Using app_with_dfu jump to bootloader.
Hi all:
I use the softdevice 2.0.0 and compile bootloader example with "dual bank" on the nrf52 DK,
Running a system that can using DFU from app then jump to bootloader as example hrm did.
After I have a deep study it, I found out that:
  1. DFU will sign a value "BOOTLOADER_DFU_START" into "GPREGRET".
  2. it will restart using "bootloader_util_app_start(NRF_UICR->NRFFW[0]);" into bootloader.
  3. While into bootloader, the main function will check the sign on "GPREGRET"(bool app_reset = (NRF_POWER->GPREGRET == BOOTLOADER_DFU_START);)
  4. The DFU flow just as the picture below. image description
  5. And the problem is: it will stuck at dfu_ble_svc_peer_data_set(&m_peer_data); --> dfu_app_handler.c line 110
  6. the nrftool DFU on my iPhone will show: image description
  7. If I mark the step 5. line 110, and it will went to the function: "bootloader_util_app_start(NRF_UICR->NRFFW[0]);", but nrftool app on my iPhone still show "Enabling DFU Bootloader"
I think that did not really jump into bootloader, but why? What should I check?
Please correct me if I misunderstanding the DFU flow.
Thx for everyone willing to help me solve this problem.
Update 2016/06/27:
There're no return error code after that break point: err_code = dfu_ble_svc_peer_data_set(&m_peer_data); image description
and the variable m_peer_data is: image description image description image description
  • @Hung Bui, the example hrm_with_dfu s132. I want to let log print on my console, so in this example need to modify log_uart_init() line 175, change APP_UART_FLOW_CONTROL_ENABLED to APP_UART_FLOW_CONTROL_DISABLED, then I can get the log on console. But it will let APPLICATION not jump to bootloader.
  • Hi Coldson,
    Good news, I found a bug. It was because we redirect the vector table to the bootloader too early in the bootloader_start() function. So if you cut the 2 lines :
    err_code = sd_softdevice_vector_table_base_set(NRF_UICR->NRFFW[0]);
    In that function in dfu_app_handler.c.
    And paste them after the call to dm_peer_addr_get in the same file, in dfu_app_peer_data_set. It should be ok. It should look like this:
      err_code = dm_handle_get(conn_handle, &m_dm_handle);
        if (err_code == NRF_SUCCESS)
            err_code = dm_distributed_keys_get(&m_dm_handle, &key_set);
                m_peer_data.addr              = key_set.keys_central.p_id_key->id_addr_info;
                m_peer_data.irk               = key_set.keys_central.p_id_key->id_info;
                m_peer_data.enc_key.enc_info  = key_set.keys_periph.enc_key.p_enc_key->enc_info;
                m_peer_data.enc_key.master_id = key_set.keys_periph.enc_key.p_enc_key->master_id;
                app_context_data   = (DFU_APP_ATT_TABLE_CHANGED << DFU_APP_ATT_TABLE_POS);
                app_context.len    = sizeof(app_context_data);
                app_context.p_data = (uint8_t *)&app_context_data;
                app_context.flags  = 0;
                err_code = dm_application_context_set(&m_dm_handle, &app_context);
                // Keys were not available, thus we have a non-encrypted connection.
                err_code = dm_peer_addr_get(&m_dm_handle, &m_peer_data.addr);
  • I provide my work around solution:
    Mark all DM_TRC() in dm_peer_addr_get()function.
    Then it work fine.
  • @Coldson: yes you can do that also, the root cause is that we use UART when we already forwarded the interrupt vector table, using sd_softdevice_vector_table_base_set(). After that call, we should not use any peripheral that can trigger interrupt.
