FOTA Not Working
I am using:
  • nRF Connect SDK 3.4.0
  • SDK Tools 3.4.0
  • Asset Tracker Template
  • Thingy91X / nRF9151
  • CoAP cloud connection
The device successfully connects to nRF Cloud and reports:
SW type:        app
SW version:   0.0.1
HW version:   thingy91x
I created an OTA Release 0.0.3 in the new nRF Cloud OTA Experience (Memfault-based OTA Releases). The release is activated for cohort 3rd_ota, and the cohort view shows:
Current version: 0.0.1 (app) (thingy91x)
Future version:   0.0.3
Device count:     1
The device is the single member of that cohort.
However:
Asset Tracker FOTA path
Running:
    att_fota poll
results in:
    nrf_cloud_fota_poll: Checking for FOTA job...
    nrf_cloud_fota_poll: No pending FOTA job
Memfault OTA path
Running:
    mflt get_latest_release
results in:
     mflt: FOTA Update Available
     mflt: FOTA Update Available. Starting Download with URL: ...
     mflt: FOTA start failed, rv=-5
I stepped through the code and confirmed that:
     fota_download_any(...)  returns: -5
The device therefore sees the OTA Release through the Memfault path, but the Asset Tracker Template FOTA module does not see a pending FOTA job.
Question
For SDK 3.4.0 Asset Tracker Template:
  1. Is att_fota poll expected to work with the new OTA Release / Cohort / Activation workflow?
  2. Is the Asset Tracker Template expected to use the Memfault OTA path instead?
  3. Is the rv=-5 from fota_download_any() a known issue or indicative of a missing configuration?
  4. Are there any additional Kconfig settings required when using the new OTA Release system?
  • TF-M FW_INFO service rejects S0 and S1 image lookups.
    FW_INFO request: address=00008000
    ret=2
    out.result=-1
    FW_INFO request: address=0001C000
    ret=2
    out.result=-1
    status2err:
    TFM_PLATFORM_ERR_INVALID_PARAM
    -> -EINVAL
    -> -22
    For Thingy91X / nRF9151 / NCS 3.4.0, are S0 (0x8000) and S1 (0x1C000) expected to be valid FW_INFO locations when accessed through TFM_PLATFORM_IOCTL_FW_INFO, or is the FOTA library using an incorrect assumption about the image layout?
    tfm_platform_firmware_info() is called with:
    S0 address = 0x00008000
    S1 address = 0x0001C000
    and both calls return: ret = TFM_PLATFORM_ERR_INVALID_PARAM (2)
    out.result = -1
    which is converted by status2err() to: -EINVAL (-22)
    causing
    tfm_platform_s0_active() -> -22
    fota_download_b1_file_parse() -> -EIO
    fota_download() -> -5
    and finally:
    nrf_cloud_fota_poll: Failed to start FOTA download, error: -5
    All this while debugging....
              tfm_platform_ioctl(TFM_PLATFORM_IOCTL_FW_INFO)
  • The instrumentation shows that tfm_platform_firmware_info() fails for both S0 (0x8000) and S1 (0x1C000), with TFM_PLATFORM_ERR_INVALID_PARAM.
    For Thingy91X/nRF9151 using NCS 3.4.0 and the Asset Tracker Template, should S0/S1 actually contain valid FW_INFO structures?
    Or is fota_download_s0_active_get() incorrectly assuming an NSIB/S0/S1 bootloader topology while this device is using a standard MCUboot slot0/slot1 layout?
  • Hello, sorry for the delayed answer. I have forwarded your questions internally to get some feedback from our developers.
    I hope to have an update within end of this week.
    Øyvind
