Application: Find my tag
Customer: SHENZHEN FEASYCOM TECH CO LTD
Your placement of the capacitors is correct. They should sit in series between the tuning capacitors and the NFC pins.
100 pF is also a good choice, since it blocks most of the Qi energy and reduces NFC sensitivity a little. You can also try a smaller value, such as 47 pF, which blocks even more of the Qi energy but reduces NFC sensitivity further. If you change these capacitor values, remember to retune C13 and C20 to 13.56 MHz.
Could you measure the Qi charging power with the NFC coil disconnected? Could you also try another Qi charger, if possible, to see if the same problem occurs?
Nissanth Karunanithy
