Requirements For Not Entering Emulated System Off Mode
Background
I had a question regarding Debug Interface mode and its relationship to entering true system off mode versus emulated system off mode (ie WFE in a while(1)).
Recently we had an issue where we were inadvertently leaving the CxxxPWRUPREQ bits set via SWD and as expected, we entered emulated system off mode. We addressed the issue by clearing the CxxxPWRUPREQ bits via SWD.
Questions
1. The Debug Interface Mode states "The device remains in Debug Interface mode when the debugger requests power through CxxxPWRUPREQ. Otherwise, the device is in normal mode. When a debug session is over, the device must be set to normal mode by the external debugger, followed by a pin reset."
I saw this related case saying that there is an equivalent to the pin reset wit just SWD connection.
Can you confirm that the pin reset (or CTRL-AP hard reset) explicitly required in order to guarantee that we enter true system off mode (rather than emulated system off mode)?
2. There does not seem to be a good way to detect if Debug Interface Mode is active on the nRF54L15, given that the  CxxxPWRUPREQ bits are not memory-mapped and inaccessible to the nRF54L15, as far as I can tell.
Am I missing something? or is there truly no way that the nRF54L15 can detect if Debug Interface Mode is active?
My goal with that would be to perform some alternative behavior, rather that getting stuck in a `while(1) WFE();` loop.
3. Assume that answer to #2 is "No, nRF54L15 can't tell if Debug Interface Mode is active or not". Can you think of any way for an application to potentially "catch" being in the WFE() loop as part of emulated system off?
Based on what I've researched, the answer is that the WDT nor HW Timers can be used to catch this condition. But I was curious what solution you might have seen others employ to try and solve this problem (have application exit emulated system off and reset after X seconds).
  • okay so following up here after doing some testing.
    #1
    1A:  CxxxPWRUPREQ bits set + cleared
    I confirmed that power performance was identical after (set + clear) vs (set + clear + ctrl-ap reset). So it turns out the ctrl-ap reset is not required (this is the main use-case i was asking about).
    - bits set: 3.2mW
    - bits cleared: 2.1 mW
    1B: CxxxPWRUPREQ bit set + halting debug session + cleared
    This is not a production scenario for us, but thought the result was interesting. After un-halting and clearing the CxxxPWRUPREQ bits, the power was elevated compared to baseline. Only after a ctrl-ap reset was done was the power restored back to baseline power (ie scenario 1A).
    - bits set + debugger active: 4.71 mW
    - bits cleared: 4.19 mW
    - after ctrl-ap reset: 2.1 mW
    This is on our projects board, not a nordic DK, but just including the magnitude of the power measured for reference. The upshot to me is that the guidance from you and the documentation online applies to halting debug scenario, but doesn't apply to non-halting scenarios where CxxxPWRUPREQ is set/cleared.
    # 2/3
    Your developer's suggestion was correct. On nRF54L15, TAD.DBGPWRUPREQ and TAD.SYSPWRUPREQ do reflect the external debugger's CxxxPWRUPREQ state, and the application can read them at runtime.  I didn't realize those existed, so thanks for highlighting them, its exactly what we were looking for.
  • Hi again Blake!
    Thanks for the thorough update! I'm glad the suggestion from the developer worked.
    Regarding what you observed regarding power consumption and CxxxPWRUPREQ I will look into if we can clarify this better in our documentation.
    Have a good week!
    Carl Richard
