Strange behavior Button 2 and Button 3 on nRF51 DK
Updates are moved to the end of the question
I created a modified version of pca10028.h and boards.h and have preprocessors changed so that the following new config is loaded:
// Custom LEDs definitions for PCA10028
#define LEDS_NUMBER    1
//#define LED_START      21
#define LED_1          21
#define LED_2          22
#define LED_3          23
#define LED_4          24
#define LED_5          25
#define LED_START      24
#define LED_STOP       25
//#define LEDS_LIST { LED_1, LED_2, LED_3, LED_4 }
#define LEDS_LIST { LED_4 }
//#define BSP_LED_0      LED_1
//#define BSP_LED_1      LED_2
//#define BSP_LED_2      LED_3
//#define BSP_LED_3      LED_4
#define BSP_LED_0      LED_4
#define BSP_LED_1      LED_5
#define BSP_LED_0_MASK (1<<BSP_LED_0)
#define BSP_LED_1_MASK (1<<BSP_LED_1)
//#define BSP_LED_2_MASK (1<<BSP_LED_2)
//#define BSP_LED_3_MASK (1<<BSP_LED_3)
//#define LEDS_MASK      (BSP_LED_0_MASK | BSP_LED_1_MASK | BSP_LED_2_MASK | BSP_LED_3_MASK)
#define LEDS_MASK      (BSP_LED_0_MASK | BSP_LED_1_MASK)
/* all LEDs are lit when GPIO is low */
#define LEDS_INV_MASK  LEDS_MASK
#define BUTTONS_NUMBER 0
#define BUTTON_1       17
#define BUTTON_2       18
#define BUTTON_3       19
#define BUTTON_4       20
I expected that this changed the BSP module to use pin 24 and 25 for LED display purpose.
Then in main.c I am setting some simple GPIO toggling behavior. Basically, at a button input interrupt event, the interrupt handler would set a flag, and in main()'s infinite loop, the according LED should be toggled. My code is basically exactly this
static bool m_input_it_flag = false;
/** @brief  Helper function to toggle output
static void __forceinline toggle_output(void)
    nrf_gpio_pin_toggle(2);
    nrf_gpio_pin_toggle(LED_2);
/** @brief  Input pin interrupt handler
void group1_input_it_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    m_input_it_flag = true;
//    toggle_output();
/** @brief  GPIO initialization
void gpio_init(void)
    nrf_drv_gpiote_in_config_t  nrf_drv_gpiote_in_config;
    // Input ---------------------------------------------------------------------------------------
    // This could return either NRF_SUCCESS or NRF_ERROR_INVALID_STATE. However, NRF_ERROR_INVALID_STATE
    // simply means the GPIOTE module is already initialized, so that error could be ignored.
    nrf_drv_gpiote_init();
    memset(&nrf_drv_gpiote_in_config, 0, sizeof(nrf_drv_gpiote_in_config_t));
    nrf_drv_gpiote_in_config.sense = NRF_GPIOTE_POLARITY_TOGGLE;
    nrf_drv_gpiote_in_config.pull = NRF_GPIO_PIN_PULLUP;
    nrf_drv_gpiote_in_config.hi_accuracy = false;
    nrf_drv_gpiote_in_config.is_watcher = false;
    nrf_drv_gpiote_in_init(BUTTON_2, &nrf_drv_gpiote_in_config, group2_input_it_handler);
    nrf_drv_gpiote_in_event_enable(BUTTON_2, true);
    // Output --------------------------------------------------------------------------------------
    nrf_gpio_cfg_output(2);
    nrf_gpio_cfg_output(LED_2);
    nrf_gpio_pin_set(2);
    nrf_gpio_pin_clear(LED_2);
/**@brief Application main function.
    gpio_init();
    for (;;)
        if (m_input_it_flag)
            toggle_output();
I have trimmed the full code and change variable name not to make this post lengthy unnecessarily. However in the original code I have that above code for both Button 1, 2 and 3. They should toggle LED 1, 2 and 3, respectively.
Now come the fun part: For button 2 and 3, after I pressed them once, their output seem to adopt the behavior of LED 4 (blink while advertising), which is BSP LED 1. In particular, LED 2 and 3 starts to blink in sync with LED 4. Sometimes they blink with the same state. Sometime they blink with reversed state. The output just toggle in sync.
Button 1 does not cause this problem.
Also, if instead of setting flags and handle the job in main, I toggle the output right at the handler, then this problem does not happen.
I could post a video of this if requested, but that seems too much work right now.
Do anyone have any guesses on what is going on?
Edit 1: I am using nRF51 DK with SDK v10.0.0 and SoftDevice S110 v8.0.0.
Edit 2: After some discussion with Øyvind in the comment down below, I have found some further issue even when not using BSP.
main.c code: buggy_gpiote_in_flag_main.c
Edit 4: In Edit 2 and 3's attachment I forgot to remove some irrelevant includes and codes. Here is a better trimmed down main.c file buggy_gpiote_in_flag_main.c
I tested it and it should run and reproduce the issue simply by replacing main.c in SDK v10's ble_app_uart example.
At the beginning of the file are two macros DEV_CFG_USE_FLAG and DEV_CFG_USE_BSP. Setting them to 1 will change the code to use flag raising to run GPIO triggered code or to use BSP, respectively. Setting them to 0 will change the code to run event code directly in GPIO handler or to disable BSP.
Also here is the board support file that could be used with it to observe the weird behavior when used with BSP. It is basically the code I have in the post. pca10028_modded.h
  • Sorry Øyvind, I missed those when I trimmed out the unrelevant part. Another thing I forgot is enable the flag macro. If you change DEV_CFG_USE_FLAG to 1 it should enable using flag instead of using handler directly. DEV_CFG_USE_BSP on the other hand enable and disable BSP feature
  • Just updated the question with a better edited main.c and the modified pca10028.h I used for your convenience.
  • If its working without the flag implementation, why not stick with that?
  • I thought I replied last week already but it turns out I didn't. I probably forgot to hit the add comment button or something. Sorry about this. The reason is because I often need to run a fair amount of work at a GPIO event, not just a couple of GPIO toggling like this. Meanwhile, I believe I should avoid running large amount of code in the interrupt context (unless there is some difference thanks to nRF's PPI system?). That is why I often use the flag raising strategy, sacrificing a little response time for safety. Therefore I would like to find the root of the problem to avoid issues in the future.
    But you are right that for my current particular case, I could just run the simple GPIO toggling in the handler.
  • I didn't quite get why you were using GPIOTE, either way you need to clear the pending interrupt at the start of each interrupt handler. For example by calling NVIC_ClearPendingIRQ(GPIOTE_IRQn);. Otherwise the interrupt will call itself again and again.
    You were also setting the wrong flags to false, change to the code below.
    #if DEV_CFG_USE_FLAG
            if (m_group1_input_it_flag)
                nrf_gpio_pin_toggle(GROUP1_OUTPUT1_PIN);
                nrf_gpio_pin_toggle(GROUP1_OUTPUT2_PIN);
                m_group1_input_it_flag = false;
            if (m_group2_input_it_flag)
                nrf_gpio_pin_toggle(GROUP2_OUTPUT1_PIN);
                nrf_gpio_pin_toggle(GROUP2_OUTPUT2_PIN);
                m_group2_input_it_flag = false; //Change this
            if (m_group3_input_it_flag)
                nrf_gpio_pin_toggle(GROUP3_OUTPUT1_PIN);
                nrf_gpio_pin_toggle(GROUP3_OUTPUT2_PIN);
                m_group3_input_it_flag = false; //Change this
    #endif // #if DEV_CFG_USE_FLAG
    Be aware that there is a limit on the maximum low power resources, this can be changed in the file nrf_drv_config, found in ble_app_uart\config.
