[NRF51822QFAC][SDK11] How to recover Uart errors
I'm trying to interface SIM808 with nrf51822 over uart using nrf_drv_uart. Everything works well for some time, but then uart starts reporting error code 1, NRF_UART_ERROR_PARITY_MASK, for all transactions on uart. Re-initializing the uart doesn't correct it. Also the time after which error starts appearing is also random, varies from 15 minutes to 1 hour. The problem is not with the module as when the error occurs, I can still communicate with the module using external uart to usb. Here is what I think is relevant information:
  • Baudrate is 115200
  • Tx is blocking
  • Listen to rx for 20ms
  • Max transaction size for rx is 10 bytes
I can upload the code, if necessary.
Hoping for a positive response and thanks in advance :)
  • Works like a charm!!! Events clearing was the main issue. I'm still getting parity error on some commands but re-initializing the uart resolves it. Just a minor correction in your solution, a typo:
    nrf_uart_event_clear(NRF_UART0, EVENTS_ERROR);
    should be
    nrf_uart_event_clear(NRF_UART0, NRF_UART_EVENT_ERROR);
    should be
  • good that it worked, thanks for fixing the typo. I have fixed the answer with your correction.
  • Sorry, forgot to mark as answer. Done. And thanks for help.
  • Hi Lalit, i edited the subject for this thread so that it is easy to search for others with similar issue, hope that it is ok.
1 2 3
