how to wake up from IDLE mode using ppi?
Hi
I want to know how to use ppi to wake up CPU from IDLE mode.
I've tried to use timer timeout event for triggering Port Event and wake up CPU, but can't assign NRF_GPIOTE->EVENTS_PORT to ppi channel. nrf_drv_ppi_channel_assign returns NRF_ERROR_INVALID_STATE.
ret_code_t err_code = nrf_drv_timer_init(&timer1, NULL, timer_event_handler);
nrf_drv_timer_extended_compare(&timer1, NRF_TIMER_CC_CHANNEL0, 0xFFFFUL, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
nrf_drv_gpiote_init();
// Configure 1st available PPI channel to stop TIMER0 counter on TIMER1 COMPARE[0] match, which is every even number of seconds.
err_code = nrf_drv_ppi_channel_alloc(&ppi_channel1);
err_code = nrf_drv_ppi_channel_assign(ppi_channel1,
                                      nrf_drv_timer_event_address_get(&timer1, NRF_TIMER_EVENT_COMPARE0),
                                      NRF_GPIOTE->EVENTS_PORT);
NRF_POWER->TASKS_CONSTLAT = 1;
nrf_drv_timer_enable(&timer1);
while (true)
   __WFI();
    if(LED_IS_ON(BSP_LED_0_MASK)){
        LEDS_OFF(BSP_LED_0_MASK);
    } else {
        LEDS_ON(BSP_LED_0_MASK);
    NRF_GPIOTE->EVENTS_PORT = 0;
I don't want to configure any pin for GPIOTE, just want to use register.
Thanks!
  • Hi I paste my codes.
    void timer_event_handler(nrf_timer_event_t event_type, void * p_context){
        printf("kumi %d\n\r", nrf_gpio_pin_read(LED_1));
    static void ppi_init(void)
        uint32_t err_code = NRF_SUCCESS;
        err_code = nrf_drv_ppi_channel_enable(ppi_channel1);
    static void timer1_init(void)
        nrf_drv_timer_extended_compare(&timer1, NRF_TIMER_CC_CHANNEL0, 0x7FFFUL, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        uint32_t err_code;
        timer1_init(); // Timer to generate events on even number of seconds.
        nrf_drv_timer_compare_int_enable(&timer1, NRF_TIMER_CC_CHANNEL0);
        const app_uart_comm_params_t comm_params =
             RX_PIN_NUMBER,
             TX_PIN_NUMBER,
             RTS_PIN_NUMBER,
             CTS_PIN_NUMBER,
             APP_UART_FLOW_CONTROL_ENABLED,
             false,
             UART_BAUDRATE_BAUDRATE_Baud115200
                        UART_RX_BUF_SIZE,
                        UART_TX_BUF_SIZE,
                        uart_error_handle,
                        APP_IRQ_PRIORITY_LOW,
                        err_code);
        while (true)
            __WFI();
            printf("Current count\n\r");
           } else {
  • Can you post the rest of your code as well? For example ppi_channel1 is not defined anywhere, and neither is timer1.
  • Hi, of course I defined them like below.
    const nrf_drv_timer_t timer1 = NRF_DRV_TIMER_INSTANCE(1);
    nrf_ppi_channel_t ppi_channel1;
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
  • hi I tried commenting out printf in while loop, then CPU sleep again and printf in timer_event_handler runs every 2ms and BSP_LED_0_MASK(LED1) blinks. printf in while loop is bad coding?
