Timer handler mess up application flow
I have a working application with TIMER1 setup to fire handler every 10us. I would like to add a 560us periodic event to enable/disable a PWM, so I add a little more code to my timer handler:
static uint16_t                         m_10us_cntr2= 0;
void timer_event_handler(nrf_timer_event_t event_type, void* p_context)
    // TROUBLESOME_CODE  -----------------------------------------
    m_10us_cntr2++;
    if (m_10us_cntr2>= 56)
//        NOT EVEN DOING ANYTHING HERE YET
        m_10us_cntr2= 0;
    // /TROUBLESOME_CODE  ----------------------------------
    m_10us_cntr++;
    if (m_10us_cntr>= 100000)
        m_second_counter++;
        m_10us_cntr= 0;
    //m_second_counter++;
    if (m_second_counter == PERIODIC_TASKS_PERIOD)
        m_periodic_flag = true;
        m_second_counter = 0;
To my surprise, just the presence of the if block make the app crash completely during TIMER1 initialization. The debug printf() statement "end of timer_init\n" I had after my TIMER1 initialization function calls could only push out "end" or "end o" before the app crashes.
What is causing this? Is there a way to fix it?
Update: for reference, here is my timer_init() code:
void timer_init()
    DEBUG_PRINT(("timer_init\n"));
    uint32_t                err_code = NRF_SUCCESS;
    uint32_t                time_us = 10; //Time (in microseconds) between consecutive compare events.
    uint32_t                time_ticks;
    nrf_drv_timer_config_t  timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG(1);
    timer_config.frequency  = NRF_TIMER_FREQ_16MHz;
    err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_event_handler);
    if (err_code != NRF_SUCCESS)
       // The only error possible for this function is NRF_ERROR_INVALID_PARAM	according to SDK v10 documentation
       // TODO: handling error
    time_ticks = nrf_drv_timer_us_to_ticks(&m_timer, time_us);
    DEBUG_PRINT(("time_ticks = %d\n", time_ticks));
    nrf_drv_timer_extended_compare(
        &m_timer, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    DEBUG_PRINT(("end of timer_init()\n"));
The app always failed while printing out the last debug print ("end of timer_init()").
Update Apr 20 2016: So I run a few more experiments, and the details bizarre me even more, so please bare with me.
  1. I first tried to use uVision debug to look at what cause the app flow to hang. When I hit stop, I found the current-line-of-execution pointer sometimes points at nrf_timer_event_check(), sometimes at my timer_event_handler(), sometimes at nrf_timer_event_clear(). It feels like this is a case of interrupt handling taking too long and block the code flow.
    I also observed that the "end of timer_init()\n" print not only fails midway, but also sometimes have characters print out of order.
  2. I tried to move the timer_init() call to the bottom of all of my initialization function calls. This moves the following two functions to be called before timer_init():
    a- i2c_slave_drv_init(): A function I used to read confirmation values and initialization values to an I2C slave peripheral. In case it matters, my I2C read and write implementation uses the following blocking wait to wait for TWI Driver events
        watchdog_counter = 0;
        while(!twi_drv_evt_received && watchdog_counter < 60000)
            nrf_delay(1);
            watchdog_counter++;
    b- ble_advertising_start()
    The app can now run without major issue after this change. The only minor issue is my 1s flag now takes a lot more than a second to fire. I assume this is due to timer_event_handler() processing delay
  3. Now here comes the bizarre part: I tried to reproduce the issue by moving timer_init() back where it was. And the issue stop happening. However, that is only as long as I don't add another if block to timer_event_handler. If I change the TROUBLESOME_CODE into the following, I can then reproduce the issue:
    if (m_10us_cntr2 > 56)
        if (m_pwm_toggle) {
            // TODO
        } else {
            // TODO
        m_pwm_toggle = !m_pwm_toggle;
        m_10us_cntr2 = 0;
  4. At this point, I found out that the app did not actually got stuck entirely. Returning to the console after writing the above, I found that the issue is:
    a- While running initialization code, it just takes almost half a minute to print out a single characters. You can see in this screen record: uart_rate_init.avi (Please excuse the low quality. I need to do so due to the long duration of the process)
    b- While running main()'s super loop code, the app could only print 3-5 characters a second. You could see in this screen record: uart_rate_loop.avi
And that is the last of my observations. I hope somebody have an idea what is going on. This is really too strange for me to have any idea.
  • Yes, it could happen with the amount of code you have. More importantly, the chances are more if the timer interrupt latency is increased by having other interrupts. I think 10us is too short for reliable interrupt handling especially if this has to work with rest of the interrupts.
  • That is indeed unfortunate. With TIMER0 occupied by SoftDevice, TIMER2 used for PWM, I am left with only TIMER1 to handle both PWM toggling and periodic app task timing. On the other hand my feature really need that 10us if not 5us, because PWM will need to be toggle at irregular interval.
    I guess we won't be able to add that feature for now. Perhaps if I got more time later I will try to think of another solution, just got an idea actually but I ran out of time for this feature for now. Thanks for the help, Aryan.
  • By the way, should we update one of the answer with the conclusion that stack overflow happened?
  • Hi, Sorry for late replies, I really think 10us is not feasible. If you want such timing you should design something that do not need interrupt handlers using PPI and GPIOTE. Else use nRF52 where you have dedicated PWM modules which will be able to give any kind of complex PWM patterns. I will update my answer that the stack overflow happened and you could accept the answer. Think about using nRF52 instead.
  • I don't see how the timer handler here is called recursively. The timer handler is called from inside the timer interrupt so by definition, even if another timer interrupt arrives, the first one is finished and returns completely before it's taken again.
    I can see (and thought originally when I saw the 10us in the original post which was clearly infeasible) that the timer would be getting constantly called, ie as soon as it returns from one call, it's called instantly. I can therefore also see how the CPU ends up doing nothing but servicing the timer, stopping anything else useful from happening, but not recursively and thus not overflowing the stack.
    Is there actual evidence here the stack overflowed as opposed to the CPU just being unable to keep up with the rate of timeouts it needs to handle and never really getting out of the TIMER interrupt code?
