restricted peripheral access
I want to access restricted peripheral: TIMER0. After small research found that I should use sd_ wrappers, in my case sd_nvic_SetPendingIRQ(TIMER0_IRQn) however I got always NRF_ERROR_SOC_NVIC_INTERRUPT_NOT_AVAILABLE error. How can I check if resource is currently used by softDevice? __sd_nvic_app_accessible_irq(TIMER0_IRQn) also gives always false.
  • Inside the timeslot event there will be no SoftDevice activity, set up a timer to terminate or extend the timeslot when it runs out of scheduled time. If you do not end the timeslot in time you will hardfault. A simple implementation of this is described in the timeslot tutorial.
  • Yes, inside timeslot event there is no sd activity but I don't known that I'm inside timeslot. I want to call termination procedure from another rtos thread so i must check that softdevice is active at the moment. So my question is simply: How to check that softDevice is doing something at the moment?
  • Where is the above code running, and in which context? If you want to update the m_timeslot.in_timeslot variable to indicate is the timeslot is ongoing, you should not do it in the NRF_EVT_RADIO_SESSION_IDLE event.
    This event might appear to your application after the softdevice is active again, because the event is given on a lower priority. You should update the m_timeslot.in_timeslot variable in the callback function for the timeslot.
    Set it to True in NRF_RADIO_CALLBACK_SIGNAL_TYPE_START , and to false in NRF_RADIO_CALLBACK_SIGNAL_TYPE_TIMER0 (i assume that you have started a timer that times out before the timeslot is over).
