Hey there,
are there any plans for NRF52 USB development dongles (just like the NRF51 dongle)?
Jens
Hey there,
Jens
Might also be interested in a nrf52 dongle, especially if I could plug it into a laptop and sniff/talk BT5 and 802.15.4 flavours.
Did someone test the "ABSniffer USB Dongle 528"? It seems to include a nRF52832 connected to a serial to USB bridge.
Just a short update about our test with the ""ABSniffer USB Dongle 528". We have just received 5 pieces of the dongle and could program the dongle with our firmware over an external J-Link. Now it's working as a Nordic connectivity device. The nRF52 on the dongle is connected to the UART-USB bridge by the same pins as on the nRF52 DK. The same firmware that runs on the nRF52 DK can be used for the dongle.
Hi
Just a short help if you try to use the "ABSniffer USB Dongle 528" as nRF52 Dongle. To program the nRF52 you need to connect the J-Link to the pins marked in the picture below.
Regards Adrian
I also had success reprogramming the ABSniffer USB Dongle. Note that there's actually 4 pads in a row used for programming (the GND and VCC pads to the bottom-left of the SWCLK and SWDIO pads). If you contact April Brothers via email, they will sell you the POGO-pin assembly they use to program the device ($8 per + $6 shipping). If you plan on programming several, this may be the better solution. See photo of the assembly here: i.imgur.com/cPDdzFa.jpg
Or if you want to make your own assembly, the pads are designed for a 5-pin 1.27mm pitch POGO pin assembly (middle pin not connected, sits between VCC and SWCLK pads).
