Custom board SWD programming with nrf52-dk
Hi everyone,
I am trying to use a PCA10040 (nRF52 DK) as an external debugger to program a custom nRF52832 target board, but I keep running into J-Link backend errors (-256 and -102).
Interestingly, my board's interface/debugger chip is an onboard nRF5340 chip, and the J-Link logs show it initializing with the J-Link OB-nRF5340-NordicSemi firmware.
To ensure proper power and signal integrity, we verified that the target VTG is connected directly to the board's onboard VDD rail (sitting stable at 3V), and all ground paths are securely tied together. Additionally, a full continuity test was performed from the physical chip pads to the debug header to guarantee there are no broken traces or cold solder joints on the SWDCLK, SWDIO, and reset lines
Hardware Setup & Verification:
  • Debugger: PCA10040 (nRF52 DK)
  • Target: Custom nRF52832 board
  • Power & Logic Checked:
    • Target VTG is stable at 3V.
    • GND lines are firmly connected.
    • nRF Reset pin is pulled up / stable at 3V.
    • SWDCLK and SWDIO are correctly mapped.
What We Have Tried:
  1. Swapped SWDIO/SWDCLK pins to double-check against accidental reversals.
  2. Verified that the P19/P20 select pin voltage states are active.
  3. Lowered SWD clock frequencies.
  4. Attempted recovery using both nrfutil device recover and nrfjprog -f nrf52 --recover.
Error Logs:
When running nrfjprog --eraseall --log, the J-Link backend throws error -256 repeatedly, followed by a Coresight configuration failure:
[2026-Aug-25 10:56:48] [error] [SeggerBackend] - JLinkARM.dll reported error -256 at line 736.
[2026-Aug-25 10:56:48] [info] [SeggerBackend] - Segger dll version 9.24.a loaded.
[2026-Aug-25 10:56:48] [trace] [ JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Jul 8 2025 10:15:34
[2026-Aug-25 10:56:48] [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 250 milliseconds with result -102
[2026-Aug-25 10:56:48] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2026-Aug-25 10:56:48] [trace] [ JLink] - - 0.638ms returns -1
(Note: The log shows the debugger firmware reporting as J-Link OB-nRF5340-NordicSemi, even though the board is a PCA10040).
Also output for vscode flashing:
Error: One or more batch tasks failed:
* 1050357465: Device error: Setting the debug port SELECT register failed while powering up sys and debug regions (Unknown error in the J-Link DLL (error code =-1)).
This might indicate that the debug port is unavailable. Double-check device power supply and SWD lines, and ensure that SWD is not disabled (Generic)
FATAL ERROR: command exited with status 1: nrfutil --json device x-execute-batch --batch-path 'pathto-projectfolder\zephyr\generated_nrfutil_batch.json' --serial-number 1050357465
Another output from nrf programmer:
11:45:48.291
Reading readback protection status for Application core
11:45:48.292
Reading readback protection status for Application core 0%
11:45:48.331
Reading readback protection status for Application core 50%
11:45:48.331
11:45:48.443
Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Device error: Setting the debug port SELECT register failed while powering up sys and debug regions (Unknown error in the J-Link DLL (error code =-1)). This might indicate that the debug port is unavailable. Double-check device power supply and SWD lines, and ensure that SWD is not disabled
And log file for nrfjprog --eraseall --log
[2026-Aug-25 11:47:24] [debug] --------------------------------------------------------------------------------
[2026-Aug-25 11:47:24] [debug] nrfjprog --eraseall --log
[2026-Aug-25 11:47:24] [debug] nrfjprog version 10.24.2 external
[2026-Aug-25 11:47:24] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2026-Aug-25 11:47:24] [ info] Library loaded, loading member functions.
[2026-Aug-25 11:47:24] [ info] Member functions succesfully loaded.
[2026-Aug-25 11:47:24] [debug] [ Client] - open
[2026-Aug-25 11:47:24] [debug] [ Client] - start
[2026-Aug-25 11:47:24] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 640b1508-83b7-471c-9256-6a7c53393fd4.
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2026-Aug-25 11:47:24] [debug] [  JLink] - Logger sink registered in JLink logger
[2026-Aug-25 11:47:24] [debug] [  nRFXX] - open
[2026-Aug-25 11:47:24] [debug] [  nRFXX] - just_check_family
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - open_dll
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2026-Aug-25 11:47:24] [trace] [ Client] - Command open executed for 75 milliseconds with result 0
[2026-Aug-25 11:47:24] [debug] [ Client] - config
[2026-Aug-25 11:47:24] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V924a\JLink_x64.dll.
[2026-Aug-25 11:47:24] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2026-Aug-25 11:47:24] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - Set batch mode
[2026-Aug-25 11:47:24] [error] [SeggerBackend] - JLinkARM.dll reported error -256 at line 736.
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - dll_version
[2026-Aug-25 11:47:24] [error] [SeggerBackend] - JLinkARM.dll reported error -256 at line 629.
[2026-Aug-25 11:47:24] [ info] [SeggerBackend] - Segger dll version 9.24.a loaded.
[2026-Aug-25 11:47:24] [trace] [ Worker] - Command open executed for 3 milliseconds with result 0
[2026-Aug-25 11:47:24] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
[2026-Aug-25 11:47:24] [debug] [  nRFXX] - config
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - enum_emu_snr
[2026-Aug-25 11:47:24] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
[2026-Aug-25 11:47:24] [debug] [ Client] - enum_emu_snr
[2026-Aug-25 11:47:24] [debug] [  nRFXX] - enum_emu_con_info
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - is_connected_to_emu
[2026-Aug-25 11:47:24] [error] [SeggerBackend] - JLinkARM.dll reported error -256 at line 3139.
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - enum_emu_con_info
[2026-Aug-25 11:47:24] [error] [SeggerBackend] - JLinkARM.dll reported error -256 at line 911.
[2026-Aug-25 11:47:24] [trace] [ Worker] - Command enum_emu_con_info executed for 2 milliseconds with result 0
[2026-Aug-25 11:47:24] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
[2026-Aug-25 11:47:24] [debug] [ Client] - connect_to_emu_with_snr
[2026-Aug-25 11:47:24] [debug] [  nRFXX] - connect_to_emu_with_snr
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - ---just_get_num_emus
[2026-Aug-25 11:47:24] [error] [SeggerBackend] - JLinkARM.dll reported error -256 at line 3087.
[2026-Aug-25 11:47:24] [error] [SeggerBackend] - JLinkARM.dll reported error -256 at line 3112.
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2026-Aug-25 11:47:24] [error] [SeggerBackend] - JLinkARM.dll reported error -256 at line 3349.
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - Segger logging enabled.
[2026-Aug-25 11:47:24] [error] [SeggerBackend] - JLinkARM.dll reported error -256 at line 3160.
[2026-Aug-25 11:47:24] [error] [SeggerBackend] - JLinkARM.dll reported error -256 at line 3176.
[2026-Aug-25 11:47:24] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Jul  8 2025 10:15:34
[2026-Aug-25 11:47:24] [trace] [  JLink] - Hardware: V1.00
[2026-Aug-25 11:47:24] [trace] [  JLink] - S/N: 1050357465
[2026-Aug-25 11:47:24] [trace] [  JLink] - OEM: SEGGER
[2026-Aug-25 11:47:24] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2026-Aug-25 11:47:24] [trace] [  JLink] - Bootloader: 2021 May 18
[2026-Aug-25 11:47:24] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
[2026-Aug-25 11:47:24] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2026-Aug-25 11:47:24] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2026-Aug-25 11:47:24] [trace] [  JLink] - WEBSRV Failed to put socket into listener state (port 19080)
[2026-Aug-25 11:47:24] [trace] [  JLink] - WEBSRV Webserver running on local port 19081
[2026-Aug-25 11:47:24] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V924a\JLinkGUIServer.exe
[2026-Aug-25 11:47:24] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V924a\JLinkGUIServer.exe
[2026-Aug-25 11:47:24] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V9.24a "
[2026-Aug-25 11:47:24] [trace] [  JLink] - Device "CORTEX-M4" selected.
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 61.399ms returns 0x00
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_HasError()
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_OpenEx(...)
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 36.036ms returns "O.K."
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_Lock()
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.005ms returns 0x01
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.004ms returns 0x00
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.006ms returns 0x00
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.608ms returns 0x00
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2026-Aug-25 11:47:24] [trace] [  JLink] - 128000000 Hz / n, n >= 64
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.074ms
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_GetSpeed()
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.008ms returns 2000
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_GetSN()
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.002ms returns 1050357465
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.003ms
[2026-Aug-25 11:47:24] [debug] [  nRFXX] - read_device_family
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_IsOpen()
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.002ms returns 0x01
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - read_debug_port_idr
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - read_debug_port_register
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - coresight_configure
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.251ms returns 0
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2026-Aug-25 11:47:24] [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 232 milliseconds with result -102
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 102.008ms returns 0
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.747ms returns -1
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - ---just_abort_debug_action
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.605ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.494ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.567ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.521ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.513ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.573ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.438ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.543ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.502ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.455ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.460ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.544ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.557ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.570ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.439ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.610ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.602ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.540ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.582ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.509ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.506ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.449ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.511ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.436ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.522ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.501ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.537ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.448ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.446ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.539ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.465ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.486ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.467ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.478ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.515ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.534ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.496ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.457ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.036ms
[2026-Aug-25 11:47:24] [error] [ Worker] - An unknown error.
[2026-Aug-25 11:47:24] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 228 milliseconds with result -102
[2026-Aug-25 11:47:24] [debug] [  nRFXX] - close
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.004ms returns 0x01
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - close
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - disconnect_from_emu
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - is_connected_to_device
[2026-Aug-25 11:47:24] [trace] [  JLink] - JLINK_IsConnected()
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.003ms returns FALSE
[2026-Aug-25 11:47:24] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.484ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.549ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.487ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.564ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.505ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.462ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.587ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.452ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.479ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.532ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.616ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.658ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.471ms returns -1
[2026-Aug-25 11:47:24] [trace] [  JLink] - - 0.447ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.491ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - JLINK_HasError()
[2026-Aug-25 11:47:25] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.487ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.602ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.539ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.601ms returns -1
[2026-Aug-25 11:47:25] [debug] [SeggerBackend] - ---just_abort_debug_action
[2026-Aug-25 11:47:25] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.490ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.460ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.462ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.513ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.511ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.445ms returns -1
[2026-Aug-25 11:47:25] [trace] [ Client] - Command close executed for 56 milliseconds with result 0
[2026-Aug-25 11:47:25] [debug] [ Client] - terminate
[2026-Aug-25 11:47:25] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.478ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.495ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.470ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.514ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.569ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.466ms returns -1
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.549ms returns -1
[2026-Aug-25 11:47:25] [debug] [SeggerBackend] - Ignore exception An unknown error.
[2026-Aug-25 11:47:25] [trace] [  JLink] - - 0.034ms
[2026-Aug-25 11:47:25] [trace] [  JLink] - JLINK_Close()
[2026-Aug-25 11:47:25] [debug] [SeggerBackend] - Segger Backend closed.
[2026-Aug-25 11:47:25] [debug] [  nRFXX] - nRF family DLL closed
[2026-Aug-25 11:47:25] [trace] [ Worker] - Command close executed for 45 milliseconds with result 0
[2026-Aug-25 11:47:25] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2026-Aug-25 11:47:25] [trace] [ Worker] - Executed 6 commands for 280 milliseconds
[2026-Aug-25 11:47:25] [debug] [ Client] - Worker process exited with code: 0
[2026-Aug-25 11:47:25] [debug] [ Client] - Child process terminated with result 0
[2026-Aug-25 11:47:25] [trace] [ Client] - Executed 6 commands for 393 milliseconds
Questions:
  1. When using a PCA10040 kit equipped with the nRF5340-based interface MCU to debug an external nRF52832 target, does the cross-family CoreSight mapping require a specific configuration or command line override?
  2. What could be causing the JLINK_CORESIGHT_WriteAPDPReg function to return -1 during the target connection handshake?
Any guidance would be greatly appreciated!
    krf said:
    any update?
    It does not help to bump a thread less than 16 hours since your last update.
    Q1: Do you have any other nRF DK's to use as a programmer?
    Q2: If no; You have one of these cables, correct?
    Could you connect this on your nRF52-DK, from P19 (Debug out) to P18 (Debug in), to verify that the DK itself switches the debug port correctly?
    If you are then able to flash/erase/connect to the on-board nRF52832 device, then that has been verified.
    Håkon
