Disconnect nrf51822 when the correct connection interval is not negotiated with the phone
Hi Sometimes the nrf the central does not accept my connection interval of 7.5ms. I want to disconnect nrf51822 when the correct connection interval is not negotiated with the phone.just want to know if the if statement at the end of the code is the correct way to do this
 uint32_t err_code;
 cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = true;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
This is my conn_params_negotiation function. I believe the app_start_timer is called in the right position
static void conn_params_negotiation(void) {
// Start negotiation if the received connection parameters are not acceptable
if (!is_conn_params_ok(&m_current_conn_params))
    uint32_t err_code;
    uint32_t timeout_ticks;
    if (m_change_param)
        // Notify the application that the procedure has failed
        if (m_conn_params_config.evt_handler != NULL)
            ble_conn_params_evt_t evt;
            evt.evt_type = BLE_CONN_PARAMS_EVT_FAILED;
            m_conn_params_config.evt_handler(&evt);
        if (m_update_count == 0)
            // First connection parameter update
            timeout_ticks = m_conn_params_config.first_conn_params_update_delay;
            timeout_ticks = m_conn_params_config.next_conn_params_update_delay;
        err_code = app_timer_start(m_conn_params_timer_id, timeout_ticks, NULL);
        if ((err_code != NRF_SUCCESS) && (m_conn_params_config.error_handler != NULL))
            m_conn_params_config.error_handler(err_code);
    // Notify the application that the procedure has succeded
        evt.evt_type = BLE_CONN_PARAMS_EVT_SUCCEEDED;
m_change_param = false;
This is my conn_params_change_conn_params
uint32_t ble_conn_params_change_conn_params(ble_gap_conn_params_t * new_params) {
uint32_t err_code;
m_preferred_conn_params = *new_params;
// Set the connection params in stack
err_code = sd_ble_gap_ppcp_set(&m_preferred_conn_params);
if (err_code == NRF_SUCCESS)
        m_change_param = true;
        err_code = sd_ble_gap_conn_param_update(m_conn_handle, &m_preferred_conn_params);
        m_update_count = 1;
        err_code = NRF_SUCCESS;
return err_code;
  • Hi ua,
    Yes, but you need to check if it's actually called or not. This will explain why update_timeout_handler() is not called.
    It's more important that you find out how the code works and why it didn't work in your case. I would suggest you to add some UART debug trace to get to know what happens.
    Basically, the way it works is that depends on whether you set start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID or not when init the module, the module will execute conn_params_negotiation() on either BLE_GAP_EVT_CONNECTED or BLE_GATTS_EVT_WRITE (when write to CCCD). If you set start_on_notify_cccd_handle to something, and then never write to CCCD, then connection parameter will never be executed.
    Inside conn_params_negotiation() we will check if the current parameter matched with what we want then we will do nothing and notify the main application with BLE_CONN_PARAMS_EVT_SUCCEEDED.
    If not, we will start the negotiation process by starting up the timer (if we haven't started) and then in each timer timeout we will send a connection parameter request. We will do it MAX_CONN_PARAMS_UPDATE_COUNT (3) times, before we give up and notify the application that it's failed.
    We will also do the same process if we receive a connection parameter update from the phone (BLE_GAP_EVT_CONN_PARAM_UPDATE event).
    So you job is to check why it didn't go this way, or if it goes this way but you may want to modify something.
