Dear Nordic Team,
Thanks for supporting.
I want example code for I2C interface with AT24C32
Dear Nordic Team,
My code :
/* Copyright (c) 2015 Nordic Semiconductor. All Rights Reserved.
* The information contained herein is property of Nordic Semiconductor ASA.
* Terms and conditions of usage are described in detail in NORDIC
* SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
* Licensees are granted free, non-transferable use of the information. NO
* WARRANTY of ANY KIND is provided. This heading must NOT be removed from
* the file.
/** @file
* @defgroup tw_sensor_example main.c
* @ingroup nrf_twi_example
* @brief TWI Sensor Example main file.
* This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_uart.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
/*Pins to connect shield. */
#define ARDUINO_I2C_SCL_PIN 5
#define ARDUINO_I2C_SDA_PIN 6
#define I2C_24C128_SLAVE_ADDR (0xA0 >> 1)
/* Define version of GCC. */
#define GCC_VERSION (__GNUC__ * 10000 \
+ __GNUC_MINOR__ * 100 \
+ __GNUC_PATCHLEVEL__)
* @brief Structure for holding sum of samples from accelerometer.
#ifdef __GNUC_PATCHLEVEL__
#if GCC_VERSION < 50505
#pragma GCC diagnostic push
#pragma GCC diagnostic ignored "-Wmissing-braces" // Hack to GCC 4.9.3 bug. Can be deleted after switch on using GCC 5.0.0
/* Buffer for samples. */
#pragma GCC diagnostic pop
/* TWI instance. */
static const nrf_drv_twi_t m_twi_mma_EEP = NRF_DRV_TWI_INSTANCE(0);
void eep_WriteByte(uint16_t eep_address, unsigned char val);
unsigned char eep_readByte(uint16_t eep_address);
ret_code_t err_codecpy;
* @brief Function for averaging samples from accelerometer.
* @brief TWI events handler.
* @brief UART initialization.
void twi_init (void)
ret_code_t err_code;
//ret_code_t ret;
const nrf_drv_twi_config_t twi_mma_EEP_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH
err_code = nrf_drv_twi_init(&m_twi_mma_EEP, &twi_mma_EEP_config, NULL, NULL); //twi_handler
nrf_drv_twi_enable(&m_twi_mma_EEP);
err_codecpy=err_code;
nrf_delay_ms(5);
unsigned char eep_readByte(uint16_t eep_address){
unsigned char eep_by_address[2];
unsigned char reg=0;
eep_by_address[1] = eep_address;
eep_by_address[0] = (unsigned char)(eep_address << 8);
// setting the start address
nrf_drv_twi_tx(&m_twi_mma_EEP, I2C_24C128_SLAVE_ADDR, eep_by_address, 2, true);
// read a byte
nrf_drv_twi_rx(&m_twi_mma_EEP, I2C_24C128_SLAVE_ADDR, ®,1);
nrf_delay_ms(5);
return reg;
void eep_WriteByte(uint16_t eep_address, unsigned char val){
unsigned char eep_by_address[3];
eep_by_address[2] = val;
nrf_drv_twi_tx(&m_twi_mma_EEP, I2C_24C128_SLAVE_ADDR, eep_by_address, 3, false);
nrf_delay_ms(5);
twi_init();
unsigned char reg1 = 0;
while(true)
nrf_delay_ms(1000);
eep_WriteByte(0x0000,'A');
nrf_delay_ms(5);
eep_WriteByte(0x0001,'B');
nrf_delay_ms(5);
reg1=eep_readByte(0x0000);
if(reg1!=0){
nrf_delay_ms(5);
else if(reg1==0){
nrf_delay_ms(5);
Ok, not that I can see the problem yet. Since initializing TWI returns success - you should be able to watch the I2C communication witch a scope to see if i2c is working correctly.
Here a screenshot what that would look like:
Screenshot
OK Johannes thanks for the support.
Were you able to get the TWI running?
No i am not get any support form anywhere still trying.
