Compiling C and C++ code
We've currently only been developing our application in C. We now have a couple of C++ libraries we'd like to use and are having trouble compiling the mixture of C and C++ code.
This is the Makefile: http://pastebin.com/M4Wsybxt And this is the output when I run make: http://pastebin.com/4SmrvJuz
All the #include statements are wrapped in an extern "C" block.
The code that is causing the code to not compile seems to be this (from main.cpp file):
static void gpio_config() {
    ret_code_t err_code;
    // Initialize driver
    // Configure output pins for LEDs
    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    err_code = nrf_drv_gpiote_out_init(LED_RED, &out_config);
    err_code = nrf_drv_gpiote_out_init(LED_BLUE, &out_config);
    // Set output pins
    nrf_drv_gpiote_out_set(LED_RED);
    nrf_drv_gpiote_out_set(LED_BLUE);
    // Turn leds off
    nrf_drv_gpiote_out_toggle(LED_RED);
    nrf_drv_gpiote_out_toggle(LED_BLUE);
    /* No inputs for now */
It seems like the compiler might be ignoring the extern "C" statement, since I get the same error if I leave that out.
I'm currently using the arm-none-eabi-g++ compiler, but also tried arm-none-eabi-c++ with no difference.
Could anyone help me get on the right track to compiling this C and C++ code? I'd rather not have to change the NRF SDK code to make this compile.
  • This is somewhat solved. The c++ compiler didn't like how the NRF_GPIOTE_INITIAL_VALUE_LOW was initializing structs.
    Doing
    nrf_drv_gpiote_out_config_t out_config = {};
    out_config.init_state = NRF_GPIOTE_INITIAL_VALUE_LOW;
    out_config.task_pin = false;
    instead of
    allowed us to compile.
