Timer handler mess up application flow
I have a working application with TIMER1 setup to fire handler every 10us. I would like to add a 560us periodic event to enable/disable a PWM, so I add a little more code to my timer handler:
static uint16_t                         m_10us_cntr2= 0;
void timer_event_handler(nrf_timer_event_t event_type, void* p_context)
    // TROUBLESOME_CODE  -----------------------------------------
    m_10us_cntr2++;
    if (m_10us_cntr2>= 56)
//        NOT EVEN DOING ANYTHING HERE YET
        m_10us_cntr2= 0;
    // /TROUBLESOME_CODE  ----------------------------------
    m_10us_cntr++;
    if (m_10us_cntr>= 100000)
        m_second_counter++;
        m_10us_cntr= 0;
    //m_second_counter++;
    if (m_second_counter == PERIODIC_TASKS_PERIOD)
        m_periodic_flag = true;
        m_second_counter = 0;
To my surprise, just the presence of the if block make the app crash completely during TIMER1 initialization. The debug printf() statement "end of timer_init\n" I had after my TIMER1 initialization function calls could only push out "end" or "end o" before the app crashes.
What is causing this? Is there a way to fix it?
Update: for reference, here is my timer_init() code:
void timer_init()
    DEBUG_PRINT(("timer_init\n"));
    uint32_t                err_code = NRF_SUCCESS;
    uint32_t                time_us = 10; //Time (in microseconds) between consecutive compare events.
    uint32_t                time_ticks;
    nrf_drv_timer_config_t  timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG(1);
    timer_config.frequency  = NRF_TIMER_FREQ_16MHz;
    err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_event_handler);
    if (err_code != NRF_SUCCESS)
       // The only error possible for this function is NRF_ERROR_INVALID_PARAM	according to SDK v10 documentation
       // TODO: handling error
    time_ticks = nrf_drv_timer_us_to_ticks(&m_timer, time_us);
    DEBUG_PRINT(("time_ticks = %d\n", time_ticks));
    nrf_drv_timer_extended_compare(
        &m_timer, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    DEBUG_PRINT(("end of timer_init()\n"));
The app always failed while printing out the last debug print ("end of timer_init()").
Update Apr 20 2016: So I run a few more experiments, and the details bizarre me even more, so please bare with me.
  1. I first tried to use uVision debug to look at what cause the app flow to hang. When I hit stop, I found the current-line-of-execution pointer sometimes points at nrf_timer_event_check(), sometimes at my timer_event_handler(), sometimes at nrf_timer_event_clear(). It feels like this is a case of interrupt handling taking too long and block the code flow.
    I also observed that the "end of timer_init()\n" print not only fails midway, but also sometimes have characters print out of order.
  2. I tried to move the timer_init() call to the bottom of all of my initialization function calls. This moves the following two functions to be called before timer_init():
    a- i2c_slave_drv_init(): A function I used to read confirmation values and initialization values to an I2C slave peripheral. In case it matters, my I2C read and write implementation uses the following blocking wait to wait for TWI Driver events
        watchdog_counter = 0;
        while(!twi_drv_evt_received && watchdog_counter < 60000)
            nrf_delay(1);
            watchdog_counter++;
    b- ble_advertising_start()
    The app can now run without major issue after this change. The only minor issue is my 1s flag now takes a lot more than a second to fire. I assume this is due to timer_event_handler() processing delay
  3. Now here comes the bizarre part: I tried to reproduce the issue by moving timer_init() back where it was. And the issue stop happening. However, that is only as long as I don't add another if block to timer_event_handler. If I change the TROUBLESOME_CODE into the following, I can then reproduce the issue:
    if (m_10us_cntr2 > 56)
        if (m_pwm_toggle) {
            // TODO
        } else {
            // TODO
        m_pwm_toggle = !m_pwm_toggle;
        m_10us_cntr2 = 0;
  4. At this point, I found out that the app did not actually got stuck entirely. Returning to the console after writing the above, I found that the issue is:
    a- While running initialization code, it just takes almost half a minute to print out a single characters. You can see in this screen record: uart_rate_init.avi (Please excuse the low quality. I need to do so due to the long duration of the process)
    b- While running main()'s super loop code, the app could only print 3-5 characters a second. You could see in this screen record: uart_rate_loop.avi
And that is the last of my observations. I hope somebody have an idea what is going on. This is really too strange for me to have any idea.
  • Hi Vo,
    I have done little bit of digging in cortex M0 book and gone through this thread again. RK, You are right, It is not likely to have a stack overflow in this case because of the interrupt nesting. The AVI file Vo Thanh attached prroves that the printing thread is almost starving for CPU just after the timer interrupt is enabled. The rest of the two prints were printed normally. I have now deleted the confusing update i made ... This is most most likely that main thread is starving of CPU time.
  • Vo, the ARM6V reference manual gives you the basic interrupt latency, or just google for 'Cortex M0 Interrupt Latency' and it will point you to a reference. The softdevice spec tells you how many extra cycles are added for the trampoline, it's 49 cycles which is really just the softdevice working out what the interrupt is, working out it's external, loading up the interrupt table and jumping.
    At this point however a better question is what are you trying to do? Interrupt timers on a 16MHz processor for a 10us event is pretty aggressive. Doing it while a higher priority softdevice is running, using generic timer code which is great but not really designed for 100kHz operation is going to break down, once you're in connection, it's going to really break down as the softdevice interrupts you. If you can say what you're trying to accomplish here it may be possible to suggest a better way.
  • @rols: Thanks for the offer. I will try my best to explain my feature while staying conformed to my NDA. So please forgive me if things become cryptic because details are withdrawn. To be honest, I simply am not sure how much I can share in public forums. I think one would be able to guess what I am doing based on this much info anyway.
    What I am trying to do is precisely turning on/off PWM and/or trigger GPIO event at varying intervals, usually 300-20,000us, with precision about 10us. The exact intervals varies by the situation. Also, this feature is not used all the time.
    Because I also need my existing application work properly in the background, I decided to use a constant compare value that I could couple with a few counters to get both PWM toggling and my normal application working normally. As we have found out, that does not work so well.
  • So, as I mentioned, I did get a new idea. It is to simply halt the normal operation when I am running this new feature. The normal operation only require 5 minute precision, and the new feature's operation finishes within a second.
    I will now have the compare value at whatever exact interval I need PWM toggling, says 560 or 935. Upon timer interrupt, I update the compare value and let the timer run again. Once the process is completed, I will simply reinitialize the timer to have the normal operation runs again.
    I think this sounds way better than my previous approach. I feel like an idiot now that I looked at the big picture. Proper sleeps are really necessary for quality work after all.
    Please feel free to give your evaluation of my new idea and any recommendation you have.
