Accelerometer giving out random output
Hello. I am using a nrf51822 with sdk 10 and softdevice 130. It has an accelerometer mma8653 to read the orientation of the chip, I am trying to get the x,y and z co-ordinates from it using i2c method and have a nrf_drv_twi example as reference but the accelerometer is giving out random data which changes when I change the chips orientation. Since it is giving out no error on compliation and debugging, i guess there must be some problem in the code logic. I am putting the code up here. Kindly tell if there is some error in the logic or some other issue
#define MMA8653_BASE_ADDRESS 0x1D
const uint8_t ACTIVE_MASK  = 0x01;
const uint8_t STDBY_MASK   = 0x00;
#define RST_MASK 0x40
static uint8_t m_device_address;        //!< Device address in bits [7:1]
const uint8_t access_data                = 0x01;                                        // Data X0,X1,Y0,Y1,Z0 and Z1
uint8_t command_who_am_i[2]              = {0x0D, 0x5A};
uint8_t command_data_active[2]       = {0x2A, ACTIVE_MASK};         // Set MMA to active
uint8_t command_data_stdby[2]        = {0x2A, STDBY_MASK};          // Set MMA to standby
uint8_t command_data_intaxi[2]       = {0x15, 0xD8};                      // Enable axis
uint8_t command_data_thres[2]        = {0x17, 0x4F};                        // thres
uint8_t command_data_interrupt[2]    = {0x2C, 0x00};                      // Set interrupt polarity
uint8_t command_enscr_config[2]      = {0x2D, 0x04};                  // int source config
uint8_t command_int_route[2]             = {0x2E, 0x04};                  // interrupt route config
uint8_t access_int_source                = 0x16;                          // Interupt Source address
uint8_t control_reg_1[2]                         = {0x2A,0x20};
uint8_t control_reg_2                              = 0x20;
//const uint8_t stdby[2]                                   = {0x2D,
        //0x00};                   // Interrupt Map
    static const nrf_drv_twi_t * p_twi_master;
 ret_code_t mma8653_I2C_register_write(uint8_t slave_addr,uint8_t * pdata, uint32_t bytes)
    ret_code_t ret_code;
    ret_code = nrf_drv_twi_tx(p_twi_master, slave_addr, pdata, bytes , false);
    return ret_code;
ret_code_t mma8653_I2C_register_read(uint8_t slave_addr, uint8_t reg_addr,  uint8_t * pdata, uint32_t bytes)
    ret_code = nrf_drv_twi_tx(p_twi_master,slave_addr, &reg_addr,1,false);
    if(ret_code != NRF_SUCCESS)
        return ret_code;
    ret_code = nrf_drv_twi_rx(p_twi_master,slave_addr, pdata, bytes, false);
    return ret_code;
ret_code_t mma8653_init(const nrf_drv_twi_t * p_twi_instance)
    nrf_drv_twi_enable(p_twi_instance);
    m_device_address = MMA8653_BASE_ADDRESS;
    p_twi_master = p_twi_instance;
    //ret_code = mma8653_I2C_register_write(m_device_address, &control_reg_2, sizeof(&control_reg_2) );
    ret_code = mma8653_I2C_register_write(m_device_address, command_data_active, sizeof(command_data_active) );
    ret_code = mma8653_I2C_register_write(m_device_address, command_data_stdby, sizeof(command_data_stdby) );
    ret_code = mma8653_I2C_register_write(m_device_address, command_data_intaxi, sizeof(command_data_intaxi) );
    ret_code = mma8653_I2C_register_write(m_device_address, command_data_thres, sizeof(command_data_thres) );
    ret_code = mma8653_I2C_register_write(m_device_address, command_data_interrupt, sizeof(command_data_interrupt) );
    ret_code = mma8653_I2C_register_write(m_device_address, command_enscr_config, sizeof(command_enscr_config) );
    ret_code = mma8653_I2C_register_write(m_device_address, command_int_route, sizeof(command_int_route) );
ret_code_t mma8653_xyz_read(uint16_t * x_value, int16_t * y_value, int16_t * z_value)
    uint8_t rx_buffer[6];
    rx_buffer[0] = 0x00;
    ret_code = mma8653_I2C_register_read(m_device_address,access_data, &rx_buffer[1], sizeof(rx_buffer));
    *x_value = (rx_buffer[1]<<8)|rx_buffer[0];
    *y_value = (rx_buffer[3]<<8)|rx_buffer[2];
    *z_value = (rx_buffer[5]<<8)|rx_buffer[4];
    return ret_code;
  • I meant the read values off from any registers go to 0xFF rather than an expected value. We tried to read the device ID on 0x0D assuming we would get 0x5A but there too we got 0xFF. Which is why I tried with 0x19 as the datasheet said that the read would return 0x00 but there too I'm only getting 0xFF or 0xFE. I erased the softdevice and connected the TWI pins to arduino and implemented the TWI there and the device is working just fine. Also implemented the 'I2C device scan' for arduino and it shows the device being ack but when in comes to implement TWI resistors, mounted a new chip, also have tried just with the chip and nRF51 Dev board too, no luck. Which, is why I am not being able to exactly locate where the issue could be.
