About a procedure with UART as disable
Because of the power-saving support, I want to disable the UART before Call the sd_app_evt_wait().
I referred to two following sites to know the procedure of the case. 1.https://devzone.nordicsemi.com/question/5186/how-to-minimize-current-consumption-for-ble-application-on-nrf51822/?answer=5187#post-id-5187
2.https://devzone.nordicsemi.com/question/1119/handling-the-uart-when-sleeping/
However, there is for difference at the point that execute the following code when disable does UART in a procedure written as 1 to 2.
// Set TXD, RXD, CTS, RTS as high outputs
// Alternatively use NRF_GPIO->PIN_CNF to set pull resistors
NRF_GPIO->DIRSET = (1 << UART_TXD_GPIO) | (1 << UART_RXD_GPIO) | (1 << UART_RTS_GPIO) | (1 << UART_CTS_GPIO);
NRF_GPIO->OUTSET = (1 << UART_TXD_GPIO) | (1 << UART_RXD_GPIO) | (1 << UART_RTS_GPIO) | (1 << UART_CTS_GPIO);
As a result of having tried each procedure, I became able to reuse UART in 2 procedures, but UART did not become reusable in 1 procedure.
When disable does UART, is it right to perform in a procedure listed in 2?
  • Hi,Aryan, I'm sorry to confuse it. It is recognition from SDK_10.0.0 that nrf_drv_uart(nrf_drv_uart.c/nrf_drv_uart.h) was introduced, and my project makes app_uart_fifo.c of SDK_8.0.0 to a base. I think app_uart_fifo.c of SDK_8.0.0 to have taken the role of the driver. Therefore I do not use nrf_drv_uart. Is my understanding incorrect?
  • Hi satokato,
    I see, thanks for clarifying this. The API for the uart_fifo stays same in SDK8 and SDK11. That means that the recommendation i gave you to close the uart and the reinit again is still valid.
    while(your_condition)
        err_code = app_uart_close();
        err_code = sd_app_evt_wait();
        APP_UART_FIFO_INIT( &comm_params,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOW,
                           err_code);
  • Hi,Aryan, Thank you for confirmation. I tried a code recommended by you, but have not yet worked well. After checking it, in app_uart_init() function and app_uart_close() function recommended by you, there seems to be for difference to a register set in SDK8 and SDK10. (For example,the register setting by interrupts_disable() function and pins_to_default() function of SDK10.) As of the following code, it seems to work well if you set the register which has a difference in the manual.
    uint32_t app_uart_init() { … // Configure RX and TX pins. // << add start. nrf_gpio_pin_set(p_comm_params->tx_pin_no); // >> add end. nrf_gpio_cfg_output(p_comm_params->tx_pin_no); nrf_gpio_cfg_input(p_comm_params->rx_pin_no, NRF_GPIO_PIN_NOPULL); … }
    When I use SDK8, is it necessary to set the register with the difference by manual operation in comparison with setting of other SDK10?
  • Hi Satokato, I am sorry for late reply, I was sick all week. I did not realize that there are differences in the two SDKs for this API, after your changes, did you manage to get it to work?
  • Hi Aryan, Thank you for reply. When I compare SDK10 with SDK8 and set a certain register for the difference by manual operation for setting, I seem to work well. The register whom there was for the difference is as follows for setting.
    ・app_uart_init()
    NRF_GPIO->OUTSET
    ・app_uart_close()
    NRF_UART0->INTENCLR / NRF_UART0->PSELTXD / NRF_UART0->PSELRXD / NRF_GPIO->PIN_CNF[tx_pin_no] / NRF_GPIO->PIN_CNF[rx_pin_no]
    But I would like to confirm whether there is not a problem as a procedure.
    For example, in the case of app_uart_close() function, Between SDK8 and SDK10, I think that there is for difference as follows.
    ・In the case of SDK8
    uint32_t app_uart_close(uint16_t app_uart_uid);
    ・In the case of SDK10
    uint32_t app_uart_close(void);
