ant_background_scanning with S310 on nRF5144 loose RX packets
I modified the code of ant_background_scanning_s212_pca10040 to make it works with s310 on nRF5144 xxaa.
The code works fine, but loose a lot of RX packets (more than 80%).
ANT-WARE vs custom board
In the figure the packets received by AntWare and the packets received by the custom board.
I already implemented the same code on nRF5144 xxaa, but with s210 and the missed RX packets were very less.
This is my code:
#include "softdevice_handler.h"
#include "ant_stack_config.h"
#include "ant_channel_config.h"
#include "ant_search_config.h"
#include "ant_interface.h"
#include "ant_parameters.h"
#define ANT_MS_CHANNEL_NUMBER       ((uint8_t) 1)                       /**< Master channel. */
#define ANT_BS_CHANNEL_NUMBER       ((uint8_t) 0)                       /**< Background scanning channel. */
#define ANT_NETWORK_NUMBER          ((uint8_t) 0)                       /**< Default public network number. */
#define ANT_MS_CHANNEL_TYPE         CHANNEL_TYPE_MASTER                 /**< Bi-directional master. */
#define ANT_BS_CHANNEL_TYPE         CHANNEL_TYPE_SLAVE                  /**< Bi-directional slave. */
#define ANT_BS_DEVICE_NUMBER        ((uint16_t) 2)                      /**< Wild-card. */
#define ANT_DEVICE_TYPE             ((uint8_t) 2)                       /**< Device type. */
#define ANT_TRANSMISSION_TYPE       ((uint8_t) 2)                       /**< Transmission type. */
#define ANT_FREQUENCY               ((uint8_t) 66)                      /**< 2466 MHz. */
#define ANT_CHANNEL_PERIOD          ((uint16_t) 65535)                   /**< 0,5 Hz. */
#define ANT_CHANNEL_PERIOD_NONE     ((uint16_t) 0x00)                   /**< This is not taken into account. */
#define ANT_BEACON_PAGE             ((uint8_t) 1)
void ant_message_send(void);
void background_scanner_process(ant_evt_t * p_ant_evt);
void master_beacon_process(ant_evt_t * p_ant_evt);
static uint8_t m_last_rssi       = 0;
static uint16_t m_last_device_id = 0;
static uint8_t m_recieved        = 0;
/**< Derive from device serial number. */
static uint16_t ant_ms_dev_num_get(void)
    return ((uint16_t) (NRF_FICR->DEVICEID[0]));
void ant_evt_dispatch(ant_evt_t * p_ant_evt)
    switch (p_ant_evt->channel)
        case ANT_BS_CHANNEL_NUMBER:
            background_scanner_process(p_ant_evt);
        case ANT_MS_CHANNEL_NUMBER:
            master_beacon_process(p_ant_evt);
	DBG_init();
	LED_init();
	/////////////////////////////////////////////   ANT    ///////////////////////////////////////////////
	uint32_t err_code;
	err_code = softdevice_ant_evt_handler_set(ant_evt_dispatch);
	err_code = softdevice_handler_init(NRF_CLOCK_LFCLKSRC_XTAL_50_PPM, NULL, 0, NULL);
	err_code = ant_stack_static_config();
    /* Set library config to report RSSI and Device ID */
    err_code = sd_ant_lib_config_set(ANT_LIB_CONFIG_MESG_OUT_INC_RSSI
                                            | ANT_LIB_CONFIG_MESG_OUT_INC_DEVICE_ID);
    const uint16_t dev_num = ant_ms_dev_num_get();
    const ant_channel_config_t ms_channel_config =
        .channel_number    = ANT_MS_CHANNEL_NUMBER,
        .channel_type      = ANT_MS_CHANNEL_TYPE,
        .ext_assign        = 0x00,
        .rf_freq           = ANT_FREQUENCY,
        .transmission_type = ANT_TRANSMISSION_TYPE,
        .device_type       = ANT_DEVICE_TYPE,
        .device_number     = dev_num,
        .channel_period    = ANT_CHANNEL_PERIOD,
        .network_number    = ANT_NETWORK_NUMBER,
    const ant_channel_config_t bs_channel_config =
        .channel_number    = ANT_BS_CHANNEL_NUMBER,
        .channel_type      = ANT_BS_CHANNEL_TYPE,
        .ext_assign        = EXT_PARAM_ALWAYS_SEARCH,
        .device_number     = ANT_BS_DEVICE_NUMBER,
        .channel_period    = ANT_CHANNEL_PERIOD_NONE,
    const ant_search_config_t bs_search_config =
        .low_priority_timeout  = ANT_LOW_PRIORITY_TIMEOUT_DISABLE,
        .high_priority_timeout = ANT_HIGH_PRIORITY_SEARCH_DISABLE,
        .search_sharing_cycles = ANT_SEARCH_SHARING_CYCLES_DISABLE,
        .search_priority       = ANT_SEARCH_PRIORITY_DEFAULT,
        .waveform              = ANT_WAVEFORM_DEFAULT,
    err_code = ant_channel_init(&ms_channel_config);
    err_code = ant_channel_init(&bs_channel_config);
    err_code = ant_search_init(&bs_search_config);
    // Fill tx buffer for the first frame
    ant_message_send();
    err_code = sd_ant_channel_open(ANT_MS_CHANNEL_NUMBER);
    err_code = sd_ant_channel_open(ANT_BS_CHANNEL_NUMBER);
	// Main Loop
	while(1)
		sd_app_evt_wait();
    uint32_t      err_code;
    ANT_MESSAGE * p_ant_message = (ANT_MESSAGE*)p_ant_evt->evt_buffer;
    switch(p_ant_evt->event)
        case EVENT_RX:
            LED_redLed_setStatus(LED_ON);
            if(p_ant_message->ANT_MESSAGE_stExtMesgBF.bANTDeviceID)
                m_last_device_id = uint16_decode(p_ant_message->ANT_MESSAGE_aucExtData);
            if(p_ant_message->ANT_MESSAGE_stExtMesgBF.bANTRssi)
                m_last_rssi = p_ant_message->ANT_MESSAGE_aucExtData[5];
            DBG_log("Message number %d\n\r", m_recieved);
            DBG_log("Device ID:     %d\n\r", m_last_device_id);
            DBG_log("RSSI:          %d\n\r\n\r", m_last_rssi);
            m_recieved++;
		LED_redLed_setStatus(LED_OFF);
void ant_message_send()
    uint32_t       err_code;
    uint8_t        tx_buffer[ANT_STANDARD_DATA_PAYLOAD_SIZE];
    static uint8_t counter = 0;
    tx_buffer[0] = ANT_BEACON_PAGE;
    tx_buffer[1] = m_last_rssi;
    tx_buffer[2] = (uint8_t) m_last_device_id;        // LSB
    tx_buffer[3] = (uint8_t) (m_last_device_id >> 8); // MSB
    tx_buffer[6] = counter++;
    tx_buffer[7] = m_recieved;
    err_code = sd_ant_broadcast_message_tx(ANT_MS_CHANNEL_NUMBER,
                                           ANT_STANDARD_DATA_PAYLOAD_SIZE,
                                           tx_buffer);
        case EVENT_TX:
            ant_message_send();
There are some things I didn't consider?
Has someone advices for me?
I saw that if I dont' set the background scanning I don't have lost packets. There's no way to set background scanning and don't miss packets, is there?
Thanks
