I've provisioned AWS IoT certificates & keys as per Nordic Semi instructions and verified that they are correct in AWS IoT Core.
On placing them under <project / certs> in the aws_iot sample project, build was successful. However, on execution the application connects to local WiFi and then restarts. It fails to connect to AWS IoT.
Using nRF54LM20 + nRF7002EBII with nRF Connect SDK 3.4.1, target nrf54lm20dk/nrf54lm20b/cpuapp.
uart:~$ [00:00:13.573,118] <inf> wifi_nrf_bus: SPIM spi@c8000: freq = 8 MHz [00:00:13.573,139] <inf> wifi_nrf_bus: SPIM spi@c8000: latency = 0 [00:00:13.831,157] <inf> fs_zms: 2 Sectors of 4096 bytes [00:00:13.831,168] <inf> fs_zms: alloc wra: 0, f60 [00:00:13.831,176] <inf> fs_zms: data wra: 0, 1d0 *** Booting nRF Connect SDK v3.4.1-b20f8619ba9a *** *** Using Zephyr OS v4.4.2-33fa6a7aac6a *** [00:00:13.832,248] <inf> aws_iot_sample: The AWS IoT sample started, version: v1.0.0 [00:00:13.832,262] <inf> aws_iot_sample: Bringing network interface up and connecting to the network [00:00:13.832,691] <inf> wifi_supplicant: wpa_supplicant initialized Connection request failed (AP not found/4) [00:00:24.529,972] <inf> wpa_supp: wlan0: SME: Trying to authenticate with 96:b0:22:b2:90:61 (SSID='Tachyon-Ravi' freq=2437 MHz) [00:00:24.931,084] <inf> wpa_supp: wlan0: Trying to associate with 96:b0:22:b2:90:61 (SSID='Tachyon-Ravi' freq=2437 MHz) [00:00:24.968,663] <inf> wpa_supp: wlan0: Associated with 96:b0:22:b2:90:61 [00:00:24.969,228] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 [00:00:24.996,693] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with 96:b0:22:b2:90:61 [PTK=CCMP GTK=CCMP] [00:00:24.996,912] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to 96:b0:22:b2:90:61 completed [id=0 id_str=] Connected [00:00:25.033,994] <inf> aws_iot_sample: Network connectivity established uart:~$ [00:00:30.693,115] <inf> wifi_nrf_bus: SPIM spi@c8000: freq = 8 MHz [00:00:30.693,136] <inf> wifi_nrf_bus: SPIM spi@c8000: latency = 0 [00:00:30.951,181] <inf> fs_zms: 2 Sectors of 4096 bytes [00:00:30.951,193] <inf> fs_zms: alloc wra: 0, f60 [00:00:30.951,201] <inf> fs_zms: data wra: 0, 1d0 *** Booting nRF Connect SDK v3.4.1-b20f8619ba9a *** *** Using Zephyr OS v4.4.2-33fa6a7aac6a *** [00:00:30.952,273] <inf> aws_iot_sample: The AWS IoT sample started, version: v1.0.0 [00:00:30.952,288] <inf> aws_iot_sample: Bringing network interface up and connecting to the network [00:00:30.952,716] <inf> wifi_supplicant: wpa_supplicant initialized [00:00:36.635,446] <inf> wpa_supp: wlan0: SME: Trying to authenticate with 96:b0:22:b2:90:61 (SSID='Tachyon-Ravi' freq=2437 MHz) [00:00:37.035,878] <inf> wpa_supp: wlan0: Trying to associate with 96:b0:22:b2:90:61 (SSID='Tachyon-Ravi' freq=2437 MHz) [00:00:37.077,720] <inf> wpa_supp: wlan0: Associated with 96:b0:22:b2:90:61 [00:00:37.078,287] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 [00:00:37.112,170] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with 96:b0:22:b2:90:61 [PTK=CCMP GTK=CCMP] [00:00:37.112,385] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to 96:b0:22:b2:90:61 completed [id=0 id_str=] Connected [00:00:37.155,941] <inf> aws_iot_sample: Network connectivity established [00:00:42.156,033] <inf> aws_iot_sample: Connecting to AWS IoT uart:~$ [00:00:43.456,786] <inf> wifi_nrf_bus: SPIM spi@c8000: freq = 8 MHz [00:00:43.456,807] <inf> wifi_nrf_bus: SPIM spi@c8000: latency = 0 [00:00:43.714,798] <inf> fs_zms: 2 Sectors of 4096 bytes [00:00:43.714,810] <inf> fs_zms: alloc wra: 0, f60 [00:00:43.714,817] <inf> fs_zms: data wra: 0, 1d0 *** Booting nRF Connect SDK v3.4.1-b20f8619ba9a ***
After adding the following Kconfig debug statements to determine cause, the applications crashes.
After increasing the heap sizes to below, the application gets a little further but throws up “mqtt_helper: mqtt_connect, error: -116” ETIMEDOUT and then crashes.
I tried increasing the CONFIG_NET_SOCKETS_CONNECT_TIMEOUT from the default. The application stopped crashing but still get error -116.
CONFIG_MBEDTLS_HEAP_SIZE=81920
CONFIG_HEAP_MEM_POOL_SIZE=40144
CONFIG_NRF_WIFI_DATA_HEAP_SIZE=59856
CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=10000 (also tried 40000)
[00:00:05.768,960] <inf> wpa_supp: wlan0: SME: Trying to authenticate with 46:ac:8f:8c:6e:30 (SSID='Tachyon-Ravi' freq=2437 MHz)
[00:00:06.144,545] <inf> wpa_supp: wlan0: Trying to associate with 46:ac:8f:8c:6e:30 (SSID='Tachyon-Ravi' freq=2437 MHz)
[00:00:06.175,625] <wrn> net_if: iface 1 pkt 0x2004b260 send failure status -1
[00:00:06.181,722] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20003410, pkt=0x2004b43c, st=0, user_data=0
[00:00:06.185,758] <inf> wpa_supp: wlan0: Associated with 46:ac:8f:8c:6e:30
[00:00:06.186,393] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
[00:00:06.199,732] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20003410, pkt=0x2004b3f8, st=0, user_data=0
[00:00:06.213,161] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with 46:ac:8f:8c:6e:30 [PTK=CCMP GTK=CCMP]
[00:00:06.213,862] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to 46:ac:8f:8c:6e:30 completed [id=0 id_str=]
Connected
[00:00:06.268,300] <dbg> net_sock: zsock_socket_internal: (rx_q[0]): socket: ctx=0x200034d8, fd=10
[00:00:06.269,191] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Received restart event.
[00:00:06.291,735] <inf> net_dhcpv4: Received: 172.20.10.10
[00:00:06.291,966] <inf> aws_iot_sample: Network connectivity established
--- 5 messages dropped ---
[00:00:11.381,766] <dbg> net_sock_addr: dns_resolve_cb: (net_socket_service): dns status: -103
[00:00:11.381,813] <dbg> net_sock_addr: exec_query: (sysworkq): Timeout 2000
[00:00:11.442,125] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x200034d8, pkt=0x2004b3f8, st=0, user_data=0
[00:00:11.442,912] <dbg> net_sock_addr: dns_resolve_cb: (net_socket_service): dns status: -100
[00:00:11.442,933] <dbg> net_sock_addr: dns_resolve_cb: (net_socket_service): dns status: -103
[00:00:11.443,003] <dbg> mqtt_helper: broker_init: IPv4 Address found 54.86.151.37 (AF_INET)
[00:00:11.443,029] <dbg> mqtt_helper: client_connect: Using build-time provided security tag value from Kconfig
[00:00:11.443,066] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_DISCONNECTED --> MQTT_STATE_TRANSPORT_CONNECTING
[00:00:11.443,229] <dbg> net_sock_tls: tls_alloc: (sysworkq): Allocated TLS context, 0x20002918
[00:00:11.443,438] <dbg> net_tcp: tcp_conn_ref: (sysworkq): [0x2004b590] ref_count: 1
[00:00:11.443,458] <dbg> net_tcp: tcp_conn_alloc: (sysworkq): [0x2004b590] Allocated
[00:00:11.443,636] <dbg> net_sock: zsock_socket_internal: (sysworkq): socket: ctx=0x200035a0, fd=12
[00:00:11.463,655] <dbg> net_tcp: net_tcp_recv: (sysworkq): [0x2004b590] context: 0x200035a0, cb: 0x2ed5d, user_data: 0
[00:00:11.463,899] <dbg> net_tcp: net_tcp_connect: (sysworkq): [0x2004b590] context: 0x200035a0, local: 0.0.0.0, remote: 54.86.151.37
[00:00:11.464,298] <dbg> net_tcp: net_tcp_connect: (sysworkq): [0x2004b590] src: 172.20.10.10, dst: 54.86.151.37
[00:00:11.464,500] <dbg> net_tcp: tcp_start_handshake: (sysworkq): [0x2004b590] LISTEN->SYN_SENT
[00:00:11.464,526] <dbg> net_tcp: tcp_conn_ref: (sysworkq): [0x2004b590] ref_count: 2
[00:00:11.683,561] <dbg> net_tcp: tcp_resend_data: (tcp_work): [0x2004b590] send_data_retries=0
[00:00:12.011,782] <dbg> net_tcp: tcp_resend_data: (tcp_work): [0x2004b590] send_data_retries=1
[00:00:12.504,031] <dbg> net_tcp: tcp_resend_data: (tcp_work): [0x2004b590] send_data_retries=2
[00:00:13.242,280] <dbg> net_tcp: tcp_resend_data: (tcp_work): [0x2004b590] send_data_retries=3
[00:00:14.349,530] <dbg> net_tcp: tcp_resend_data: (tcp_work): [0x2004b590] send_data_retries=4
[00:00:14.464,665] <dbg> net_tcp: tcp_conn_close_debug: (sysworkq): [0x2004b590] closed by TCP stack (net_tcp_connect():4094)
[00:00:14.464,692] <dbg> net_tcp: tcp_conn_close_debug: (sysworkq): [0x2004b590] SYN_SENT->CLOSED
[00:00:14.464,716] <dbg> net_sock: zsock_received_cb: (sysworkq): ctx=0x200035a0, pkt=0, st=-116, user_data=0
[00:00:14.464,736] <dbg> net_sock: zsock_received_cb: (sysworkq): Marked socket 0x200035a0 as peer-closed
[00:00:14.464,757] <dbg> net_tcp: tcp_conn_unref: (sysworkq): [0x2004b590] ref_count=2
[00:00:14.464,774] <dbg> net_tcp: net_tcp_connect: (sysworkq): [0x2004b590] ret=-116
[00:00:14.464,972] <dbg> net_sock: zsock_close_ctx: (sysworkq): close: ctx=0x200035a0, fd=12
[00:00:14.464,993] <dbg> net_tcp: net_tcp_recv: (sysworkq): [0x2004b590] context: 0x200035a0, cb: 0, user_data: 0
[00:00:14.465,058] <dbg> net_tcp: net_tcp_put: (sysworkq): [0x2004b590] [CLOSED Seq=1{581805237} Ack=0{0}]
[00:00:14.465,097] <dbg> net_tcp: net_tcp_put: (sysworkq): [0x2004b590] context 0x200035a0 CONNECTING
[00:00:14.465,116] <dbg> net_tcp: tcp_conn_unref: (sysworkq): [0x2004b590] ref_count=1
[00:00:14.465,141] <err> mqtt_helper: mqtt_connect, error: -116
[00:00:14.465,166] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_TRANSPORT_CONNECTING --> MQTT_STATE_DISCONNECTED
[00:00:14.465,173] <err> aws_iot: mqtt_helper_connect, error: -116
[00:00:14.465,179] <err> aws_iot_sample: aws_iot_connect, error: -116
[00:00:14.465,184] <err> aws_iot_sample: Fatal error! Rebooting the device.
uart:~$
[00:00:00.019,528] <inf> wifi_nrf_bus: SPIM spi@c8000: freq = 8 MHz
[00:00:00.019,548] <inf> wifi_nrf_bus: SPIM spi@c8000: latency = 0
[00:00:00.276,442] <inf> fs_zms: 2 Sectors of 4096 bytes
[00:00:00.276,454] <inf> fs_zms: alloc wra: 0, f60
[00:00:00.276,463] <inf> fs_zms: data wra: 0, 1d0
[00:00:00.277,661] <inf> aws_iot_sample: The AWS IoT sample started, version: v1.0.0
[00:00:00.277,677] <inf> aws_iot_sample: Bringing network interface up and connecting to the network
[00:00:00.278,147] <inf> wifi_supplicant: wpa_supplicant initialized
[00:00:00.279,575] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Service WEST_TOPDIR/zephyr/subsys/net/lib/dns/resolve.c:45 has 1 pollable sockets
[00:00:00.279,593] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Monitoring 1 socket entries
[00:00:00.280,331] <dbg> mqtt_helper: mqtt_helper_poll_loop: Waiting for connection_poll_sem
[00:00:01.868,999] <inf> net_wifi_mgmt: Connection requested
[00:00:01.869,055] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
[00:00:05.770,093] <inf> wpa_supp: wlan0: SME: Trying to authenticate with 46:ac:8f:8c:6e:30 (SSID='Tachyon-Ravi' freq=2437 MHz)
[00:00:06.175,108] <inf> wpa_supp: wlan0: Trying to associate with 46:ac:8f:8c:6e:30 (SSID='Tachyon-Ravi' freq=2437 MHz)
[00:00:06.201,594] <wrn> net_if: iface 1 pkt 0x2004b260 send failure status -1
[00:00:06.206,313] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20003410, pkt=0x2004b43c, st=0, user_data=0
[00:00:06.211,703] <inf> wpa_supp: wlan0: Associated with 46:ac:8f:8c:6e:30
[00:00:06.212,338] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
[00:00:06.226,850] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20003410, pkt=0x2004b3f8, st=0, user_data=0
[00:00:06.240,286] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with 46:ac:8f:8c:6e:30 [PTK=CCMP GTK=CCMP]
[00:00:06.240,987] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to 46:ac:8f:8c:6e:30 completed [id=0 id_str=]
Connected
[00:00:06.258,621] <dbg> net_sock: zsock_socket_internal: (rx_q[0]): socket: ctx=0x200034d8, fd=10
[00:00:06.259,508] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Received restart event.
[00:00:06.274,646] <inf> net_dhcpv4: Received: 172.20.10.10
[00:00:06.274,876] <inf> aws_iot_sample: Network connectivity established
[00:00:11.299,932] <dbg> net_sock_addr: dns_resolve_cb: (net_socket_service): dns status: -103
[00:00:11.299,978] <dbg> net_sock_addr: exec_query: (sysworkq): Timeout 2000
[00:00:11.307,308] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x200034d8, pkt=0x2004b3f8, st=0, user_data=0
[00:00:11.308,094] <dbg> net_sock_addr: dns_resolve_cb: (net_socket_service): dns status: -100
[00:00:11.308,115] <dbg> net_sock_addr: dns_resolve_cb: (net_socket_service): dns status: -103
[00:00:11.308,185] <dbg> mqtt_helper: broker_init: IPv4 Address found 54.86.151.37 (AF_INET)
[00:00:11.308,211] <dbg> mqtt_helper: client_connect: Using build-time provided security tag value from Kconfig
[00:00:11.308,248] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_DISCONNECTED --> MQTT_STATE_TRANSPORT_CONNECTING
[00:00:11.308,411] <dbg> net_sock_tls: tls_alloc: (sysworkq): Allocated TLS context, 0x20002918
[00:00:11.308,620] <dbg> net_tcp: tcp_conn_ref: (sysworkq): [0x2004b590] ref_count: 1
[00:00:11.308,640] <dbg> net_tcp: tcp_conn_alloc: (sysworkq): [0x2004b590] Allocated
[00:00:11.308,819] <dbg> net_sock: zsock_socket_internal: (sysworkq): socket: ctx=0x200035a0, fd=12
[00:00:11.328,849] <dbg> net_tcp: net_tcp_recv: (sysworkq): [0x2004b590] context: 0x200035a0, cb: 0x2ed5d, user_data: 0
[00:00:11.329,094] <dbg> net_tcp: net_tcp_connect: (sysworkq): [0x2004b590] context: 0x200035a0, local: 0.0.0.0, remote: 54.86.151.37
[00:00:11.329,493] <dbg> net_tcp: net_tcp_connect: (sysworkq): [0x2004b590] src: 172.20.10.10, dst: 54.86.151.37
[00:00:11.329,695] <dbg> net_tcp: tcp_start_handshake: (sysworkq): [0x2004b590] LISTEN->SYN_SENT
[00:00:11.329,722] <dbg> net_tcp: tcp_conn_ref: (sysworkq): [0x2004b590] ref_count: 2
[00:00:11.610,765] <dbg> net_tcp: tcp_resend_data: (tcp_work): [0x2004b590] send_data_retries=0
[00:00:12.032,043] <dbg> net_tcp: tcp_resend_data: (tcp_work): [0x2004b590] send_data_retries=1
[00:00:12.663,289] <dbg> net_tcp: tcp_resend_data: (tcp_work): [0x2004b590] send_data_retries=2
[00:00:13.609,541] <dbg> net_tcp: tcp_resend_data: (tcp_work): [0x2004b590] send_data_retries=3
[00:00:14.329,846] <dbg> net_tcp: tcp_conn_close_debug: (sysworkq): [0x2004b590] closed by TCP stack (net_tcp_connect():4094)
[00:00:14.329,881] <dbg> net_tcp: tcp_conn_close_debug: (sysworkq): [0x2004b590] SYN_SENT->CLOSED
[00:00:14.329,906] <dbg> net_sock: zsock_received_cb: (sysworkq): ctx=0x200035a0, pkt=0, st=-116, user_data=0
[00:00:14.329,926] <dbg> net_sock: zsock_received_cb: (sysworkq): Marked socket 0x200035a0 as peer-closed
[00:00:14.329,947] <dbg> net_tcp: tcp_conn_unref: (sysworkq): [0x2004b590] ref_count=2
[00:00:14.329,964] <dbg> net_tcp: net_tcp_connect: (sysworkq): [0x2004b590] ret=-116
[00:00:14.330,162] <dbg> net_sock: zsock_close_ctx: (sysworkq): close: ctx=0x200035a0, fd=12
[00:00:14.330,182] <dbg> net_tcp: net_tcp_recv: (sysworkq): [0x2004b590] context: 0x200035a0, cb: 0, user_data: 0
[00:00:14.330,247] <dbg> net_tcp: net_tcp_put: (sysworkq): [0x2004b590] [CLOSED Seq=1{579699237} Ack=0{0}]
[00:00:14.330,269] <dbg> net_tcp: net_tcp_put: (sysworkq): [0x2004b590] context 0x200035a0 CONNECTING
[00:00:14.330,299] <dbg> net_tcp: tcp_conn_unref: (sysworkq): [0x2004b590] ref_count=1
[00:00:14.330,324] <err> mqtt_helper: mqtt_connect, error: -116
[00:00:14.330,349] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_TRANSPORT_CONNECTING --> MQTT_STATE_DISCONNECTED
[00:00:14.330,356] <err> aws_iot: mqtt_helper_connect, error: -116
[00:00:14.330,362] <err> aws_iot_sample: aws_iot_connect, error: -116
[00:00:14.330,367] <err> aws_iot_sample: Fatal error! Rebooting the device.
uart:~$
[00:00:00.019,526] <inf> wifi_nrf_bus: SPIM spi@c8000: freq = 8 MHz
[00:00:00.019,558] <inf> wifi_nrf_bus: SPIM spi@c8000: latency = 0
[00:00:00.276,443] <inf> fs_zms: 2 Sectors of 4096 bytes
[00:00:00.276,455] <inf> fs_zms: alloc wra: 0, f60
[00:00:00.276,464] <inf> fs_zms: data wra: 0, 1d0
[00:00:00.279,574] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Service WEST_TOPDIR/zephyr/subsys/net/lib/dns/resolve.c:45 has 1 pollable sockets
[00:00:01.868,838] <inf> net_wifi_mgmt: Connection requested
[00:00:01.868,893] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
[00:00:05.766,345] <inf> wpa_supp: wlan0: SME: Trying to authenticate with 46:ac:8f:8c:6e:30 (SSID='Tachyon-Ravi' freq=2437 MHz)
[00:00:06.172,618] <inf> wpa_supp: wlan0: Trying to associate with 46:ac:8f:8c:6e:30 (SSID='Tachyon-Ravi' freq=2437 MHz)
[00:00:06.212,901] <wrn> net_if: iface 1 pkt 0x2004b260 send failure status -1
[00:00:06.218,820] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20003410, pkt=0x2004b43c, st=0, user_data=0
[00:00:06.222,879] <inf> wpa_supp: wlan0: Associated with 46:ac:8f:8c:6e:30
[00:00:06.223,514] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
[00:00:06.242,123] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20003410, pkt=0x2004b3f8, st=0, user_data=0
[00:00:06.254,189] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with 46:ac:8f:8c:6e:30 [PTK=CCMP GTK=CCMP]
[00:00:06.255,112] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to 46:ac:8f:8c:6e:30 completed [id=0 id_str=]
Connected
[00:00:06.277,087] <dbg> net_sock: zsock_socket_internal: (rx_q[0]): socket: ctx=0x200034d8, fd=10
[00:00:06.277,978] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Received restart event.
[00:00:06.297,602] <inf> net_dhcpv4: Received: 172.20.10.10
[00:00:06.297,833] <inf> aws_iot_sample: Network connectivity established
uart:~$I would appreciate if someone in support can verify the sample connection to AWS IoT for target nrf54lm20dk/nrf54lm20b/cpuapp.
Thank you.
