Using app_timer_cnt_get(), get zero!
Hi there, I have done search and know there are several similar questions, but unfortunately I didn't find any useful answer after carefully reading through them, thus I decide to post a new question, and wish it could help others in the future.
As suggested by the answers under the similar questions, I have called app_timer_start(), and the timer is of APP_TIMER_MODE_REPEATED. I did debug, and traced to the function rtc1_counter_get(), but the NRF_RTC1->COUNTER is ZERO.
Could anyone give me any hints?
The background is I am studying the example in this timer tutorial, and want to obtain the elapsed time between two events with function app_timer_cnt_diff_compute The main() function is as follows,
SEGGER_RTT_ConfigUpBuffer(0,NULL,NULL,0,SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL);
// Request LF clock.
lfclk_request();
// Initialize the application timer module.
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
// Configure GPIO's.
gpio_config();
// Create application timers.
create_timers();
SEGGER_RTT_WriteString(0, "SEGGER Real-Time-Terminal: \r\n\r\n");
// Main loop.
while (true)
    // Wait for interrupt.
    __WFI(); // take care, may change!
The relevant code is as follows, where gpio_config() calls nrf_drv_gpiote_in_init, which further calls function gpiote_event_handler.
static void gpio_config()
// Configure input pins for buttons, with separate event handlers for each button.
err_code = nrf_drv_gpiote_in_init(BUTTON_1_PIN, &in_config, gpiote_event_handler);
 //Button event handler.
 void gpiote_event_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
  uint32_t watchdog_timer;
  uint32_t app_timer_cur;
  uint32_t app_timer_diff;
uint32_t err_code;
static uint32_t timeout = 0;
switch (pin)
case BUTTON_1_PIN:
    err_code = app_timer_start(m_led_a_timer_id, APP_TIMER_TICKS(200, APP_TIMER_PRESCALER), NULL);
    /* Set watchdog timer */
    app_timer_cnt_get(&watchdog_timer);
case BUTTON_2_PIN:
    err_code = app_timer_stop(m_led_a_timer_id);
    /* Check for a watchdog timeout */
    app_timer_cnt_get(&app_timer_cur);
    app_timer_cnt_diff_compute(app_timer_cur, watchdog_timer, &app_timer_diff);
    SEGGER_RTT_printf(0, "app_timer_diff is: %u \r\n", app_timer_diff);
case BUTTON_3_PIN:
    // Start single shot timer. Increase the timeout with 1 second every time.
    timeout += 1000;
    err_code = app_timer_start(m_led_b_timer_id, APP_TIMER_TICKS(timeout, APP_TIMER_PRESCALER), NULL);
case BUTTON_4_PIN:
    nrf_drv_gpiote_out_set(LED_2_PIN);
Many thanks!
  • watchdog_timer will obtain the value of the RTC when you call app_timer_cnt_get(&watchdog_timer);.
    Is the timeout handler corresponding to m_led_a_timer_id ever called (handler given in app_timer_create function)?
    Right after starting the first timer you may expect that the value of the RTC is 0 (it does not start until the first app_timer_start is called). May this be the issue?
  • Hi, Ole, thanks. I don't know the timeout handler, there do exist a handler given to app_timer_create(), but it seems have nothing to do with timeout. To prevent the value of RTC to be 0, I added a delay before returning app_timer_cur. but app_timer_cur is still 0.
    I put the main.c file https://codeshare.io/MLgBV, which is basically on the basis of the example from tutorial. I appreciate if you could have a look at part between line 59 to 70.
  • Since you are in an interrupt/handler, app_timer will not start until the event handler is done (app_timer operations are done in a software interrupt). You have to check the counter value after the event handler.
  • I moved the app_timer_cnt_get functions into the main() part, then I notice the eclipsed time. Now I somehow understand the explanation of Timer library in the Nordic Semiconductor Infocenter, i.e.,
    ... The actual timer start/stop operation is executed by the SWI0 interrupt handler. Since the SWI0 interrupt is running in APP_LOW, if the application code calling the timer function is running in APP_LOW or APP_HIGH, the timer operation will not be performed until the application handler has returned. This will be the case e.g. when stopping a timer from a timeout handler when not using the scheduler.
    I guess if proper levels are defined, I will make the time to work in the interrupts. I will do some tests on that.
  • @Ole Bauck, thanks very much, I made some changes and it works, I put what I did as an answer.
