We are evaluating the nPM2100 (EK v0.9.0) with the nRF54L15 in a coin-cell product
(CR2032/CR2450): VOUT = 3.3 V, BOOST in Auto mode, with a pulsed load of approximately
0.5 s on / 0.5 s off and 10–30 mA during normal operation.
At this load and VBAT = 2.5–3.0 V, Figure 8, "Load current triggering mode change vs.
VOUT" (nPM2100 Datasheet v1.0, 4496_057, p. 20), suggests that the boost normally
remains in Low Power mode. Therefore, battery current peaks in this mode are important
for our application.
Questions:
1. Default VBATMIN thresholds
With VBATMINLSEL/VBATMINHSEL = 0 (reset), which internal VBATMINL/VBATMINH thresholds
does the device actually use?
Register VBATMINLHSEL (0x2E, datasheet pp. 36–37) states "Default value is used."
Registers VBATMINL (0x2F) and VBATMINH (0x30) both have a reset value of 0x00,
corresponding to 0.65 V.
Are these internal default thresholds also 0.65 V, or are different internal
thresholds selected when VBATMINLSEL/VBATMINHSEL = 0?
2. Battery current in Low Power mode
a) Does IBATLIM (register 0x2D, datasheet p. 36) also apply in Low Power (hysteretic)
mode, or only in High Power mode? ILIMBOOST is specified for High Power mode only
(datasheet p. 18).
b) The nPM2100 Hardware Design Guidelines (4496_336, section 3.1) state that the
typical inductor peak current in hysteretic mode is 150 mA.
Is there a specified or characterized maximum peak current in Low Power mode, and how
does it depend on VBAT and VOUT (VOUT = 3.3 V, VBAT = 2.0–3.0 V)?
In particular, how should we relate this inductor peak current to the peak current
measured at the battery terminals, considering the input capacitor and the duration
of the switching pulses?
c) Figure 8 (datasheet p. 20) does not include a curve for VBAT = 2.0 V. Could you
share typical LP→HP transition thresholds for VBAT = 2.0–2.5 V with VOUT = 3.3 V?
3. Short startup current transients
Our external piezo driver (PAM8904H, supplied from the nPM2100 VOUT) may draw an input
inrush current of approximately 300 mA during startup, according to its manufacturer.
The actual pulse duration and current waveform still need to be measured.
This is a transient load at the nPM2100 output, not a measured 300 mA current at the
battery terminals.
With BOOST in Auto mode and VOUT = 3.3 V:
a) How does the nPM2100 respond to such a short output-current transient when
initially operating in Low Power mode?
b) Can this cause VOUT to collapse before the boost switches to High Power mode?
c) Is there a recommended way to mitigate these short transients, particularly
regarding capacitance at VBAT, VINT or VOUT?
Our understanding — could you please confirm or correct it?
A. VBATMIN and Zephyr driver initialization
The Zephyr driver npm2100_vbat (drivers/sensor/nordic/npm2100_vbat/npm2100_vbat.c)
writes VBATMINLHSEL = 3 (register control) and CTRLSET = 0x10 during initialization.
If the devicetree does not specify vbat-min-microvolt, the driver appears to leave
VBATMINL/H at their register reset values of 0x00, corresponding to 0.65 V.
Does this mean that the effective battery-voltage limiting threshold could be as low
as approximately 0.65 V, or is there another internal minimum threshold that takes
precedence?
We intend to configure an explicit VBATMIN value for each coin-cell type (CR2032 and
CR2450).
Is using vbat-min-microvolt as an initial threshold, followed by runtime updates to
VBATMINL/H when required, the recommended approach?
Are there recommended VBATMIN ranges for lithium coin cells, and any precautions when
changing these thresholds during operation?
B. IBATLIM in Low Power mode
Since ILIMBOOST is specified for High Power mode only, our understanding is that
changing IBATLIM between 600 mA and 100 mA may have little or no effect on
battery-current peaks while the boost remains in Low Power mode.
IBATLIM would become relevant when the boost enters High Power mode, potentially
during a high-current startup transient.
Is this interpretation correct?
Additional notes on the nPM2100 EK documentation
We noticed the following possible documentation inconsistencies in nPM2100 EK
Hardware v0.9.0 (4532_011):
- Page 20 identifies the permanently connected VINT capacitor as C4, whereas the EK
schematic identifies it as C7.
- Table 8 lists C50 as connected through P3 pins 3 and 6, whereas the EK schematic
indicates pins 3 and 4.
- Figure 14 appears to show the 22 µF VINT reservoir capacitor selected in the
factory jumper configuration. On our EK unit, P3 has a jumper fitted only on the
22 µF position (C49); the 10, 47 and 100 µF positions are parked on a single pin.
Could you confirm whether the factory-default VINT capacitance is 10 µF permanently
connected plus 22 µF selected through P3, for a nominal total of 32 µF?
This information is important for our battery-voltage transient simulations.
Thank you very much for your continued technical support.
Luiz
