Android Central connected to 2 peripherals
I have modified the Android Blinky App to connect two peripherals (nRF52 DK)
Scanning and Connecting to two peripherals works.. but when i want to start sending notifications of one of the peripherals the connection is terminated.
in the btsnoop.log I can see that the connection is terminated with "Connection Timeout"..
I am not sure if there is a problem with my implementation or device specific problem.
here is the source code:
        LocalBroadcastManager.getInstance(getActivity()).registerReceiver(mDatathroughputUpdateReceiver, makeGattUpdateIntentFilter());
    LocalBroadcastManager.getInstance(getActivity()).registerReceiver(mDatathroughputUpdateReceiver2, makeGattUpdateIntentFilter());
    Bundle extras = getArguments();
    mDeviceName = extras.getString(DatathroughputService.EXTRA_DEVICE_NAME);
    mDeviceAddress = extras.getString(DatathroughputService.EXTRA_DEVICE_ADDRESS);
    mDeviceName2 = extras.getString(DatathroughputService.EXTRA_DEVICE_NAME2);
    mDeviceAddress2 = extras.getString(DatathroughputService.EXTRA_DEVICE_ADDRESS2);
    mIntentDatathroughput = new Intent(getActivity(), DatathroughputService.class);
    mIntentDatathroughput.putExtra(DatathroughputService.EXTRA_DEVICE_ADDRESS, mDeviceAddress);
    getActivity().startService(mIntentDatathroughput);
    boolean flag = getActivity().bindService(mIntentDatathroughput, mServiceConnection, 0);
   mIntentDatathroughput2 = new Intent(getActivity(), DatathroughputService.class);
    mIntentDatathroughput2.putExtra(DatathroughputService.EXTRA_DEVICE_ADDRESS, mDeviceAddress2);
    getActivity().startService(mIntentDatathroughput2);
    boolean flag2 = getActivity().bindService(mIntentDatathroughput2, mServiceConnection2, 0);
  • if i only connect to one device my application works.. if i connect to two devices i sometimes recieve data from one device and it also happens, that i do not recieve any data.
    In the meantime I have found out that, setCharacteristicNotification() only enables the notification on the android device and gatt.writeDescriptor() writes the CCCD..
    and gatt.writeDescriptor() is only called for one device.
    here is a trace of the android monitor:
        D/BluetoothGatt: connect() - device: C5:7F:B0:8E:AA:91, auto: false
    D/BluetoothGatt: registerApp()
    D/BluetoothGatt: registerApp() - UUID=8c2e588c-697a-4d6c-86b6-49593dc9ea78
    D/BluetoothGatt: connect() - device: C5:87:1C:CC:95:68, auto: false
    D/BluetoothGatt: registerApp() - UUID=0291feac-df2d-47e3-acd4-12d533945892
    D/BluetoothGatt: onClientRegistered() - status=0 clientIf=6
    D/BluetoothGatt: onClientRegistered() - status=0 clientIf=7
    D/BluetoothGatt: onClientConnectionState() - status=0 clientIf=6 device=C5:7F:B0:8E:AA:91
    D/BluetoothGatt: onClientConnectionState() - status=0 clientIf=7 device=C5:87:1C:CC:95:68
    D/BluetoothGatt: discoverServices() - device: C5:7F:B0:8E:AA:91
    D/BluetoothGatt: onSearchComplete() = Device=C5:7F:B0:8E:AA:91 Status=0
    D/DeviceC5:7F:B0:8E:AA:91: Enable Notifications initGatt()
    D/BluetoothGatt: setCharacteristicNotification() - uuid: 00002a37-0000-1000-8000-00805f9b34fb enable: true
    D/BluetoothGatt: discoverServices() - device: C5:87:1C:CC:95:68
    D/BluetoothGatt: onSearchComplete() = Device=C5:87:1C:CC:95:68 Status=0
    D/DeviceC5:87:1C:CC:95:68: Enable Notifications initGatt()
    D/BluetoothGatt: setCharacteristicNotification() - uuid: 00002a19-0000-1000-8000-00805f9b34fb enable: true
    I think the problem is, that I connect to the second device, when service discovery, enable notification, write descriptor,.. have not finished..
    the nRFMaster Control Panel app works fine with 2 peripherals, so i dont think it is an issue regarding the android phone...
  • What if you enable notification and receive notification from one device, and then after that you connect to second one and enable notification on that ? Make sure you use separate BluetoothGatt instance for each of them.
    setCharacteristicNotification() should work, it should send the write command to the CCCD characteristic. Please check again.
  • that solution works. but now i have the problem, that I get the notifications from both devices on one broadcast reciever. is there a easy solution to recieve the data in diffrent variables?
  • I guess you can add more data (putExtra) about the device or the BluetoothGatt instance that send the notification in when you send broadcast. Then in the application you should be able to distinguish between the 2.
  • thanks for your help. i think, thats a solution to split the data from the two devices.
