
			label = "tfm-otp";
			label = "tfm-ps";
			label = "image-0";
			#size-cells = <1>;
			label = "image-1";
			label = "storage";
	chosen {
		zephyr,code-partition = &boot_partition;
/delete-node/ &boot_partition;
/delete-node/ &slot1_partition;
&cpuapp_rram {
	partitions {
			label = "mcuboot";
			reg = <0x0 0xc000>;
			label = "tfm-its";
			label = "tfm-otp";
			label = "tfm-ps";
			label = "image-0";
			#size-cells = <1>;
			label = "image-1";
			label = "storage";
Could you please review my configuration and advise on the correct approach for setting up devicetree partitions in an nRF54L15 MCUboot/TF-M environment?
a.da
  • Hi
    Can you check the values of CONFIG_ROM_START_OFFSET, CONFIG_TFM_MCUBOOT_HEADER_SIZE and CONFIG_ROM_START_OFFSET for the MCUboot image and let us know what they are?
    Simon
  • Hi Simon,
    Here are the Kconfig values for both the Partition Manager and Devicetree approaches.
    Although you specifically requested the values for the MCUboot image, I have included the values for the app image as well for comparison.
    Please note that CONFIG_TFM_MCUBOOT_HEADER_SIZE was not present in the MCUboot image configuration.
    • Partition Manager (PM)
      • MCUboot image:
        CONFIG_ROM_START_OFFSET=0
      • App image:
        CONFIG_TFM_MCUBOOT_HEADER_SIZE=0x800
    • Devicetree (DTS)
      • MCUboot image:
      • App image:
        CONFIG_ROM_START_OFFSET=0x800
    Important Observations and Test Results
    • Automatically set by NCS:
      I have not configured these Kconfig values locally in my project.
      These are defaults automatically provided by NCS.
      Specifically, it seems to be defined in the SoC's Kconfig.defconfig inside NCS (Zephyr).
    • Manual Workaround Result:
      As a test, I modified Kconfig.defconfig inside NCS to set CONFIG_ROM_START_OFFSET=0.
      As a result, the infinite reboot loop disappeared, and the application booted and ran successfully.
    Please let me know how you plan to address this issue or if there is an official fix planned for this Kconfig calculation bug.
    a.da
  • Hi
    Okay, that confirms our suspicion. There is a commit missing for the NCS 3.3.0 release to fix a known issue. The workaround for that should be to set the CONFIG_ROM_START_OFFSET=0 for your application in the dts app image as well. Please try that out and let us know if that works or not. This should be fixed and implemented as of NCS 3.4.0.
    Simon
  • Hi Shimon,
    It is unfortunate that this commit was missing for the NCS v3.3.0 release.
    The workaround for that should be to set the CONFIG_ROM_START_OFFSET=9 for your application in the dts app image as well.
    I assume that "CONFIG_ROM_START_OFFSET=9" in your suggestion was a typo for "CONFIG_ROM_START_OFFSET=0".
    I reverted the changes in Kconfig.defconfig inside NCS, and instead, added CONFIG_ROM_START_OFFSET=0 to the application's prj.conf.
    However, the actual build result showed CONFIG_ROM_START_OFFSET=0x800.
    It seems that the default value in Kconfig.defconfig took priority over the prj.conf setting.
    Naturally, the original issue recurred and the application did not boot.
    Therefore, to avoid this issue, we must wait for the release of NCS v3.4.0.
    We hope to migrate away from Partition Manager, which will be deprecated in the future, as soon as possible.
    a.da
  • Correct, that was a typo. I have corrected that now. My apologies. We're looking into if there's a way to omit/force the ROM START OFFSET now, but waiting for NCS 3.4.0 should be perfectly fine.
    You can already use the NCS 3.4.0 release candidate SDK versions for reference (v3.4.0-rc2 for example) to get started with a preliminary 3.4.0 version now.
    Simon
