some question of nrf51822 timer
I am developing using a nrf51822.I need delay timer that can be substitued for nrf_delay_ms(). in other words,need a task delay that can be taken some event from another side during delay time. Is nrf_timer_delay_ms() possible ? If so,please tell me how to use and attention point regarding sw side and hw side. BR
  • the timer event that i have to get during delay,is app timer(rtc1 timer) expire event for calling the handler.
  • I seems to find the good solution. I use app timer and app timer use the rtc1 timer. so I made the delay like below. void nrf_delay_ms(uint32_t volatile number_of_ms) { while(number_of_ms != 0) {
    number_of_ms--; #if 1 for(uint8_t i=0;i<30;i++) { RTC1_IRQHandler(); nrf_delay_us(30); } #else nrf_delay_us(999); #endif } } because RTC1_IRQHandler will be expired every 31us. 32khz = 31us. Could you inspect my code?
  • I'd strongly recommend you to rework your code so that you don't rely on a precise delay mechanism, but instead use app_timer to trigger tasks with the intervals you need. This will give you a much more robust solution, especially when taking into account the different interrupts that will all affect delay loops.
  • Here's my best guess. Not tested:
    #include <nrf51_bitfields.h>
    #include <nrf51.h>
    #define LFCLK_FREQUENCY           (32768UL)                               /**< LFCLK frequency in Hertz, constant. */
    // The attribute constructor ensures this runs before main.
    void initClock() __attribute__((constructor));
    void initClock()
    	NRF_CLOCK->LFCLKSRC             = (CLOCK_LFCLKSRC_SRC_Synth << CLOCK_LFCLKSRC_SRC_Pos);
    	NRF_CLOCK->EVENTS_LFCLKSTARTED  = 0;
    	NRF_CLOCK->TASKS_LFCLKSTART     = 1;
    	while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
    /** @brief Function for configuring the RTC with TICK to 100Hz and COMPARE0 to 10 sec.
    void sleepDelay(uint32_t ms)
    	// We use RTC1 since RTC0 is controlled by the soft device.
    	// Enable interrupt.
    	NVIC_EnableIRQ(RTC1_IRQn);
    	// Find the minimum prescalar for this delay.
    	// Freq = 32768 Hz / (PRESCALAR + 1)
    	// RTC1 has a 24 bit counter.
    	// So we want 0xFFFFFF / Freq > ms
    	// =>   PRESCALAR > ms * 32768 / 0xFFFFFF - 1
    	// PRESCALAR is in the range 0 to 2^12-1.
    	NRF_RTC1->PRESCALER     = ms * LFCLK_FREQUENCY / 0xFFFFFFUL;
    	NRF_RTC1->CC[0]         = ms * LFCLK_FREQUENCY / (NRF_RTC1->PRESCALER + 1);
    	// Enable COMPARE0 event and COMPARE0 interrupt:
    	NRF_RTC1->EVTENSET      = RTC_EVTENSET_COMPARE0_Msk;
    	NRF_RTC1->INTENSET      = RTC_INTENSET_COMPARE0_Msk;
    	NRF_RTC1->TASKS_CLEAR = 1;
    	NRF_RTC1->TASKS_START = 1;
    	// Wait For Event.
    	// This wakes up when any interrupt is fired so it is possible that the delay will not be as long as requested.
    	__WFE();
    /** @brief: Function for handling the RTC0 interrupts.
     * Triggered on TICK and COMPARE0 match.
    void RTC1_IRQHandler()
    	if ((NRF_RTC1->EVENTS_COMPARE[0] != 0) && ((NRF_RTC1->INTENSET & RTC_INTENSET_COMPARE0_Msk) != 0))
    		NRF_RTC1->EVENTS_COMPARE[0] = 0;
    		NRF_RTC1->INTENSET = 0;
    		NRF_RTC1->TASKS_STOP = 1;
  • When I try to use this project using the resources available in SDK8 in Keil, I am getting an error saying that file is missing
    "no source": Error:  #5: cannot open source input file "..\..\..\..\..\bsp\bsp_btn_ble.c": No such file or directory
    Which SDK is the project timer_example_timer_mode.zip based on
